- What happens if i drop my car?
- Brake Light on and off while driving when really cold.. Any ideas??
- Gravity Gullflame Pearl White on Wicked White IX
- Alignment spec ?'s
- ce28 weight differ from each other
- Lots of grease on rims-- help!
- mechanical grip
- 265/30/19 on 8.5's? should fit..
- E brake...need help!
- Stock advans vs 255/40 azenis
- EVO9 AXLE: how much abuse(hp)can it take
- street brakes question
- How Long Did It Take Your Stock Struts To Blow Out After Installing Springs?
- Alignment help
- stock wheel weight
- Why people choose 17x9 over 17x 8 and they are both putting 255's tires????
- Toyo RA 1 heat cycling?
- StopTech BBK 332mm
- Will This Fit? 18x10 +22
- recommend me aggressive deep wheels for my silver ix
- Powdercoating BBS wheels = Good Idea?
- Quick Brake Bleed Question
- Best Balanced Size
- tenzo dc-6 18 x 8?
- Please Help! Very annoying!
- Can the Evo suspension take well to bumpy roads?
- Shave Rotors?
- Agressive Suspension
- Stock ADVANS, Winter, and Me....
- Track and race season is coming - what are you running?
- quick help: changing brake lines
- Driveshaft Hub seperation problem Evo 8
- Dealership Scratched My Rims
- Tell everyone what u think about your aftermarket tires and compare
- Caliper torque specs?
- volk
- Tire change question.
- any pics of?
- Evolution 1 - 3 Stock Spring rates.
- wheel spacer
- Should i purchase new rear rotors?
- SS Brake Lines
- Will gram lights 57 optimise match apex silver
- *** Rubbing Concerns (235-40-18) ***
- Recommended wheel offset on Endless 6-pot calipers?
- CCW Wheels?
- Brake pin wont come out.... anyone had this problem?
- NEO CHROME aka Aurora plated wheels? anyone run them?
- Found some information on Tenzo wheels
- 18 x 9.5 35 mm 5zigen fn1orcs 265 or 255
- Stock brakes not so durable
- Need E brake adjusted !
- is $2000 for a set of volk rims + falkens
- Enkei PRF1 17x9 offset?
- Expereince with Girodisk
- Benifitcal suspension bushings
- squeal when I turn wheel all the way and brake
- Azenis = sh*t?
- pad life...
- swift sway bars
- Do I need to roll my fenders with this setup?
- recently lowered car drives fine, still need alighment?
- tein s-tech ?
- 18x9.5 +25 Bbs Rg-r??
- Hubcentric Rings Who Uses Them??
- Brake system question?
- Evo Thread Pitch For Lugnuts???
- rotor
- Toyo RA1 vs Advan A048
- Megan Coilover Durability?
- good coilovers for the street/ track bot circle and strip
- brakes squeekin AND.....
- 16" Rims and tires for winter?
- H&R Coilovers?
- Alignment Issues
- KWV3 coilover assembly question(s)...
- Won a set of Bridgestone's what size?
- High temp touch-up paint for Brembo's?
- fender rolling question
- Evo IX Stock Alignment Specs?????
- help ?
- Why are EVO brakes to blasted expensive?
- General Altimax Arctic?
- What wheels are these?
- 18"x9.5" @ +27 / +36 offset Prodrive GC-05F
- 17" work emotion chrome
- wheel locks?
- Pics of your wheels on you evo
- Whiteline Roll Center Correction kit--need some help
- spring install.. will I lose stock feel??
- coilovers
- 18x9 +29 tire size?
- Help with some questions...
- Powder coating wheels
- wheels offset
- Who has Tein SS OR BC Racing coilovers installed? Which is more like stock?
- MR bilsteins w/swift. sway needed?
- Advan TCII , Spokes ?
- staggered offset question
- how is it to get service for Ohlin's coilover?
- 17s vs 18s
- Best snow tires?
- Damaged stock wheel with lugnuts--fixable?
- Is there a way to measure tire contact patch or grip?
- Anyone have opinion/used VOXA rotors?
- Wide Body Offset
- Whats the best tire for..?
- First impressions: Goodyear F1 AS tires
- Nokian Hakkapeliitta FTW
- struts vs. coilovers
- DC-5 or DC-6
- Big as possible
- WTK: Evo IX Brake and Wheel Hub Specs
- Having some Braking Issues
- Any difference in spring rates between Evo VIII & Evo IX?
- For those of you running snow tires in the snow
- What Size Tire???
- handling/tread life for summer tires
- Is 265 too wide for street driving?
- Evo VIII & Evo IX OEM shocks and struts the same??
- installed new pads and rotors...draggin brakes/buzzing sounds
- 18"x9" vs. 18"x9.5"
- How do they last "Hawk HPS"
- Lookin to do some Brake upgrades...
- Would a 18x9 +20 fit an Evo 8 no problem?
- Rota P45R's: Gloss Black w/ Red Lip vs. Royal Black w/ Polished Lip??? **POLL**
- Curb Rash + Some
- Quick Question
- Advice on bushing press
- Sport Max wheels
- Aftermarket Valve Stems
- Camber kits: what do you use?
- What else do I need besides lowering springs?
- good non noisy tires ??? which one to choose from ?
- Whiteline Max-C Camber Plates just released!!!
- Interesting Tire/Wheel Factoid
- f/s tristsre/ 06 se bbs wheels
- Best sway bars / biggest sway reduction?
- Ride height adjustment and its effects on the suspension setting
- Volk Sf-Winning
- volk gtps off of 3000 gt
- wheel spacers
- stiff brake pedal?
- calculating offset question..
- Pic Request: Evo w/ SSR Type-C RS Wheels
- Pillow ball mounts for stock shocks
- Yokohama W4S
- Got an alignment
- found some wheels... need help?
- MR Wheels
- wheel shaking strange noise question
- shock education
- Max Tire Size
- Winter Tires: quick answers, quick questions...
- MR Bilstein and Swift Spring Combo or Megan Coils ????
- new shocks
- OEM wheel fit 245-45-17 tires?
- blizzaks
- i'm so happy, got to share some news
- Rota P45R +15 Front Offset
- Ksport pillowball top mount installation?
- outer tie rod replacement
- What a piece of cake to install pad shims...
- More than just bilstiens....
- Enkei RS5 wheels and tires help
- Blizzaks
- Sport Compact Car Brake Upgrade Review Evo VS STi
- ARP wheel studs installed
- Smoother/better ride
- P45R in Red Metallic with Silver Lip
- ssr gt2 white wheels with tires
- New brake pads means new roaters?
- rota p45r's
- I'm looking
- My Jic A2 experience....
- steel rims
- Which Michelins?
- Wheel fitment question!
- Nokian vs Nokian (for winter)
- Kosei K1 17x8 - what tires
- Question about offset fitment. .
- help wheel noise
- Endless Braking System Installed - Photos and Weight Comparison
- 16s..what rim
- Suspension Settings For Drag Racing
- Enkei RPF1 questions
- Need some wheel info please
- Looking for opinions: DMS 40mm
- wheel spacers...
- Look what happened today =(
- powdercoating mr wheels part 2
- Hawk HPS Brake pads are squeaking.
- ERRRRRRRRRR my wheel jsut about fell off!!!!
- Snow tire traction
- Wheel lugnuts
- Need info on Bilstein HD and springs
- Did I receive real Buddy Club QF's ?
- stock dampers+swift or mr dampers+gf210
- Broken Rim!! HELP
- optimum tire pressure for 245/45r17 falkens
- Ideal tire pressure for some 245/40/18's?
- 255/40/18
- Volk te37 bronze color code
- Hotchkis and Bilsteins
- Adjusting Rear Camber
- Good Year Eagle F1 All season
- requesting pic
- Suspension NEWB
- Weather got cold outside, and brakes started squeaking.
- Which Tires?
- Stiffest springs for stock dampers?
- Let's talk real about Rotas
- WTB: Motegi Traklite 15s for Drag Evo ASAP!!!
- Before I sell my springs.....
- Best drag tire for 18x9
- Widest rear rotor thickness possible
- New pads = no stopping power
- Broken lug please help
- Need help with Brembos!
- Suspension Upgrade Options
- Tires that don't burn out after 10,000 miles
- Brake kit?
- Stock Pad Replacement Cost?
- Requested Pics
- Megan or KSPORT Coilovers
- what wheels wuuld look the best on a white evo?
- need some clarification
- Noises after installing Megan Coilovers?
- Brembo 6 pot mono bloc
- winter tires
- will whiteline bumpsteer kit cause rear toe adjustments to run wide?
- looking for volk ce28n's
- Anyone running 18x9.5J +30 offset?
- SWIFT Springs or BC/Megan Coilovers
- whats a good choice for wheels?
- People with advan rgii's
- Hankook Icebear
- 18x8.5 +35 offset axis Hiro perfect evo 9?
- PIC / PURE TT Coilovers
- Brake pad sqeek...
- Jic flt-a2 dampening settings
- Enkei NT03 - hubcentric rings?
- Need help looking for tires
- Bilsteins + Tanabe springs= ??????
- New lug nuts from Rays
- stock brakes and bed in procedure information
- Volk TE-37 Time Attack 18x8.5 +40 compatible with Brembos?
- Has anyone tried Nitto 555 RII Tires?
- No Winter Tires = Crash
- Anyone do their own alignments??
