View Full Version : Evo Tires, Wheels, Brakes & Suspension - Sponsored by The Tire Rack
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. 5zigen fit???
  2. TEIN Mono Flex -- Feedback
  3. Wheel Spacers for Stock Wheel
  4. Deciding On Tires
  5. Will the 285/30 18 A6 fit on a 18X9.5?
  6. alignment problem...
  7. Lugs
  8. Scaped my rims on the curb and the car is acting funny when not going straight...
  9. Evo 8 vs Evo 9 Struts
  10. help, how to paint oem evo 9 rims gold???????????
  11. New socks and shoes!
  12. PIC request: 18x9.5+22 CE28s
  13. Will these Tenzo-R's fit?
  14. 2 piece rotors: Which would you get and why?
  15. 255/45/17 for drag racing
  16. 1g or 2g alloy wheel lug nuts same as Evo lug nuts?
  17. Lowering springs for EVO 9 with bilstein
  18. Rota Slipstreams
  19. Lug Nuts
  20. Best drag tire, not a DR. nitto, falken, bfg, toyo?
  21. Cant find cusco stuff
  22. nitto 555 or falken 615? launching, not handling
  23. good all-seasons
  24. Was somewhat stuck in the snow...
  25. Coilover/spring rate/camber ????
  26. Southerways
  27. help from guys running 275 / 17's
  28. work xt7 wheels
  29. Evo IX Wheels
  30. best 17 X 9 rim in gold?????
  31. stocker wheels...
  32. What Pads to replace Stock Brembos
  33. Still have uneven fender gap after drop??
  34. odd wheel shake issue
  35. when do you get new tires?
  36. black rotors!!!
  37. Two thumbs up: Michelin Pilot Alpine PA2
  38. weird problem
  39. gf210 springs with allignment?
  40. Will Evo 7 Suspension Fit into evo 6?
  41. swaybar question
  42. Its Like Christmas At My House Today!!!
  43. alignment specs....
  44. SSR Typr-C RS 18 x 9.5 +22
  45. Tire question.
  46. evo 8 stock rims 17 x 8 or 17 x 7?
  47. Ralliart wheels by Enkei... part number?
  48. 18x9.5 et20 will 255/40 fit?
  49. Changing the front brake pads
  50. Just Bought a set of RE30s
  51. EVO VIII springs = EVO IX springs ?
  52. Tein S-Tech spring problem
  53. Front end "clunk"
  54. Repainting your Brembos?
  55. Lug wheel closing torque !
  56. Confusion with Swift Springs and MR Shocks
  57. Anyone know of a street tire that "likes" negative camber?
  58. trade springs anyone?
  59. Front struts are banging hard
  60. Stock Advans on 17x9?
  61. Ferodo DS Performance pads any good?
  62. Help: Center caps for RPF1's
  63. Lug nuts stucked after i hard torqued them
  64. Lug nuts stucked after i hard torqued them
  65. So if I want aftermarket lug nuts I need after market rims?
  66. Missing Advan RS Valve Stem!
  67. IX MR: Swift springs or Apexi ExV N1 Coilovers?
  68. New Tires - Yokohama Advan S4
  69. 255/40-17 Azenis RT-615...good hydroplaning resistance?
  70. 245/45/17 a good idea for IX's?
  71. New Kicks - 18x9.5 +28mm Volk RE30 w/ 265/35/18 RT-615's
  72. OEM spring specs - 06MR vs others
  73. 255/35/18 with +29 offset??
  74. Will enkie value stems work on VOlks
  75. 18x9.5 Work Emotions +20 offset
  76. Picture Request "Chromed stock wheels"
  77. tanabe GF210s
  78. Tire decision help?
  79. Cold Weather=Super Sticky Tires???
  80. OK, my last summer tire thread, I promise!
  81. SSR SP1 or Wedsport SA-70
  82. Diameter of the holes in the ball joints on camber plates?
  83. Are 17s really better than 16s?
  84. Who Sells Rc5 In The Usa
  85. B & G RS2 Coilovers
  86. wheels sizing
  87. brand new MR, steering feels very loose.
  88. how low is to low?
  89. What springs are people using w/ their MR's
  90. Rear stab bar bracket snapped off...
  91. how long do stock tires last?
  92. how long do stock tires last?
  93. Coilover quesiton?
  94. What would last longer?
  95. Need advice soon! non-matching tires bad for tranny?
  96. Who has BF T/A drag radials(cheapest)??
  97. Cheapest tire contest
  98. Coilovers Question
  99. IX Coilovers...recommendations?
  100. Wheels and spring question!
  101. To keep or not to keep.
  102. Wrinkle Walls - what is available in 17s?
  103. Summer Street/Track Tires....
  104. DIY sway bar mods- my experience.
  105. how much for stock 05 struts
  106. Thinking of changing suspension.
  107. BREMBO brake calipers fading.. Question.
  108. Anyone know what wheels these are?
  109. Help: megan coilover rear noise
  110. Ultra High vs. Max vs. Extreme
  111. These wheels look pretty strong ;)
  112. brake pads!
  113. Tire Size Help!
  114. brake shims
  115. Muellerized Buddy Clubs
  116. Megan coilover question?
  117. Got Questions And Need Answers!
  118. Volk equivalent of "Hyper Black"?
  119. how to avoid burnt or discolored paint on brembo calipers at the track
  120. Will EVO 8 Top-hats fit on MR Bilstein Struts?
  121. Snow Scare - How are Advan S4's
  122. Damaged Rota Torque Wheels
  123. 17x10 and 17x9 35mm setup
  124. Centerbore spacing for 03 hub-need to know for hubcentric spacers
  125. any pics of Volk GT-U's on evo
  126. tein flex
  127. 17x8 +25 ??
  128. Snow + Advan = Disaster
  129. Differential carrier bushings really worthwhile upgrading???
  130. 18s Rubbing on Side Skirts
  131. four piston break seperator.. Where?!?
  132. Yokohama ADVAN S.4. HELP
  133. Tire Scapling...please Help
  134. Cooper tires?
  135. Got Some New Shoes!!
  136. WORKS White Paper: Damper Curves
  137. Installed some KW V3. Corner balance weights inside.
  138. Which wheels - P45R or 5Zigen?
  139. What spec are these wheels?
  140. Tow piece rotors
  141. Lost my lugnuts key
  142. Does anyone have pictures of an EVO with Advan RS 18x8.5?
  143. Stock Auto-Xer
  144. SSR MS1 Pic Request
  145. Fender lip rolling tool...
  146. Warped rotors covered under warranty?
  147. Evo to Lancer front Brakes.
  148. Brake problem please help!
  149. Volk RE30 18x9.5 +29/+34 with 265/35R18
  150. fitment enkei evo5 wheels? help
  151. brembo paint peeling!!! help
  152. FS:- Swift springs & Tein camber kit.
  153. WedsSport TC005 17x8.5 +38mm fitment?
  154. Stop Squeal
  155. BC Racing or Stance Coilovers
  156. Rota p45r 18x9.5 for Autox???
  157. Check out my new WedsSport wheels, 18X9.5 and only weight...
  158. Front drop only?
  159. Help me pick my all season tire (poll)
  160. Whats the cheapest 17 x 9 out there
  161. alignment specs please
  162. 18x9+35 & pss9's....what size tire??
  163. Rota Weights...
  164. How to seat brakes
  165. NEED HELP! odd Tire wear
  166. Powdercoating question?
  167. Any body else WAiting FOR THESE???
  168. Pad questions
  169. Auto-x tire size guru's: Offest for a 295 tire?
  170. Volk RE30 18x9 40mm offset caliper clearance
  171. Questions about gramlights 57c
  172. Aftermarket brake rotor owners---a question!!
  173. wheels for lowered evo??? PLEASE HELP
  174. anyone have
  175. OEM Springs and the Paint Dot Markings?
  176. Raybestos Pads
  177. 18x9.5 Enkei Nt03-M et27 f (10mm spacer) and et40 rear, what do you guys think?
  178. 18" x 9" +29 Advan wheel weights?????
  179. Wheel colors on a 06 GG MR
  180. need good all season tire for ice/snow
  181. Cold Weather=Squeeky Bushings?
  182. Tanabe Pro SEVEN (hard drive version)
  183. 255/40r/17 or 245/45r/17?
  184. brake light...
  185. Just had Kumho Ecsta ASX's installed
  186. 265/35R18 on Volk 18x9.5 +34 Wheels?
  187. Project Mu B-Force pads...anyone got'em?
  188. 255/45 or 255/40?
  189. rotors and brake pads
  190. 18 vs 19
  191. wheel weight?
  192. tanabe gf 210
  193. wheel paint
  194. tires for stock rims?
  195. 17 in vs 18 in
  196. Lug Stuck on broken Stud
  197. Kosei k-1 Ts for winter setup
  198. Tire/Wheel Storage
  199. Hawk Brake Pads
  200. lowered evo. wat wheel size will work? HELP!!
  201. brake pad questions...
  202. Evo wheels 17
  203. 2005 Evo VIII Advans: What fits?!
  204. Will these lugs work with the stock Enkei's??
  205. IX MR Suspension Question...
  206. strange suspension question.
  207. 265/35/18 on 18x9 +39
  208. Sharing the wealth
  209. Weird JIC FLT-A2 leak
  210. I need HELP, BIG TIME!!
  211. 5zigen FN01R-c
  212. Megan Coilover Alignment Specs
  213. Only passenger front tire rubs? Anyone experienced this?
  214. Installing used tires
  215. Need 18inch wheel/tire recommendation for street/drag use
  216. Looking For Ap Gulfer Brake Kit!!!
  217. Can anyone tell me what wheel?
  218. Apexi EXV Spring ID??
  219. Best street tires out now! What ya think?
  220. Negatives of Megan Coilover?
  221. Please help whats the best coilover kit out there
  222. new Rays GT-7 rims questions
  223. coilover installation in NY/NJ/CT ????
  224. Source for dunlop super sport race tires?
  225. Fitment question
  226. Cusco camber plate and KW variant 3 - incompatible?
  227. Vendors: Need Buddy Club P1QF, 18x10
  228. struts MR's only
  229. Touch up paint for rims? Where????
  230. Spring EVO 9
  231. Right rear clanging
  232. Resurface Slotted Rotors
  233. WTF? Stock Tire Shreads Apart On Highway !!!
  234. ideal offset for 17x9 rim?
  235. Any chance these could fit?
  236. Looking for light weight 18inch wheels for $2k or less
  237. 18x9.5 +22 fit?
  238. How to flush old break fluid?
  239. Red Lug Nuts for FQ400 Wheels?
  240. brake question
  241. Robispec KW Clubsports
  242. Broke a camber plate bolt, am I ok?
  243. -2 Front Camber?
  244. stock wheels offset?
  245. Rear suspenion uneven?
  246. Pic Request: Gold WORK Meisters on EVO
  247. The smoothest coilover???
  248. Talking tires - RE050, RE55, ADVAN Sport
  249. Calling out all lowered evos!
  250. Volk CE28N's in 17x9.5 +15mm... Will they fit??
