View Full Version : Evo Engine / Turbo / Drivetrain
  1. Blown Headgasket?
  2. Where to buy Diaqueen and BG synchroshift
  3. How Much Boost can my stock motor handle
  4. exedy twin not making noise anymore?
  5. Full boost at a higher altitude???
  6. hand brake center diff disconnect
  7. max psi for IX diverter valve
  8. 8 psi max on a stock ix!
  9. bolt-on GT35R turbo for Evo's...
  10. buddies bran new evo ix with "service engine light" with only 27 miles????
  11. Englishtown Summer Slam Race; 9.8 @148 in qualifing
  12. Speed Element / Full-Race GT35R 91 OCTANE DYNO
  13. Need Injector help FAST!
  14. MAF question
  15. Question about BOV!
  16. A stupid freakin question.
  17. Sputtering/Fuel Cut at 23PSI
  18. EVO 8 Repair Manual. (search down for me )
  19. 60,000 miles timing belt time! Advantages and Disadvantages to a OE belt?
  20. just installed new oem clutch...?....
  21. po11, oh man
  22. Cam Install... 2 quick questions
  23. Grounding Kit Results
  24. People in mass with upgraded turbos?
  25. Test pipe AFR
  26. Front 02 sensor shot?
  27. DSport Magazine Feature car search
  28. 03 owners, I could use some help
  29. Greddy Profec B Spec II Pressure Sensor Test
  30. mivec head on evo viii?
  31. Who's running Jun 272's?
  32. Dynojet run fie
  33. Air Conditioner = Cooler Coolant temp
  34. Dyno results PeakBoost 3076 Dyno4mance
  35. Stock 2005 EVO MR clutch question
  36. dry nitrous users
  37. REV To 9 Grand
  38. Has ANYONE had this problem" drivetrain/driveshaft"
  39. co2 i/c
  40. Tanabe Concept G - Pass Beer Can Test???
  41. Less boost taper after intake install
  42. IC Hardpipes?
  43. Form Works cams to FPC300... Over 30% increase in TQ
  44. Fuel filter?
  45. axle is busted
  46. Damn, 1800 miles and clutch wont hold a launch..
  47. Cams and Headgasket
  48. Ix Turbo
  49. boost spuddering problem
  50. exedy clutch question...
  51. remove mivec?
  52. exhaust question
  53. A little idea floating around my noggin..
  54. what time woudl a wrx run with these mods?
  55. Ultimate Racing Licp
  56. New plugs making car run lean?
  57. Back to back testing of Invidia, Ebay and Works 02 housings......
  58. wastegate solenoid
  59. HELP BOOST LEAK testing
  60. engine coming out next week!
  61. Exedy twin howl/whine when clutch engages
  62. Tanabe Medalion Touring Exhaust ::JawDrop::
  63. Possible Transmission Problems
  64. motor swap
  65. Better location for wideband 02 sensor...Pics provided
  66. Full short shifter linkage
  67. exedy twin disc
  68. boost LEAKS and aps bov people all help please
  69. Evo 9 Spark plugs
  70. hks 272/272 cam setting
  71. Silly question
  72. Exhaust header with wastegate off let
  73. car making low power : help plz
  74. Who running a HPF FMIC?
  75. Does any one build custom turbos?
  76. Battery Relocation
  77. BOV question
  78. Boosting problem
  79. leaking head...I think I can live with it.
  80. 60 on IX
  81. 2.1L from SBR arrived...Pics
  82. Which o2 housing and throttle body?
  83. Going with a GT30R on my evo...
  84. Engine Bog/Sputtering
  85. Exedy Twin Plate HD set-up?
  86. 421 Horsepower 91 Octane w/ Meth **Full Function Turbo Kit**
  87. buschur front motor mount installed
  88. TurboXS FMIC Review
  89. A little BOV experiment, feedback/answers please....
  90. How much whine is too much whine when it comes to the TC?
  91. Cam choice
  92. normal tranny noises?<--new IX owner
  93. Are the pedal stops for the tilton available yet?
  94. 5k and 10k?
  95. hmmm question...
  96. Buschur Racing Deluxe FMIC on EVO IX MR, Two thumbs up!!
  97. blown engine
  98. can't go WOT!!!!
  99. oh what to do??
  100. Hi Performance clutches....
  101. Where to get a block?
  102. Fuel injector Physicists, please help!! inj. question.
  103. AMS LICP vs EBAY LICP
  104. What does this mean?
  105. Flywheel resurfacing? what are my options?
  106. codes
  107. *HELP* Detailed write up on problems!
  108. which clutch/ differences???
  109. O2 housing - (Invidia vs. helix vs. ebay)
  110. *HELP* Boost Problem
  111. What happened??
  112. injen UICP and BR hardpipe intake
  113. 10.5 hotside w/ o2 housing
  114. Good turbo w/o sacrificing spool
  115. Aquamist 2d water injection
  116. Quick Question on Shaft Play
  117. -4/-1 or -2/+1 cam timing? Same LSA. What will be different?
  118. Q on HKS RS intake
  119. my new setup decission 20g...
  120. egt probe,best place to put it?
  121. So how loud is this new Tanabe G blue exhaust?
  122. EVO IX 20G Stage II Ti/Al setup Turbo
  123. car not boosting..what can I check for?
  124. Intercooler holes and intake holes
  125. Do all 2005 Evos have the 10.5 hotside?
  126. boost problem found
  127. help installing hallman mbc
  128. Stud install causing gasket leak
  129. **PROBLEM: Greddy V Spec FMIC
  130. gt35r+meth aem tuned dyno #s
  131. An interesting question on Stock inj/alky/2.3
  132. po420 code *no exhaust work
  133. At what RPM's do you reach full boost??
  134. Has Anyone Tried a Precision SC34 Turbo?
  135. My car keeps dying on me??
  136. Cams and Fuel Pump ?
  137. O2 Housing hp gain?
  138. Want a nice aftermarket turbo that's not too bad on lag? Consider a Garrett 3071
  139. Tuning experts, help. fuel issue/question
  140. Timeing Belt Replacement
  141. Exedy twin disc exploded view???
  142. wastegate actuator ristrictor size?
  143. Speed Element's DIY FR install phase 2
  144. Engine wont start
  145. Evo ECU Help
  146. EVO 9 Turbo
  147. need some help on fluid's
  148. How's your Evo with upgrade cams?
  149. Best bang for buck Gt3076r turbo kit?
  150. What to do next
  151. Revolver Idle
  152. EVO 9 Turbo Question (guru help please)
  153. Service Engine Soon Illuminated
  154. Factory Knock Sensor
  155. The ultimate HKS272/272 Cam Timing????
  156. Loud thump noise when I depress the clutch in reverse
  157. Alky on a IX??
  158. Need REAL TECH Expert help! No Fuel or Spark after engine swap
  159. 50 trim on 2.3 stroker
  160. inner diameter for boost hose.
  161. opinions preferred
  162. Fidanza Clutch and Flywheel
  163. symptoms of a bad rear diff?
  164. Need More Power Before Tune.
  165. Which cams
  166. BBK vs. Accufab TB
  167. HorsepowerFreaks Turbo Kit Teaser (Pics!)
  168. Twin scroll T3 manifold
  169. What to do next..
  170. Anyone use Total Seal Rings ?
  171. New Evo MR owner, exhaust question
  172. Intake for an EVO IX
  173. Buschur Motors Kick Ass!!!!!!!!!!!
  174. NorCalEvo exhaust sound clips?
  175. Fujita Intake...
  176. Wastegate vacuum line question
  177. How much cam overlap is ok ?
  178. code fix / cell fix
  179. I need help with repairing these codes????
  180. Drain Plug / Oil Temp.
  181. boost controler line?
  182. UHH OHH!!!! t-case, front diff, or tranny
  183. electric cutout on test pipe!
  184. I know I suck....
  185. Shaun's dyno sheets, before and after.....
  186. People with Megan catbacks
  187. Still waiting....
  188. evo 9 tach pin on ecu
  189. I feel so sorry for a friend....
  190. Act streetlite vs stock flywheel weight measured
  191. mid cam install, urgent advice needed...
  192. Bigger BOV needed with Bigger Turbo???
  193. Boost leak issue
  194. Full-Race Down Pipe
  195. Can I use the "Tial 50mm" bov on the stock turbo?
  196. Should I use Redline Water Wetter in my EVO????
  197. Anyone running a revhard manifold here?
  198. 30 PSI?? This can't be right...
  199. boost leak please help!
  200. 9mr - stock-modded untuned dyno graph
  201. 03 New Trans & Clutch Break-In
  202. Boost Creep?
  203. GT3076R vs. FP3065??? Which one is better for 93+Methanol?
  204. Question about adjusting Forge MBC
  205. How bad is a clutch install?
  206. Bent MAF screen...NE1 else had it?
  207. Another BR3065 installed
  208. Car going into gear feels "sludgy"
  209. Clutch question
  210. water temp question
  211. Boost Leak?
  212. Blown Motor: Head teardown pics = ???
  213. advice on turbo manifold...tried the search
  214. help needed - Car stalling
  215. what upper ic pipe w/ hks intake?
  216. What do you think about heatsoak? Dyno proof?
  217. Would Buschur be willing to build a 2.1L EVO 8 Block in house?
  218. What Piston to wall clearance and Ring end gap are all you big hp people doing
  219. Car sputtering and wont boost above 10psi?
  220. What are the standard 560cc Injector Lag times?
  221. Drill/tap for EGT: Possible after coating?
  222. Help! I gotta leak.
  223. ARP flywheel bolts for EVO8
  224. At what point are injectors needed?
  225. how many miles on your 2.3 kit?
  226. OK to go from Synthetic tranny fluid to NON-Syn?
  227. Amsoil Or Bg Syncro Shift Ii
  228. keep blowing alternator fuses
  229. 03 evo worth it for an LSD?
  230. AVERG. lifw of stock trans?
  231. works TBE
  232. Evo IX vs. STi pumpgas/stock turbo/reliability/gotchas?
  233. TOB and exedy HD
  234. Over pressurizing the crank case
  235. AC condensor leaking! can I start my car and still drive?
  236. 2.1L Spun Rod Bearing
  237. Startup difficulties
  238. Where to find Injen coupler?
  239. what clutch should I get?
  240. Can you replace the fuel feed line?
  241. Evo IX staying basically stock, best bang for the buck?
  242. MR Tranny takes 2.3 quarts... right?
  243. whats the exhaust temp....
  244. Any way to mount "normal" battery?
  245. Tranny help. Instant help needed!!!
  246. intercooler piping
  247. Best place to get my cams
  248. Surging issue
  249. anything i should do b4 long trip
  250. grinding gears
