View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. Brembo Brakes on an Eclipse
  2. Advan Wear Issue
  3. Question on MR Suspension
  4. New Rims
  5. 17X9.5 with +38 offset.. will they fit?
  6. stock tire question
  7. Toyo RA-1 or ADVANS?
  8. New Evo VIII, help with brakes???
  9. help me out with tire choice guys!
  10. painting wheels
  11. 97 GSX rims fit the EVO?
  12. The infamous Ralliart street springs: Installed!
  13. how low for 235/40-18's?
  14. Megan Racing coilovers?
  15. Rre
  16. Difference between tein s and high tech
  17. Testing: Apexi N1 Damper ExV (Expert Type V)
  18. Weird Brake Vibration Noise???
  19. Gram Light 57S-Pro
  20. 19" rims...anyone have them on their Evo?
  21. OEM Wheels and Tires...what are they worth?
  22. What tires should I get?
  23. Front Wheels Whine when slow down... Is this normal?
  24. New rotors
  25. Tanabe Coilovers ?
  26. Stabilizer Bar
  27. Falken Azenis ST115 or fuzion ZRi ???
  28. PZero Nero
  29. Brake padel height adjustment??
  30. Clear coat peeling on Brembos?
  31. 2 Michelin tires for sale 245/40/18
  32. Whats your opinions on Nitto NT555 tires?
  33. Best Rims?
  34. The difference between +22 and +29 on Volk TE37?
  35. questions about hawk pads or any other pads
  36. hawk hp brakes squeal VERY loud is this usual
  37. question about work emotion
  38. Lowering Springs, Feedback And Suggestions
  39. toe in on front tires ok?
  40. break squeal
  41. Will these tires clear my fenders. Please Help
  42. tein squeking noise
  43. Off-road/tarmac "Rally" Tire?
  44. Anyone runnng CCW rims?
  45. PLZ HELP w/Advan Question!!!!!!!!
  46. Tein Camber Plates
  47. MR Springs Feedback Thread , Got springs on ur MR? GO HERE!!
  48. Anyone need H&R 15mm hubcentric spacers?
  49. project MU brake pads
  50. Long run for springs?
  51. Strut bar weights
  52. Shock Technology Page
  53. Sti s03 pole position tires?
  54. Summer wheel/tire suggestion?
  55. So you want a light wheel
  56. 245/45/17 Rs2s on Hotchks springs.
  57. can I run 235/40/17's?
  58. Lookin For Some Wheel Suggestions.
  59. How to Tune Your Suspension!
  60. Stock Ride Height Question
  61. 2 Questions Axis Reverbs and price for stud install
  62. any 16" wheels that will fit on the evo
  63. steering wheels shakes when braking??
  64. Cusco Zero2R Spring diameter
  65. Gram Lights on Tire Rack?
  66. This is Dumb
  67. ROTORS wheight
  68. Anit-Sieze Compound on Wheel Studs.
  69. Wtb: Swift Springs
  70. warped rotors.. what to do?
  71. New tires - what would you reccommend, Neal?
  72. GramLights 17x9.5 fitiment question
  73. StopTech vs Brembo Rotors
  74. Tire pressure?
  75. pics of my new wheels.
  76. What size tire for 18x8.5 work emotions and which brand?
  77. Opinions Please 19x9.5
  78. Just installed my brake pads
  79. question about brake PAD install
  80. **STUPID*** Question
  81. Chronic Mis-Alignment DRIVING ME INSANE--please help!
  82. Guess the offsets to these....
  83. Tein Flex owners please read
  84. Hotchkis Rear Sway
  85. Alignment Shop in Socal
  86. Pictures of 9" wide wheels on the Evolution?
  87. Anybody use structural foam?
  88. will this fit my evo?
  89. FN01R-C avl at WORKS
  90. Tire Wear (alignment???)
  91. Buddy Club P1 Racing II?
  92. Unusual Front Passenger brake wear
  93. Tires for 18x9 29 offset volk gtu
  94. Need Help! - Vibration
  95. What are the Widest Tires Possable?
  96. MR suspension noise question
  97. Tire shop screws up rims
  98. aligment question
  99. What are some of the HOTTEST NEW wheels out?
  100. B Force pads, SS lines, and super blue review
  101. For those with the Sparco harness bar...
  102. 19x9 wheels
  103. Missing brake piece, what is it and is it 'really' necessary
  104. Tire Rotation
  105. Will camber plates OR"aftermarket eccentric bolts" fix chronicly UNEVEN front camber?
  106. Back-end Wiggle at High Speed: how can I eliminate?
  107. stock pads and stock rotors
  108. where to buy espelir
  109. Brake Pad Options Or Trade
  110. Works MR edition Springs
  111. EVO 7 parts change..FOR EVO 8
  112. How wide can you go ?
  113. Arrows on Stock Brake Pads?
  114. cusco bars...
  115. need you input on Gramlight 57S
  116. Wedsport SA90 -- Owners??
  117. Motegi Trak Lite wheels???
  118. I heard that we cant bleed our brakes??
  119. these line ups are the hotness
  120. need opinion on these 2 wheels!!!
  121. Rota wheels that fit STI's
  122. ATTN: Cusco Zero 2R OWNERS!
  123. have you had a brake air guide snap off?
  124. Brembo vs Endless
  125. Clunk Clunk Clunkity Clunk
  126. Black Racing Pro-N1 fitment?
  127. Neal: news on SSR SP1?
  128. Bolt Pattern for EVO VI
  129. Slotted Rotors
  130. Falken Torque 5 Wheels for EVO - DON't FIT!
  131. Painting the stock rims.
  132. bendix brake pads?
  133. Hotchkis springs cause rubbing?
  134. Need tires for 18x8" Privat Sekt
  135. Need diagram of EVO rear strut/spring
  136. Help - Brake piston stuck out
  137. Suspension suggestions?
  138. Why is my front caster messed up?
  139. ATTN: Project Mu B-Force break pad owners...
  140. Performance Difference: Volk 18x9 vs Oem Enkei
  141. Need Help! Removing hard lines from master cylinder
  142. PLEASE help diagnose clicking sound
  143. what does dual height adjustability mean?
  144. EVO8 brakes fit what else?
  145. question for anyone with volk racing ce28n wheels.
  146. What tire size for 18x9 with 34mm offset?
  147. Wheel Advice
  148. I need help please. 245/40/18 on 18x8.5+30 with stock suspension.
  149. Do patched tires BLOWOUT at high speeds?
  150. Brute Force Brake pads, POS!!!
  151. Tein or HKS coilovers?
  152. Forgeline ZX3-Rs installed. 18x9
  153. Tein or Cusco camber plates?
  154. Tire size on 18x9?
  155. 18x9 or 18x9.5?
  156. What's needed to eliminate wheel hop?
  157. anyone using track coilovers?
  158. FS Espelir ASD springs
  159. Will Evo OEM rims/tires fit on a 2G eclipse?
  160. bad day
  161. Will these rims fit an 03 Evo?
  162. Volk Evolution pictures.
  163. 18inch black wheels
  164. MR BBS wheels- dealer cost?
  165. What are some other tires other than the Advans that I can put on my evo?
  166. RRE BuddyClub suspension thoughts pls.
  167. "Street" Alignments
  168. Does anyone carry the TDR Visage wheel yet?
  169. MR type shock/spring for '03 Evo again....
  170. "Brake" light under hard braking??
  171. Alignment after lowering the car
  172. jic flt a2
  173. Does anyone make an 18" rim that looks like this...
  174. To Volk or not to Volk, that is the question.
  175. wheel studs??
  176. 18x9's 38mm Offset....Rubbing and Looks?
  177. Help me find this trunk bar!
  178. Gold wheels on silver evo
  179. Rim Help!
  180. Red wheels
  181. Tein H-tech rubbing issues?
  182. Attn Neal
  183. Anyone mounted 17x9 wheels with 275/40-17 tires?
  184. Installed coilovers = Noise?
  185. Kids, don't let this be you!
  186. Pics of my new shoes.....
  187. Alignment Specs
  188. Screw + Tire = BAD??? How about after a few weeks?
  189. Is this a brake indicator?
  190. What SCCA AutoX class would my friend be in?
  191. HELP: leaking brake cycliner??
  192. Cheap Stoptech Slotted Rotors???
  193. Wheel fitment?
  194. Volk LE28n and Bridgestone S-03 questions ???
  195. Anybody got pics of Racing Hart CR
  196. Who has TOYO RA-1's and how long do they last
  197. new to evo... bad brakes @ <1000 miles?
  198. What rims are these?
  199. Any pics of 5Zigen FNO1RC black with polish lip?
  200. Endless SS S front installed
  201. HAWK HPS pads..how R they??
  202. Are there any stiffer-than-stock springs that don't DUMP the Evo?
  203. JIC FLT-A1 Coilovers
  204. Wheel wax
  205. Fitment of 18 x 9 wheels - do the wheels stick out beyond the tire?
  206. Falken Azenis 615 vs. Toyo T1-S vs. Stock Advans
  207. 18x9.5 Evo pics
  208. Best Hotchkiss sway bar setting?
  209. Need Help - Vote - Which Coil-Overs
  210. Color Choices for OEM Enkei wheel!
  211. how much do HKS Pro coilovers cost?
  212. Tein S tech springs or coilovers?
  213. What off set etc. needed for wheels on Evo 8
  214. 18x8.5 +32mm offset?
  215. stoptech vs Works vs Agency brake lines
  216. 215s for daily driving?
  217. WORK:Emotion??Centercaps
  218. Anybody running 245/45/17 w/ stock springs?
  219. Question about wheel spacers
  220. desperately looking for the right wheels
  221. got my new wheels on
  222. Pics of Drilled Rotors ON CAR!
  223. OEM Brake Fluid for the EVO
  224. brembo brake pads
  225. how much do stock wheels cost?
  226. HKS Pro coilovers?
  227. Ohlins owners, what camber plates fit !?!?!
  228. Thanks again Z1Auto!
  229. ZEAL Function Xs
  230. rear toe ?
  231. Rear strut tower brace
  232. Advan Neova's on my car now!!!
  233. Best lowering springs???
  234. What company makes this rim?
  235. stock wheel paint code number?
  236. wheel spacers?
  237. Which tires for autocross?
  238. MR Bilstein damper questions
  239. Question about springs...
  240. Wheel Fitments ALL FINDINGS HERE PLEASE
  241. Rotor blanks
  242. Daily driven evo: ss steel brakelines and upgraded brake fluid necessary?
  243. How do you adjust ride height on Tein coilovers?
  244. need pictures of 17x8.5 with 235!
  245. FS MR suspension
  246. hotchkis rear sway bar ?
  247. Redrilling Rotors? Suggestions
  248. question about going to 18" rims
  249. will Hotchkis springs damage my shocks?
  250. just installed Hotchkis springs...problem...
