- Where to find Injen coupler?
- what clutch should I get?
- Can you replace the fuel feed line?
- Evo IX staying basically stock, best bang for the buck?
- MR Tranny takes 2.3 quarts... right?
- whats the exhaust temp....
- Any way to mount "normal" battery?
- Tranny help. Instant help needed!!!
- intercooler piping
- Best place to get my cams
- Surging issue
- anything i should do b4 long trip
- grinding gears
- Octane booster: which ?
- 03 vs 05
- Help!!! Engine Won't Start
- Lessons learned ~ 2.3 stroker w/ stock turbo
- please help with intercooler kit?????
- sliping clutch
- Tilton + TRE tranny & Ralliart LSD
- Best Turbo for....
- injector size???
- Help!! Engine hesitate and misfire
- Best intake manifold
- Odd Drivetrain Whine...
- 3065 lb/min ???
- Aftermarket Fuel Rails: Perrin vs. Agency Power?
- Exhaust pops
- Evo IX BOV question again...
- UICP Qs...
- FIC Injectors 850cc help with install??
- Oil Change today, good info
- Turbo back exhaust??
- Disappointed with agency power bov...
- Stock IC Sprayer
- Lower Your intercooler temps
- Big thanks to Greg@GSC!
- Q on long block and short block
- PrecisionTurbo 680cc Injectors
- Disadvantages of using an Electronic Boost Controller
- Forced Performance(FP) HP Wastegate Actuator opinions
- Why no SC61?
- Big gains from fairly minor parts changes at Buschur Racing...
- Red dust on clutch pressure plate? Could this be bad?
- POS BOV?? Need help!
- mobil 1 vs. mobil 1
- blow by after break-in.....
- Cusco twin plate clutch arrived..pics
- 450 to spend what do i buy??
- need help my clutch has went out? need some advice
- Emergency Help Please!!!!!!!!!!!!
- forge mbc and spiking issue
- Walbro Woes...
- Any easy way to tell?
- Tial Wastegate gasket fried!
- help with afr!
- 600whp with 35R and stock intake manifold?
- Evo IX turbine
- DynoDynamics
- What size fuse is used on the battery terminal connector?
- 264/272 cams=louder exhaust?
- Simple question: negative terminal cable gauge thickness, anyone?
- NOS Single Fogger Wet EFI System - Jet Sizes?
- Custom Flash vs. SAFC-II tune, your experience
- Is it just me or..........(long)
- What is better big turbo or smaller turbo and stroke
- cam smog legal for CA
- clutch and tranny
- Evo's with aftermarket o2 housings, roll call
- Bushar race FMIC
- Boosting 28psi on pump gas
- Catch can question
- hks cams
- Boost leak test.
- o2 housing testing????????
- nitrous users??
- Warralton, pressure tester questions...
- Who sells valve covers?
- Stores In Anaheim: I Need Hks Cams!!!
- engien wire harness removal
- Help me chose the parts
- im new and need some help
- speed sensor
- Turbo "Studdering"
- minimal budget: cat-back or metal substrate HFC?
- No cat, anyone ever get caught?
- High flow cat for evo ix mr?
- intake manifold
- Car Acting Funny Help Would Be Appreciated
- any how to's on water injection kit
- Exedy Twin HD Comes With Alignment Tool??
- What should i do next??
- Throwing Code P0403: EGR Circuit Malfunction
- Calling Warrtalon or anyone who knows what there doing, Plug question
- Big mores .....weak ???
- What Turboback Exhaust are you running on your IX?
- Trim....turbines that is
- oil consumption in a stroker
- Magnaflow Ti vs. JIC Ti
- Centerforce clutches. Anyone actually using them?
- problems with new exedy single plate
- Cusco oil catch tank & Royal Purple gear oils
- Problem After 4th Gear Run !!!
- 2.3L stroker hp gain?
- competition clutch brand
- Strange Idle Activity [Video]
- To coat, or not to coat.... the test pipe?!
- Stock Ported O2 Housing WHP VS Aftermarket O2 Housing WHP
- AMS Stroker/AMS Meth/Hks 280's/TME turbo review.
- Does an air intake have any long term effect on the engine?
- Just got my 6-puck installed
- Evo IX 5 speed vs. Evo MR 6 speed
- cam question
- New intake question
- 02 Sim Install questions
- Question About Forge MBC
- MR trans suck when cold
- figured i would post this here to for any help
- Slowboy Intercooler?
- HKS cams vs. CROWER cams???
- BOV Question
- could my tranny be doomed :(?
- Greddy Type RS One Spring od
- Help On Bov ...
- more power for under 1.5k
- Best set up for cam gears & 280's
- Tranny making noise
- After WOT acceleration RPM dip to 200, norm?
- just installed Buschur Stage 1 on my IX...
- Turbo Timer
- Axles giving me a hard time
- Leaky APS BOV.. pics
- evo IX MR on AEM EMS w/ GT40R ? yep we did it
- what size injectors for a 35r turbo kit
- latest dyno figures modded evo 8 stock turbo
- wierd winding sound from rear diff.
- Greddy Evo2
- greddy wastegate
- Agency Power Front Motor Mount
- tanabe exhaust?
- HELP....tryin to install my Evo 2 exhaust and I can't get the midpipe bolts......
- Tuning in Europe
- When am I going to max out the potential of my IX's turbo??
- GT3071 Turbo Kit questions
- Weird Idle
- What Next???
- Sport muffler shop exhaust system?
- Biggest turbo kit w/ stock heat shield
- Aftermarket Exhaust Manifold
- Starting to hear WG flapping sound: OK?
- How many of you are running inline oil filter to your ball bearing turbo?
- Another cracked manifold
- Any danger in buying used cams
- Turbo question...
- 4g63 Mivec
- Need Shop Near Me For Clutch Installed...
- Why did prices for HKS Cams and Cam Gears up?
- new clutch i found!!!
- AMS Intake Issues
- C-16 vs. VP Import???
- How I Fixed my flutter / sputter at low boost
- Intercooler pipe?
- FMY: comp ported shroud but still surging...
- what do you guys think about this dump pipe
- Funny Story
- I need some help!!!
- WTB: Tilton Cerametalic Clutch
- Tuning.....Alky + Race Gas?
- My Peak boost gt35r 557.8 whp on methanol, tuned by Sean Galzer
- GSC Power-Division EVO 9 Cams
- Turbo Upgrade
- Engine setup in this video of AMS Evo?
- Aftermarket O2 Housing and Gaskets
- Should I downgrade from my HKS EVC 5 to a Hallman MBC???
- Help !!!!!
- Zeithronix working great. Home tuner types check my log. Hows it looking????
- Coolant Leak
- GSC Cams fitted and 10.5mr housing.
- P0420 code.....possible causes?
- Tanabe medalion touring
- next mod?
- Evo 9 turbo?
- can aftermarket licp cause boost spikes?
- Just a few quick questions ...
- Has anybody change there alternator yet.
- Garrett GT35R that bolts to stock manifold.
- Best turbo for torque
- Hks 272 cams
- HKS parts for sell
- Stock Airbox into Custom Heat Shield???
- what are signs of bad/going bad O2 sensor
- Project evo MR... mani pics
- My new Coil-on-Plug set-up.....
- Tilton Twin Disc/Hyrdaulic t/o bearing/Clutch Experts, Help diagnose w/ Ideas
- HKS RS intake causes SES light?
- Zeitronixs issues, not working, help!!!
- locate carrier bearing heat shield IX
- water pump questions
- Looking for an rs rear diff.
- BR performance package
- 2.3 w/ 20G HELP.
- evo 8 vs 9 int. man. diff.
- Quick oil Question
- Ideal gap for spark plugs running 23psi?
- Stupid Boost question ..
- nitrous and plugs
- FS: Turboxs Catback
- need help bad
- Buschur intake kit vs K&N TYPHOON intake(LOL)
- Will Megan Racing TBE fit a new IX ? ? ?
- lanuching car problem plz help!!
- Best 750cc injectors to run off of stock ecu??
- water shoots out of coolant reservior tank
- Just ordered a Greddy EVO2 for my Evo 9...what to plug the O2 sensor with?????
- Question about mods with stock turbo
- Problem starting when engine hot??
- Cosworth head and cams
- 280's and starting
- JunBL Exhaust Install and Review
- spun rod bearing in buschur motor
- Tranny Issues...adjust clutch rod?
- Recommended auxillary gauges...
- Tomei BOV
- Thinking about doing 2.3L
- Fuel injector clinic injectors okay for stock ecu?
- hks cams, question
- do afr's lean out when...?
- what is max hp for walbro on stock fuel lines
- ble lifters anybody using them
- 2.3l stroker kit---vs---2.3l short block
- exhaust manifold leak
- arp head studs
- what will I need??
- Are O2 sensor sockets universal?
- gear oil choices
- HKS final drive gears 122mph 4th gear @7000rpm
- OEM clutch question
- shifting problem please help!!!!
- Dragtime & whp 2.0vs2.3
- what clutch to get?
- Can the manifold and hotside come out as one unit with ebay o2?
- 2.0 or 2.3 for highway runs?
- resonated test pipe vs test pipe (HP difference)
- rpm problem! please help!!
- Strange (possible) leak from t-case..
- 05 T-case
- Throw out bearing issue
- FMIC Question
- GREDDY fmic problems
- Disappointed with TIAL BOV
