View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. Parking Brake - Uneven Wear
  2. What ever happened to zzyzx?
  3. generic coil overs.....
  4. eBay brakes and rotors, good idea or not??
  5. Paint Peelings on Calipers
  6. NTO3s and me, what do i need + alignment spec?
  7. Evo VIII Chassis Bracing/Stiffening
  8. thoughts on this custom color combo? v. OZ wheels
  9. How do i prevent premature wheel bearing failure?
  10. torque wrench opinions
  11. 245/45/17 on stock rims
  12. new Eagle GT?
  13. Will 17x7 42mm offset work on my IX?
  14. Works 2pc rotors
  15. Help please! I'm looking for an aggressive rim
  16. my suspension questions
  17. OEM steelies that fit over the Brembos?
  18. Wheel Stud Help pics
  19. Brake Job
  20. looking for opinions of durability
  21. ride height fix/problems
  22. Tire Wear / Drivetrain Damage
  23. Advan RS 18x9 +29 with swift springs Fit?! Evo IX
  24. washers between the 2 bars under the DP???
  25. 235/40/18 fit?
  26. Bilstein compression question
  27. Suspension issues--do I have the solution?
  28. Tire Size on Stock SE Wheels
  29. wheel lock key?
  30. No one probably has this set up...
  31. What size Rota P45R will fit?
  32. Anyone Use Their Z1's In The Snow Yet?
  33. Evo's on 19's please
  34. Phanton brake light
  35. Looking for a light weight wheel..white with a red lip..
  36. Hotchkis spring snapped
  37. Brake squeal
  38. Coilover/Spring+Shock Jackets
  39. My Kuhmo ASX's wasted my time tonight...
  40. I need with wheel size. PLEASE
  41. Need to find some rota's
  42. ALL Robispec KW customers inside please!!
  43. duplicolor caliper paint kit?????
  44. Make your own toe bar
  45. Best overall street coilover
  46. Weird tire wear
  47. Eibach Drop numbers
  48. Brakes squeel when pulling into parking spot only.
  49. KYB or Bilstein Struts
  50. What PSI for 255's?
  51. 18 Inch Tires
  52. Blizzak WS-50's Brand New for $98.00 a piece
  53. All-Season tires. too large?
  54. alignment issue
  55. hks hypermax3
  56. what color lugnuts?
  57. MR Bilsteins & Swifts - Another Review
  58. spacers on stockers?
  59. Need suggestions on rotors and pads.
  60. Brembo Caliper Refurbishment?
  61. is the fender liner needed?
  62. Anyone running MR Bilsteins/AfterMkt Springs with 265/35/18 tires?
  63. help wheel!!!
  64. A lot fo smoke after hard braking
  65. Gramlights 57 Max 18 X 9.5 +22 In Evo 9
  66. 225 50 17?
  67. Lip on Rotor
  68. S.S. Brake Line ?
  69. muteki lugs on volk rims?
  70. DS2500 Pad Failure or Normal Wear?
  71. race set up
  72. Help? Tire and wheels.
  73. Espilir Spring install...HELP!
  74. How much should an alignment cost?
  75. Which size 215/ 55 R 17 or 245 /45 R17 snow tires would you run
  76. Help !! How To Get Rims Painted ??? (opinions Also Please)
  77. Stickyest 255/35/18
  78. Would you use these lugs?
  79. New Hawk pad compound - check it out
  80. Enkei RFP1s
  81. Need help. Grinding noise.
  82. Can someone identify these luguts?
  83. Whiteline Rearbumpsteer kit and alignment
  84. FYI: HD Bilstein front strut assembley part # has changed.
  85. Tire fitment
  86. I need help.
  87. TE37 Generation II a.k.a TE37 G2
  88. drawbacks of running wider tires?
  89. Apexi N1's??
  90. rotorpros rotor pictures
  91. Rotor fitment question
  92. What Is Largest Size 18" Tire I can fit on Evo 8 ??
  93. Brake light wont go off!
  94. Replacement tires?
  95. Brake screech after they ae warmed up
  96. Enkei RPF1's 17x9.5 +38 offset
  97. Racing Brake ET700 pads/RotorPros review
  98. clunking noise
  99. Just bought 18x9 rota g-force..Need fitment advice.
  100. Damned S-techs!
  101. HKS hipermax II coilover HELP!!!
  102. Alinement specs?
  103. What brake fluid am I using?
  104. Please post your Compomotive MO6
  105. Big Wheels
  106. Juat got the 18x8.5 brozne 5zigen FN01R
  107. Confirm MR strut fitment
  108. My massive suspension question brain dump...pls. pic off a question or two!!!
  109. rota toruqe 35+
  110. can anyone help? fitment
  111. 225 too small for front wheels?
  112. Ichiba wheel apacers
  113. 18" Rims?
  114. racing brake 2 piece rotor
  115. how wide of a tire can i mount on OEM IX wheels ?
  116. Work Emotion CR Kai
  117. stronger legs
  118. 18" upgrade question
  119. New Release: Nitto NT05 Performance Tire
  120. Timken Wheel Hub Assy.
  121. What tire size on Stride Sevens, 18x8.5+29
  122. Robispec to FL
  123. What site had damaged wheels?
  124. Noob Question :(
  125. Bilstein HD versus Bilstein Sport
  126. Scratching sound when braking
  127. squeakin from driver side wheel well
  128. Rear end noises?!?
  129. BC Coilovers?
  130. Drag Wheels
  131. Evo X MR wheels on Evo8
  132. Question about wheels/tires
  133. Coilover Strut Help
  134. PSS9 Install, Setup Questions, etc....
  135. Direzza Z1 Star Spec
  136. Front Sway Bar Install - Without Dropping Subframe?
  137. performance frictions brake?
  138. Tire pressure question......
  139. megan coilover noises
  140. Tread Depth difference
  141. tirerack belstein
  142. new shoes!!!
  143. Brake Rotors & Pads for < $600
  144. best replacement strut for my evo
  145. G-Games 99B? Discontinued?
  146. 2 pc. rotor question
  147. your tire choice
  148. Racecomp Engineering/GTWorx and At Speed Motorsports join forces!
  149. Need help with new KW V3's setup
  150. blown front struts...common?
  151. Best Choice in Coilvrs fo Around 1m
  152. Life Running 255's on stock rims..
  153. Direeza - Anything Better ?
  154. fill your tires with nitrogen
  155. where to get replacement drum brake pads?
  156. Review: Autozone Duralast Gold CMax Pads (Ceramic Brakes) for the Daily Driver
  157. help Brembo Caliper Bridge Pipes
  158. winter setup, on stock MR bbs.. opinions?
  159. New brakes, cant stand the dust
  160. Brake problem
  161. Team Dynamics Pro Race 1.2 18x9
  162. Coldest Temp for Direzza Z1 Star Spec
  163. Alignment, what do you guys run?
  164. Which Rims???
  165. New wheels and tires, suggestions on both?
  166. just got power slot rotors, small question
  167. Endless or rotara brakes?
  168. CORRECT hub centric rings for Rotas?
  169. Anyone using whiteline rear sway bar on an IX?
  170. Neal out till Monday the 27th
  171. help rear spring noise
  172. Wheels color question...
  173. fitment??!
  174. stock brembo brake caliper question
  175. Rims Came In The Mail Today!
  176. Goodyear F1 A/Ss or Bridgetone Blizzak WS-60s?
  177. Best Pads For My Car...(Searched)
  178. color lug nuts too ricey?
  179. Which Rims are these???(exact model of Rays?)
  180. Help: Does 17x9.5 fit???
  181. Wtfuxs! Brakes are loud!
  182. powder coating
  183. Brake pads under $17 !
  184. 245 45 17 Blizzacks Ok to run on 17"s?
  185. Big Brake Kits, Comments on Wilwood, Rotora & KSport
  186. Wheel fitment
  187. Roll Center Adj. Kit...
  188. Argh, rear passenger suspension clunk BUT...
  189. Wheel conundrum
  190. Why we do what we do and the sacrifices we make to get what we want.
  191. Need help in identifying Wheels
  192. Which rims shoud i get? Poll
  193. Flexing calipers
  194. Just a simple question !
  195. Brakes Help!!!!!
  196. Loud knock when I first apply brakes at low speeds?
  197. Bilstien/Swift installed correctly?
  198. vibration when braking
  199. Wheel+Tire Fitment Help
  200. Need new rear lower control arm bushings
  201. Free Tires
  202. BIG suspension help question
  203. Nail punctured sidewall :(
  204. Wheel bearings?
  205. Tire Wear..
  206. Squealing Ferodo's?
  207. Ways to reduce tri pod mode?
  208. Measuring Tred on Stock Advans...
  209. Rota G-Force Yamaha Black
  210. p45r fitment.please help
  211. Feedback requested: Fender brace design
  212. Need help with winter tires (Neal pls read!)
  213. Just bought new rims...
  214. 17x9 +22 CE28 REALLLLY close to calipers!!!!
  215. Broken rear ABS tone ring?
  216. Brake Pads!!!
  217. Brakes only squeal when in reverse?
  218. Does ANYONE have pics of BBS MR wheels with spacers??
  219. Coilovers
  220. Just got alignment done. Quick questions
  221. Adjusting Megan Coilovers
  222. Dunlop Z1 Star Spec VS Bridgestone RE-01R
  223. need brakes all 4 corners pads rotors all the good stuff just reusing stock calipers
  224. evo 8 enkei
  225. all weather tire question
  226. negetive camber question
  227. Anyone have BBS LM rims on Evo 9?
  228. Need info on these wheels...
  229. Missing wheel lock key
  230. Lower ball joint removal & install
  231. Who said cusco front brace does not fit with after market IC???
  232. TIRES "R" Compound Looking for a Freind
  233. Neal out till Monday the 13th.
  234. Old Advan RGI 17x9.5 +35 clear brakes?
  235. Brake lines
  236. BBS RIMS what tires should i use?
  237. Sway Bar End Link Boots
  238. Tre rear diff upgrade!!!! Maxx lock
  239. grinding noise when braking and turning right?
  240. CE28N Time Attacks 18/9.5+28
  241. shop for caliper rebuild
  242. offset/fender Q
  243. Look what i got!
  244. Tire noise
  245. suspension & tire pressure for drag racing
  246. Need Better Ride Quality???
  247. evo 7/8 with GTC?
  248. How do I tell?
  249. Hotlap Brakes cooling ducts under the tray
  250. inner wheel eaten up
