- Look at what I found in my UICP......
- Boost leak test help
- CEL problems
- Clutch fork springs
- Is this an evo trans?
- Burning oil after boost leak test! HELP
- ACT HDG6 - Multiple TOB Springs?
- Car diagnosis?? Please help
- Strange 1-2 Shift Issue
- I F up my motor lastnight's 1/8 mile race
- engine mounts
- DP and Brace Combo
- HTA 3582 oil feed line
- FP white vs. IX w/TME mag CW
- Anyone using a after market speedometer?
- in gear, car won't go past 2000 rpms
- O2 dump vs BR ss o2 housing
- Mystery cams? Please help.
- Is it bad to buy used Cams?
- QTP Downpipe Flange hitting driveshaft.
- BC 280 cams & stock TB VS kelford272 & boomba tb
- 550 WHP Fuel system
- 6 Pad solid hub or performance disc??
- 1000cc+ injector user's stock ECU
- Notes from my garage - Tbelt
- Would Cams do alot to my set up?
- Check engine light help!
- knocking?
- How do I get a bbk full turbo?
- 9.8 vs 10.5
- Turbo Rebuilders?
- help with hardwiring walbro
- timing belt ?
- Part Throttle Issues. Any help?
- Car running lean.
- Intake pipe, JM fab or Samco
- evo9 block with evo8 head
- Synchronic BOV Install
- Wheel bearing replacement?
- Stock '03 is going to AMS for a dyno tune.. Did I forget any of the bang4buck mods?..
- Exhaust Leak in the Head? HELP
- Speed sensor, bad idle???
- Best Tuner Shop in ARIZONA?
- Evo 8 Longblock Weight..
- FP give info on the new HTA green, we pump people need it
- What companies make intake manifold gaskets?
- Evo IX trans manual
- need radiator
- strange noise....helpppp
- 3'' HKS hi power exhaust
- 1,2,3, and 4th gear synchro's and sliders...is that supposed to look like that?
- Subframe studs broke?
- Engine build finally complete, yeah.
- Wheel bearing or front axle?
- how to tighten timing belt tensioner pulley?
- Full-Race Twinscroll 35R + AMS 2.3L + GBR Race Team Build = FAT powerband
- Car dying with new walbro 255
- Clutch rattles on Deceleration?
- What kind of gains?
- Head work
- Reason for the new FP oil line for EVO's
- Cam upgrade
- First time replacing clutch...
- whats wrong with my evo?
- need help fast
- Control Module for ACD
- tcase fluid change help
- Trouble bleeding clutch
- Quaife ABT Differential Front
- Best way to access bottom of condenser fan - Help!
- Project Buschur double Magnaflow Quiet Exhaust
- Resonator
- dc sports downpipe questions
- lagging? or what
- trying to find out what cams??
- evo 6 speed and gt3240?
- K&n drop in or cone filter ??????
- Building the CT9A 4g63 Evo Engine by TTP-Engineering
- Evo 9 6 speed??
- cuttin out
- 02 housing which one for 06 mr ?
- ignition wont unlock
- mystery problem! help diagnose
- advice needed: something dropped in valve port
- whp number questions after a tune on 05 rs
- AMS 2.3 Stroker sounds like a desiel...
- Fuel system
- Anyone have a PTE billet 6765 in stock?
- P0300 on my IX - 33k
- Building a better/mongrel turbo at guv-ment cheese prices...
- OEM Pins
- What the heck is this pipe?
- What are these parts? Removed from 06 IX
- 8 turbo to 9 turbo HELP!!!
- Milky Oil in Catch Can
- iac troubleshooting in my idle freak evo
- Car running on 3 cilinders, urgent help please
- ACT 6 Puck?
- Will a MAF from a 96 3000GT VR4 work on an EVO IX
- Exhaust Manifold XS Power VS. Megan???
- Can the EPM O2 Housing fit with the ETS V2 LICP??
- Strange Tranny Noise after Clutch Install
- Catch Can Help
- Loose Injectors
- Lower vacuum after switching to a different BOV?
- How reliable is the 2.3 vs a 2.0
- It does this?
- best turbo
- Urgent: Car dies when clutch is engaged
- Defi boost gauge in IX MR - question
- Will the HKS suction intake fit 3" or 4" turbo inlets?
- any good shops in CHI area
- anyone making power on a stock catalytic converter
- Serpentine Belt Tensioning: How?
- Clutch chatter more so now then before
- BBK Owners: Anyone running an upgraded WGA?
- Hks mbc?
- Robert @ Forced Performance
- Max boost for AVC-R
- Thermostat question
- Opinion on a flywheel
- question about oem tranny, tcase, rear diff fluid
- SPEC Twin Clutch for 2003s?
- Whoops! (Timing Belt)
- oh my CAT!
- "Upgrade" from Injen LICP
- Is the Mini battery strong enough in the Northern States?
- ACT pressure plate help
- Outlet Pipe
- TCASE pulled for the 3rd time, all seals replaced..STILL LEAKING....WTF!! (PICS)
- ETS front mount intercooler
- turbotrix busts out an 8
- CBRD radiator with slim fan owners, question about fan wires
- AMS 4G63 Race Balance Shaft Eliminator Kit
- OMG My engine!?
- ACT, you suck
- cracked exhaust manifold
- New Radiator being built: NEED Aeroquip, Goodyear Radiator hoses....where can I buy??
- FP 25psi Wastegate, Spike?
- innovative lc-1 help plz~!
- HTA3076R installed... can I safetly boost to 13psi?
- boomba inline manual boost controller
- Does anyone have an ARC oil catch can installed in their car? Please help.
- Spark Plug Ceramic Broke Off
- HELP! fuel pressure sensor leaking
- Boost spike after turbo, TBE and O2 Housing?
- Oil treatments??
- K&n intake or drope in not sure which?
- HKS twin plate clutch
- Greddy type S BOV top nipple
- Help, over oiled K&N air filter!
- Evo 3, Cracked Ring Lands - Need Pistons
- idle
- brian crower springs and retainers
- Rattling coming from my engine
- I'm getting tire of my evo......
- brakes when you have aftermarket cams?
- Funky smell after replacing wedge clip??
- What Tranney Fluid do you use?
- Starter go bad?
- For same price - AMS 3.6" vs ETS 4.0" IC
- Tuned stock MAF pipe vs Tuned 3" MAF pipe?
- ACD Problem!
- Will myu running HKS 280s on my 05 EVO VIII cause a CEL on the stock ECU?
- Can anyone reach TRE for me?
- To wrap or not to wrap?
- Stock Rear o2 Sensor. WHERE DOES IT GO
- Stalling turbo
- Coolant temp gauge?? goin crazy
- whats are these for? (relays?)
- Signifigance of 15psi stock 8 turbo?
- Phelonic Thermal Intake Gasket??
- Boost / throttle problem
- oil pump walked in housing
- VIII going to green
- rear diff going bad?
- snapped a headstud...
- Where are the AMSoil dealers?
- Looking for Wavy Rings/Washers for Exedy twin mod, anyone have them?
- evo 8 bellhousing bolt pattern?
- I need an o2 housing
- Managing boost pressure -- issues and options
- what do i need to do to fit a evo 8 turbo onto my 95 gsx?
- Help finding partnr on seal.
- Clutch failure , act MB7-XTG6
- Turbo gasket question. help, quick question
- boost leak test questions
- Fuel Guage ??
- Help with wiring in a evo 8
- Rear diff noise
- Timing belt rubs on the crank sensor blade?
- rpm's reving in gear
- removing stock turbo manifold?
- Ebay Intercoolers and piping
- upper I/C pipe P!$$!n6 me off!!!!
- mystery: drivetrain vibration! suggestions?
- Evo IX Idle Issues, Overseas HELP!
- What would you guys do?
- HKS 272 and 280 Exhaust cam lift
- Denso fuel Injectors leaking
- Professional and experience input needed. FPred vs. 50-trim.
- Knock Sensor Location ?
- No power to fuel pump and I think the rel
- MDC Install
- Hallman MBC doesnt hold?
- weird noise at 4500 rpm
- Timing issues
- gaskets?
- tanny problems
- only have 10psi anyony know wats wrong
- hey guys need advice on cams
- TB Idle screw air leak
- Crankshaft K1 or OEM ???
- turboXS tbe install/ problems with brace
- Help: Melting Catalytic Converters and More!!
- Car starting issues. Engine flooding maybe?
- Shep trans/ F 4.3
- Anyone watch their IAT's?
- AMS 1000 HP Fuel System installed and now fuel pump wont turn on, what could it be
- EVO OBD-II Code List
- Lightest Exhaust
- oil leak dripping onto downpipe
- clutch gets stuck..
- Need your help! Please!
- Coolant - What Are You Using?
- New FMIC worth the money???
- If you have a Turbo Kit & A drivers side fan this thread is for you
- gt35r t3 or t4
- People with Buschur UICP and intercooler. What size T-bolt clamps???
- Exedy twin disk issue
- FPred tried to eat my honeycomb
- Help Question: Evo ACD lights all on. Wheel speed sensor??
- Modifed stock intake manifold
- Help identify these evo 8 cams!
- Help...Forward O2 Sensor removal/replacement
- turbo temp
- Cel p0137
- Service Engine Soon with AEM?
- Stock Turbo, Max PSI/Boost?
- Anyone using the Dejon Intake tube for Evo
- Do I need a fuel pump?
- camgear question
- stutter at wot?
- Are the VIII & IX head gaskets the same?
- how to read Check Engine Light
- Upgrading help
- Boost control question.
- Profec B spec II High Boost
- TOB clicking when clutch ingaged
- evo 8 turbo full bolt ons
