View Full Version : Evo Engine / Turbo / Drivetrain
  1. Turbo Coolant line Bolt Size?
  2. want to buy 20g-9 turbo now! where?
  3. Rocker arm came off the lash adjuster
  4. Exedy Twin ?'s
  5. I searched in vain, re: boost leak testing
  6. OEM Clutch Maximum HP?
  7. where to fill ACD??
  8. Low oil pressure on Defi BF
  9. Broken bolt in hotside...0....me...1
  10. just got my car running after new motor, oil has air bubbles?
  11. 20G Turbo without cams?
  12. Boost problem..
  13. DC Sports turbo manifold not verified for Evo IX?
  14. Turbo Guru's
  15. My 20G-6-9 = Dead
  16. 05 MR Stock only @ 10psi
  17. ATP 3071 whp
  18. Installed aftermarket parts and boost went down?
  19. Is it necessary to have the metal honeycomb inside the maf
  20. My Project (56k, make a sammich)
  21. Boost questions?
  22. NEED HELP!! fuel pump...
  23. Wastegate for 50 trim, need opinion
  24. Engine
  25. Clutch That Can Handle 600whp
  26. Does Intercooler effect AFR?
  27. Next Mod?
  28. How much whp can I get with my 3071
  29. 10+ hours of searching im now more confused (Best Clutch)
  30. Evo IX Compressor on Evo VIII Turbo???
  31. Are all 4G63 the same??
  32. 20G-9 5blade vs 6 blade vs STock JDM EVO IX MAGNESIUM TURBO
  33. Please Help, Walbro fuel pump Noise / BOV Flutter (Sputter) at low boost
  34. Evo randomly shutting off while driving
  35. Next Upgrade?
  36. homemade manifold?
  37. gapping
  38. forget the pop sound wtf happend thread
  39. Megan Racing Manifold Experience
  40. knock link controller?
  41. Engine power support;
  42. White smoke- PCV related?
  43. Read my spark plugs
  44. Who is running the AMS 50R turbo kit?
  45. Sputtering misfire problem? plugs?
  46. Why am I hearing my BOV (dumb question?!)
  47. New mod to my car 93oct 385hp
  48. Vishnu vs. Buschur April 25th??!!
  49. MBC all they way up and only 15lbs boost
  50. gt35r
  51. 2.0 vs 2.3 stoker
  52. New toys!!!!!
  53. what IF you skipped break in?
  54. MBC continued with pics
  55. Anybody near Ralegih NC done a clutch install??
  56. Car Wont Turn Over
  57. Car needed for fitment in Akron, OH
  58. DC manifold and tapping EGT sensor
  59. HELP! Super laggy stock turbo, 22psi @ 3800rpm
  60. Throttle seems sticky
  61. Any reviews or oponions of clutchnet clutches?
  62. dyno/tuned
  63. Driving my 900 WHP Evo 8 - Round 2
  64. checking spark on an evo
  65. Tranny help
  66. Is this engine knock? (video)
  67. Valves
  68. Northern Guys, AFR's Changing In Winter?
  69. injector upgrade necessary with EVO 20G-9 STG 2??
  70. Exedy Twin disk SD or HD?
  71. 20g-9 and Forge actuator.
  72. Evo 9 Oil Filter
  73. -PICS- I Modified my HKS RS intake again, Amazing results inside.
  74. Invidia G200
  75. Anyone running cam gears with 264/272 combo?
  76. Exedy Tripple Ceramic Clutch
  77. DOG BOX and AMS DRIVESHAFT
  78. I Want My Car Back
  79. O2 sensor
  80. This just in! (TRE Upgrades round 2)
  81. Why did my CV joint brake?
  82. My custom Upper IC pipe and Small Battery kit **PICS**
  83. Will I get more torque with 93+meth instead of 100 octane
  84. MBC w/o Reflash
  85. do you need a flash for a test pipe?
  86. boost creep on my 37r
  87. Instructions for Power Entreprises MBC
  88. 3" catback vs 2.75" catback?
  89. tbe = loss in power
  90. VE / BSFC / pressure loss
  91. Shep Stage1 T.C.
  92. anyone using a centerforce DF clutch in theyre evo
  93. black smoke after shifting at redline
  94. Just got Flashed
  95. Godspeed Intercooler... how good is it??
  96. 2800 miles on new IX.... clutch toast + warped flywheel?
  97. UR testpipe
  98. Help with removing front half shafts
  99. intake pipes that fit stock air box???
  100. Popped my motor..... maybe
  101. Injector harness/clip went bad
  102. Lifters ticking?
  103. Forced Performance Petition
  104. Please help with clutch install!!!!!
  105. Does an FMIC lean out the AFR?
  106. driving on a slipping clutch
  107. Ultimate Racing GT35R
  108. question about tial wastegate
  109. new clutch issue...
  110. Buschur 20G-9 vs HKS 2835R
  111. That's not good...
  112. Think She'll be fine for now?
  113. the biggest turbo to fit factory mani.
  114. I am newbie, but i really need help
  115. boost settings and weather
  116. intercooler piping
  117. ok here are some pics of MBC
  118. Something interesting in O2 housing
  119. Vishnu vs Buschur and Al.......I LOSE!!!
  120. Quest for 400whp
  121. testpipe?
  122. Jun 2.2 Stroker motor
  123. New Toys Showed Up!!!! **pics**
  124. firing order
  125. ACT HD Extreme plate - Act Flywheel
  126. Successes of EVO 8 @ Rally NY
  127. Getting locked out from 1st to 2nd gear
  128. Clutch Wouldn't grab on launch
  129. Where To Buy Nisei Lower Intercooler Pipe?
  130. GT3076R-12 vs -13
  131. Pink Gasket type liquid on Forge RS.
  132. Coming to the darkside..WRX-EVO..????
  133. 475hp 419 ft lbs @ 26psi GT3076R ***VIDEO***
  134. Flowmasters on a evo, anyone
  135. Possible exhaust leak?
  136. Just Another Yellow evo Part II
  137. Fuel pump kit...
  138. Injen Intake Question
  139. Hi definition compressor maps?
  140. Boost gauge install questions
  141. stock boost
  142. 2.75inch or 3inch DOWNPIPE
  143. ECUFlash for EVO, Subaru, 3rd Gen Eclipse
  144. Blitz DD BOV flange?
  145. Safe boost increase w/ race gas?
  146. SBR GT3076R turbo kit
  147. Problem starting the car... please help me out!
  148. Anyone running GT35R w/Koyo radiator?what fan are u using?
  149. 31 psi oil pressure???
  150. Is 0 psi possible?
  151. Post Your Dynojet Run Files
  152. 4g64 2.1L Build Up
  153. BG SynchroShift ok to use in 06 EVO IX MR Tranny?
  154. Best Turbo for 93 + alky
  155. HUUUUUUGE exhaust leak or much worse than that?? VIDEO INSIDE
  156. Stay stock plugs or go 1 or 2 step colder?
  157. Fastest spooling pump gas (big) turbo?
  158. electrical smell please help!!
  159. Bad idea to add exhaust after a custom flash?
  160. pop sound wtf happend
  161. Harmonic Balancers
  162. Question about Turbochargers.com
  163. transmission =[
  164. Tranny wont come out
  165. Engine stutters when I open the throttle 100%
  166. fuel pump...
  167. need help fast with fron o2 thats broken
  168. Will a 2.3 stroker pass emmisions?
  169. Possible ignition problem...help
  170. stock bumper lip...
  171. For those with an aftermarket intake, Easy mod, This helps alot!!
  172. Maximum AWHP limits of 2.3L, GT35R, HKS 280's, 93+Meth??
  173. Oil Change
  174. clutch stats
  175. Evo IX dyno pre and post exhaust
  176. Winpep 7.1.3 Dynojet Charts
  177. IX MR clutch seems diffrent now....
  178. New Dyno #
  179. Evo IX went to the dyno
  180. Good choice? BB 50 Trim, T3/T4, E cover, .86 A/R, 4-bolt....
  181. To build or not to build a custom turbo kit?
  182. Will a Forge WGA reduce Boost Taper?
  183. Stumped by screeching noise under load
  184. 03 w/27k miles grinding in 5th
  185. CBRD PROJECT MR exedy twin disk and new lines etc... pics
  186. Cosworth = Cometic (head gasket)
  187. CNC Machine work question
  188. what else might i need?
  189. Dyno #s on Tomei O2, DP, and Manifold!!
  190. safe to run?
  191. where to get a anti surge cover for my 35r.
  192. Coolant temperature sensor swap...
  193. ACD in 03 Evo???
  194. Water Injection Kit
  195. i did a pressure test....
  196. How to install a Greddy Type-S By Pass Valve
  197. installed megan cat-delete and cat-back
  198. Why should anyone upgrade turbos?
  199. too much stagger for ACD
  200. Looking to get flashed...but not tuned
  201. 2nd Dyno day at BR
  202. Fuel Cut at 18psi?!?
  203. buddy club pro spec exhaust!!
  204. Spoolup question?
  205. Exedy Twin Disk HD Install Question
  206. Technical question: Turbo exhaust iris
  207. Licp question??
  208. Wastegate Problems
  209. EVO VIII stock fuel pressure
  210. SARD HF cat installed
  211. Which aftermarket manifold with T3/T4 flange to choose?
  212. GT30r ETs?? MPH?? WHP?? please
  213. Ported Turbo Manifold
  214. just removing my heat sheild
  215. Turbo experts please look
  216. help please evo boosting only 11-12 lbs
  217. Evo 8 Stage IV IX20G vs. Evo IX Stage I = both are 11.6 ?
  218. Does anyone have....??
  219. Clutch Install...
  220. Minor boost issue.
  221. New Manifold, New Gaskets??
  222. Slowboy racing intercooler fitment?
  223. Forge MBC problem.....
  224. 20g-9+2.3l stroker+Nitrous?
  225. Piston specs
  226. Will they hold?
  227. boost issue's with the 35R
  228. All you ever wanted to know about Evo gearing and gear speeds
  229. exhaust leak
  230. Boost question
  231. Evo 9 turbo....or.....TME?
  232. Cam timing theory?
  233. What size injectors for GT35R?
  234. Sunoco alky?
  235. 10.5 vs. tme w/10.5 help
  236. Exedy D-Core
  237. Sudden Intake Noise Decrease
  238. Why change pistons?
  239. boost help
  240. 544hp Stock Ecu
  241. Thermal Research Exhaust, Anyone have one? Input?
  242. Broken SPEC clutch pics
  243. I just broke my T/C and Transmission (Lots of pics)
  244. MBC pics....?
  245. SAYC In 06 IX Help
  246. My setup.. Need advice
  247. Clutch Master Cylinder Help
  248. Evo IX clutch issues
  249. Boost drop after fmic install
  250. Having a boost Problem give me a hand please =(
