View Full Version : Evo Engine / Turbo / Drivetrain
  1. Works Power Performance T4 Manifold
  2. common engine failures poll
  3. Anyone had their crank angle sensor fail as yet?
  4. Alcohol Locked
  5. utt ohh freeze plug
  6. Clutch question?
  7. Need new Flywheel Bolts
  8. IC bottle relocating help please....
  9. High Pitched Whine
  10. black inside the plenum
  11. manifolds that fit into the cusco heat sheild =)
  12. Anyone buy from here?
  13. 350 whp on stock turbo possible?
  14. hELp!!
  15. Boosting 12lbs.....??
  16. Evo VII Boost !!
  17. Swapping in the evo 9 engine in a 8!
  18. Evo 9 vs Evo 8
  19. Swapping from 30r to 35r
  20. How do you check for exhaust leak?
  21. Buschur cat back Vs Greddy Evo 2 cat back?
  22. Coolant Hoses - Trouble
  23. nos evo dyno vid. This normal? (MERGED)
  24. issues after 10.5 hotside, o2 housing, ic piping install
  25. Manifold for GT30/evo6
  26. EVO7 OverHeating Problem
  27. Parts and Performance Review: Buschur ported manifold, 10.5 Hotside, and Ebay 02
  28. Dynoflash my IX
  29. Throttle Body Coolant Bypass - Trouble
  30. Over Boosting.!! Why??
  31. My bolt-on turbo that I KNOW is worth the $$
  32. 20g-9-5 guys...need some help with boost
  33. Pics of my cracked piston
  34. Hondata Heatshield
  35. Has anyone tried those $199 Ebay TBE's?
  36. Evo 8-9.8 vs Evo 9 turbo Dyno results
  37. Installed a IX turbo on my VIII
  38. Stock motors
  39. My New Toys: RNR GT40 KIT/2.3L Parts, Pics
  40. pressure regulator
  41. syncro??
  42. Sputtering
  43. LPG Direct Injection
  44. Timing belt tensioner??
  45. Buschur Parts Just arrived **pics** inside :-)
  46. new toy COSWORTH cylinder head
  47. DC Sport Downpipe
  48. breaking up!! (not w/ my girl)
  49. please help
  50. Garret GT2871R
  51. Turbular Manifolds, Daily Driving, and Rain
  52. Please ID these two turbos
  53. The time has finally come...
  54. long startup cranking time...
  55. Another IX Dyno (Baseline) .. have some questions.
  56. HKS 264 Cam Timing
  57. Couldn't Find For Ix Intake !!!
  58. Will I need a retune for AMS LICP & Works Drop in?
  59. Engine Service Soon O2 code with HFC
  60. Just dynod car 2005 evo!!
  61. New IX MR, thoughts on these mods?
  62. CEL/SES Code P0138
  63. Boost
  64. Buschur Racing tunes 3065 turbo kit....on race gas
  65. i have a lame ?
  66. Comp Cams 280
  67. ix only need exhaust cam????
  68. How much boost.. big turbo, pump gas?
  69. High engagement point on pedal with ACT clutch!!!
  70. 4G6-MIVEC Valve Clearance Adjustment
  71. Walbro 265 Fuel Pump Installed **PICS**
  72. Which manifold Dnp or dc sports?
  73. More Power EVO exhaust
  74. How clean - cam install
  75. Lose of power after o2 housing/header install
  76. MBC and constant elevation change...yes or no?
  77. 2k to spend on 2005 evo what next?
  78. Greddy AFR warning memory guage
  79. dc sports exhaust
  80. 13k miles and f***ed up clutch
  81. Turbo Gurus Please Read
  82. Evo VIII Oil filter
  83. how to dyno on a two wheel dyno?
  84. Thinking about buying the white rabbit turbo?
  85. Alignment on the Balance Shaft belt.
  86. Invidia Cast O2 Housing (pics)
  87. which is better 272in/264ex or 264in/272ex?
  88. 700whp EVO 8
  89. E85 Ethanol in a WRX. Good INFO for EVO?
  90. Just Dyno'd and Also a Few Questions
  91. 9 engine
  92. Oil pressure dipping?
  93. Elbow Racing Intake Manifold
  94. Anyone here used a "Cutout"
  95. Rear Axels
  96. Mostly stock with Boost drop problem
  97. Wheres the tranny fluid plugs and how many quarts is it?
  98. More Boost issues for me.... help if you can im lost.
  99. TME and E IX compressor maps/ flow#'s?
  100. Evo build!
  101. New IX. Boost gauge installed. Few questions re: boost.
  102. whats my problem?
  103. New Advanced Tuner Forum Announced!
  104. Big Al's next trip to Buschur Racing May 19 & 20
  105. Love Fab Evo Manifold...
  106. Cam gear settings with GSC 272s
  107. ATTN: RNR Racing
  108. Just cams and fuel pump
  109. anyone running a 2.3 stroker from buschur
  110. Good old P0401 won't go away.
  111. Conclusion to blown turbo
  112. O2 housing question
  113. New Dyno #'s with CAMS
  114. 272's or 280's?
  115. Cel from test-pipe Gruppe-s
  116. Dynopack dyno compared to other dynos
  117. Undercar photos of my sidepipe!
  118. hks cam valve events
  119. ACD Reflash ????
  120. If the Evos TC is weaksauce, then whats the options?
  121. Cosworth M2 High Lift Cam Specs
  122. Help me with my times and mods
  123. Turbo upgrade?
  124. should I change my sparkplugs at every oil change interval on my EVO??
  125. 174mph Data Log - Do I need a new FMIC?
  126. IX Decel Whine
  127. my 3rd gear problem
  128. Can you run a wastegated manifold on an internal turbo?
  129. Front Diff broken?
  130. Decel Noise
  131. Who wants a turbo that spools faster than stock but with more top end?
  132. need to change throw out bearing on clutch install?
  133. driving without a cam cover?
  134. To Sequential or not
  135. 680 injectors Drivability
  136. Manual Boost Controller : yes or no?
  137. srock intake for sale?
  138. Question about O2 fixes for test pipes
  139. Help Diagnose my Idle Problem
  140. Driving with an Exedy twin...
  141. Cleaned maf (now runs like crap)
  142. Friends 03 dyno#s!!
  143. Really need some help after Cam install guys
  144. Major Major drivetrain issues, any help is more than apriciated
  145. What Is The Stock 03 EVO Fuel Pressure?
  146. turbonetics t3/to4b on an evo?
  147. BR8ES or BR8ES Solid?
  148. Can you run methanol injection without geting it tuned?
  149. HKS SSQ Recirculate
  150. problem bleeding clutch line
  151. Fuel Pump Options?
  152. Removing stock injectors on an 05 Evo?
  153. Spark Plugs and Wires??
  154. RM01A Review - No Dyno #s
  155. P0335 and P0340 Codes after cam install
  156. Cam ? (Noise depending on Cam Timing)
  157. i need help
  158. dnp Manifold how are they in the evo's?
  159. why aren't there many short shifters for the mr
  160. Does the Sard 280lph fuel pump work on Evos?
  161. boost leak??
  162. question about MBC and turbo wast gate actuator
  163. What cams to go with?
  164. clutch/ tranny noise? please help!
  165. caution when buying from one fab
  166. po 300 and slightly rough idle
  167. HFC with a catback
  168. Please Help
  169. idoling problem
  170. help me choose the cluth plz...
  171. Sandwich adaptor question
  172. LS 3" DP W/Flex,UR HFC and Apexi N1- will this work on EVO IX?
  173. JDM E9 RS bolt up to 04 E8?
  174. intake manifold
  175. Stock Evo Ix Mr Boost Questions!
  176. Intake problem
  177. boost problem
  178. Anybody have fitment issues with their (APS 3.5' TBE) on 03'-05' evo's?
  179. Buschur Racing ready to"Attack"
  180. Brand new IX leaks oil everywhere at 2k miles
  181. HKS hurry the hell up
  182. MAXED stock turbo pump gas
  183. The highest safe boost for evo
  184. forced performance cams
  185. HKS DLI II impact on coils
  186. Thank you Matt Gold
  187. intercooler question
  188. What's wrong with this picture?
  189. Oil Return Line, Need Help!
  190. HKS Valcon
  191. tap for water injection?
  192. help loud tranny noise
  193. Help needed...MR won't start
  194. Kaaz rear Diff
  195. bought some 264/272 cams...
  196. what size of flange should i use??
  197. What does it take to rev the evo over 8500 rpm?
  198. Putting in exedy twin hd, should i keep the restrictor pill?
  199. UR testpipe Bung
  200. New Cam Install. Difference in Pull.
  201. gas smell from exhaust? stalling after recirculating?
  202. Passes the Wife Test, thanks to David Buschur
  203. Cusco LSD's for IX
  204. Trapped 109 (almost) Next mod please!
  205. For people running 37R kits ?
  206. XS Engineering Power Pack Ignition Amp V2
  207. Coolant line washers part number
  208. Problem after the 1/4 mile! T-case???
  209. Another Stupid Exhaust Tread ... need some opions
  210. clutch wont disengauge!!!!!!
  211. Drivetrain issues - Help!
  212. trany fluid help plese
  213. Oil feed...-3 or -4?
  214. loud booming clunk on fast 1-2 shift
  215. LICP install ? on a IX MR
  216. Tanny problem
  217. aftermarket clutch issues
  218. Where is this oil leaking from (Pic)
  219. Oil Catch Can
  220. Valve question
  221. TBE + Down Pipes fit ix w/o heat tc/oil pan
  222. new clutch problem....
  223. 50 trim "custom" kit in the works....
  224. grindy fourth gear
  225. exedy twin plate clutch
  226. How many passes have you got on your trans?
  227. Injector question?
  228. Greddy 20g turbo kit info?
  229. Exhaust/DP Fitment on Evo IX
  230. Exhausts that don't hit driveshaft.
  231. Quiet Turbo Back Exhaust with no cat
  232. Boost- control + Blow-off valves
  233. "Crank Walk"
  234. what dealerships in mass are mod friendly?
  235. Time Attack, Black EVO, battery kits etc......
  236. Weird problem when raining...??
  237. Evo 9 and HKS 280 Cam
  238. ACPT carbon shaft
  239. Pulling the engine
  240. Dumb power question
  241. Cosworth Cam Specs Finally
  242. clutch slipping?
  243. P0304 Code on 06 MR, help please...
  244. CEL ... need some advice
  245. .82 a/r question with 3076R
  246. Manifold ? for GT turbo
  247. Open her up after 2k mile break in today and my new IX already broken ?
  248. emissions and cams....
  249. Noise on cornering
  250. Compression 101
