View Full Version : Evo Engine / Turbo / Drivetrain
  1. boosting??
  2. White Smoke form radiator
  3. Missing bolt...... again!!!
  4. Intercooler Piping / BOV
  5. Boost control solenoid
  6. Question on afr/rpm
  7. Anyone noticed a little vibration at 2k rpm?
  8. Driving with p0401 CEL code?
  9. Stock EVO Ex-Manifold weight?
  10. Help on Clutch!
  11. Raising Boost... Ignition Help!!
  12. JDM Evo 9 Turbo Problems?
  13. Aftermarket Intercooler
  14. What dp/cat will play nice with Blitz Nur-Spec cat back?
  15. Wastegate Dump
  16. Installed my TBE tonight, no check engine light? how come?
  17. Stupid Fbody made me stall ;/
  18. Oil Pressure Sender Relocation
  19. MBC/stock exhaust?
  20. 12psi problem please help
  21. help please.. what causing this
  22. another TRANS PROBLEm!!!!
  23. Car wont IDLE HELP!
  24. any idea or recomendations for my next mod?
  25. CLunk after car goes into gear and
  26. turbochargers.com turbo owners report here
  27. Which TURBO!! Slowboy, RNR,Shearer,Buschur
  28. anyone running all methanol?
  29. Blitz Dual SBC Spec S installed.. only 12psi
  30. Lean start all of the time
  31. buschar/warrtalon stage one- car wont start- help?
  32. getting locked out of gears
  33. IX Exhaust help
  34. Mild build-up for street Evo PICS!!!!
  35. Probably a stupid question...
  36. Smogrunner's Super Stock Stroker Finally Hits the Track
  37. my 280 cams
  38. EVO IX Dyno Sheet - 75 more ponies than before
  39. Fan Blade Snapped!
  40. Question?? Difference Between Meth/alky Kits
  41. 02 housing/sensor problem...
  42. Thoughts on engine ticking...
  43. Knock Sensor Voltage Question
  44. Good clutch
  45. Sudden boost drop...leak
  46. 2 part A/F ratio?
  47. I have hks 264's, but just upgraded to 50trim
  48. Ported and polished head or stroker??
  49. adjusting boost after Drop in Filter?
  50. "Break-in" procedure/method for multiple new engine parts?
  51. JUN BL exhaust with downpipe?
  52. ARC intercooler info
  53. New Tomei Exhaust Manifold
  54. CAMS 264/272 or 272/272? help!!
  55. Boost Leak Test?
  56. Road Race Engineering RRE turbo kit Who has ONE???
  57. how much gains will i see?
  58. Is my motor good?
  59. Arizona Forced Induction 42r setup...Completed pics..
  60. Best Alky Kit For My IX:
  61. Anyone w/ a RNR GT35R Kit with more than 550 WHP?
  62. question about ams evo 9 package
  63. Help the Mechanically Disadvantaged - Acceleration Probs
  64. Tech question: Disk install backwards
  65. clutch adjustment?
  66. Differences in 1st and 2nd gen Magnus Intake Manifolds?
  67. evo 9 turbo installed in my '05 evo 8....
  68. megan racing dp fit ix
  69. Gruppe-S Prototype Manifold & 20G-6 Dyno
  70. Missed 2nd gear and 5th gear several times...
  71. popping from transmission
  72. Small hole in radiator fins any quick fixes?
  73. Boost leak question?
  74. slow boy stroker kit?
  75. Clutch failure or something else?
  76. Performance Guidance
  77. Every EVO shold have this two mods even you feel stock EVO is fast enough !
  78. Fuel Tank Setup
  79. DYNO results, can gurus chime in?
  80. which cams produce most power: HKS 280's VS Comp Cam 280's
  81. Need serious help please
  82. is it possible
  83. MBC problem help please
  84. 584whp/527wtq Stock ECU!
  85. Info on HKS Light Action Clutch
  86. The Purpose for ONLY having 91 Octane in certain states?
  87. Which Front LSD?
  88. Clutch mileage thread
  89. Perrin o2 eliminater?
  90. Can you apply a gt35r to a stock block?
  91. Need Help car wont start
  92. Which buschur muffler is this....
  93. Help-Dealer says using GL4 for entire drivetrain?
  94. Test Pipe Thread
  95. 280 cam install
  96. Dyno results. Evo9 Flash
  97. GT30/GT 35r with ALKY where do you start injection?
  98. going to install DP spacer got ?'s
  99. Anyone looking to get the NEW SBR turbo kit 451awhp???
  100. EVO 9 ECUflash Results!!!
  101. Boost leak test
  102. Cosworth head
  103. For all of you that want 20G numbers...
  104. 3076 with .83 vs. 35r with .63
  105. Agency power Turbo kit tuned on EVO8
  106. noob spark?
  107. What should be next?
  108. MBC=Blown Engine?
  109. which cams for evo 8
  110. The latest Buschur Racing dyno test..........a wash.
  111. When are you guys changing out your stock plugs?
  112. Boost problem!!!Help!
  113. Suddenly my close to stock EVO runs rich...
  114. 2.3 Stroker!!! GT35 or gt3076????
  115. WHP on a 20G
  116. 42r's
  117. Wheel hop - How to eliminate it?
  118. Aem Random misfire
  119. great now what is my problem???
  120. Megan Testpipe flanges not alligned?
  121. another quick pic of my 2.1L
  122. clutch install problem
  123. Catless TBE installed w/o CEL Fix...how long is this ok for?
  124. Exedy twin Carbon D-Core installed
  125. po 134 code and po 171
  126. What's a GOOD FMIC 'Intercooler' AIR TEMP??
  127. enging back mount removal?
  128. who's running the ss autochrome FMIC?
  129. Buschur Racing dyno testing brake rotors?
  130. GT30R .83 owners I have a question for you.
  131. need help fast
  132. Little problem..
  133. gm 3 bar map sensor
  134. Thread size/pitch question
  135. Timing belt.
  136. braking hard and clutch in ?
  137. Sound clips of JIC and Magnaflow TI?
  138. Am I running too Rich or Lean?
  139. Possible low/hi fuel pump relay faulty?
  140. AEM EMS, 50 Trim, 1000cc inj, M15 alky nozzle
  141. warped head, gasket what else?
  142. 100 octane IX boost setting
  143. Project CBRD MR, 2.3 liter JAM
  144. boost and power levels on stock motor and head
  145. Clutch selection?
  146. Need confirmation on IC/IC Pipe combination fitment.
  147. Please help with stalling issue
  148. Blew my motor!!! What to DO!!!
  149. tourque specs of pressure plate
  150. Anyone with Autometer boost guage.. Little HELP please....
  151. anyone using an exhaust cut-out on their evo IX's???
  152. So let's finally set it straight with aftermarket crank pulleys...
  153. Exhaust parts\info needed
  154. Engine Diagram Needed
  155. HKS vs Tial
  156. 27psi + BR3065 + Stock MAF = pic inside
  157. Turboxs FMIC installed on evo ix....
  158. Which Exhaust is louder?
  159. problem with hks tt
  160. Parts to rebuild Exedy Twin
  161. recent dyno,
  162. oil catch can cause engine oil leak???
  163. Aftermarket radiators?
  164. HKS DLI II Nightmare install HELP!
  165. Question for the guys running meth.......................
  166. SBR GT35R Kit - Anyone getting over 500bhp??
  167. Please confirm my decel noise is normal
  168. Boost leak help
  169. Tranny Problems
  170. Stock clutch finally done @ 51,995m
  171. Hks Vs. Vishnu
  172. ideas on twin fuel pumps????
  173. Rapid Boost drop cause?
  174. stumped on exhaust for my 9 mr
  175. Quick timing belt replacement Question....
  176. Evo Boost issue, please HELP! (i searched already)
  177. Agency Power Turbo Kit = AMS Kit????
  178. GT4088r Vs. GT4292r
  179. Questions for those with 2.4 motors
  180. tried Amsoil MTG in IX MR 6-speed
  181. oil squirters needed?
  182. Is my BOV in backwards; is it a big deal?
  183. Pennzoil Syncromesh
  184. Solutions: Broken fuel pump bolt?
  185. 4g92 turbo all people with knowlegede of this engine please read
  186. Six-Speed Short throw shifter update
  187. transfer case/tranny options...
  188. spark plugs for evo 9
  189. spark plugs for evo 9
  190. Downpipe
  191. Helpful Thoughs on 50trim
  192. 880cc with ecuflash
  193. ACD Problems...
  194. Anyone using HKS 272 cams?
  195. 05 clutch change
  196. Need some expert advise on cam timming
  197. Alternator problems anyone ???
  198. question on vacuum
  199. Another GT42r Evo...
  200. whitch turbo is better
  201. Peak Boost Manifold vs Full-Race Manifold...
  202. Stock Evo IX with intake and flash ... #'s?
  203. Where can I buy heat shielding?
  204. boost creep?
  205. evo ix with cams alky, front mount, etc
  206. Most WHP on Pump Gas 93/94 Octane
  207. gt35r + flash = ?
  208. Customised Works o2 Housing
  209. what manifold for pte 60 trim
  210. engine idle problem
  211. Aftermarket Intercooloer
  212. Anyone with Blitz SBC and Optional Harness?
  213. Injen Intake
  214. Good AFRs... Still possible to blow a motor?
  215. Where's all my antifreeze going??
  216. i need a clutch bad!!
  217. HKS EVC V Readings
  218. O2 sensor question
  219. Exedy Single or Stage 1 anyone?
  220. Stock turbo exhaust housing fitment
  221. How much WHP will HKS DL handle?
  222. build engine and gt42r for street use?
  223. 2 codes (need Help)
  224. Help please.. Car wont start after heavy rain..
  225. greddy profec boost problem
  226. out of all the EVO IX owners with upgraded FMIC, and/or LICP, who has BOOST leak?
  227. Any IX with JDM FMIC?
  228. Problem with HKS GD Pro clutch
  229. longer gears?
  230. Evo 8 Rear Mech. Diff and Axles
  231. Mis-Fire
  232. Recurculation???? (newbie)
  233. Broke the sensor...which is it?
  234. couple nitrous questions.
  235. IX MR exhaust manifold
  236. ebay store
  237. Greddy Type S leak
  238. Best engine dampener?
  239. weird clunk!!
  240. Tme-9 Rip?
  241. Stage II OBX Camshafts
  242. Fuel System
  243. exhaust gaskets - 3"
  244. broken turbo
  245. Quick oil pressure adaptor question
  246. Taking off rear section only
  247. mitsubishparts . net NEED HELP
  248. JUN b.l review
  249. intercooler pressure test question
  250. I have a problem with evo III
