- 18 x 9 Rota G-Force Gunmetallic
- new tire decisions
- Is negative toe, toe in? or out?
- Thinking about running yoko ao48 on the street?
- My new HKS Hipermax III Sport Coilovers
- need rims
- coilovers for street mostly
- Rota P45F?
- te37
- Rolling vs shaving/grinding using dremel tool for rear fender??
- need help with tire size
- Need help finding the weight specs on Nitto NT555R
- What size tires to get
- 17" konig monsoons, will they fit?
- Where to get good deals on Potenza RE-01R???
- After Alignment car pulling to the left..
- Where to get new tires mounted
- Staggering Tire size
- noob question about higher rear spring rate vs. rear sway bar and advice on rates
- Installed brake pads
- RE-01R 255/35/18 on 18x9 +29 Advan RS lowered w/ Swift Sport Mach Springs?
- Trying to go lower : 245/40 or 255/35?
- For those looking to buy new tires...
- motul
- Problem! And mitsu is being dumb.
- Grassroots guru need your help and tips on DIY alignment
- ATTN: All newer Zeal coilover owners, I have questions
- Question about Lightweight 19s...
- 255/40 on 18x9 +35 fitment?
- Tein Price feeler
- Question on Enkei RPF1 17x9.5 +38
- Some Pics of my TEIN Camber Plates Install
- How much did you pay for MR Bilsteins?
- Hub Centric Rings, Aluminium vs. Polycarbonate
- Wheel locks...Advan RGII
- Lugnut Question
- Advanced suspension questions, all Pros please chime in
- Help With Rotors!
- 245/40/17 and GtWorks springs
- Alignment
- Racing Gear Coilovers- help please!
- so im new to suspension
- brake squeek???
- First time installing coilovers
- New Wheels: Weds
- WHITELINE ROLL CENTER kit on stock evo??
- Megan Coilovers
- fitment i know nothing
- Lug Nut spec on evo 9
- Who else daily drives with coilovers?
- Rotating Advans side to side
- OEM front pads, $180 on ebay
- Will these fit my car
- Evo creeking
- Cheapest place for Stock or ferodo ds2500 pads?
- Will they rub
- Espelir ASD springs
- Volk GTF's
- steering wheel shaking problem - with a slight twist
- Swift springs
- VIII vs IX steering
- Greetings From SSR USA!
- Help deciding on what color
- KSports?
- the basics for a nice street setup
- fitment ?????
- Does this wheel exist: 18x9.5, more than +35 offset, no front spacer required, <20 lb
- *** Choose 2go w/ Coilovers...but what ya think.....***
- BUDDY CLUB new SF Challenge Time Attack Style ** What you guys think ? **
- Wheel Fitment Question
- Anyone have gold wheels? (pic request)
- Hub ring For Work Meister S1
- Swift sway bars and springs installed.
- Yokohama AD07 Neova vs. stock A046 - noise?
- Brembo brakes
- Coilover alignment questions...
- Springs or Coilovers
- Sounds Like Bs!!!!
- track suspension set-up
- My brakes, uh oh...
- Falken 912, Where to buy
- Brembo Decal Size
- camber trouble
- 18x8.5 ce28n's what size tire?
- Hawk Pads
- Need some help/opinions please
- Street/Drag Tires
- New tires, oh crap.....
- What Hawk rear race pad compound should I match with the front?
- PIC Performance Select R1
- Tein replacement part question
- tires on 18X8.5s
- BFG R1 285 30 18s on 18x9.5" rims?
- Biggest I Can Go On Stock BBS
- help me choose tein or stance
- Need help choosing street tires
- Lug Nuts. Open end vs Closed end.
- 18X8.5 +33 with 245/40R18? Fit OK?
- Coilover Strut blew out (Megan)
- getting new rotors
- 255 or 265 tires with 18x9 30 offset?
- looking for confirmation on a lug nut question
- R-1 Racing Wheels - would they fit Evolutions?
- RPF1 17 x 9.5 what offset for EVO
- right rear sitting too low after wheel install
- Rear rotors are being a pain
- No Brembo 2-Piece Rotors in Stock Sizes
- Swift spring and wheel help!
- Sumitomo HTRZ III tires
- Brembo Stickers
- To All Buddy Club P1 Racing Qf Rims Owners!!!
- SSR wheels
- Go with RE-01R or RE050A?
- upper strut mount
- Brake pad replacement
- Potenza RE-11 vs. Direzza Sport Z1 Star Spec
- Hawk Race and AutoX Pads are Much less $$$
- Stock Suspension,clunking while turning left. Help please.
- Falken rt-615 Treadlife?
- upper strut mount
- Wheel Help
- grinding noise from front brakes
- What lugnuts for Kosei wheels, rays dont fit.
- Looking for the brake gurus.
- any TB Evos with the Gramlight 57 Optimise?
- Looking for a creative mind....
- Replacement tires from RA1's
- Rear Spherical Bearing top mounts
- Rolled Fenders.........
- Clutch / Brake situation help please
- r888
- Ok with all the talk about the Z1's vs the RE-01R's.... *I hope this helps some*
- Tire help, 18x9 +25 rims
- 255 40 18 with falken 615's gonna fit w/ swift springs?
- nitto, falken, bfg, Potenza?
- T1R or RT615.. dd?
- Do I need to replace rear pads with the front?
- E-Brake Issue
- Dunlop Direzza Z1 vs. Advans A-046 (stock tire)
- The better tire
- Need Recommendations for an Aggressive Wheel Set Up (Vendors are definitely welcome)
- Steering Problem - Could use some Help!
- Sticky Tires
- Quick Offset Question
- calipers
- Performance Difference between 18x9 vs. 18x9.5/10 wheels?
- THinking of getting STANCE coilovers
- Swift Spring replacement, how long and torques?
- need pads and rotors but....
- Swift SPEC-R Sport Springs
- Dunlop Direzza Sport Z1 in 255/40/17 on stock rims
- Best Performance Tire vs. Price
- HKS suspension is being installed
- Evo BBS MR on Acura TL
- 17x9, stock suspension?
- 245/40/17 Problems??
- Coilover settings for the Quarter Mile
- 275/40/17 on stock wheel?
- ROBISPEC Install
- Autocross pictures ????
- team dynamics wheels 17x8
- autocross 255/40/17 on stock wheels?
- Factory Evo MR inverted Bilsteins.
- Brake pad
- Suspension newbie has some ?s
- Keeep stock tire size or upgrade to 245/40/17's?
- 18's: 255/35 or 245/40?
- SPP slotted rotors
- The Basics of Advanced Suspension
- Looking for pic - IX with bronze CE28Ns
- 17x9 +35mm FN01R-C - will it fit with stock studs?
- Need help
- Why doesn't Enkei offer RPF1 in black?
- Just installed my Swifts
- what are evo8 wheels selling for?
- Are coilovers naturally louder than stock suspension?
- New CenterCaps for stock enkies
- Ultimate Brake Cooling!!!!
- Tires On The Left Side Wears More?
- Where else can I buy'em?
- Dunlop Direzza Sport Z1's vs bridgestone REO1R
- can u say robi spec race kw's
- Does 17x9" 38mm offset wheels fit an EVO 6????
- What rim is this?
- evo viii wheels
- brembo clearance
- Rear upper control arm bushings?
- What ones.....
- Brake Pads Upside Down?
- 255/40/18 on 1.6 inch drop all over...
- Pic request
- hotchkis springs and which shocks
- wheel weight fell off
- Lug nuts
- Steering problem - drifting to the right
- Cut Rotors?
- Process to Powder Coat Wheels?
- Brake pads?
- Need Help With Tire
- how much to install ROLL CENTER KIT.
- Rotor replacement question
- problems with megan coilover
- Aggressive Street Pads
- Looking for suggestions on tire sizes
- Good choice for disc/pad upgrades?
- Big A$$ Brembos -- Upgrading my Evo IX RS with the Brembo GT 4-wheel kit
- Tein-S tech ACD version vs Non
- Raze R85
- Megan Coilover rattle - yes I searched!
- 18x9 +30 Konigs + Swift Spec-R on IX GSR
- Interested in buying Enkei RFP1 but have a question..
- 255/40/18 with 2 inch drop?
- GTR Face?
- Where can I find Wheel Spacers?
- Alignment shop tells me stock suspension is -3.0
- Performance Friction rear pads
- New rubbers!
- Question about Auto-X'ing w/ Hoosier R6's
- New for 2008!!! Rays 57 Motorsports Wheels - Light weight, Rigid and Balance!
- Tire selection question
- Looking for reviews of STANCE coil overs
- Buddy Club P1 Racing QF 18x9 35 offset require spacers?
- Refinished my spring wheels.
- VENDORS: Need WedsSport SA-70TT
- Rubbing at Full-Lock
- Whie EVO 8 Rims
- QUESTION ABOUT RIMS - 18x8.5
- OFFICIAL: Kansai Service Mitsubishi Evo CT9A Front Tower Bar
- Project Mu NS or Hawk HPS
- cheapest vendor for swift springs
- enkei tamacs v volk gramlights
- Thinking about selling TEIN Coilovers for Springs & Go Fast Parts...
- coilover height measurment
- STU class Tire
- Issue with springs...
- OFFICIAL: Tanabe Sustec Under Brace Front Center Rear 03-07 Mitsubishi Evo 8 and 9
- In your opinion: Best bang for buck wheel... style, weight, strength...
- ability to fit 20s on vehicle?
- wheel nut and bolts
- Help!!! Brakes dragging after caliper change
- MR Lowering Springs (Expert Opinions Please)
- help brakes grinding!
- clunking noise and it's not a blown strut.
- Congrats To Me On My First Messed Up Rim
- Direzza z1 owners
- Coilover Newb with a question
- Volk RE30 Titanium Gunmetal
- Potenza RE750 tires
- Effects of coilovers on drivetrain?
- Anyone running Volk RE30s in 17X9 +35 offset?
