- Hotlap Brakes cooling ducts under the tray
- inner wheel eaten up
- Wheel help?
- Ce9a evo II gsr lug pattern? Offset?
- new DIy brake lines?
- 255's on 18x8.5" rim?
- Rota G-Force
- Axxis/PBR pads making NOISE!!! Help!!!
- Tire Size for Stock BBS Wheels?
- Help with wheels
- New Tires=Scratched Rims
- R-comps: Toyo R888 vs Bridgestone RE55 vs Yokohama A048
- Is this how the stock suspension is??
- Wheel Locks...
- Brake squeals when turning left or right
- Need help to find right tires at right price
- Teins Or Swift?
- Away from forum till Monday the 6th
- Anyone fitted a SSR Type F ?
- Yokohama S. Drive Tires
- Need help. Car is apart doing springs, popping noise
- Copper Antiseize? right one for brakes?
- ride height/alignment specs help - setup listed
- OFFICIAL: Tanabe USA Nagisa Gacchiri Support Coming Soon!
- re30 rims
- Will these fit??? ----> 18x8.5 +40 CE28's
- Got Some New Shoes!!!
- Good set of tires wanted~
- Coilovers (PIC)
- so yea.... nt03s on 245/40/18s don't fit
- tein flex or stance gr+pro
- Coloring stock wheels? EVO IX
- Tien Recall On Lower Brackets On Flex Setups
- would enkei rpf1 17x9.5 38+ fit w/o major rubbing?
- Do MB Weapons clear with no spacers? 17x8 +28
- so who's got the widest tires?
- Enkei NT03+M 18x9.5 +27 +12 +2 offset fitment - pics
- what wheels are these...?
- 265's on 18x9 30+ offset ??
- Girodisc Has New SS Lines!
- I Need Brake "Ducts" for Cooling For My Evo 8
- Running with no lower brace?
- Coilover top hats.. will these fit?
- How Do I Fit 275 Size Tires Without Fender Rolling ??
- Motul Fluid OK for DD Evo?
- Brakes or bearings?
- Energy Suspension Kit vs. Whiteline.
- question about wheels size.
- Stance coilover help
- fender brace where at?
- Need cheap tires this year, dont know what to get?
- Time for new set of brakes...
- 235/35/19 Or 245/35/19
- K-MAC camber plates, anyone...?
- 2 piece rotor
- Spacers?
- Suggestion on Endlinks
- Evo alignments
- Got aligned twice, still not straight
- HAS ANYONE USED R1 Concepts' D/S brake rotors ???
- 18x9.5+20 Spacers Yes or No??
- Uneven brake pad wear?
- brakes!?!?
- Rubber running low need a little help deciding what to get.
- Tanabe coilovers
- 19's ???
- new pads now anti-lock light
- All Season Tire Only!!!!
- New springs, end links, and swaybar, new sound...
- Springs now or Coilovers later??
- 4 New Kuhmos, mounted, balanced AND a free alignment!
- wheel and tire guestions 17x8 17x9 please help
- Tire Advise
- New Front Struts Caused by Tein??
- Post pictures of your Evo on Volks/Works/Advans
- Anyone run Hoosier R6 for autox???
- it won't stop bleeding
- ABS Light blinking
- OFFICIAL: SSR Type C Wheels Available Now! No Need to Wait!
- Affordable wheel spacers without built-in lugs
- Anyone has any experience with JBT BBK?
- Best rim and tire combo for road racing?
- putting springs on increased highway mpg?!
- Brake Light Randomly On
- Perrin sway bar and stout mount issue :(
- Need rim cleaning help!
- need help wheel/tire gurus
- muellerized jic
- Is there a larger rotor kit for the 17" rims?
- Running a BFG's (almost 2years been sitting on the garage)Is it still fine to use it?
- quick bilstein question
- Necessary to reuse OEM shims with new brake pads??
- What brake pads do you recomend?
- Tein Monoflex spring preload
- advan RG 2/255 tire/hotchkiss
- suspension bolt sizes?
- Just a note I'll be away till Monday
- Durability of Stock Rotors w/ DS2500s
- quick offset question for wheels
- Lug Nuts...Your Preference? Street/Track?
- 2 tire questions on Advans
- Weight of EVO X BBS rims
- 235/40/17 on an EVO
- Stock suspension rear camber fully adjusted is still out of spec
- AXXIS ULTIMATE brakes
- AXXIS brake pads
- anybody use these rotors?
- Wheel cupping info
- Volk Centercaps
- In Desperate Need of a Ray Lugnut Wrench
- roll center correction kit legal in bsp?
- rear brake squeal..
- 06 RS daily driver suspension build
- Need fenders rolls in orlando
- Wheel Fell off!!!
- jic flta-2 coilovers
- tire pressure - need help quick
- Would likd to ID these wheels
- New alignment rack for WORKS
- Feeling sloppy on wet roads
- Factory brembos
- just got some rota's will they fit?!!!
- Rubbing Problems =\
- Painting Advan RGII's Questions
- 18 * 9.5 offset 28
- About To Buy New Lowering Springs....any Thoughts?
- Tanabe, Buddy Club, or HKS
- Stock Front Alignment Questions
- new kw variant 3 need help
- Helper Spring
- Fat tire-low offset guru's!!!!!
- Wheel Fitment Troubles
- Tanabe Sustec Pro S-OC Type II
- Brake making knocking noise
- Need help with brakes!!
- rubbing from right wheel well??
- Swift vs. GTWorx springs
- Painting wheels - need help/have questions
- Help Me Out
- 17x9 Enkei RPF1
- Help Wheel Hop
- braces/suspension parts worth buying?
- Need Performance Brake Rotors for TRACK Use, Affordable
- KICS 15mm spacer & RE30 fitment QUESTION
- Need help SILVERSTONE FTZ TYPE RR or Kumo V70A
- Center caps that fit Ralliart R-01's?
- question about +20mm offset
- FS: Enkei RPFL 17's
- Swift Spec R advise needed
- Am I missing some bolts?
- time for new rotors help please
- maybe fit?
- Coilover Ride Height.
- Axle maybe?
- How will the car handle if???
- in need of some repairs, looking for guidence...
- need spring rate advice!
- Auto-x tire pressure for Dunlop Star Specs
- just got my rotors from Rotorpros
- can coilovers ever match bilsteins ride comfort
- What Is Least Expensive Coil Overs For EVO 8 ???
- whats a good "in between" suspension?
- what springs to use for 17x9 +17
- Evo IX MR suspension improvement
- ***pic Request*** Ccw Classics On Apex Silver Evo8 Or Evo9
- Changing Brake Fluid - order?
- grinding braking and when not
- Premature rotor wear
- B & G suspensions
- Question about Buddy Club Rims.
- 225/45R17 on a 9'' wide rim
- 255/35/18 good for 9.5's?
- question about tires
- Another squeal thread -> only turning left?
- Popping noise when turning wheel with swift springs
- Sunday Suspension Discussion: What do you look for in a coilover?
- black or oem enkei?
- EBC Yellow's are terrible
- Hub centric rings 17
- hotchkis springs on bilstein sport Strut or Hds
- work emotion cr kai 18x9.5 30offset
- ROTORPROS discs installed
- volks le28N...
- BFG Radials
- 18x9.5 rims and a 245/40/18 rims?
- Changing stock suspension alignment
- What wheels are these?
- Gt-Spec trunk cage
- Dunlop Launches a New Star in Extreme Performance Summer Tires
- required bolts
- Adrenalin - Bridgestone POTENZA (RE 001's)
- valve stem?
- wierd noise from coilovers, should i be worried?
- Vrdestein Ultrac Sessanta anyone???
- Question about Brakes
- Brembo Fiber Shims
- Brake Squeal Question
- Subframe help please
- blisten hds
- Recommendation on Brake Pad Shims?
- Will these Work...
- Got set used Bilsteins, Install Question.
- I need volk hub bore size
- rubbing on swift springs
- are rota p45f's good racing wheels
- Rota Wheel Weights....
- Baer vs. Girodisc
- Falken Azenis 615's - 245/45/17???
- Dunlop Star Spec Update!
- brakes
- HELP! will these caps fit on the RE30s (18")?
- Rota G Force Hyper Black + Project Mu BBK
- where to buy tires!!!!
- need help with rim fitment
- ABS possible in an evo rs
- CLUNKING in front part of car
- nt03+M
- Fire
- Factory Evo IX Alignment Specifications?
- stock rims with racing lugs?
- need help with rubbing rims....
- Brake Rotors
- Stance GR+ Pros...
- Installed Brakes
- best springs for a sexy drop, and no loss of performance
- Best springs for me on stock struts?
- installed new wheels + suspension
- evo x wheels on my IX making me slower???
- Brembo GTR
- te37 gtr face, what are my options?
- Brembo Caliper reseal
- suspension setup???
- My Brakes My Brakes My Brakes???
- Need help with suspension!
- Why the hell do I keep eating up frt wheel bearings?
- Progress swaybar brackets broke AGAIN!!! Solution?!?!?
- Springs for auto-x
- Your thoughts if you've tracked 2 or more of these: RE01R, Neova, Falken 615
- bed in new pads
- swift springs
- I've searched and searched: pic request - evo with white rims
- Where to buy blank RotorPro rotors?
- Suspension Noise... Trying to figure out what i broke or need to replace
- Wheel offset
- R compound longevity for track use
- please help
- Question about tires
- need help with wheels
- Ohlins PCV settings?
