View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 [52]
  1. I want suspension.. but can't decide what?
  2. snow chains on lancer oz...
  3. Adjusting headlights higher?
  4. Weight of the front strut bar
  5. Rigid front strut bar
  6. US EVO8 rear brakes dragging
  7. Just got the RMR lower control arm brace
  8. Volks on Evo
  9. New Pics of my 19" TE37
  10. My Wheels
  11. 19" TEs on my Evo
  12. Lowering springs
  13. Brake air guides
  14. 5Zigen FN-01R
  15. Fikse Wheels
  16. Brake Squeal?
  17. would 245/45/17's work on evo?
  18. Evo 8 wheel options?
  19. Paint code for stock Evo rims
  20. A bunch of Suspension Components here.
  21. group buy on ferodo brake pads?
  22. Yokohama A046 now available at Tire Rack
  23. source for decent Coilovers?
  24. best lowering springs and coils for an ES??
  25. Evo sucks in the snow ! BAD
  26. Pics or white te37's on red or blue evo7-8?
  27. What is the recommended torque specs for wheel bolts on our evo's?
  28. Question regarding 2-piece "floating hat" rotors
  29. Te-37s
  30. Ralliart rim lookin might good!
  31. Enkei RPF1?
  32. What is a good brand racing brake pads for evo's?
  33. New wheels on the way...
  34. Recommended tires?
  35. question about static weights on the rims
  36. Evo stock alignment specs
  37. Heard ARAGOSTA suspension from Japan?
  38. weight of stock tire/wheel combo ~45lbs! :(
  39. Will this work?????
  40. EVO bolt pattern & offset?
  41. Will 17x9 Wheels fit on An EVO 8?
  42. where to get evo rotors and pads?
  43. disabling ABS
  44. Lugnuts
  45. Weight of stock Enkei Evo 8 wheel?
  46. 17 X 9.5" Volk racing TE37 fitment on Evo 8?
  47. Energy Suspension Polyurethane Bushing kit on Evo 8?
  48. SSR Wheel fitment
  49. how to hook up 4 point harness.
  50. Where is the EVO8 gas tank located?
  51. the spring spacer????
  52. spring spacers - how to remove
  53. Zeal Suspension
  54. Tires......when the time comes
  55. EVO VIII Tein Install...
  56. EVO 8 Rear sway bar stats?
  57. New Shoes and a How To!!!
  58. Need help choosing Evo rims
  59. What rims look good on an Evo VI?
  60. What will you torque your wheels at?
  61. Need new wheels...
  62. EVO lateral balance question
  63. Volk SE37A Wheels
  64. Brake rotors...
  65. EVO VIII Tires
  66. SSR Competition wheels
  67. yokohama ao46
  68. tein already makes coilover for evo VIII
  69. EVO VIII Suspension Components
  70. Wheel offset
  71. Brake pads for Evo 6 Brembos.. (street)
  72. 18" evo 8 wheels
  73. Enkei Tarmac Evo Wheels
  74. wheels for my vi rs?
  75. Knocking sound on Evo 7
  76. Spring rates
  77. Grp N. Bushings install (in progress)
  78. ok, CTF discs...but which pads
  79. Stock Evo Brembo Brakes
  80. Evo Wheel Diameter
  81. 18x8.5 te37
  82. Disks / Rotors?
  83. US Lancer & Evo7/8 have same offset?
  84. All Wheel Drive
  85. Best TeinSetup for the Evo7
  86. Two piece disc with TÜV
  87. Hydraulic Handbrakes
  88. Evo 4 Wheel size
  89. E7 wheels OZ Superleggera or Prodrive GC-07?
  90. Possible Strange Source Rotor Swap for ES
  91. Toyo Proxes
  92. EVO wheel offset and bolt pattern
  93. GAB shocks
  94. Intermittent squeal from brakes when turning
  95. Apex-i Brake Rotors & Pads
  96. I need new street tyres...
  97. Blitz Wheels
  98. Maximum Tyre Sizes for TME Rims
  99. 17 x 9 or 17 x 8.5 wheels
  100. Can't tuck my rims w/ enkei RS 6
  101. Speedline Magnesium Wheels
  102. Tyre pressures?
  103. Bolt Pattern on Evo VII vs OZ Rally
  104. Strut Bar
  105. New Suspension?
  106. OZ Superleggera for Evo6
  107. RMR ralliart Suspension
  108. New discs or 6-pot kit?
  109. lowered seven?
  110. JSpeed springs for Bembo calipers
  111. Wilwood Brakes
  112. Gas shocks vs oil
  113. Stock alignment figures and adjustability for Evo7
  114. RRM Brake pads
  115. Tein Suspensions
  116. Pads for OEM-discs
  117. I ain't crazy, BUT what do you think...
  118. Question about Coilovers and wheels
  119. Wheel Spacers
  120. Semi-slicks?
  121. Check dis, Magnesium wheels
  122. Who makes the EVO7GSR wire mesh rim?
  123. Dumb question
  124. Springs for Proflex / Öhlins
  125. CTF discs available at Sandtler NOW
  126. Advan Model 6 18 x 8
  127. Debating on which brand to get
  128. Suspension: EVO IV vs V vs VI??
  129. AYC recall...
  130. BRAKE PROBLEMS
  131. how long to run in discs?
  132. Orig. Tyres of the Evo7
  133. EVO Suspension Pictures
  134. Tire Size for Evo V
  135. Brake Disc Question
  136. RalliArt parts list ?
  137. Play at the steering
  138. Serviced one Proflex damper
  139. Just got new tyres
  140. Bilsteins anybody?
  141. Help to Make a Lancer to LanEvo
  142. Front Upper Strut Brace
  143. EVO VII handling VS WRX/STI handling?
  144. Andre!!
  145. ordered the moufous
  146. AYC/hand brake
  147. 366 Euros per DISC!!!!!
  148. What about Conti Sportcontact 2?
  149. CTF got back to Sandtler
  150. Brake fluid cooling elemente??
  151. EVO 1 BRAKE PADS
  152. A question
  153. My order with I.S.A. Motorsport
  154. what about Mintex pads??
  155. HELP - My TME Sick again!
  156. OZ 18" wheels for Evo6
  157. Tyre Storage
  158. Evo 7 bolt pattern
  159. sport suspension
  160. suspension question
  161. Please HELP!... :-(
  162. wheel offset?
  163. New Evo 6 FAQ Section
  164. 18 inch wheels
  165. Tein suspension
  166. Wheels
  167. Movit Brakes
  168. Strut bars, materials?
  169. Centre diff or gearbox busted?!?
  170. Moving front 4-pots to the back??
  171. REAL Tires
  172. The never ending brake saga... part 543
  173. Any news about Superleggeras??
  174. Help on geometry settings...
  175. Front rotors
  176. Winter rims for the EVO VII
  177. Tires: looking for better than Kumho
