View Full Version : Evo Engine / Turbo / Drivetrain
  1. Installed clutch and now i cant boost.
  2. Part numbers to the 5th gear grind TSB-04-22-003REV
  3. Clutch is going but still works perfectly...should my gears lock out?
  4. What other options for getting cold air into our intakes? One of my ideas:
  5. Megan Catback Fitment Issues
  6. i need parts asap!! HELP!!
  7. another TC Whine noise question
  8. XS-POwer UICP fitment
  9. New Mitsubishi books are in and ready to ship.
  10. Who has the strongest stock turbo IX???
  11. Buschur pure power?
  12. Need some advice
  13. Injen FMIC VS Buschur FMIC
  14. Propeller Shaft boot broken :(
  15. Converting back to Pull style clutch(what parts!! HELP)
  16. Stock IX intercooler core size please
  17. axial supercharger amazing!
  18. 3" exhaust, open air filter, MBC, walbro, which are best and where to buy?
  19. Is my clutch shot?
  20. COP ignition
  21. Exedy Twin disc Vs. Single disc Question...
  22. injen intercooler
  23. 5 year smog.........LOL
  24. Do 03-04 axles fit 05's?
  25. I need pics of the Buschur intake installed - Please
  26. Cleaning up Titanium?
  27. whats better... 5 speed or 6 speed?
  28. Is SMC Good
  29. tme boost log in 3rd gear needed
  30. ACT clutch & gear lock in
  31. need help...
  32. Exhaust bolts???
  33. Mr Freeze injection kit
  34. Stainless steel cluchline
  35. Anyone have a Vibrant Cat-back?
  36. Stock clutch & Gear Lockout?
  37. ix turbo installed=>03 evo/comparsion(pic)
  38. Greddy V-spec Intercooler
  39. How much WHP with my mods ???
  40. RMR Turboback quesions
  41. Looking for a utec map!
  42. What are the steps?
  43. TC howling????
  44. o2 housing and port exhaust manifold
  45. People running 91 & Alky, come on in
  46. ARP head studs, is this the correct part?!?!?
  47. Anyone does OIL Change in MR by yourself? Q inside!
  48. Tranni removal tricks OMG????
  49. porting exhaust manifold and gasket matching
  50. 20g records, Stock Appearing Class etc.....
  51. 35R dyno results??
  52. c16 on 104 tune
  53. CEL Codes p0441 & p0452
  54. Need to adjust the clutch?
  55. new intercooler installed now a noise pleas help
  56. Quaife owners speak up
  57. transfer case
  58. pluging hole in intake for vta?
  59. push and pull clutch systems?
  60. TINY TINY CHIP on hks272 lobe.?
  61. Office Evo QTP Down pipe
  62. Hallman boost controler evolution and evolution rx
  63. evo8 tranny + t-case dimension?
  64. Stock turbo + Cosworth Head
  65. In the quest for a Road Race Turbo Kit
  66. apex cone filter
  67. Please Help
  68. My RnR gt37r project
  69. SBR gt-35r kit (why i dont need a gf)
  70. Oil Return Line leak
  71. EVO VIII boosting problem....
  72. Need a replacement diaphram for the Greddy Type-S
  73. stock injector leaking boost??
  74. cooked head repair
  75. Falling Out of 3rd Gear on Track
  76. Tanabe Concept Blue and cell fix?
  77. Octaine booster?
  78. What you think of the AMS UICP w/ tial bov
  79. ARC FMIC for IX?
  80. 110 to 93 on tune
  81. What should a properly tuned BOV sound like??
  82. stock ecu with 35r
  83. Any LICP Dyno gains?
  84. Any aftermarket turbos bolt on to stock hotside?
  85. FS: USED K&N DROP IN FILTER W/ LESS THAN 4500 MILES ON IT.
  86. Crank Pulley Issue
  87. question about evo 9 cams
  88. Is it Blown?
  89. hks RS or stock w/K&N drop in?
  90. Best clutch for daily driver EVO
  91. Buschur running 8.95 @ 163?
  92. Flash psi vs MBC psi
  93. super scared possible clutch problem!! help!
  94. Questions on upgrades...
  95. Changed transfer case oil yesterday - low initially? (little long)
  96. gearbox oil gl-4 75w-90 75w-85 or straight 90!
  97. car running very badly
  98. prolbem with AEM wideband air/fuel
  99. Samco hoses
  100. best bang for the buck mod
  101. Whistle while under boost?
  102. launch rev limiter
  103. Adjusting clutch. It adjusts PEDAL height ONLY?
  104. Need help, can't boost to 28
  105. plug gap quesiton
  106. just installed HKS 264/272...
  107. Stock Injector Fuel Pressure
  108. Clutch update.....I think I'm done with the Evo
  109. Tuning and break-in period.. what to do?
  110. I Need Help - Oil Light Flicking - Yes I Searched
  111. Purpose of Replacement?
  112. misfire and sputtering(i did search, just read)
  113. how much is too much on the stock turbo?
  114. ebay 02 and manifold!?
  115. Oil filter housing plug sizes
  116. EXO IX CAMS, Comparison questions
  117. intake part question
  118. Gas pedal adjustment
  119. Greddy Type-S lower vaccume port question
  120. Boost problem !!!
  121. Help on boost loss issue
  122. problem at WOT....?
  123. Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
  124. Opinions on Spec clutches
  125. greddy intercooler
  126. Hole in transfer case from exhaust...Help
  127. When should one upgrade the intercooler and radiator on a IX??
  128. Rs*R ExMag Downpipe
  129. valve clearance question (mivec)
  130. Pinks Evo!!!!!
  131. 20G Turbo
  132. Do revolvers only work on the east coast??
  133. Full Race Manifold stock manifold
  134. wierd gear grinding pattern
  135. overheating issue
  136. Am I getting screwed over?
  137. forge mbc with heavy spring?
  138. Tansfer Case Noise
  139. evo 9 cam??
  140. Stroker/35R cam choice?
  141. Clutch install ?
  142. Buschur Racing Raises the Bar.... A New Record has been set!
  143. Intakes on the IX
  144. has anyone ever use this clutch
  145. my 35r dynograph
  146. Which mod next?
  147. Prediction?
  148. bar and plate intercooler question
  149. sticky clutch pedal
  150. Air Research compressor maps
  151. evo ix intake cam
  152. Shimming JDM MR DV?
  153. Exhaust Question
  154. stock boost evo8
  155. Need Tune after raising the Boost?
  156. just installed tial race bov....
  157. fuel starvation prevention
  158. Rod bearings
  159. real boost pressure?
  160. Evo Cam Options?
  161. Thoughts on the tanabe medallion touring exhaust
  162. High octane leaded race gas?!?
  163. Best Way to make 30 whp
  164. Has anybody used the Gruppe-s Flywheel yet?
  165. Tomei Ehx. Mani - pictures
  166. New Clutch Questions
  167. Does B&B use Magnaflow mufflers?
  168. Is this normal after TBE install ?????
  169. hks ssqv problem
  170. Warrtalon Package
  171. My Evo Hiccuped today
  172. Blown turbo on a STOCK evo 9! Please Help! *pics inside*
  173. Sorry another engine noise question
  174. What threads are on Hallman MBC, 1/8 NPT?
  175. anyone w/AMS 3076R Turbo kit on thier IX
  176. evo 8 - no power
  177. 30r .63 and .82 actual comparison
  178. Help with flywheel autopsy
  179. No "balance-shafts" - Engineered 4G63 crankshaft.........??
  180. Can someone answer a rear diff question for me??
  181. 670 WHP/545ft/ib update 10.72@135mph
  182. A-Spec Titanium TP Review
  183. just installed 20g 9 5 overboosting?
  184. Not bad for ATP 3037s
  185. Whining issue
  186. MoTec - Mitsubishi Centre Diff Controller
  187. Eboost-2 ?
  188. Which part would you get?
  189. boost going up,down and up again
  190. Boost spazzing out
  191. Which clutch should I buy
  192. Oil question
  193. Is this Super AYC or a mechanical rear diff?
  194. Tough time shifting..... help
  195. Hi-Flow Cats causing CEL; solution?
  196. When spool-up matters
  197. exedy twin problem!!
  198. How Long Has Your Exedy Twin Plate Lasted?
  199. Stock Evo 8 16g or Evo 3 GT RRE B16g?
  200. Need Help: Installing Boost Lines To Tial Wastegate?????
  201. Clank when shifting from 2nd-3rd at low speed?
  202. questions about injectors/turbo/ic
  203. Boost spiking ?
  204. boost problem *need help*
  205. Did I MUFF up my car?
  206. Where do you get your tranny/diff fluids?
  207. Buschur bullet muffler and JDM rear ?
  208. Electronic Stethoscope For Knock Monitoring
  209. o2 housing now or wait for a hotside?
  210. Can AEM Serial gauge show EGT in over 1000c ?
  211. ISP turbo kit 537whp at 30 psi
  212. Is my car running lean?
  213. Is this correct for stock boost? (short vid link)
  214. TRE probably the most inconsiderate shop ever
  215. Invidia downpipe evo ix
  216. 2.4 block and Evo head?
  217. Vishnu or Buschur.... Decisions, decisions
  218. Cam Angle Sensor Gasket
  219. Who Sells a good head gasket for the IX
  220. Do EVO IX's regulate/stabilise oil pressure in head?
  221. Help on my JDM EVO7 Steptronic (pictures)
  222. Buschur GT3065 Review
  223. Throw out bearing stuff?
  224. A/F ratio under boost
  225. Anyone know this Cosworth Camshaft for EVO 9 ! *pic
  226. boost problme 05evo8
  227. Increasing down force?
  228. just got off the phone w/ mitsu
  229. Anyone have this "catch can" yet?
  230. found a walbro fuel pump in my spare parts box
  231. car not boosting
  232. Cosworth Head vs. Stock(EVO VIII)
  233. evo ix or tme turbo please help
  234. Strange stalling when raining
  235. How many miles has your stock clutch lasted?
  236. biggest turbo on stock flange?
  237. Check my setup..what else do I need?
  238. Ok, Had Enough, What Is This!
  239. Finally installed my Exedy Twin, w/ a couple of pics
  240. Problems with my intercooler piping!!!!
  241. Axle and Driveline Strength?
  242. just installed cams , gears and fuel pump
  243. Low Gas=Check Engine Light
  244. Intercooler piping question
  245. Where can i buy the....????
  246. 6 speed + non oem fluid = bye bye tranny
  247. Help! My RPMs are dropping at wot
  248. Does the Greddy Ti come with mounting hardware?
  249. Requesting a good engine pull writeup.
  250. Update..515 whp/362 ft bls, 93 octane alone........
