View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 [44] 45 46 47 48 49 50 51 52
  1. random brake noise with no braking..
  2. Proper width and offset for 19" wheel?
  3. 13" brake upgrade for under $1700
  4. Anyone here ever warp a set of Rotora's?
  5. Pirelli Pzero Nero M&S OOS Everywhere?
  6. Replacement tires in SoCal?
  7. i want my wheels black, or something dark
  8. clutch line should be in soon, and words of advice before install??
  9. Newb to this whole thing?
  10. Eibachs and alignment
  11. evo 8 front calipers fit on lancer???
  12. Size of factory lug (socket size needed)
  13. Shopping coilover kits for serviceability, avail. of replacement parts, warranty, etc
  14. Break noise
  15. Installing springs
  16. roll back issue
  17. Tein Springs!?
  18. Could someone explain corner balancing to me?
  19. Michelin Pilot Sport Cup
  20. Sumitomo HTR Z II VS BFGoodrich g-Force T/A KDW
  21. Shocks bottoming out???
  22. Girlfriend curbed my new Black TE37's
  23. Help Please I am driving cross country!!!!
  24. Little Dilemma
  25. EBC greenstuff pads installed
  26. TEIN-S Springs and Front Tires...
  27. re
  28. red brake light on dash seems to come on alot
  29. How much is everyone paying for replacement Evo tires?
  30. Can lowering a car cause trans/drivetrain problems?
  31. gram lights 57S 17x8.5 offset?
  32. Where Can I Get Yokohama Advan Ad06
  33. volk rim question
  34. what are coilovers?
  35. Best springs to keep EVO's handling qualities?
  36. Metal squeel plate for brake chang..Up or Down?
  37. Any other cars come factory equipped with a tire as aggressive as the Advans?
  38. a046 vs exalto pe2
  39. New wheels!!!!!
  40. Grease Gasket on rear trailing arm
  41. is there a coupon for tire rack?
  42. is there a tire that is better than the stock advans that can be driven daily?
  43. Can I get Neuspeed springs?
  44. Getting rid of my Tien S springs
  45. volk gt-c wheels
  46. AVS Sport - FYI
  47. TRACK/ STREET setup
  48. RRE JIC suspension installed
  49. Had the car aligned 2wice With H-Techs, still handles like Sh1tzue
  50. Any one that is using Perrin products!
  51. Have Rota Torques, need center caps that fit over our hub
  52. stock tires
  53. Anyone KNow what rims these are?
  54. How the heck did I wear out my rear pads before my front?
  55. dealer service
  56. Help! Yoko advan - what does the "SL" stand for?
  57. Falken Azeni Sport Size Help?
  58. How many pads changes is everyone getting till youve replaced your front rotors?
  59. Neal, when are the OZ Supperleggeras coming out for the EVO?
  60. Photoshop request...
  61. Warped my rotors i think....any suggestions
  62. How to repair brake caliper
  63. 215/50/17 on stock Evo wheels?
  64. Anyone running Ferodo 3000's on the street?
  65. AWD and HP
  66. RS Trunk Bar?
  67. Rota Torque Wheels are here!!
  68. NEED HELP please?
  69. rebuilding coilovers
  70. info please!
  71. Decisions Decisions... Tire Help Please
  72. tire help
  73. FINALLY, A proper Alignment
  74. Anyone with 18 SSR GT7 in the Light Gray on an Evo yet?
  75. Black wheels (w/red lips?) for the RS?
  76. need hubcentric rings
  77. Good Brake article
  78. Winter wheels and tires
  79. Jic Flt-a2 Or Works/tien?
  80. Stock springs really that soft?
  81. contribute data to wheelweights.net
  82. New BF Goodrich g-force sport tires.. Help.. Tirerack?
  83. Wheel Repair
  84. Bolt Pattern of EVo wheels
  85. Ferodo pads
  86. Just got HKS Hipermax RS
  87. Coilover Installation ?'s
  88. Love the AO46, but...
  89. Cusco rear sway bar which hole
  90. What 19" wheels will work for the Evo?
  91. What Coilovers does the HKS TRB EVO8 Use?
  92. Need some wheel help
  93. Is alignment covered by warranty?
  94. Wheels????
  95. Evo RS Brakes
  96. Brake job?
  97. Pirelli PNero Zero M&S Experience
  98. electrically adjustable ride height?
  99. Is replacing 2 tires ok?
  100. Tire Question
  101. ANybody know anything about Velox Progear?
  102. Which Tire is Best for EVO?
  103. Would these fit an Evo?
  104. tire/road noise
  105. attn track guys: coilovers...none of this lowering spring bs
  106. Saw these rims in SCC...
  107. Vibration from Stock Rotors, Which to go with?
  108. bigger rims and tires VS stock questions
  109. NEED HELP: where to buy TOYO TRAMPIO vimode
  110. racing hart 19in
  111. RA-1 as a daily driven street tire.
  112. Type of wheel locks for OEM wheels?
  113. Tein springs 1 year warranty
  114. Tire Pressure Question
  115. Replacement tires?
  116. wheel setups
  117. How do I remove front rotors?
  118. Anything that compares to Advans?
  119. Black Racing N1 wheels
  120. Tein H-Techs
  121. steering wheel shaking violently at 100mph
  122. what a different -2 camber made from -1.7
  123. tires for black evo
  124. Need longer studs to fit some wheels
  125. Tire/wheel combo
  126. Which R-Compounds should I buy!?
  127. Stock tires are almost gone!!
  128. Opinions on Work XSA-02C Rims
  129. Tein Basic coilovers
  130. Fender rolling tool
  131. EVO stock front strut tower bar
  132. spring and shock combo
  133. Is the offset printed on the rim somewhere?
  134. Done some hard braking tonight with my Project Mu's
  135. Question for Neal ???
  136. Torque Thrust Wheels
  137. "HP EVO" rim fitment..
  138. volk te-37 question for all you wheel experts
  139. Volk GTC or Emotion Kai's ?
  140. ... and front swaybars ?
  141. Sumitomo tires? any good?
  142. What brake pads?
  143. Enkei WRC Tarmac Evo 18x8.5 price
  144. Rear S-tech springs
  145. Factory Specs for wheel alignment
  146. 18x9.5's +35
  147. Cusco lower cross bars or Works rear sway bar?
  148. Anyone have black rotors
  149. Rear Strut Bar Weight? Anyone?
  150. Shot in the dark (steelies that cover bremb's)
  151. Help! bled caliper dry
  152. black evo 8
  153. EBC pads
  154. EBC pads good or bad?
  155. lowering w/stereo equipment in trunk...
  156. Haven't seen this problem before...
  157. 11k miles..rotors warped!!
  158. BFGoodrich g-Force T/A KD question
  159. Just got my BBS LM F1s ( all gold, even lips) today...THANKS Gruppe-S
  160. Blown struts?!?
  161. Front End Clunk - Check Strut Bearings
  162. Which vendor here sells Roja wheels?
  163. Need Help With Tire and Wheel setup!!!
  164. Michelin Pilot Sport PS2
  165. I have a question about HKS Kansai tracks.
  166. Evo soon, winter wheel/tire shopping...
  167. Best Lowering Springs???
  168. Fuzion Tire Updates?
  169. Wheel and Tire fitment for 17x9 Rim
  170. First Evo in the U.S. with............
  171. Brembo Cross drilled rotors installed - WOW!!!
  172. Well, the ABS works . . .
  173. Outter Tire Wear 9000 miles
  174. Bizarre alignment at Firestone?
  175. Advan Wheels Group Buy!
  176. Coilovers or ?
  177. Winter steel wheels for Evo?
  178. AutoX wheel combo... Neal help..
  179. Stasis 2-Piece Floating Rotor
  180. Team Dynamics Racing Wheels Stock on FQ 340
  181. Enkei OR52
  182. Hallman PRO Kit MBC
  183. Need Help!!!
  184. Will Tein S-Tech's kill my stock struts?
  185. Pics (real or photochopped) of gun-metal ralliarts rims on Apex Silver?
  186. Brake air guides
  187. Stock tire is almost done...
  188. Factory Suspention Specs
  189. Cheapest place to find Advans..
  190. Cusco Or Hks Coilovers?
  191. Tein S-tech Alignment for AutoX?
  192. Ferodo's or Project Mu ?
  193. Tanabe GF210
  194. Street pressures, Kuhmo Ecsta MX
  195. To All Tien S-Tech Spring Owners
  196. Front Camber kit
  197. 01 Design Systems
  198. Where to buy adjustable camber plates
  199. Are the EVO wheels interchangable with 05 STI wheels?
  200. Tire circumference and the center Diff
  201. If I run a 18x9 or 9.5?
  202. Goodyear F1 GS-D3, any experience?
  203. Please gelp me decide! (Tein VS Tanabe)
  204. Enkei Stock rims with Blizzaks
  205. Anyone got pictures of black Ralliart R-01 on EVOs?
  206. buddy club p1 racing QF wheels?
  207. Stiffest Sidewall
  208. Brake Fluid
  209. Which New Tire for stock rims?
  210. Lug Nuts
  211. Hawk HPS, opinions? (I have searched)
  212. Toyo T1-s
  213. Which Tires For 18in Wheels??
  214. Neal, best 1/4 mile rubber?
  215. Pennie TEst Brake pads
  216. evo vii wheels?
  217. My new shoes. :)
  218. everyone, check your spare tires !
  219. Anyone know where to get a good deal on HKS Hyper Max II's?
  220. How long do summer tires last????
  221. Toyo tire question
  222. Tire/wheel weight question - performance view
  223. Directional Tires
  224. FS: TEIN Flex w/EDFC barely used!!!
  225. Brakes -what caused it
  226. G35 Coupe manual brake set for EVO?
  227. air bushing
  228. Suspension on 19"s???
  229. Pictures and Info on my Suspension mods
  230. Advan 048......what compound ?
  231. Just had an Alignment and I have a ?
  232. Source for Toyo Proxes RA-1s?
  233. BBS CH plasma...
  234. Running 18"x9.5" Wheels
  235. Grinding noise when braking and afterwards
  236. Brake Help
  237. Rear Swaybar Poly D-Bushings
  238. pics of 19" Konig Next w/nitto nt555
  239. Wheels: Rear wider than front?
  240. MOMO QUASAR 18 X 8 (45 Offset)
  241. Ohlins For Sale
  242. Custom rear lower control arm and front fender setup to run 305's...
  243. Inverted aftermarket struts?
  244. opinions bout bridgestone potenza re750
  245. Best Prices on Volk Wheels?
  246. Weds TC 005
  247. MIVEC engine for 97 LAncer
  248. Volk center caps
  249. Wheel bearing problems?
  250. Where do I get these rims?!
