- help me with rims to my EVO 9!
- D2 8 POT BRAKE KIT Vs KSPORT
- just got my alignment
- Swift Springs/ stock shocks
- people running coilovers camber bolt question for ya!
- RE-01R Stock Wheel 245/40 vs. 245/45
- teaser pics of zeal coilover
- Front wheel bearing noise/bearing preload?
- New chasis braces from Cusco for CT9A
- New Tire Advice - Toyo T1-R
- I can't narrow down my vibration at all, please help!
- Got Lip? SSR SP1 and MS1's do! :)
- Where to get Advan RS ?
- AMS Brake Duct Kit - Anyone tried it?
- Dunlop Direzza Sport Z1
- At my wit's end with these #$!&*% brakes!!
- 245/40/18 Potenza RE01-R's on 18x9 +29 Advan RS's
- Quick Camber Bolt Question
- Camber plate and aligment question
- Need Brakepad advice!!
- Best Tire Size for me
- Very Bumpy Ride
- will these rims and tires fit?
- ? for those who painted stock wheels
- any one run a 275x35x18?
- Robi-Spec and Alignment Q's
- Tire suggestions for my new wheels!
- axxis ultimate brake pads??
- brembo decal for my painted brake cal
- opinions on rota wheels
- Stock endlinks with hotchkis sway bar
- Monday's Project
- Toyo RA1 Alignment Question
- will these clear the brembo's and fit my 05 EVO
- Toyo RA-1 noise?
- Rays valve stems and TE37s
- Can EVO 9's Brembo brake(rotor+caliper+pad) fit on other Mitsubishi's car ??
- Which brake set do I get?
- will 05 evo 8 suspension interchange with evo 9 suspension?
- need some help with ohlins
- will 18x10's with a 44 offset fit?
- MB Wheels Competition 17x9
- tire vendor???
- powdercoat wheels gloss blk w/ red lip!!!
- FN01RC-- stock lugnuts ok?
- new wheels- sloppy feel
- 18x9.5/+20 Works Cr KAI......TRUTHS NEEDED!!!!!
- 19x9.5 offset +22, will these fit evo9?
- best cheap rain tires
- how good is stock suspension with springs?
- how do you STORE tires?!!@!@!@!
- Swift springs
- New Tires?
- 100 lb enough ???
- racing brake pads with brembo stock brake disks! please help!
- where can I buy ROTA P45R Black w red lip 18x9.5 +30
- tire help............please?
- Just Used my Motive Power Bleeder
- WORK Emotion CR Kai (18x9.5 +20mm offset) or WORK Emotion XD-9 (18x9 +20mm offset)
- What size tires for 18x8.5?
- Whiteline Bushing Kit
- 18x8 245/35 or 40 what would u run??
- SoCal Evo 35k Needs Brakes
- Next Stage Snow Tires with Retractable Studs! Delivered by Q Tires
- how to remove the read brake disk?
- 'nother noob question (sway bar)
- Projec Level 900 or Pagid Orange???
- Q's about RT-615
- where can I buy Brembo locking pins?
- replacing tires
- Will these fit? (275 40 17 on 8.5s with stock struts)
- who has Nitto NTO1 255x40x17 in stock ?
- Stock tires
- Tein Heads
- z06 brakes on evo???????
- Anyone from TireRack? Have Q regarding OZ ultraleggera 18X9 wheel?
- Megan Track coilovers on the street
- KICS wheel spacers
- volk te37?
- Changed Pads, ear piercing noise now
- best springs?
- Work Kai 18X10..... NAUGHTY!
- Installing swifts on MR
- Black Wheels on an EB
- OEM center caps?
- Which swaybar is better.
- Replacing stock lock nuts
- got my DBA 5000 red hats installed
- Advan A046 Tire Pressure for Track
- Whiteline Control Springs
- Camber plates twisted forward
- Skunk 2 Springs?
- Advan RS Gunmetal 18x9
- Brake DIY
- best rear sway bar for evo9 MR?
- what would it be?
- Widest Wheel I Can Fit?
- products used to buff out rims
- MR springs. which ones?
- Rear Upper Control Arm Ball Joint
- Will I need to roll my fender??
- upgraded brakes question (couldnt find anything with search)
- Cyro PowerSLots rotors
- who has good deals on wheels for EVOs
- Black or gunmetal alloys on a black Evo?
- Weird click noise on brakes...
- Block heat or block noise, 2 different pad shims from Girodisc
- Rays G-games fitment
- Volk GT-F
- CE28n Volks
- Swift or Hotchkis springs?
- if you know your ****, help me out
- Spacer / Rims Evolutin 18's
- modified brake ducts
- Will 9x17 ET35 fit EVO IX?
- Installed my Swift springs...
- want to run 18"'s
- Carbonetics brake pads
- When to change tires after a long drive?
- New Girodisc drilled/slotted rotors
- Best Rotors???
- Tire size question
- Free Tein Flex's or buy Swift's / Bilsteins?
- My replacement brembos now peeling!!!
- New Konig Wheel!! Need advice on fitment
- 235/55 on stock rim?
- Neal away 7th-12th
- Tanabe Rear Sway Bar
- What Type of Gold are the Advan RG IIs?
- Painted wheels... whatcha think?
- will SSR's fit on the evo?
- Advan Vs Volk My choice
- Stasis Alcon Brake Kit Question
- Tein Flex Help
- Sa70tt
- DMS 50 VS KW Variant 3
- Toyo RA-1
- kumho mx...loud?
- How to tighten top shiock nut on Buddy Club
- Alignment specs (DD & Drag Racing)
- Brake response with Snow Tires.
- exceeding stock evo susp.
- value of stock wheels?
- Whats the BEST TIRE for the Money?????
- what lugs do u recommend?
- springs for EVOIX MR?
- 2 Piece Rotors
- Problems with my new 2-pc Rotors and new pads :-/
- Many thanks to Neal and Tire Rack!!!
- Wheel help! FNo1-RC or Emotion CR kai??
- need help looking for the best pricing on some michelin tires
- Stock BBS = Aftermarket Lugs?!
- Volk GTN - 17x8" 5x114.3 +41 Will they fit
- 18x8.5 +22 Volk TE37s, will they fit?
- F/R Spring rate combo
- replacing camber plates
- stock wheel locks or volk lug nuts
- weird noise
- EVO 9 BBS SE wheel fitment on EVO 8
- Stock Alignment Off - Suggestions
- Pot hole damage questions......
- if know, please answer
- does going bigger means lots of recalibration?
- Volk Racing Wheels Time Attack
- RobiSpec to Omaha!
- owered evo w/ NT03 17x9.5+ 38 offset
- Steering wheel slack @ 93k miles
- VOLK CE28N 18x9.5
- Suspension? Which type?
- another "is this ok?" thread... (tire size question)
- car shakes, steering wheel gone crazy!!!
- Ralliart Springs
- wheel hum
- Advan RS 18x9 Tire size?
- Best first mod ?
- ABS problem..help
- 18x9.5 Rota Torque...what does it take?
- 18"... tire size?
- Brake install question!!!
- Spacers on 18x8.5 +33 5 zigen gn+
- Yokohama Advan A046 trend life
- suspension noise, possible growing problem?
- photoshop request
- WTC:18" wheels on tb
- what tires???
- Fake Time Attacks???
- Black rims on white?
- How much should it cost to install swift springs on an MR?
- Having trouble removing OEM brake lines
- rota deals?
- Light/Strong Rotor/Wheel Upgrade?
- help need new pads
- Discovered: Alignment Bolts are set in Opposite Directions??
- what tires would u recommend for my needs
- Falken RT-615 vs Kumho MX Results!
- Anyone have Michelin Pilot Sport PS2 size 265/40/17?
- might come off as a noob
- need help with rim fitment....
- 265/35/18 on +35??
- HKS Hypermax II!
- Wheel Stud
- Can't decide...
- ADR M-Sport 18x8.5 question
- Tire Rack Order
- WW IXmr: stock BBS to Advan RG II silver...
- Springs vs. Coilovers
- WTB & Discuss Ground-Control Camber/Caster Plates
- Anyone know of Brembo caliper extenders for oversized rotors?
- Volk SE-37K
- Enkei RPF1's or NT03's (17 inch wheels)
- Golden Goodness....ZEALS!!!
- Falken Azenis RT-615 / Drag Racers Please Help
- Lightest 17s available
- got slotted rotors...does this happen to you?
- Quick alignment question.
- 245/40/18 or 255/35/18 ... which one?
- DIY removing wheel lock
- Drag Radials and Daily Drivers.
- wheel offset and size help.
- Swift spring problem???
- Lug Nuts for EVO
- BFG 245 45 17 drag radial
- Spring Install
- What wheel size do you prefer
- LE28N's 18X9.5 +28 on 265/40/18 BGF Drag radial
- please help, Can you over tighten a bolt when installing a coilover kit
- trade stock enkei for stock bbs
- Buying rotors for the Evo (cheap ones)
- Track Rotor advice (replacing stocks)
- problem with wheels
- fn01r-c with s-techs?
- what else is left?
- which spring is better for the mr performance wise
- Suggestions for new Summer Tires
- camber
- rubbing with these???
- replacing yokes ao46
- Falken Azenis on stock rims
- 5Zigen Fn01r-C Decision
- Just put on my Volk CE 28's Gold with Polished Lip
- Cold weather = struts make noise?
- Carbotech vs Ferodo
- How are these Alignment specs after coilover install
- Enkei Hyperblack
- looking for Brembo drilled rotor installed pics
- Diff tire size for stock enkei wheels?
- Looking for Advan RGII 18x10 in gold
- Advan RS on blue evo 8
- black wheels....
- TEIN are C R A P
