View Full Version : Alternative Fuel
Pages : [1] 2
  1. E85 vs 93 oct
  2. anyone try these denso 1600cc ???
  3. Was getting P0171 when running E85, switch to 93...no codes
  4. ROM 96530706 Tephra v7.0 on E85 - questions
  5. Any one running E85 AND meth/h20 injection?
  6. Cellulosic ethanol plant opens in Pennsylvania
  7. How many gal. of E85?
  8. e85 and nitrous?
  9. Lets talk cold start
  10. 248.3 Miles to one tank of E-85
  11. E70
  12. Real world E85 "issues"
  13. Need help with e85 please!!!
  14. Gizmodo: Microfueler Home Ethanol Pump
  15. Evo E85 Registry thread???
  16. Lean Or Rich On E-85 Maybe A Boost Spike
  17. Just made the switch to E85.. awesome!
  18. good article on algae-based production of ethanol
  19. E-85 Going Away?
  20. E85 Fuel Filter
  21. "E-85 Army" Stickers
  22. Map Change Harness for my E-85!
  23. May get the Zeitronix Ethanol Content Analyzer but need advice.
  24. Help
  25. E-85 a/f
  26. Curious about DLL and how accurate the HP/TQ #'s are compared to a mustang or dynojet
  27. supra pump died
  28. Do I need an ethanol content sensor?
  29. Tephra Map switch is a waste of time, E-85 sucks
  30. e85 ON STOCKER
  31. Should I trade my HFC for a test pipe w/ E85?
  32. 1st day on e85......1200 PTE and walbro impressions
  33. low rpm knock with e85
  34. E-85 storage observations
  35. tuning by turbine color with E85
  36. To those running E-85..
  37. E85 big injectors low idle Q
  38. E85 parts checklist..Have i missed anything??
  39. Worlds Most Powerful Octane Booster
  40. E85 vs. Q16 - discuss
  41. E-85 is a corrosive
  42. Zeitronix Ethanol Content Analyzer Installed and Reviewed by TTP!
  43. GM Ethanol Sensors now available from TTP at affordable pricin!
  44. E85 spark plug poll
  45. E85 Locations
  46. E85, GT3076, 1600cc Inj, Single Walbro?
  47. E-85 vs meth injectors/pump
  48. E85/meth combo
  49. Got some E85 thats smells like yeast burning?
  50. E-85 +/-
  51. My E85 tune... thoughts? torque suggestions??
  52. got my 1200cc PTE injectors in W00T!!! E85 here I come
  53. E85... Will it eat the stock fuel lines or not.
  54. Ken Block and E85
  55. methanol suppliers
  56. e85 and Oil - How they mix
  57. What do i need to run C16
  58. Noticed something about E85 gas prices
  59. CBRD BBK Full and E85
  60. Jay Leno & E85
  61. E85, Injector Gunk & Seafoam.
  62. Question about those of you that switch between pump and E85
  63. e85 and n2o?
  64. Max power on 1600s and 1200s
  65. E85 from 91oct. Should I close my plug gap some?
  66. My motor on E85...
  67. specifications for E75-E85
  68. CES eth content sensor installed, flex fuel patch coming soon
  69. Lead fouling
  70. What size/ brand of injectors do you use for E85?
  71. So I haven't even driven my EVO yet but I'm thinking about E-85
  72. E85 Year Round MIDWEST
  73. E85 Spool AFR Transition
  74. E85? Dual Maps? New E85 Forum Needed?
  75. E85 vs C16
  76. EPA May stop future e85 stations
  77. EVO gets twice the gas mileage of Prius!
  78. Difference
  79. Are the Greenies confused?
  80. Flex-Fuel = more HP?
  81. Read fast B4 this gets moved to OT.
  82. can i or what do i need to run e85
  83. Tephra Patch and E85/91 octane Injector Scaling
  84. E85 and Track Weekends
  85. where can i get C16?
  86. Cross Country on E85
  87. Packed and ready to get tuned
  88. How-To: Warm/Hot Starts (and cold ones) with E85
  89. E85 Blender Pumps
  90. Who likes E85!?!?!?
  91. Fuel Rail?
  92. Getting ready for E85, some questions...
  93. show pics of flex fuel sensor mounting location
  94. fuel economy
  95. E85 % calculation - how to mix yer own :)
  96. E85 and Emissions
  97. Injector "gunk" and E-85
  98. switch
  99. e85 tuning ?
  100. E85 Road Race Tune?
  101. e-85 EGT's
  102. Are my mods enough to run e85?
  103. changing maps?
  104. 10 % ethanol fuel
  105. HP Guess...
  106. e85 tryout?
  107. E85 Timing Maps
  108. HELP?! Please...
  109. White Lightning Flex Fuel Kit
  110. More alternative fuel goodness
  111. P0300 Gone...
  112. Highest Miles on E85
  113. Are there really NO certified containers for E-85 ?
  114. E-85 or Meth wich way to go ?
  115. Ams and the amazing tuner chris!!!
  116. Is there a difference if use e85 winter or summer?
  117. E-85, what other supporting mods will help me reach 400 whp?
  118. Fuel system for a GT4094R
  119. E-85 pumps across America...
  120. From beer to ethanol
  121. Ethanol/Gasoline mixing pumps
  122. Double pumper finally installed!!!!
  123. Ecu Boost Control + 3" FMIC+geared 272s+E85 + Stock Evo VIII turbo=rally torque
  124. Poor Mans Ethanol content analyzer
  125. fuel regulator and fuel rail E-85?
  126. WingzPerformance.com '98 GSX goes E85.. See inside for gains
  127. e-85 and DEQ?
  128. Fuel rail-e85?
  129. Simple question
  130. Best Hi Boost Controller That Helps Prevent Taper(Stock Turbo)
  131. E-85 in Turkey Lake Plaza
  132. E85 Fuel Cell Setup?
  133. Are you running E85 all winter up north?
  134. buschur double pumper
  135. Mod advice sought on E85
  136. E85 Tune = +59 Hp & +97tq
  137. The New Fuel of the Future :: Wood.
  138. question about e85...
  139. what if no e85 is around during emergency?
  140. Why can't E85 just stay E85 lol
  141. Injector scaling for PTE 1200's
  142. E85 with 100% meth or 50/50 meth/water?
  143. To the ''dark side''
  144. After E85 fill, running leaner and leaner.
  145. E85 Spark Plugs and Gaps
  146. E85 Sensor spec sheet
  147. Octane Rating of E-70? Winter Blend?
  148. E-85 tuned, stranded for 500 miles with only gas stations
  149. E85 - 13:1 (gasoline AFR) - ACK!
  150. Should i switch??
  151. Tips for better cold start w/ E-85 & AEM
  152. 91 octane to E85? Should I make the plundge?
  153. Unable to break 26psi
  154. 1600 cc injectors
  155. E85 - First timer, observations on mpg.
  156. Confused about WB reading.
  157. Can someone critique my timing map.
  158. Fuel upgrades for E85 and BiggerTurbos
  159. Question on single pump w/in-line vs. double pumper
  160. Single pumper numbers and turbo-please post!!!
  161. Just filled up on my first tank of E85, does E85 ping?
  162. Tips on a AMS 30r on E-85?
  163. EvoX on E85?
  164. Verasun files Chapter 11, gets financing
  165. New Zeitronix ECA - Ethanol Content Analyzer
  166. Max power on Lucas 120lb running E85?
  167. fuel trims
  168. Base Low Coolant Timing Map
  169. Storing E85 in 55 gallon drums
  170. $1.85/gallon - Also good info for California E85
  171. Filled the tank of the evo last night for $25!!!
  172. Low-throttle richness solution?
  173. Our results with E85
  174. E85 = +73whp/+62wtq over 91 oct
  175. injectors help
  176. Another cornfed on the list
  177. E85 = +60whp / +55wtq peak
  178. My AMS 35R tuned on E-85...1000cc Inj with Single Walbro Pump....
  179. E85 tune
  180. E85 from your own political view..
  181. safe psi
  182. DUAL fuel Pump
  183. Winter coming up, back to 91 or stay with E85?
  184. E85 usuage
  185. Mixing your own E85
  186. Who has been using E85 the longest?
  187. Internal engine material changes with E85
  188. Bad E85?
  189. CNG powered Evo wins international rally race
  190. E85 Email flash tuners?
  191. E85 or E100 ???
  192. I just got off the phone with BP fuels
  193. Any help? Lean A/F @ high RPM
  194. CEL - Idle Higher than expected????
  195. seasonal e85 tuning question
  196. Lean Cruise limits
  197. Evo Red, E-85, and passing inspection..
  198. e98 track day's
  199. Ignition amplifier needed when using E85
  200. E85 - RC 1000cc - idle and cruise
  201. Up-stream 5th injector.......idea???
  202. Injectors for switching to E85
  203. E85 and CA smog
  204. E-85
  205. Evo 9 - E85 - 400 club
  206. Time with E85
  207. Plugs and E85
  208. Our second E85 station just opened up $2.65 gallon.
  209. P0300 and E85 ???
  210. Is a highflow Fuel Pump mandatory for E85?
  211. Hyper Ethanol Production
  212. Atl Fuel Cell
  213. Getting ready for first tank of E85
  214. 1200cc injectors for e85 and stock 8 ECU...injectors to big for stock ecu??
  215. Before and after E85 Dynojet graph
  216. E85 price gouging!!!
  217. E85 stations
  218. Road Racing on E85
  219. Potential great news for California E85
  220. My new E85 Storage container
  221. e85 storage in gas cans
  222. Downsides of E85
  223. What kind of boost are people running on E-85?
  224. E85 hints and tips…
  225. Knock with Toluene
  226. Do you guys use colder plugs with E85?
  227. Just made the switch to E85…
  228. Flex Fuel capabilities for the Stock ECU. When?
  229. E85 Volitility class by month
  230. Double Pumper necessary?
  231. E85 combustion (burn) rate
  232. Anyone switch to E-85
  233. grade of gasoline in E85?
  234. E10 cocktail fuel - ???
  235. E85 and catalytic convertor
  236. Dual fuel tanks
  237. E85 tuning notes
  238. My E85 Impressions
  239. Counter to aniti-ethanol folks
  240. graph of run today on e85
  241. Torco/tolene data logging questions
  242. How to get E85 in your town
  243. Swift Fuel?
  244. Made switch to e85 today
  245. FIC 1050cc settings for e85?
  246. Please post your E85 stock turbo IDC%
  247. Question about Methanol
  248. E85 tuners - step up and be counted!
  249. Thanks RRE for Stage 1E (E85) 383whp/ 383 tq V5 Tephra mod
  250. 25 Days until my E85 coversion at AMS....
