View Full Version : Evo Engine / Turbo / Drivetrain
  1. Boost drop after fmic install
  2. Having a boost Problem give me a hand please =(
  3. Perrin Test Pipe Question
  4. Same driveshafts Evo VIII as Evo VI?
  5. Can the BR Bullet be hushed?
  6. Stroker
  7. best turbo manifold for the stock turbo
  8. Gas Poll
  9. ordered manifold yesterday
  10. Clutch for 2.3+30R?
  11. Invidia Downpipe on Ix
  12. clicking noise till cams warm up??
  13. Need pics for WG turnbuckle tightening!!!
  14. So, have you ever seen the center Viscous let go?
  15. Humming noise while turning the car to the right?
  16. This Is A Tough One...
  17. LICP recommendations
  18. 20g-9 Cams Question?
  19. Best spark plugs & gapping for 30psi boost+75hp shot nos on 35R
  20. What next for the IX
  21. J&S safeguard
  22. Clutch blew up, need a little input.
  23. Cams and afcII
  24. do i have a problem.
  25. nos question
  26. Added noise from Fidanza flywheel??
  27. 12V ignition on power source?
  28. Apexi Noir Evo Cat-Back
  29. ATTN To those who have shipped out ecus to be flashed
  30. TC problem or bad wheel bearing?
  31. Help me diagnose this oil leak?
  32. EVO 8 Problem Please Help!!!! Bogging down
  33. Got a CEL today...HELP!
  34. when does the IX turbo lose efficiency
  35. Anyone know the correct thread size for the taps on the head??
  36. Bolted up a 20g-9.....untuned !!
  37. Once again HELP! Engine Problems
  38. boost gauge fluttering???
  39. Greddy SP2 Pics
  40. Drivetrain noise...
  41. Thanx to TT
  42. which clutch
  43. gt3076r and plug gaps
  44. I know I know ...Im a newb but....
  45. Tilton from a honda, Will it fit in an evo 9?
  46. EVO IX - HKS Exhaust Cam?
  47. stock turbo and 11s??
  48. Replacing Helix catback with?
  49. Quick question:Sun Auto Cyber Products
  50. Stock IX FMIC core?
  51. Redline Heavy Duty Shockproof candy
  52. detonation, need new pistons
  53. SBR GT35R dyno results
  54. Forgot the washer on the rear diff drain plug... bad?
  55. oil lines leak - oil cooler
  56. SPEC clutches really this bad????
  57. how much damage did I just do?
  58. To GT35R or FP3065 ???? choices, decisions....
  59. 20G 9 ti wheel
  60. ACD Overfill ?
  61. apexi noir vs rsr ex mag
  62. Driving impressions: BR Race FMIC on Stock 05 Turbo
  63. Dynoe'd my 03 EVO! Am I about right?
  64. Cant find o2 housing on ebay
  65. really cool washing machine!!
  66. Brand new EVO IX, 1100 miles, strange problem
  67. need help, I was sent 264, 280 hks camshaft ?
  68. 264/280 cams??
  69. Engine misfire
  70. Cat or not to cat
  71. CEL question
  72. 20G Turbocharger
  73. Brake fluid concern !
  74. WTB: stock turbo from a EVO 7 or 8
  75. spark plugs
  76. QTP First Evo 8 Down Pipe/Cut Out!
  77. any one use Trufilter oil filter
  78. got questions on gauges
  79. US Only Oil Filters? What gives?
  80. Finishing up cam install and...
  81. Gsc 264/274's are bigger injectors needed?
  82. To 35R or not To
  83. Review: WORKS Axle-back muffler "Videos"
  84. Throttle seems to Stick..
  85. Mivec question?
  86. MBC problem continured
  87. 1.2mm Head Gasket + Head Stud Kit
  88. Maybe my next mod path
  89. exhaust flange
  90. 1st Dyno attempt ever for me.
  91. WTB stock evo 8 turbo manifold
  92. Cosworth head repost
  93. Is my clutch slipping?
  94. Turbo
  95. Decibel testing on different exhausts and combinations....
  96. In the market for an 02 housing +10.5 hotside
  97. what manifold should i do??
  98. How to clean oil residue in Turbo inlet
  99. Turbo xs fmic dyno gains?
  100. Cosworth cam info...
  101. Issue with timer harness and not happy with Lancershop customer service!
  102. Installed some part on a friends Evo
  103. Do I have Headstuds?!?
  104. help me continue my mods!!!
  105. 05 transfercase
  106. I'm tired of my coffee can exhaust - Alternatives?
  107. Bushur Exhaust Question
  108. Head Flow Data Comparison
  109. Turbo XS D-tec EBC
  110. type s
  111. Another clutch question
  112. what kind of turbo is on the f400
  113. Trans/ TC fluid Chaos
  114. replacing stock manifold with aftermarket???
  115. Greasing the APS BOV?
  116. EVO 9 and Upgraded Turbos
  117. anyone run a shearer 50 trim?
  118. Clutch gave out today.....
  119. Maf Problem Help
  120. Monster Sports Parts Debut
  121. Timing Belt Change Question....
  122. Fujitsubo RM01A....NOT 3" Through Out
  123. in ref to sticky - stock evo track day?
  124. turboXS HPMBC
  125. MBC is being a douche bag
  126. Cam Gears
  127. Anyone install a low profile fan? - Instructions?
  128. T case fluid change
  129. Engine/Boost problem.....
  130. DEI exhaust wrap
  131. Trans. Fluid Alternatives
  132. my IX on 100octane daily
  133. Gearbox or Differential
  134. Align hone with ARP Mains??
  135. Tales of my EBAY O2 housing
  136. IC pipe leak and BOV question
  137. yet another turbo recomendation needed
  138. User-Tunable ACD Controller for 05-06 EVO? Anyone Interested?
  139. MBC problem
  140. front mount swap. look here.
  141. anyone know about flywheels???
  142. MBC or Greddy Profec B spec 2?????
  143. Looking for catback...
  144. Injectors
  145. White Rabbit Peak PSI Flow?
  146. best power for the money cams?
  147. Boost lower then normal....
  148. Malibujack's Mechanical Engine Porn
  149. another whining noise thread.....
  150. Piper 290 Drag Race cams??
  151. Electrical Problem 1st day..
  152. Just dynoed my ams gt3076 kit
  153. Rear Axle WHP Capacity
  154. any one use Clutch Masters stage 3
  155. Turbo Back Exhaust = Less boost
  156. Hks Ssqv
  157. Stock MAF testing: Is it really restrictive?
  158. Trans or Tcase
  159. alchy or ams intercooler
  160. This is how my Full-Race turbo kit install went today......
  161. which clutch??
  162. Will this Work???
  163. Gauges
  164. just for fun, how much hp after turbo install estamate
  165. Removing lower IC piping....
  166. street tuned the GT35R
  167. shorter 5th gear for '03?
  168. TURBO! I can't decide which one...
  169. Throttle Body Spacer??
  170. EBC and HKS RS intake combination
  171. Intercooler piping and intake ???
  172. Weird noise when downshifting???
  173. CEL code question...
  174. Need a AEM map ASAP (35r,1000cc,5bar)
  175. Help on Clutches, love to hear from AMS, Buschur, Turbo Trix, and Auto-Xers
  176. HKS cam question
  177. greddy ebc
  178. anyone using the carbon fibre driveshaft as yet?
  179. DC Downpipe Problem?
  180. WORKS clutch line problem???
  181. Clutch Slipping Solutions?
  182. Does the stock wg arm need to be adjusted for high boost?
  183. Its that time...
  184. Boost after Dynoflash
  185. thought i should share
  186. are my cams causing these codes to be thrown???
  187. IX 5 speed much better than VIII 5 speed?
  188. Where can I buy an O2 sensor including connectors? Need help!
  189. Clutch Help!!!!
  190. Clutch chatter on new clutch?!?!
  191. smc alky kit questions
  192. what would be faster?
  193. 05 VIII Going under the knife this weekend...
  194. Will this intercooler work??
  195. Agency Power Turbo Kit - DYNO RUN VIDEO
  196. Breaking in a Stroker Motor
  197. Evo IX Compression test
  198. Best/Easiest way to measure fuel pressure?
  199. Intercooler pipes
  200. CEL code after mods/tuning
  201. 20G-5 vs. 20G-6 wheels and compressor surge
  202. Engine RPM's
  203. **VID** My HKS 280's cams idling on my 05 EVO 8
  204. is my clutch ok?
  205. for you people w/ ebay style O2 housings
  206. 3076R hotside, .63 or .82 ?
  207. Evo IX Gearbox
  208. Will $5K get you into the 10's in a IX?
  209. someone please explain heatsoak
  210. 2.3l + what turbo?
  211. TurboSmart E-Boost2 Boost controller
  212. Which intercoolers work with the oem sprayer?
  213. How much Hp for AMSGT-35R
  214. FWD Evo??
  215. Ignition Problems
  216. Dyno graphs...topspeed tuned
  217. Anybody using AEM's twin fire ignition module?
  218. fluid leak =[
  219. Looking for Intercooler
  220. Is the shifter different between an 03 vs 06?
  221. Test Pipe Gasket HELP HELP
  222. my 280 cams idling before tune - video
  223. Cosworth Cams
  224. New Buschur Racing 3" V-Band Turboback Exhaust
  225. Greddy T-67 Kit
  226. Parts
  227. 02 housing question
  228. Detonation, What's it all about?
  229. Bosch 044 vs. Aeromotive A1000 or Eliminator vs. Magna Fuel ProTuner MP-4302?
  230. fuel pressure problem
  231. Should I upgrade Intercooler????
  232. revolver cams vs Hks 280 cams
  233. How to grease Forge MBC?
  234. questions
  235. with or without?
  236. Just got AMS flashed
  237. So Confused ... Turbo Question
  238. Timing Belt Problem, Please Help!
  239. PO171 & PO134
  240. wait for flash?
  241. Ignition Troubles
  242. Engine revving for no reason
  243. David and the Buschur crew, Thanks for helping the kids.
  244. Anyone running AEM Twin Fire?
  245. Does anyone try this product already?
  246. My Buschur Racing RACE FMIC arrived....all damaged!!! Pics Inside!
  247. defi egt install help.
  248. boost on a GT35R???
  249. FMIC: stock vs Rnr vs Buschur race
  250. Have i gone to far?
