- New Tenzo wheels in Matte White
- Big brake kits for Evo III
- Best lowering springs for the IX?
- TRE stole my understeer ... (and I don't want it back!)
- Tein flex
- quick help stock rim tire fitment
- Off Road Evo
- suggestions for sway bars and end links combo?
- Rota wheels - what is wrong with them?
- Wheels on the STIKiller Evo?
- Swift Springs Does it Again!
- I waas wondering... 265's??
- Work Emotion Wheel's
- Newb question...
- Questions about Dunlop Z1's
- BfGoodrich T/A Drag Radial
- Espelir ASD- Cut Bump Stop?
- front brake calipers on the rear ??????
- Rear Rotor help!
- Valve stem location on Performance tires
- New Rotor Suggestions
- The bent rim issue.
- renting weigh scales
- Best shocks for autocross?
- Problem with Robispec endlinks
- do my rotor need resurfacing???
- Opinions on Yoko AVS ES100 (or alternative)
- Tire Suggestions
- tire issue
- Anyone had problems with KW Variant 3s?
- Whiteline Roll Center - Ball Joint Press Question?
- Anybody ever heard of BrakePlanet rotors?
- What is the difference between Robi spec Kw and normal kw's?
- How to adjust KW Coilovers
- Installing Whiteline Roll Center Kit...
- what causes wear on rear pads more than front pads?
- Riken Raptors
- Swift Sport or Swift Spec R
- Putting STi wheels on Evo 8 ? Possible or no ?
- Something tells me I need a brake upgrade. Take a look.
- Suspension Setup
- Installed KW V3 coilovers! My impression...
- front drives side tire balding on the outside??
- What do u think of these rims
- 19x8F +30mm 19x8.5R +33mm fitment questions
- Question about Tein S-Tech...
- Which Brake Duct Cooling Kit for my EVO 8 ???
- Advice please on this spring/suspension setup
- Konig Beyond
- best track pad for a newb
- For those into putting 15" wheels......
- fender liner rubbing issues
- does evo have stock adjustiable cambers
- Away from June 10th - June 17th
- 18x9 with 30mm offset lowered on swift springs
- How to fit 265 width slicks on evo9?
- What's a Strong & Light Wheel for Track, and Not Expensive??
- time for new tires???
- Problems with HKS hypermax
- un-even tread wear anyone?
- cold weather climate people please help.
- Spring rate only 8kg?
- Tein Super Street vs. Bilstein b6 in Poland
- Brakes (Creaking Noise)
- Perrin Rear Sway Bar Clearance
- WORK vs. Enkei
- rota 17x9
- Noob Pad and Rotor Life Question
- JIC Magic RS
- Evo X Wheels on IX
- my great wheel debate
- 18x9.5+20 work CR Kai
- What tire size on stock rims?
- What style lugs do I need?
- Help me find this Wheel!!
- Brake Fluid
- *AMS PRODUCT RELEASE* Rally Front Brake kit
- How to balance wheels with inside tire wear?
- Coilovers
- Black Magic Titanium Wheel Cleaner
- Adapters for wheels to run on EVO 9
- Is this the right set-up for running 15's?
- Attn: Suspension Gurus
- What's The Biggest Wheels to Fit 2003 EVO ??
- Long trip pressure
- Strange noise while stopping from going in reverse...
- Quick Lug Size Question
- Who makes the best rotors.
- what are your experiences with the stock BBS wheels on the track?
- Castrol SRF brake fluid questions
- no splash gaurds on street?
- Brake failure/ first track day with the Evo
- Black Rims with Red Lip
- Advan RS Center Caps...
- your favorite tires
- help with rotors/ pads confused :(
- Anyone know the tire size on these 18x9.5 +20 works????
- 5zigen FN01R-C x2 114.3 17x8 +25
- Brake fluid
- Rear wheel stud replacement
- Black Lug Nuts for Stock Wheels
- New Tires To Wrap My New Shoes
- stock tires
- breaking in new tires?
- Suspension setup Question
- ride heights for good weight distribution
- rims
- Advan rg IIs
- MR Bilstein Suspension VS. IX GSR Suspension
- suspension squek?? helppp
- How good are the HSD coil overs
- what tire size are best for drag and adding mph???
- Rear wheels rubbing actual wheel well
- Volk Re-30 17x9, 22 Offset
- Wheel model and brand
- buddy club racing spec adjustment snapped off!
- Strange feeling on new tires? Falken FK452
- Quick ?: Spring Compressor
- Tein SS Coilovers or.....? (searched....alot)
- Camber Kits
- Need help on chargespeed front fender
- Need Input on alignment issue
- debating on rims
- 1.0g skidpad what does it take?
- does anyone have the tanabe sustect sevens?
- Coilover Adjustment
- Are Ferrodo DS2500's the BEST?
- Bilstein PSS10 Arrival???
- Need help with passenger axle
- Getting to be time for new brake pads, any suggestions?
- Interesting Hybrid Brake Project
- 18x9.5 SSR Type C-RS
- Suspension problem?
- Fixed Sqealing Hawk brake pads
- Changing my INNER TIE ROD... need special tool?
- all season tires
- Custom 3 Point Under Tie Bar With Downpipe Clearence Created, Pics Inside...
- Sumotomo HTR ZIII....?????
- Let my mom take the evo for a cruise today...
- 06 Evo MR alignment specs needed
- Advan Rs or Work Xt7???
- evo x wheels on 1-9?
- O.Z. Ultraleggera
- Volk RE30 18x10.5 +15???
- Bilstein HD Dampers
- New brake set-up. What do y'all think?
- Whiteline Roll Center Correction kit....Help Please!
- agressive summer tires?
- lifespan of brake pads?
- rotor and pads on a budget
- Brake pad compatability...
- Changed Wheel Bearing, and Noise Is Still There??
- 16 inch Wheels?
- Anyone had this prob?
- StopTech 355x32mm 6 Piston Brake Kit Front
- 18 x 9.5JJ Wedsport TC105N
- Newb Question....
- Rolling rear fenders without creasing??
- Change of brakes ?
- Wheel Bearing gone bad already???
- Awful awful awful grinding
- 20mm Kics spacers?
- EVO X brakes???
- What brake fluid to use?
- Anybody running 19's?
- Need help with MR Bilstein and Aftermarket Springs Set Up
- Mixing & Matching Front Rear Rotors
- Tire Question
- rear brake pads question
- 17x9 or 17x9.5
- Lower car using springs
- need some help on 5zigen's
- choosing b/w 245/45/17 and 245/40/17 on Z1s
- Evo IX rally grp n gravel calipers kit
- Which Strut does IX SE have stock?
- what size tires should I get
- Missing front cross bars... advice?
- Crazy/Stupid: Advan A048 on Street
- Hate My New RE-01Rs
- Camber gauge recomendations
- correct evo 7,8 wheel fitment
- Serious noise, Suspension maybe
- NT03M's 18X9.5??
- Ap racing dealer site?
- does anyone have pics on an evo 8 with swift spec R lowering springs
- Fitment for 17x10 +25
- Ceramic pads vs Stock rotors
- 17x8 +25mm?
- any vendors here with this size RE30 in stock?
- Bumpy ride...what could it be?
- O no
- Enkei RPF1; strong enough?
- Rear Strut tower brace
- 245s or 255s w/ GT-U 18x9+29
- brake pad installation
- Preping Rotors for new pads
- RT-615, Z1, or Invo?
- Oh my god, another Direzza Z1 thread?!?!?!
- Recovering trashed wheels?
- Front sway bar for the track info and feedback needed please.
- What brake guides?
- Am I the only one who HATES the factory tires?
- Rota P45R 17s with 245/40/17?
- Brakes Shaking Only When Hot.
- Car shakes when braking
- what is the best asymmetric tread tire?
- New TA Rota G-force on the way, what tire/size?
- Rims + Tires Help
- Argh!
- Are Goodridge SS lines coated?
- Just Installed KW Variant 3's and..
- titanium burnt wheels (whole bunch of fatties)
- Ziex-912 tires, anyone running them?
- Recommended tire psi for Z1 Star Spec Tires
- Recommended Lug Nuts
- New spring problem.
- 18' Tires
- Which 16" Wheels fit stock EVO brakes?
- Pic Request: 245/45/17 Dunlop Z1's on stock wheel
- best auto x suspension
- Bushings, bushings, bushings......
- I lowered my car, now my axles are clicking?
- drop springs....
- Direzza Z1 star spec
- Is anyone running Star Specs in the 255 width?
- Best 17" auto-x/track/DD wheel?
- Tein Control Master Flex Coilover "default" settings
- rims w/o center caps
- rotors?
- Polish help!!
- STU: Understeer Understeer!! can you help ?
- Hawk pad help
- hks or kw battle of the iii's
- new KWV3's chirping noise
- Help with CE28N on a EVO IX wheel suggestion?
- My Evo VIII MR - Cusco Zero2E... Work XC8... bla, bla, bla
- anyone drive their car with the front strut bar removed?
- Wheel weight help!!!!
- Running on Spare tire for extended use...
- wheel fix question~
- stud busted
- confirm fitment?
- Quick IX Tire and Spring Question
- Swift spring users...did you cut the bump stops?
- Stock Rim Weight???
- Sachs Group N Suspension
- Thanks to EVObrakes and the staff of KNS!!!
- Finally!! FORGED ADVAN WHEELS!!! ADVAN Model F7 - New for 2008!
- Are these good Brakepads/Rotors
- Suggestion on tires ver35434234.2
