View Full Version : Alternative Fuel
Pages : 1 [2]
  1. Thanks RRE for Stage 1E (E85) 383whp/ 383 tq V5 Tephra mod
  2. 25 Days until my E85 coversion at AMS....
  3. Anyone switched from Meth to E85?
  4. engine wear with e85?
  5. E98 where to buy
  6. CornFed Independence
  7. Great news for ethanol users. You can make your own E100.
  8. Motor Oil with e85
  9. Flex Fuel Sensor
  10. fuel pressure monitor via ECU
  11. cars run on that h20?
  12. Another corn fed evo!
  13. E85: fuel pump body grounded to chassis?
  14. FIC 1050 folks: what are your peak IDCs and whp values?
  15. How much E85 can I mix with gas and not retune?
  16. Fic 1000 E85 injector scalings/latency
  17. What you Need for E85?
  18. E85 max power rich
  19. Getting upgraded fuel just a few questions
  20. different injector scaling needed for E85 and pump gas?
  21. Boost cut, spark plugs, or what?
  22. 606awhp@30psi E85
  23. High volume fuel rail needed for E85?
  24. Which Walbro is everyone using?
  25. E85 fuel trims
  26. A new E85 converted Evo
  27. What type of gas do you guys use?
  28. 26-28psi stock turbo on E85: FMIC necessary?
  29. E85 in a JDM evo?
  30. 1000cc inj. and Evo9 Fuel Pump
  31. E98, Who has acces to it in the mid west?
  32. What kind of gas mileage are getting on E-85?
  33. E47.5
  34. afr/lambda to aim for with different ethanol content
  35. New production method for ethanol.
  36. is there a difference between e10 vs 92octane
  37. E-85/70 tune from Mitch Mckee @ Vividracing
  38. Pumps in NY
  39. E85 vs. 100 octane
  40. E85 now available in Los Angeles
  41. Lower fuelpressure or injectorscaling?
  42. Ethanol content boost
  43. Stock ECU E85 settings
  44. flex fuel on stock ECU coming soon...
  45. E-85 recommendations
  46. Interesting study about MPG on different ethanol blends..
  47. Converison. Injector for my setup?
  48. E85 cold start tips and tricks
  49. Daily Driven E85??
  50. low lead 100octane?
  51. ethanol content gauge group buy..?
  52. E85 and Evo Green
  53. Fitch® Fuel Catalyst in an EvoIX
  54. E85 seasonal changes?
  55. Interesting E85 conversion product
  56. xylene
  57. Best Turbo for DD E-85 2.0l?
  58. ethanol content gauge
  59. Legal Ramifications of E85 Conversions
  60. Any benefits from mixing E85 + pump gas?
  61. Full Flex International
  62. New Site On Alternative Fuels
  63. Evo on E85
  64. Indycar switched to E98, why not E100
  65. e85
  66. E85 Questions
