- when should i change my rotors? i'm at 60k
- Help me figure this out...
- wheels alignment!!
- How to fix tire touching fender liner
- Goodyear Eagles?
- wheel spacer question
- help with bilstein hd struts
- Hankook's Answer to The Advan A050 Introducing Ventus Z221 TD
- Question regarding understeer and throttle input (or loss of)
- wagner brake pads
- Speedline Turini Wheels
- magic pads clunk?
- Evolution Apexi N1 Damper EXV Coilovers
- Springs/Struts
- Evo's on coilovers
- Please post your Evo on Swift springs!
- long wheel stud?
- wheel bearing/hub 1996 evo 4
- What color, color code is this?
- Brake Caliper Line Repair (Need Advise)
- EVO 8 swift springs Squeaking
- Spacers on the BBS?
- EVO ride height uneven Swift Spec-R lowering springs
- tire help. please...
- megan street coils vs k sport
- What size Hypercoil Springs for Autox?
- Mickey Thompson ET Street Radial Tires
- Budget Build Suspension, Opinions??
- Anyone running 255 on 8.5?
- STANCE AL+ Pro with SWIFT Springs - custom rates - *pics*
- Pic request: Evo with Axis Widetrack wheels
- fender rolling idea.. good or bad?
- NT03+M 18x9.5, differences between +27 & +40 offset?
- GTWorx KW Variant 3 Coilover spring upgrade
- Anyone seen Sprint Hart CPR's on an Evo?
- Brake tick
- RAYS lugs in red.. PINK?!
- Good DD suspension for Evo
- anybody fit 265/35/18 on a 18X9 +35
- NT03's. Why so DIFFICULT to get 'em?
- to do or not to do with my ce28n volks
- Tires to run topspeed ?
- should i or should i not volks????
- What's the preferred suspesion?
- WTF happened to my caliper?
- Need some advice on my new setup
- which tires/
- Bushing Brands, what's the difference?
- how do I get 18x9.5 +22's to fit on my 9
- Does anyone have images of The Advan RS/ Rota G-force wheels in 17x8?
- Wheels Question
- advan rs, evo ix fitment?
- Evo crashed, need new tires
- braided brake lines
- Wheel spacer questions
- Advan wheel question.
- evo lug thread size
- best size tire for 9.5" wide +27 offset wheel
- Brembo Fade
- EBC Green Stuff Brake Pads
- Grex 6 Pot
- is it safe to drive with stock evo tires?
- kumho tires and swift springs
- BBS RR - Evo fitment?
- TE37 fittment questions
- Hankook Ventus Sport K104 VS Sumitomo HTR Z II
- which brake pad?
- Post your Tein Superstreet Setup here
- Do you guys want to see a 18x9 Grid for the Evo 8/9? (similar style to the 18x9.5)
- RobiSpec in Denver
- Volk Diamond Black - what does it really look like?
- 255/35 options?
- Evo wants to go left!!
- 18x8.5 +30, which tire size for best rim protection?
- Drag racing suspension setup
- le28n lug nuts ??
- Slid into a curb, need help...
- need new tires
- advan wheels
- Will these even fit?
- McGard spline drives from my subaru work w/ my Evo?
- noise from front springs? any suggestions on what to do?
- Touchup paint
- Who is running a Falken tire on a 8" rim?
- Tyre Fitment
- all season tires
- Looking for Nokian Hakkapeliita R
- Yokahama Neova/S.Drive
- What percentage do I have left on my stock Advans?
- 5Axis
- anyone ever use a vacuum/pressure bleeder?
- steering wheel still shakes after balancing and alignment!!!
- Brake Squeal
- Tire suggestion
- staggered wheels, same size tires?
- Trouble will Ball Joint on Rear Trailing Arm
- SSR Professor VF1 Wheel
- What is best tire and size for Time Attack street class?
- White Line + slicks? Will it work?
- Wheel with biggest lip
- What to check for- front end collision
- 255/40/17 rt615's stock advans,lowered.rubbing issues?
- Bilstein HD
- Bouncy ride with Hankook Icebear
- Need some help.
- OmniPower coilovers?
- Replacement of Endless Brake Rotor
- progressive springs for KWV3's?
- Racing Brake ET 300 brake pads
- Quantitative Spring/Strut vs. Coilovers Thread
- drop spring rates
- C8 Sport Coilovers
- What rims are these?
- 285 on 18x9.5
- Question about Rotas?
- **** my wheel fell off!
- Advan RS 18x9 +29 fit stock evo???
- choosing between 3 tires HELP....
- Really need help, it rubs like SHIX
- Tire Mounting
- slow leak?
- Alignment Troubles
- Center bore on SSR type-f?
- Swift Spring... now I get a clunk
- Eibachs
- New Enkei wheels
- Advice needed - 2 sets of 3 tires!
- Need to ask a favor from SWIFT and 17" wheel owners
- Tanabe's are kicking my butt, help!
- Need Pics of your Dampening Adjustment knobs please
- OK to mix new tyres together with old?
- Rim/Tire/Offset Question.....How big?
- Everything You Ever Wanted to Know About Rake
- Enkei RPF1's 18x9.5" +45. Will it work?
- tien basic coilover. megan racing coilovers
- TEAS Adjustments
- Squishy noise coming from rear suspension
- Camber Plates / Pillow Ball mounts .. Need Help Identifying
- Help!!! Tire questoin
- OEM brake dust!!
- springs and shocks??
- Continental ContiExtreme Contact or Goodyear Eagle GT
- GTWorx with MR. Bil
- The Brake Rotor, Pad, Line, Fluid, and Duct Thread
- Stained center caps!?!?
- vibration
- Enkei RPF1 offset 30 or 35
- Question on Springs!!
- stock mr bbs wheel offset
- Stock brake shims not fit on Autozone pads?
- 17x9.5 +28 Volk RE30 and Pilot Sport PS2 PICS & weighed on scale (56k prolly)
- 275 on 8 inch wheel
- Evo x brakes on my evo 9?
- Painting help!!!
- Stock shock weight?
- has any one used dms coilovers
- Loud Clunking noise...please help ???
- skinny wheels and skinny snow tires?
- Whose car is NOT lowered?
- winter tire size for stock wheels
- camber question
- Softest coilovers for street
- What bushings are recommended for optimum handling?
- tire question
- Crooked Steering Wheel
- anyone have hyper black g-force rims?
- Swift Spec R's Reviewed!!!
- Trunk panel cut-outs
- Nexen N3000
- Bbs ch wheels
- question of performance and durability of blizzack
- Uneven height after spring install
- road racing wheel+tire size setup
- What's My Stock Suspension & Misc. Parts Worth?
- Quiet Brake Pads with Minimal Dust?
- I think i got runflats
- BBK clearance, quick ?
- 5 Zigen ZR+520
- Beatrush Roof Brace
- Your opinions are welcome
- Urgent Help!! Tire Question
- need some help.... can this/has this been done
- Falken RT615 245/45/17 Tyre Pressure
- How can I make my evo ride smoother
- What wheels are these?
- Anyone have experience with the Mickey Thompson et street radial II's?
- my brembo pride is OVER!
- Does your Evo pull right when accelerating?
- Performance Friction rotor bolt/nut torque spec
- wheels from the dealer!
- Brake/Clutch Bleeding Tools
- Rear sway bar
- Enkei RPF1 17x9.5 +18
- Coilovers
- Espelir Active GT Springs w/ Bilsteins - Reviews & Pics!
- Brembo big Brake front kit for Evo IX
- Will CE28Ns clear BBK?
- any pic of SSR type F at evo
- Who's rocking Enkei RC-T4's? Pics welcome even if they arent yours.
- When to put on winter tires?
- corner balance - yeah but what numbers
- 17x7.5 w low offset search
- Robispec Suspension Packages
- EVO X brakes on IX?
- Corner Balancing in PA
- Will Tein camber plates fit over Ohlin coilovers?
- Lowering Springs....
- question about lowering
- BBS > Pothole
- Need new tires
- Allignment Advice
- Coilover Advice
- Pictures wanted: ROTAS 17x(8-9) with specs please....
- Brakeline and Clutchline Swap
- Nice Wheel Coating
- Where can i find: Adjustable Front Lower Control Arm ???
- Flat red wheel paint
- RE-01 or Direzza Z1 vs. Nitto’s NT-01
- Brade Pads
- Noise when slamming the breaks
- Bedding Req'd If New Pads = Old Pads?
- Look at my Tires!
- 245 R-compound or 275-street compound Debate?
- rear sway bar option
- Alignment Question
- Competition only use rims question
- Evo 8 Wheels Paint / refinish?
- Spring install question
- 17 x 7
- Dunlop Direzza 036
- Suspension replacement / suggestions?
- Coilover mounting?
- Tire Recommendation
- How noticable is a 2lb increase in wheel weight?
- CORNER EIGHT COILOVER any good?
- Question about changing springs on coilovers.
- 27mm Front Sway Bar?!?!
- Bridgestones Blizzak LM22 235/50R17
- Alignment for, rear 1" lower
- Those of you running 10" rims ...need your help/ see pics
- camber plates or not?
- What rims should i go with??
- 16 inch wheels do they fit the stock brakes?
- Advice on Reconditioning HKS coilovers...
- What After Market Springs Come In Red???
- Megan coilover springs
- my 03 evo VIII Pulls
- MR Bilsteins done?
- Parking Brake - Uneven Wear
