- Ohlins PCV settings?
- RP-F1 center caps
- 255/40/17 g-force t/a kdw 2
- rust on tanabe gf210s?
- Axxis brake pads
- Axxis Halo Rims
- Need help on a part?
- evo 9 hks hypermax 3 suspension set up
- Grinding ! ! HALP PLEASE!!!!
- wheels and suspension
- red touch up paint for P45R
- Has anyone weighed kw variants?
- Quick Swift/ RCE Question
- Rotor Warranty?
- Continental ContiSportContact 3???
- Shortest Drop Spring
- Anyone have a junk harness bar?
- A few questions about Cusco stuff.
- Just bought the Stance 3 Way
- DIY Adjustable Front Sway Bar
- Braking causing car to drift
- Rims Need Opinions
- Tire question...
- All 3 ACD lights on?
- Lug Nut Fitment
- How to get the stock feeling back in the handling of my IX?
- Whats your method for?!?!?!?!
- Tire wear...help!
- IX RS OEM Wheels
- Problems with k-sport
- Why do spacers help wheels fit?
- 245/45/17 tire pressure
- changed suspension but popping noise still there
- Brembo front caliper detail question
- Ball joint compatibility
- Looking For Brembo Mounting Bolts
- Tein Type HT coilovers?
- Where to buy Carbotech AX6
- Stance Coilover REVIEW
- Auto-x'ers...Bouncy around turns
- Evo front Brembo's on my RX-7... trying to clear a +50mm offset SSR comp wheel...
- I need new tires PLEASE HELP
- powder coating stock rims question
- Ray G- Games
- Where to find EVO style OEM rims?
- new suspension
- 2 diff tires
- Blizzak Fitment
- wich pads to go with?
- Racing Brake ET500 pads review!
- bbs rs info on florida evo with bbs rs
- Stance coilovers
- I need help on tire size.
- Anyone know where to buy Dunlop's...?
- Wheel and Tire Size for Autox/Track/Spirited Driving
- Tenzo DC 5 Picture Request
- BC coilovers
- anybody out there run 255 falken 615s on stock IX SE BBS Rims?
- Alignment?
- Brakes/rotors for Evolution 1.
- OE Brembo Question?
- re30 le 18x9 size tires
- Its time for brakes... i need help
- Hard brake pedal
- OFFICIAL: Tanabe Sustec Under Brace For Evo
- rolled rear fenders, but rolling fronts?
- Evo 1 Rim sizes, advice?
- Coilovers....
- Pic Request: Enkei RC-T4 17x9 +35mm
- Cobalt Friction Brake Pad
- Experts please.
- Lug nuts at local part store?
- Advan #1? or Advan #2?
- Rims
- Stance GR+'s help/suggestions
- new tires
- rally tire selection
- Advan Question
- Racing Brake ET500 Early Impressions
- Enkei rp03 17x9.5 +38mm fitment?
- Coilovers question..
- Rotor issue..ok to swap rotrs and keep old pads?
- Anyone know who makes this strut bar?
- Anyone have old stock of Gram Light 57S's?
- ce28n time attacks in 18 x 9.5 +22
- Considering some lightweight coilovers: Apexi N1 EXV??
- 235/40/17 tires on stock rims
- ccw classic fitment and offset??
- SSR Type-F 17 x 9.5 +28 offset for EVO 9?
- RobiSPEC at Buschur Racing August 11-17, 2008 *NOW TAKING APPOINTMENTS!*
- best way to keep brake dust off?
- STANCE - damper "clicker" extension! *NEW ITEM*
- 2 air valves in wheel?
- Ohlins coilovers for drag racing?
- color of OEM IX MR BBS rims?
- Best DD Tire?
- 18X8 with a 40mm offset will it fit?
- Enkei NT-03M + 38 and 25mm spacer issues?
- Brake bias with BBK
- need to buy slicks...
- evo 10 rims
- New rims need help
- 5 lug
- fender rolling in nj
- Glazed pads
- Volk SE37 18x9.5+12 ?
- Swift Spec-r installed
- Cusco Zero2E Seized!
- What Springs do you guys think are better
- What offset?!?!
- STREET Brake Pads (yes another thread)
- any one confirm this???
- Wheel shake high speed braking
- What about BC racing?
- Wheel question
- Powder coated rims????
- Winter tires?
- which spacers for 17X9 +35
- Special Edition RE30's...
- I need rotors, are Rotorpros the way to go?
- Anyone have these wheels with pics??
- Evo 8 Suspension help
- Where can I buy Agency Power Lower Control Arms???
- LOUD brake squeal
- Should I try, 17x8 47+
- Brake job quetston (spreading calipers?)
- Advan RS vs RZ?
- Stock wheel weight
- Megan Racing Coilovers?!?!?!?
- evo shakes?
- how to choose offset?
- what rims are these?
- Front Sway
- Brake pad rattle?
- Need A Taste For New Rims.
- choices for tires...
- How to tighten top strut nut? (KW V3)
- Tires for IX MR
- STANCE / DBA / Whiteline - front suspension setup for Auto X
- i want to buy a work emotion cr kai wheels with tires
- For those that like look of the factory wheels..
- Screw in Tire... how well will a plug hold up?
- where can i buy and what offset? Enkei RPF1
- Not sure about ordering new wheels and tires
- oem wheels
- Q about longevity of swift springs on gsr suspension.
- Need a recomendation for brake lines
- Rim size for Voltex wide body kit
- 17 or 18" wheels for AutoX?
- powder coat
- Is this too much of a stretch?
- R888 225s big enough for 9MR
- Check my alignment
- quick help - rear suspension adjustment bolts
- Will 9 mr suspension fit my 05 8
- Megan street coilovers
- Lux Rims
- Weird Brake Problem
- *AMS PRODUCT RELEASE* Steering Rack Precision Kit
- What would be needed to fit? Need a pro please!!
- EVO RS.. First time I had to lock'em up
- SE wheels?
- GReddy 6/4 Big Brake Kit advice needed
- CLUNK front passenger - bilstein/swift R, please help diagnose
- WHAT OFFSET to buy?? Rota P45r
- Rota P45r's
- Tire Sizing and the Star Specs
- brake disc evo III
- Vendor Required to sell replacement APEXI N1 strut
- Whats faster: camber plates or rear sway bar?
- Help Finding Part
- Rim fitment
- Black Racing Pro N1 Wheel's
- Robispec or Swift Springs?
- Tein Racing Dampers
- 42 offset
- k sports clicking
- E-Brake Screeching
- what kind of rotor and brake pad should i use
- rota p1 and rota tarmac 3
- Nitto 555R REVIEWS?
- Issue with Whiteline Roll Center Correction Kit
- KW Variant 3 spring swap
- Squeaky Front Brakes. Whats could be the cause?
- HELP!!! Rota D2 vs. SSR Professor SP1 vs. WORK Meister S1
- Another steering wheel vibrations thread...
- Anyone running Yokohama S.drive tires?
- rotora bake rotor
- VOLK time attacks dipped in black chrome?
- Q: Are there any after-market wheels that do not need...
- Something Special Wheel Wise ?
- Installed Swifts and only one problem (help please)
- help
- nitto nto1 245/45/17
- Rear brake Caliper leaking
- Advan RS for evo 9
- Kosei K1 +45 offset too much?
- Where to get bigger camber bolts
- E-brake light on dash?
- Bridgestone Potenza RE030
- GTWorx vs Swift Sport for Stock IX???
- 265/35/18 on 18x8.5?
- Will 18x9 30 offset with 255 35 18 RE-01R Rub?
- Nankang NS-2 Tiresm (NS2 NSII NS II) or recommendations
- Help! Cusco camber paltes for KW V3s???
- Evo X BBS fit Evo IX?
- Coilover ride height?
- Any one have pics of 235/40/17 tires on stock Enkies
- lowering springs
- ghetto "powdercoating"
- IX wheels Black?
- Simple ? about wheel fitting.
- Coilover and alignment issue
- advan rs and 265/35/18 will it rub?
- Direzza Z1 Star Spec rotation
- hawk hps/powerslot rotor combo is SO NOISY!!!
- World's FIRST 100% Carbon Fiber Wheels
- Will I Need To Roll Fenders? (255/35/18)
- Coilover on otherwise stock supension - how low to go?
- evoX rotors
- my evo with sa70 (no 56K)
- Quick Question about Tire Selection?
- Brake pedal travel after pad install
- Neal@Tirerack help on finding this tire
- offset
- broke 2 studs
- Suspension/Mount Changes for AX,RR, & Drag Evo VIII
- hotchkis springs
- Help! What brand springs are these?
- What kind of rims are these??
- Need Info!
- I have a question...
- Advan RZ fitment?
- lowering springs
- enkie evo 5 wheels??
- post your bluebyyou evo with rims
- Bent rim and spare tire?
- Best straight line tires
- BEST street/auto-x pad hands down
- Are all alignments created equal?
- Ferodo DS2500 Fitment, Evo 8, Evo 9
- My brakes went out! help.
- Big brake kit/ ultimate brake set up
- Direction of cross-drilled and slotted rotors
- Value of Lightly Used, Stock IX SE Suspension SET
- Wheel options for fitting 285/30 R compounds
- Got a nail stuck in one of my tires.....
- hawks HPS brake install?
- Good alignment shop in the Bay Area?
- Smoke coming from tires??
