- Falken Azenis ?
- HKS Hipermax 2 HELP!!!
- Tein S. Tech Springs good or bad?
- Enkei RPF1 Wheel 17x7.0 +48 fit with 10mm spacers?
- 4" wheel studs
- Cusco trunk bar
- Help hit curb at 10-15mph
- Fitment on Tenzo's
- powder coating brembos need some help!
- Looking for Rota P1's on Evo?
- Bedding-in new pads old rotors
- Fitment: 18x9.5 +38 in the rear? Stock shocks
- megan coilovers
- Car not leveled
- Where to buy parts for spherical ball joints?
- clunking noise after lowering spring install
- Noisey breaks please help!!
- Sway Bars Tech Q's
- evo 8 (gsr) springs with stock shocks..?
- stock height alignment
- Tire Pressure ??
- Can you lower bilsteins
- Drag DR-31, MB Wheels Gear: How much do they weight?
- Are these the right brake pads?
- Wheels question
- 18x9.5 +12 te37 question
- Where can I get This
- SmikeEvo's New Tires - Muhahaha
- 18'' rims, what tires size
- Going from Volk's to Stock to Rota's
- Front anti-sway bar bushings - tough install?
- Which all season tires these days?
- For those with front end "clunking"
- Front Strut
- Need Help/Expertise Diagnosing a Problem
- 17x9.5 Volk CE28 +28 offset
- What suspension bushings to replace?
- Front end links
- fitment 18x9 +30 et
- Alignment needed?
- Help will this fit with the brembos
- new brakepads and rotors after 27000 miles
- Broken stock wheels
- 5mm spacers, stock studs
- Tire Rack
- Which Brake Pads Some Questions!?
- Question about spacers and camber
- What suspension component is this?
- Rubbing is frustrating
- hotchkis springs install...
- Brake pad question!!!
- Help on install for cusco e-con dampining controller
- What Happened? One Side 1/2" lower than the other.
- painting wheels
- Need alignment?
- wheel size???????
- 93 Evo 1 Coilovers
- Easy general evo7/8/9 brake question
- Anyone runs 17x9 +22 enkei rpf1?
- Suspension advice.
- Skunk2 Coilovers?
- nt555r 245-45-17 weight?
- Question for Suspension Guru
- Anyone have a detailed front brake diagram?
- Enkei RPF1 Question.
- Hawk Track Brake Pads
- Suspension question..
- WW IX with X rims
- Torn between 3 sets of wheels for my Rally Red! Please help me guys!
- Need advice on repaired wheels (pics included)
- Lowering springs in front, stock springs in the back?
- Installed Springs/Struts, Creaking Noise From the Front??
- Help with wheel spacer!
- Nitto NT05
- Bad brakes, ABS, or pads not bedded in correctly?
- can someone tell me what they think?
- Which Brakelines should I Go With
- Gruppe-S SS Brake Lines
- MR Bilsteins/Swift Spec-R: Most aggressive 18" wheel width and offset?
- Energy Master Bushing Kit
- nto3+m 18x9.5 +27=what fender mods???
- What wheels for my car?
- Rear Coilovers Need rebuilding
- Faded paint / clear coat calipers
- Tires...255 vs 275!
- Trouble Removing Bolt on Rear Shocks?
- 255/40/17 S.Drive on IX BBS
- Broke a wheel stud
- tireeasy.com ?!
- Does anyone have pics of rolled fenders?
- NASTY/HORRID/INSANE front brake howl.....questions.
- tire recommendation
- Will these rotors last?
- Front camber adjusment
- Spacer Needed?
- Bilstein HD same as Bilsteins from an MR?
- Would damaged tie-rods cause 'loose' or numb steering?
- Swift Spec-R springs
- Brembo 6 piston caliper piston size?
- Anyone have Hotchkis springs installed?
- Aftermarket Lugs for stock wheels
- Found a source for HD Bilsteins
- Works brake pads
- How do I make 265's fit?
- driver side thump vibrations
- 18x9.5 +22 - Widest tire?
- help what wheels are these:)
- Evo 8 wheel paint? touchup paint
- Tire thread Transfer case failure..?
- 1996 Evo 4 CN-9a Rotors+pads ??
- Ever Seen Uneven Rotor Wear like this?
- help pulling the tierod
- whys my evo drive like $h!t in the snow/wet?
- Fitment Question
- Stupid noob question, but...
- Worst grinding sound evAR!
- Tire review S-Drive and Proxes T1R
- Bridgestone RE01R tires--SPECIAL BUY My Thread Was Moved
- Wider track or wider tires ?
- Painting Brembo's?
- Tire Question
- Tanabe GF 210 ride height
- Squeaky "Girodisc Magic" brake pads
- MAX Rim size ??
- Spring Install help, this okay?
- uneven tire wear
- How do you check for good coilover?
- Nitto NT05 sizes for the Mistubishi EVO now released [see sizes]
- best springs to get?
- KW V3 HELP! how to fix this?
- Wheel Manufacturer Qualifications
- Bad road force on tires?? Need some input
- Just ordered my new brake setup!
- Replacement brake pads...
- Car starts shaking around 40 mph?!?!
- Upgrading rotors from Ebc to racing brake slotted? A
- rt-615 camber question
- 255 on stock 06MR BBS, fender rolling?
- Sway Bar Advice
- coilover and spring questions
- custom wheel spacers
- best hillclimb tyres
- SWIFT lowered 8, wheel fitment help for a newb
- Knocking Noise when turning
- E Brake adjustment
- KW V3 help!!
- Hawk vs Mu
- Suspension popping - fixed - not what you would think
- Best racing tire
- Are your tires safe?
- Klunking sound
- Stock Evolution Suspension Weights
- if the rims are 18x9.5 +22 can i run a 245 with stock suspension on a IX
- Megan Racing Toe Control Arms?
- Snow packing in rims bad for rotors etc?
- On tein s-tech what size tire and rim to run???
- Brembo bleeding problem
- Does anyone here use Swift springs on the stock KYB (GSR) struts?
- E-Brake Light Stays On Sometimes?
- Where to get Works Center Caps
- Stock parts for Bilstein HD's (Tophats, Camber Plates, ...)
- all season tires?
- Anyone know what rims these are?
- ----!!!----What is the best setup for NO RUBBING???----!!!----
- Choosing coilover spring rates for your EVO
- Popping from front left corner
- Coilover Opinion
- Recommendation for Stock Strut Replacement
- Tire Help??
- Ksport and Megan question
- NTo3+m 18x9.5 fittment
- Some Questions Before Powder Coating Brembos
- Shaving tires
- Help Identifying springs
- front brake kit and wheel fitment question
- anyone running tein springs
- help! rear break seal
- Cheapest place to buy rear magic brake pads?
- Ride Height Measurements for GTWORX Springs and Swifts?
- New tires come spring time
- Camber plates and ride height???
- Will 18x9.5+15 with 265/35/18 clear the stock strut?
- trouble installing dc sport front strut bar
- Legitimate and Serious Wheel Questions. Help me out.
- Would it be ok to wear 18 by 9.5 rims for drag racing?
- I give up
- Reasonable for new Axxis pads to squeal like a stuck pig?
- Replacing/Fixing my suspension
- Need a photoshop done
- Z1 star specs.
- Will these wheels fit?
- Any body using 25mm spacer with stock wheels?
- XXR 502 Wheels Help Pls
- WEDS SA-90 17 fitment?
- camber question for swift sport springs
- SSR Type C RS - Fitment/Pic-request
- kosei;s? anyone running them
- anyone with JIC JFORCE07 wheels
- New rotors+pads == bad vibration?
- Whiteline products !!
- JIC FLT TAR Coilovers
- would you drive on these tires?
- knocking noise!! help please
- Hotchkis Adjustable Sway Bar... Bracket broke
- Looking for lowering spring suggestions
- How many have had premature bearing problems
- Kyowa KR 628 rims ???
- ABS sensor
- 18X9.5+15 on a Evo 8
- Yokohama S. Drive....help?? RT-615s
- Megan Street Coilovers making Noise
- E-break light
- Handling Advice for Autocrossing
- Swift Mach vs Spec-R with stock shocks?
- OMG coilovers...what ones? sooo many
- Anyone know of a good place to purchase BFG KDW 2's?
- 8.5" wheel, +35 offset, 20mm adapter
- 35 Offset 8.5" wheel with 20mm Adapter
- Whiteline W0588... where does this go?
- Wheel fitment
- Quick Question on Tires...got a problem
- Big Brake Kits!
- Buying New Tires Gone Horribly Wrong
- Picture Request
- Upper hat on suspension bad... what can I do?
- Evo 9 SE vs Evo 10 wheels
- Hawk Brakes
- Tire question
- Camber/Caster Plate for stock struts
- Seibon TE37 paint Code
- Tire Size question
- Would you guys run these rotors on your car??
- lugs for rota p45
- Work VS-XX fitment EVO IX - HELP!
- May I introduce the new OZ Alleggerita HLT
- What are those Wheels?
- Pic Request: Enkei RP03 17x9.5 +38mm
- Max. Spacers with 9x18 e30
- Advan RG2 in anthracite silver???
- KYB Rear Struts - Disassembly?
- Yokohama Advan RG2 Color Code?
- Can someone show me where I can get the OEM brembo rebuilt kits for cheap?
- OEM wheel bearing replacement
- Is HKS full suspension worth buying?
- alignment before or after new wheels?
- Agency Power StrideSeven Wheels 18x8.5 29mm
- Evo8 shocks vs MR and ride quality?
- What do u guys think of these tires at this price?
- 4-way suspension
- drag racing suspension
