- Stock Advan replacement = $315 each??
- OnLineTires.com Help
- Wheel alignment OFF?!
- Help fitting wheels... 35 mm offset
- Hub Centric Rings!?
- The future of rims and tires. According to Michelin.
- Dunlop Direzza Sport Z1 (recomended tire pressure)
- EBC brakes red
- Konig Afterburner
- Which Rotors do you pick?
- Evo 8 Stock Enkeis on Evo 9?
- rotorpros??
- Suspension/Brake/Tire - Track and Street Review
- Rear brakes sounds like there is something rubbing...
- Direzza Sport Z1 Star Spec tire pressure
- Buschur Time Attack Evo
- For those with slotted rotors...
- pulsing of brakes...
- Front Ball Joint Replacement - Warning
- HRE 18x9.5 & KW's on my IX
- 17x9 Advan RS +29 Offset + Swift/Bilstein Combo = rubbing?
- brembos to brownbos
- Evo VI pads
- GT Spec Trunk Cage....
- Front sitting high???
- KW varient 3 config
- pics of prodrives?
- Brake Problems, Stock rotors, Hawks HPS, 44k
- Lowering springs pros cons???
- Should Gruppe-S Bring In the Enkei RC-T4? What Colors?
- Vibration help
- Vendors: Anyone have 15mm wheel spacers?
- Swift Stabilizer Bars Reviewed
- Wheel Spacer / Extended Wheel Studs question
- Lets to seats.
- Custom Gunmetal w/ Rainbow Sprakles RPF01's
- Thread size and pitch for MR Bilstein struts?
- Girodisc's FTW
- GTC's on an evo 7
- cusco power braces
- NT03 Question
- Review Update on Hawk HPS Pads
- OE Fiber Shims
- Front control arm balljoint removal
- 24K Gold Volk Racing RE30 - Racing Meets Bling
- Enkei Decal Size
- Change in wheel fitment from aftermarket rotors?
- Best suspension set up for a 10/9 sec drag car?
- front brake making odd sound help
- will 5zigen FN01R 17x8 35mm fit?
- Rotor Questions
- MEGAN springs
- Finished Product **CALIPER REPAINT**
- Any shops on LI do corner weighting?
- Wheel fitment
- Full Floating 2 Piece Rotors
- Dunlop Direzza Sport Z1 size dilemma
- Falken Azenis RT-615 255/40/18 on 18x8.5
- Camber Plate squeak
- 17X9 +35 with 255/40 and Swifts?
- STI OEM Rotors?
- Question on fitting NT-01's on stock rims
- Brake Gurus, what do you think?
- Any of you guys run 235/40/17 Nitto NT01 for track?
- Gauging interest
- Dunlop Direzza Z1 Star Spec review (post-autox)n
- Caliper Question
- Best tire size for dd/auto-x car (Dunlop Direzza Z1 sports)
- need help on tein mono flex
- tire fitment: ce28n-TA with g-force R1
- Tires for tarmac with bit dust/gravel surface?
- diamond black bbs gone?
- which tire? opinions and suggestions welcome
- Eagle F1 all season???
- Is This A Good Deal?
- used coilovers
- Need Brake pads
- Stoptech....or Centric Rotors...new
- EVO 5-9 and X brake differences
- What are the best brake pads?
- CE28N Faces difference? (offset question)
- Kumho Ecsta MX......Are these Great tires?
- fubar caliper w/ stripped bleeder
- Anyone try the RE760's?
- Infamous shake under braking
- How durable are the stock BBS wheels?
- Hankook RS2 - any other options?
- So I'm torn between getting...
- anybody running stretched tires??
- Post your Evo X rim pics
- 18x9.5 Nt03+m???
- powder coating
- 235/45/R17 Front, 255/40/R17 rear is possible on a Evo 6 RS2
- Why is the huge price difference RE-01R?
- street tire recommendations
- where to get kics 10mm spacers?
- getting frustrated
- Upgrading EVO IX Rotors...need help!
- drilled or slotted rotors?
- Ferodo DS3000?
- Bilstein HD + GTWorx EVO Springs + Whiteline 24mm Rear Swaybar Install
- anyone know?
- Swift Sport springs vs. Sport SPEC-R
- Busted my front brake line.
- To rake or not to rake... racers please help
- steering wheel position senor question
- When do calipers need a rebuild?
- The ultimate coilover noise thread...
- Brake noises
- Anyone have a pic of 17" rg2's??
- Best spacers?
- Help - Need reputable vendor for 5mm-8mm wheel spacers.
- Rota Torque Hubcentric Rings (size)
- Current Tire Promotions
- axis ultimate pads???
- Need help with installed coilovers. Possible problem
- Help Diagnose My front tires wear
- adjust dampening on tein mono flex coilovers?
- tanabe springs
- squeeking rear suspension
- How necessary is an alignment after spring installation???
- ball joint failed at 35K
- does this mean i need a rebuild?
- Just noticed something after alignment...
- Look what show'd up today... Work XC8
- touge suspension question
- toyo R1R
- Moton or JRZ?
- FN01RC Question
- Ohlins DFV owners please help
- Looking for Volk TE37 Vendor???
- 225/45/17, ok for an Evo?
- Cusco Coilover kits.. Which kit is the BEST for Street Performance....
- KW Variant 3 Rubbing Noise?
- Tire pressure for 235/40-18
- Best set of coilovers?
- tire pressure
- enkei rpf1 Question
- Advice on new set of tires
- HELP! Does anyone has a diagram of rear coilover setup?
- steering wheel vibration possibly zeal coils or spacers
- Sway Bar Mount Bolts
- need 255/35/18 tire advice please
- shooting for at least a 1.6 60ft
- Tire Question
- Scar on front left rotor...
- which brand
- torque specs for hub to spindle?
- How do the pros determine spring rates?
- Vendors: Can anyone get Weds Sa-70 in 18x10 +32?
- Best 265/35R18 tires for the streets
- 14" Big brake kit fitment?!!
- How much help will springs be?
- Brakes Dragging?
- Symptoms of failing suspension?
- need alittle help here
- my suspension!!!
- Tein 2 Alignment?
- R1 Concepts OEM Style Rotors ?
- Tire size on stock rims
- New wheels...tell me what you think
- cheap brake pads...ugh
- Help with Rota G-Force 18x9...
- sway bars pros cons on certan brands? recomendations?
- KW Variant 3's (V3)
- Advan RS 17x9
- What are the stock camber and toe settings on a 06 Evo IX?
- ? tein drop with 17x9
- FALKEN FK-452 Review?!
- front srut upper mount bearing? please help
- Just Curious is an axle problem part of the Warranty?
- Camber for Summer vs. Winter!?
- Biggest Slicks from Tire Rack for Evo 8 ?
- need help with lugnut torque specs!!!!
- Good deals on TIRES?
- Bilstein HD and Swift GSR Product Review, Comparisons, Impressions, and Comments
- which springs?
- steel wool on caked up brake dust?
- Black EVO GSR wheels on EVO IX
- d2 or tein?
- Rota D2 17x8.5 fitment
- suspension decision
- quick rim question...
- Evo IX MR coilovers
- If you have stop tech rotors read this!
- Anyone have these tires?
- center caps
- Gram Lights 57F - width and tire options
- Look what show'd up today... Cusco Zero2e
- are evo8 and 9 axles the same?
- RE050A Pole Positions
- Help with Advan RS
- how do you tell brake judder due to warpped rotors instead of uneven pad deposits
- Brembo Seals Instalation Guide
- Direzza Sport Z1's 245/40/17 vs 255/40/17
- JIC FLT-A2 Lower Lock Ring
- 17x9 and 17x8 Desmond Regamasters Don't Fit
- Serious Rim/tire problem
- Front and Rear Piston MM??
- Buddy Club RSD's something wrong?
- I got a Black on Black Evo Ix. All i need is the RIms...
- Price on Advan Racing RS wheels?
- Question about wheel stud
- Is the wheel stud same as the lancer?
- changing lines and fluid
- Anyone have any info on 45mm Jic's?
- How bad it is to put spacers on stock wheels?
- Z1 or Z1 Star Spec
- Next stage up in handling?
- New Dunlop Direzza Z1 Star Specs - Best Street tire?
- Tires & Wheels
- Which Wheel Size?
- Performance Friction Z pads or Ferodo 2500!?
- Some suspension questions. Share your input!
- Quick help!
- Pillow Ball Mounts, Bolts, egg-shaped, stripped bolts? Not sure whats up here..
- Getting new wheels
- Front Brembo Calipers on Rear Disc?
- about mr bilstein shocks
- megan springs???
- Rear Sway Bar mounts
- BFG Drag Radial on Street
- Question about hawk ceramics
- Will these fit?
- springrates VS swaybars
- Having Problems... Need Help!
- Running 255-40-18 with springs?
- Driving this Sunday in the cold, summer or all season?
- Tire questions for P45R and Stock wheels.
- Anyone know the Recommended Torque specs for the suspention bolts???
- cant decide suspension
- 235/40 vs 245/45
- -3 front camber - handling feel effects
- 245/45/17 on stock rim.......rubbing?
- who can rebuild my JIC-FLT-A2 coilovers?
- Tire size help please...
- anyone have gt-f volk evo pic
- What wheel is this??
- Outlander brakes
- Will They Rub
- Apexi N1 Coilover Compression Adjuster
- Will It Rub???
- Speedo Question (New Tires)
- Damn it guess Im gonna have to roll the fenders!
- NEED HELP! Coilovers!?
- Who's front camber plates are different from side to side?
- Best Coilovers?
- Your favorite tires?
- Whiteline Suspension Q's
- car pulls left and right problem?
