View Full Version : Evo Engine / Turbo / Drivetrain
  1. Radiator fan issue
  2. transfer and diff oil?
  3. Fmic question??
  4. Starter Going???
  5. BLE solid tensioner
  6. Random break up?
  7. bfic or not
  8. SES light from Test pipe
  9. Boost gauge only reading 15psi **UPDATE**
  10. crazy loud noise!!!
  11. VP Imports vs Q16? Anyone made a back to back dyno test?
  12. slipping
  13. Idle Surge
  14. wtf
  15. wtf is wrong?
  16. Built 2.4L vs Built 2.0L
  17. kelford 280/280 vs kelford 280/272
  18. exedy or act??
  19. Guestimate approx. HP Gain?
  20. battery light and brake light on while cruising
  21. What goes here?!?
  22. ebay licp
  23. RPM's acting weird at idle....?
  24. eBay O2 housing problem
  25. Geting Tired of Small Power and Feeling the need for Big Power
  26. WOT Throttle, Fuel Cut. then ASC off Light turns on!!!
  27. engine rebuild questions
  28. Q: Evo Timing Belt Length ?
  29. HELP with oil leak!
  30. FP HP WGA questions....
  31. Boost problems
  32. My Porting Job!!
  33. Boost is a lot less in 2nd gear comapred to 1st?
  34. Using port on Oil filter housing for FP oil feed line, now where do I put oil temp?
  35. Exedy throw out bearing OK?
  36. Flywheel scare
  37. power loss at higher rpms majorly
  38. BOV=No full boost?
  39. Oil Pressure Problem on 2.3L 4g63
  40. Quick problem, missing bolt on o2 housing
  41. Idle probelms....need so advice
  42. Mopar timing belt on evo?
  43. MBC users thoughts?
  44. Clutch HELP
  45. 3" vs 3.5" IC and fp-red
  46. got a few questions about making power
  47. I hope someone from Tilton reads this...
  48. what sensor is this???
  49. hks gd twin plate clutch
  50. Coolent leaking behind crank pulley help!
  51. starter problem
  52. My front axles going bad?
  53. Bearing clearances (again)
  54. What Cam Gear Are Good To Put On An Evo 8 With HKS 272 Cams??
  55. Apexi N1 Exhaust - How loud is it??
  56. possible causes for clutch pedal pressure lost?
  57. Good Exhaust combo?
  58. Need help choosing a turbo kit for my IX
  59. Non CDI Coil On PLug: Really worth it?? Good read!
  60. My $80.99 full ebay tbe
  61. NEED help/opinions/feedback on what route I should go with....IM vs Cam upgrade
  62. TOMEI ARMS 7960 vs BBK FULL ??
  63. Modding a car that has been previously tuned
  64. Exhaust advice
  65. evo 7 build from Australia
  66. i again call on the knowledge of EVOm
  67. TT600 stock frame style turbo!!!=)
  68. Why We Leak Test Each Intercooler! and HOW!
  69. ETS End Tank Design! - No One Compares!
  70. EVO 8 Shakes Violently Under Throttle
  71. Intake filter fitment issue
  72. Stock Exhaust Manifold...Is this normal?
  73. how does the fp-red sound?
  74. epm dump which version works w/ niesi licp
  75. the proper clutch for my power
  76. Help w/ 2.5" lower AMC IC piping to FP Red
  77. 2.3 pistons
  78. How not to install a CBRD radiator.... and, well.... everything I guess.
  79. new stock clutch vs. others.
  80. throttle kicker for antilag
  81. Another ACD thread...Sorry guys.
  82. Anybody Have Experience with Both GREDDY Ti-C and Ti Exhausts?
  83. ARP headstud installation problem.
  84. Bucking at 1/2 to full throttle
  85. evo 9 vs evo 9 mr
  86. Radiator hose kit comparison question
  87. Mechanical t-case?
  88. stp engine oil treatment?
  89. O2 housing fitment
  90. time to play "name that thing"!
  91. 2.4 Thread
  92. Mysterious oil leak
  93. Closer 5th Gear
  94. need diagram of stock map sensor pigtail
  95. Turboxs exhaust vs AMS exhaust
  96. what power can a greddy vspec front mount hold
  97. Cant get o2 sensor out of o2 housing
  98. FP Red looses punch after 120 mph.
  99. ALS on gt series or Fp turbo's
  100. Newbie questions.....
  101. and an idle problem
  102. Need some help..
  103. New FP red vs Old FP red?
  104. Buschur Race 4" FMIC
  105. Anyone had the A/C condenser fan fail?
  106. WOW you will never believe it
  107. what ever happened to top mount turbo kit
  108. Carrillo vs Manley
  109. Fp black dyno #rs
  110. Boost Surging/Slipping?
  111. Cat Question
  112. What to do? max stoxk turbo or upgrade?
  113. anyone use these?
  114. My EvoIX SE w/ FP Black and stock block
  115. Gasoline Leak - Odd
  116. Suggestions for air/fuel "gauge" setups needed..
  117. Cosworth M2 IX lobe centerline?
  118. What size vacuum line?
  119. Polished up one of the turbo manifolds....
  120. evo9 head onto evo 4-8, what is needed?
  121. Ebay O2 housings
  122. coils keep burning??? need help??
  123. A lag monster is spawned! (cam timing)
  124. clutch question
  125. Kasey at MAP's 2.4 Hybrid Build
  126. fuel pressure gauge adapter
  127. Anyone running the new PTE ceramic bearing 6262?
  128. 35R Long Rod 2.0 Build
  129. Injector Resistor Evo VIII 2003
  130. exedy twin disc slipping!!!
  131. Help guys i just want to know if a t28 flange will fit on a t25?????????
  132. Question: HKS DLI (Ignition Amplifier)
  133. intercooler question.
  134. clearances...what's acceptable?
  135. My FP Black
  136. Braided Lines? What to Change?
  137. PT6262 in ... FP Red out
  138. Ebay HKS 272's , not really
  139. Installing new Motor Mounts?
  140. Coolant Smell
  141. ACD leak, checking for more obvious places for leak before dropping transfer case
  142. Unofficial Quatermaster Twin disk review
  143. MR Turbo
  144. Stock Evo 8 exhaust diameter
  145. MR trans fluid in my hihg mile EVO 8
  146. IX OEM bonnet heat shield removal
  147. coated housing/exh manifold worth it?
  148. Synapse Piping
  149. Bov ?
  150. Best Fluids?
  151. Evo IX revv hang?? Anyone??
  152. Oil leak under transmission
  153. Busher's 3” downpipe fitment
  154. Car acting weird under boost!
  155. HKS 280 cams, whats wrote on them, and rust issue
  156. Cars banging around?!?!?!?!
  157. cluctch ret. spring
  158. car whines alot but runs good ideas?
  159. lets play y wont my car start...again!
  160. please help !!
  161. HELP -water pump
  162. compression test
  163. water pump?
  164. 2 ?'s. Is an 044 overkill for stock lines? Who makes tank to rail lines?
  165. Tial Recirc BOV
  166. Why does Fidanza hate MR's?
  167. Code: P0240 Catalyst System Efficiency Below Threshold
  168. One wheel on air and the other 3 don't move
  169. 6 speed output shaft
  170. 12psi at full boost? maybe problem with UTEC?
  171. comparison
  172. jun oil baffle/ slicer
  173. CBRD halfwidth rad, design input..
  174. valid test?
  175. Will Exhaust Silencer Reduce Power?
  176. Help!!! Boosting 1.8 Bars!
  177. Those of you who do their own porting,...
  178. siliconeintakes "non" catalytic converter
  179. MR (6spd) transmission drain plug magnet?
  180. BR, 2.4, high hp/high rpm build?
  181. Help!! Leaking oil!!
  182. Help: Ignition Coil Cooked itself...
  183. oil line and banjo bolt solution
  184. Another FP Black Thread
  185. Can P0420 error code be caused by air/fuel ratio gauge?
  186. HOW TO check for shaft play on turbo
  187. 2nd Gear clunk?? (yes, i searched)
  188. Sparktech COP? Big Turbo? Are you happy you did?
  189. hks twin disc
  190. idle problem
  191. black smoke after WOT
  192. My Epic Ebay TBE Install Thread.
  193. Stock Valve Question. Please Help.
  194. t-case gearing question...
  195. new built motor! smokin a little wen cold ???
  196. Stock internals - rev limit
  197. What size oil feed line should be used for a 35r?
  198. OEM crank vs Eagle crank?
  199. ses flashing at wot
  200. Tcase question!! HELP!
  201. casting imperfections?
  202. Diff Clunk
  203. 4g64 block with 4g63 trans
  204. Speed Sensor Leak: Removal?
  205. getting CCI Clutch, Can I reuse stock TOB?
  206. Boost leak bucking caused diff noise?
  207. 6-speed shifter vibration question
  208. HKS SSQV not working
  209. Mynes 3076
  210. Urgent Pully help needed!!
  211. help plz
  212. easy way to remove stuck doughnut gasket on dp?
  213. Normal for used set of cams?
  214. intake/clutch
  215. Is it my tune or o2 sensor?NEED HELP!!
  216. Lets play a game, whats wrong with my engine?
  217. pte 1000 cc install issue º
  218. Installed ETS Intercooler, UICP - some questions about hoses
  219. Idle Oil Pressure
  220. Boost leak test performed today.
  221. oil pump questions
  222. What is your highest injector duty cycle stock turbo and injector?
  223. exedy lightweight flywheel
  224. Not getting into gear!!!!
  225. Exhaust 2,5 with 2,75 ralliart or all 3 inch.
  226. yet another timing belt/tension problem, please help
  227. cel for o2s when they work fine?
  228. Aftermarket clutches wear faster?
  229. Maf Adapter and Cone Filter questions
  230. new LICP and O2 dump do i need a tune?
  231. Evo 8 shortblock in a 9? What's it take???
  232. Lets talk: Radiator Surge tanks!
  233. FP Green vs. FP RED vs 35R (non hta)
  234. Stud for top intercooler bracket snapped
  235. Megan Racing testpipe question
  236. P0171 and P2195 codes thrown while car idled for a while
  237. Does this sound like a blown headgAsket
  238. Having a P0335 issue
  239. Ecu code p0603 (help)
  240. Having a P0335 issue
  241. EVO 8 Stock Internals
  242. clutch and flywheel
  243. Cooling Fans stay on??
  244. Block surfacing needed?
  245. More wideband issues
  246. Oil pressure drop-when to act??
  247. Fp Red vs Fp Black Direct Swap #'s
  248. Stock Motor FP Red Thread
  249. Some Clutch issues?
  250. new in town
