- ACD Upgrades
- Best place to buy Manley Spring & Retainer Kit?
- New act slipping ?
- Hooking up EBC to Tial Wastegate???
- Throw out bearing
- Which is better, ARC intake or HKS RS?
- 50/50 water meth injection power increase?
- my cam confusion...wtf
- What to plug the O2 sensor with on the midpipe with a evo 9????
- Retune needed with the addition of HKS DLI2???
- Suggestions on Intercooler for RoadRacing
- What typical psi drop occurs accross IC plumbing?
- UPS delivered this to me today...
- Tranny whining sounds?
- Stock turbo hybrid??
- APS Cold Air + IC Piping
- Reverse Gear issue HELP
- BJS Cylinderhead
- ignition problems anyone?
- Thoughts about running gsc 264s w/ 50 trim bb
- Question on cams : Brand & grind
- 2.3 stroker EVOs, what's your redline?
- APS EVO-8 330 HP bolt on system
- Rev Hard Turbo Manifold Mitsubishi Lancer Evo
- ACT OR TRANNY ?? What now!
- Next mod advise...
- APS cold air intake - ? replacement cone filters
- MR 9 best clutch for high hp? dailydriven
- Strange noise from turbo
- Installing wideband sensor in O2 sim elbow
- CUSCO Pressure plate Retainer Clip????
- Adjusting New Blitz SBC-i
- GT35R guys with 2.3L need your help
- BOV on t-case!?!?
- Not good crackling noise on occassion
- No more MR nice guy! Parts installed.
- t-case rattle, is this bad?
- *Please help* Loud whining sound from the rear
- Which brand of injectors to run?...
- second run out with the GT35R AMS kit
- Incredible gains on the dyno....Better look fourdoor Keith;)
- Turbine info
- P0300 code
- Buschur Vs. AMS Vs. RNR
- Stock BOV Fluttering around low boost levels???
- Tilton's in stock???
- EVO Throttle body question
- oil in cylinder
- Great Dyno Equalizer
- Driveline Lash...again
- - is it worth it to get these 2 items?.....
- What should I do next?
- walbro pump install question,,??
- LICP or Intercooler Hose Kits???
- Stinky
- cams and head gaskets
- Plug PCV and only use one Crankcase Ventilation hole?
- 2 clutches down...
- Tuning question
- what boost do you think?
- Dtec Bc Proa
- Whick manifold, stock ported buscher or megan racing?
- HKS Silent Hi-Power Review
- Im not happy with what i got. Long story bring someing to snack on.
- ACT Pressure plate Problems
- does the walbro fuel pump need an install kit?
- HELP front diff/TC problems
- Help me install my HKS twin power..having a little problem
- - 20G - TD05HR : Compressor wheel......found, available in the US ?
- axles stuck
- Weird boost spike
- 60K Mile Service / Headgasket Questions
- A/F/R after i installed my FMIC
- 2.5" better than 3" exhaust?
- Cant shift into gear when car is started
- polyurethane vs metal shifter bushing
- CEL after LICP install
- clutch going out?
- Mmmmmm... Toasty Clutch....
- Dual Port vs Single Port hot side
- Stock clutch chatter
- High Velocity Exhaust Jackets (Thermo-Tec)
- piggyback vs custom flash
- Quick question about a wideband 02 sensor?
- Which way to go
- Boost problem....need help
- My new Big Beauty
- which ebay exhaust is this, doesn't look like tsudo, or xs power.
- Under Drive Light Weight Pulley are GOOD
- Which turbo for 700awhp?
- Can you identify this mysteriuos turbo housing??
- Please help!!!
- Anyone else put a IX turbo on an 05?
- Revolver cams? Who has them?
- What is needed to rev IX past 8k rpm?
- Found a boost leak....need some help
- 1-3 19psi taper to 16 4th 20 psi
- What's the next best step?
- ? about the authority short shifter
- AC condenser removal help/suggestions needed.
- cam problem please help
- B&M Adj. Shifter
- need help
- How much power from muffler delete?
- True Mitsubishi TD06H-20g????
- Bolt-on turbo availability for IX owners...
- Do I need hangers for the HKS SS Exhaust???
- Video: HKS 280s + cutout idle.
- just got my comp 280s installed
- the 35R the 37R or 42???
- XS Engineering Lightweight Battery
- Stutter While Accelerating
- Cigaret lighter problem
- oil leak between the block and head
- SMC Alky trunk kit question
- Time for another round of... Guess... That.... Part...Number!!
- Eratic Idle after spark plug change...
- need pic of intercooling piping
- Shiftin w/out clutch
- Not runing stock maf sensor can i just put a filter right on the turbo?
- Max Psi On 91 Oct
- GSC Power-Division Evo 1-3 Cam Release Dyno Inside!!!!!
- tilton vs exedy twin
- Aftermarket Headers Stock Turbo
- Fresh install: Short wirte up on the Buschur 3065
- Intercooler Kit With Stock AIr Box ?
- WRC EVO race car crank (Pictures inside)
- FINAL 5 spd vs. 6 spd thread!!!
- Results! 16G/HKS 280's vs. Buschur 20G-9/Revolvers
- honing the block
- BR Alky Kit
- Popping sound when cold
- Effect of higher ethanol % on Evo?
- Out of fuel stock block still 562 Wheel
- HKS cams and HKS cam gears
- 272/264 v 264/272
- Anyone Have Headwork Done by EngineLogics?
- any good shops i southern ca
- Team Rip Engineering and Jon
- Rear O2 replacement?
- RnR HKS cat back review.
- What should my oil pressure be?
- Dc DP+Megan Catback problem
- Building the EVO 8 4G63 for road racing, big turbo, sustained WOT, high boost .....
- Diaqueen Super Multi Gear Oil
- clunk in rear end?
- Lets hear from those with ported intake and throttlebody!
- 35r and external wastegates.... let's chat.
- question about fuel pump
- HELP with turbo timer
- Colapsed Lifter
- How does Ecutek interface with MIVEC? I've got pressure problems
- need part #. turbo hoses to and from boost silonoid
- Okay so ive read some bad stuff about full race manifolds and downpipes...
- Down Pipe install quesion
- fist run out with the GT35R AMS kit
- EVO and turbo results 9.60 @ 150 mph!
- How much motor oil is PCV system (check vlv side) supposed to let by
- Tranny and t-case getting shipped to shep
- My is idle "RPM hunting"
- Noise normal idling in neutral clutch out?
- question about dynoflash
- Best place to buy exhaust gaskets
- wont go past 4000 in 4th gear
- crappy idle when AC is on
- Oil light flicker
- Moan/whine evo 8 03 tcase/tranny help
- Stock BOV Question
- turbo spool leak!!!
- Custom GT35R Kit - Pics + Dyno
- 4g63 'power Tr Unit'
- dog box
- Who has problems shifting with act 2900 streetdisk and whos is just fine.
- Different Clutch in IX?
- Why I loose boost at 3500 rpm ?
- Need help choosing a clutch...
- 2.3L Stroker Kit - 4G64 Crankshaft?
- Need help with Boost and EGT readings on a IX...
- BOV decision.
- hellp i need some help
- I have about 340whp. Wich is the proper clutch setup for me?
- Clutch problems?
- funny sound when WOT
- How much power will i get from this?
- Is this true about meth or alky? Life of fluid in tank, weird question
- evo 7 rear noise where from????
- 56,000 miles front axles slinging Grease....
- Tial Bov
- atp has a twin scroll 35r
- Need a clutch and suggestions!!!
- Think your speedo is accurate....
- My Car Died
- How many track days can you get on the stock clutch
- Clutch Engagement point higher after launch?
- Help w/ buschur race Ic please
- stainless exhaust housing
- question for PLX wideband users
- what do i need in order to achieve 350whp?
- Swapping from GT35 Platform to 20g
- HKS hybrid drop in filter vs stock
- tanabe super medalion... anyone have it?
- Yet another fluid thread!!!
- Where to re-build Exedy clutches!! Read this!
- The Best "50 trim" Ball Bearing Turbo Kit
- ARPs or with cams or not?
- HELP w/ MR reverse gear pop out
- 2-step builds boost?
- garret vs precision??
- Strange Engine Noise
- Tranny issues anyone?
- Crap..anyone with a tre rebuild help?
- HKS GD Clutch Max (Twin Disk) -- some pics and impressions
- Invidia O2 Housing Install - O2 Sensor Cable Problem
- crank no start
- 20g9 or 6.5 rs tme for Alky?
- Engine management question.... Megasquirt??
- what the difference between the hallman and the perrin mbc
- Pic request: o2 sensor wire on aftermarket exhaust
- Sound Question
- is this normal?
- What Im looking for in a turbo kit
- Taipan XP Exhaust Clips, Pics, Dynos!!!
- Strange vibration, exhaust or engine?
- HKS Exhaust Price drop
- BOV sound/vid clips?!?!?!
- Help for fuel system...
- AEM ignition amplifier NOT compatible with Evo
- Stock Boost Control Solenoid & Lines Ques.
- Ouch! 10.93 @123 EVO 9 in PR
- Some daytime pics of my new Defi Gauges
- Jdm MR deverter (bov)??
- Slave Cylinder Question
- Question after install of BR FMIC and intake
- Help! with warrenty, ACT clutch, and 4th to 5th gear syncro!
- Need help stat plz! Seeking Expert advice
- Stock turbo UPGRADE
- Pics of ams exhaust
- Dynoflash says Turbotrix 280 intake cam on my evo 9 caused low numbers after dynotune
- Avid full replacement mounts for 349$ shipped???
- boost prob on IX
- Finally Tuned and Dyno'd
- Evo 9 fuel pump
- gargiling sound
- POLL. My Ic pipe popped off
- Anyone with quick disconnect lines?
- Pulled my CEL... now what?
- ATP Turbo
- Need Major Assistance
- Evo IX Actuator that will hold 1.6bar...where can i get one?
- More Power Please!!!!!!!
