View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. new springs + new tires?
  2. wheel bearing
  3. 80% track 20% street ride hight
  4. Trying to choose between these tires... anybody have input?
  5. can the brembo calipers be rebuilt?
  6. ABS ring tooth question. should any be missing??
  7. OEM lugnuts?
  8. What type of suspension goes on rally cars?
  9. NITTO 555R Extreme Drag tire weight answered
  10. need info on wheel fitment will they fit????????
  11. Powder coating calipers
  12. What have you done to stop Brake Squeal? No opinions, please!! FACTs ONLY!!
  13. ABS connector placement
  14. Camber HELP! - ANYONE!!!
  15. will evo X rotors fit on a evo IX
  16. Question from a noob...
  17. Evo steering wheel shakes pretty bad when i hit brake
  18. Strut top play....
  19. porterfield r4-s Squeal?
  20. what rims are these
  21. Q: How much does toe change with camber change?
  22. Whiteline Roll Center Kit KCA395 ??
  23. ROTA P45R with the tire 245/40 R 18
  24. 5mm Kics spacers
  25. Swaybar preload question
  26. tires
  27. I've searched but no luck
  28. Rota Grid 18x9.5 +20 or Rota DPTs 18x9.5 +22?
  29. Shaky steering wheel, different tire sizes
  30. Should I change my tires now?
  31. Anybody Have a Pic of a 235 & 245 Tire on a 9.5" Wide Wheel?
  32. brake problems
  33. Need 21mm (0.84") OD lug nuts !!!
  34. Wheel Lug Brand??
  35. stiff brake pedals after springs installed
  36. Whre I can find lug nuts wit OD 0.85" ????
  37. 2 questions: front CV Axles, and weird noise from rear susp.
  38. Stuck Coilover
  39. Evo X wheel lock nuts - Is it safe to use this type?
  40. now these are HOTT!!!
  41. Wheel Stud Installer ...
  42. 20' Wheels?????
  43. RPF1 18x10.5 +15 ?????? Fitment on a widebody Evo 9
  44. Spring questions on MR
  45. Megan Coilovers bad in less than 12 months
  46. What lug nuts for Konig Zero ???????
  47. Firestone Firehawk Wide Oval
  48. Neal out till May 1st
  49. People running 17x9's --- need some help
  50. BF Goodrich T/A KDW for **DD**?
  51. Toyo proxies air pressure?
  52. Front RHS braking shudder?
  53. Advan A032R vs. Nitto NT-05
  54. Any lightweight wheel recommendations?
  55. Need Help with TE37 +22
  56. goodyear eagle GT tires what u guys think?
  57. Blown D2
  58. Is installing only front springs okay?
  59. New brake pads... ??? before I install them
  60. Needs confirmation on 17x8+ 42 offset.
  61. 17x10 +25 5zigen FN01R-C
  62. car reacts badly to rain on road
  63. Shot Wheel Bearing
  64. Knuckle Nuts
  65. alignment help
  66. Evos with 255/40/17s on stock wheels --- post up pics!
  67. Question on the swift sport springs
  68. wheel/ tire combo question
  69. 3mm wheel spacer/ RPF1s
  70. Suspension help?
  71. Coilovers or new set of good springs?
  72. Rota grid 18x9.5 +20mm offset fitment
  73. Bottom strut bolts won't come out
  74. will this lugnut fit? (muteki sr35 + extrended studs + 6mm spacers)
  75. What slicks should I get
  76. Need new Tie rod end
  77. New rims with old tires
  78. megan coilovers
  79. HKS lowering springs??
  80. swift sport or spec-r?
  81. best lowering springs
  82. evo and tires
  83. Quick question guys....
  84. Anyone know if there are preload spacers available for stock struts/springs?
  85. HELP!!! 17x9.5 +15
  86. steering wheel vibrates when braking/slowing down
  87. Why is my Evo sitting slanted?
  88. Tein basics or Megan...
  89. Brokwn wheel lock key.. suggestions?
  90. what causes brakes to squeal?
  91. Advice for track tires please?
  92. Lugnut thread pitch size
  93. to all you track guys
  94. K-Sport Coilovers
  95. What offset for 265/35/18 help please..
  96. The New Konig Zero In, suggestions and comments
  97. Steering wheel vibrating help
  98. 18x10 +9 Wheel with HRS Wide Fenders??
  99. Staggered Te37 Tire Question
  100. So I rolled my fenders this weekend...
  101. 6.5mm Spacer and Stock Studs ...
  102. Correct tire pressure.
  103. KW Variant 3 Coilovers.. need some help!
  104. Black Enkei RPF1 18x9.5 +38 available?
  105. So my new tires are 245/45/18....
  106. !!! Problem with wheel spacers !!!
  107. Evo IX MR USDM Stock Brakes specs
  108. hotchkis lowering springs
  109. Feedback on Buddy Club Racing Spec Coilovers
  110. suspension suggestions
  111. Ready to pull the trigger on wheels finally.
  112. Thinking about getting some wheels...
  113. squeaking while moving
  114. Tire pressure gauges - what to buy?
  115. Suspension Discussion Thread Links
  116. drag xxr 006 HELP
  117. Why are rt-615s so cheap?
  118. how do I instally center caps on oem rims?
  119. will 235/40 fit on stock rim?
  120. EVO IX - Coilovers - need help
  121. How long can you drive on your spare tire?
  122. Swaybars: Robispec or Whiteline?
  123. 245/45/17??
  124. help
  125. 20mm spacer on stock mr bbs's
  126. lost my wheel key
  127. 18x10 +20 wheel fitment?
  128. Suspension Discussion: Camber vs. Caster
  129. need brakes & tires
  130. waiting for bilsteins
  131. Ve3-b843-h2
  132. Powdercoat Rims
  133. rays/gram light center caps
  134. Wheel liner and 17x9.5 NT03 +38 ??
  135. 255/40/18?
  136. AST Double Adj. 5200RR Finally Here!
  137. Rota P45's
  138. Coilover problem
  139. Coilovers installed, the car rides amazing now.
  140. wide body fender liner
  141. Tail happy rear end, has me not so happy. Need advise
  142. Question about wheels and stock suspension
  143. Popping noise caused by lowering springs..
  144. WEDS SA70 RR - 18x10 +18 or +32
  145. Will 18/9.5/+25 and 255/35/18 fit stock, not lowered EVO 8????
  146. Looking 4 aggressive tires on stockies
  147. Soft Brake Pedal
  148. brakes for my 2003 evo 8???
  149. swift spec-r springs installed
  150. Cusco Camber plate help
  151. Falken ZE912 questions...
  152. Beatrush undertray + Carbing lower arm bar fitment???
  153. Problem???
  154. brake sqeal - driving me nuts
  155. Evo X Brakes on Evo 8?????
  156. rear suspension won't drop on 9 MR
  157. How do I reduce bounce and body roll?
  158. will a set of evo 8 springs work on evo 9 struts?
  159. Pulling rear fenders?
  160. Rear left ebaring on a JDM Evo 7
  161. Bridgestone Potenza RE-11
  162. How much fender rolling is required for 18x9.5 40mm with 25mm spacers
  163. sway bar question
  164. NEED HELP - Sway Bar related -
  165. Evo viii/ix brakes/steering wheel on a 1g?
  166. Braking problem
  167. Will these wheels fit ...
  168. 5Zigen FN01R-C 17z9 +15???
  169. Stick on wheel weights, will they last?
  170. Coilovers that match this criteria?
  171. What wheels are these? New EVO IX MR SE owner looking for rims
  172. Issue.. just replace rotors/lines/pads
  173. Pros and Cons about Hotchkis Lowering Springs
  174. wheel bearings
  175. ABS light - speed sensor codes all 4 wheels
  176. Help Rear Fender Roll
  177. Evo suspension parts
  178. STANCE Coilover Height Adjustment Problems
  179. tire opinions
  180. (Max) tire size Advan RGII 18*9 +29 on Evo IX
  181. 19" wheels on Evos
  182. Ohlins Flag Coilovers settings HELP!!!
  183. Front sway bar makes a big difference!
  184. RT615, Star Specs, or NT05.
  185. Remove Lower Front Control Arm on and EVo 8?
  186. evo 8
  187. Best Tire Size for AutoX?
  188. Question (Rubbing RE01R)
  189. fitment help with 18x9 + 20 offset
  190. question about lugnuts for new rims
  191. light wheels
  192. Has anyone successfully retrofitted Evo X brakes to an Evo 8 or 9?
  193. Help with front wheel well liner rubbing
  194. noise when braking and driving slow
  195. ROTA Subzero wheels 17 x 7.5 5x100 anyone??
  196. K-Mac or Vorshlag camber plates?
  197. Someone help with master cylinder brace installation!
  198. can wheel center caps come off by themselves or did I get jacked.
  199. Screeching, clicking noise when turning slight left?
  200. QQ about the alignment marks
  201. Megan Racing BBK
  202. best tire for my setup
  203. Which rear chasis bar setup?
  204. Girodisc Bailout Blank Rotors vs. RotorPros Blank Rotors
  205. Toyo R888 Vs Advan A048
  206. HELP! Need to know about a certain fitment!
  207. Best Looking wheels.....
  208. New Stance - GTWorx Street/Track Springs
  209. DD Tire recommendation?
  210. Would you pull the trigger on these wheels?
  211. Which tire would you reccomend?
  212. 255/45/17 Stock 8 Rims
  213. Another Alignment Question!
  214. any bby with the 5zigen fn01r-c on them?
  215. Will these wheels fit?
  216. Tire Valve Hole Size OEM BBS ???
  217. Rotor thickness question.. how far down?
  218. Wheels and rotating
  219. anything i should know before i tackle this?
  220. Centering my steering wheel
  221. tire size question
  222. Weds Sport SA-97F
  223. offset help.
  224. Nitto NT-01 tires noise.
  225. Diagnose My Brakes
  226. What rims to get
  227. Brakes squeaking badly!
  228. What size tires can be run on Evo 8 wheels?
  229. Front clearence Help!
  230. wheel spacer and studs install?
  231. PF-Z What?! (Performance Friction Z rated pads)
  232. Swifts or RobiSpecs? Help Me Decide!!
  233. Best tire size for auto-x on stock suspension
  234. Anyone interested in a custom set 18x9.5 Grids in white that fit w/o fender rolling??
  235. kmac camber/caster plates
  236. Volks CE28n T/A or Advan RS D/G
  237. Volk le28n gold chrome lip 18x8.5 +43
  238. Enkei RPF1 n00b question
  239. Ohlin flag series coilovers
  240. 255/40 (OEM non BBS wheels) what psi?
  241. Got the strut apart, quick question!!!
  242. cusco front control arm brace question
  243. How is this brake set?
  244. ANYONE here rock a Rota Sub Zero Rim?
  245. Brake Rotor Size's???
  246. Powdercoating brakes
  247. Thumping noise
  248. Solution to aftermarket wheels and spare tire
  249. Re01-R Break In and PSI Ques
  250. Jic tar and a2
