View Full Version : Evo Engine / Turbo / Drivetrain
  1. catback & dp, what next?
  2. rear 02 cross reference
  3. 475 whp, 341 ft lbs, 93 octane and still going.....
  4. heater core
  5. Need Help With Egt Gauge
  6. HKS/EIDS/ECU Help
  7. Need some quick help ASAP
  8. SoCal Clutch Questions
  9. Problems with Injen intake for evo IX
  10. Has anyone seen this intake?
  11. My MBC mounting solution
  12. Very small dent on honey comb on maf...
  13. Dyno graphs of the twin scroll set up.
  14. Need Help/opinion
  15. After clutch install issues...
  16. Injen CAI/UICP owners:
  17. Is the MIVEC just in the cylinder head ?
  18. oxygen sensor question plz help!
  19. Help please
  20. new clutch possibly clutch problems?
  21. Forge DV lowering boost
  22. 11.4, no NOS, no Lag, no problem
  23. HELP! Need Clutch Install advice!
  24. Bad / Loud ticking noise at idle and low revs
  25. 2g to EVO8 Swapping?
  26. Automatic Evo
  27. Best Turbo kit for stock internals and quickest spool up?
  28. Gas mileage and my performance desires
  29. good aftermarket manifold?
  30. shifting problem
  31. white/grayish residue
  32. 25 psi, no power HELP!!!!
  33. Clutch started slipping today
  34. Tranny woes, please help
  35. Help!
  36. HELIX 3"Downpipe Ver.1
  37. ACD ECU location
  38. AMS Uicp w/ tial ?
  39. Found something neat while screwing around!
  40. MBC only gives me 18 psi ???
  41. new clutch to give many a run for their money
  42. Can't control my Tial38.
  43. Oil Cooler
  44. Noob Here!
  45. Adjustable cam gears on stock cams?
  46. break in?
  47. Modifying Fuel System
  48. Your thoughts on a new clutch ?
  49. I had this discussion at MOD 06
  50. AEM twin-fire
  51. HELP!HKS GD CLUTH Pro
  52. Blitz SBC Problems Help !
  53. HKS 272 ex cam on IX
  54. Major {thumbup} to Dyno4mance!
  55. Cosworth M2 cams?
  56. HELP!! Over boosting with stock soleniod back on..
  57. Car doesnt seem to be pulling as hard?WHy
  58. Engine longevity with HKS cams
  59. 2.3 or 2.0 for quarter mile
  60. weird issue, please help (could be normal)
  61. 2.3 Stroker!!! What street TURBO??? INFO FOR ALL 2.3 setups
  62. Q on boost controller
  63. New destroyed tranny record?
  64. BG Synchroshift
  65. AEM Boost Controller Guage
  66. Only 17lbs of Boost?
  67. tranny fluid?
  68. 2.4l Problem
  69. Question about going from stock TB to 75mm TB on a SMIM...
  70. Boost Leak Test Results
  71. springs and retainers help!!
  72. AMS Licp fit undertray?
  73. Air Fuel Ratio Question
  74. Question about Tein Flex
  75. Anyone using ralliart air filters?
  76. TME locked up/rebuilding options help
  77. 4th gear grinding problem
  78. Is this a boost leak?
  79. Evo Speed limiter remove "WTF" ??
  80. ACT Install.. please help
  81. Under hood shifter bushing question
  82. Competition Clutches? Any Good?
  83. Custom Turbo Kit Guys!!!!!
  84. Evo 8 spark plugs do not fit a 9
  85. How Does my tranny Look?!
  86. Please Help me figure this out!!
  87. A boost/efficiency question
  88. What to Gap Plug's?
  89. No more Heat Soaked intercooler !!
  90. Header design w/ pics
  91. 3" TBE TO LOW
  92. Intercooler Piping question
  93. IX cam torque settings
  94. Fluttering at high boost.. Help.
  95. Torco And Boost?
  96. Single clutch
  97. 4th gear grinding problem
  98. Intakes: Buschur vs. HKS RS
  99. help car wont start(ping)
  100. NEED HELP! Shifting problem..
  101. Boost Up then Down?
  102. fuel pressure solenoid resistance?
  103. stroker vs. overbored and head being addressed
  104. 500+whp EVO 200% guaranteed!!! HA
  105. No AEM for alky?
  106. How much Boost on a EVO9
  107. primary 02 sensor....
  108. gas octane questions~~
  109. Questions of 4G63 Stroker kits
  110. Need help with future mods....
  111. Damn rain, we had to stop at 9.22 @ 158 mph
  112. new aeromotive fuel rails
  113. Big turbo guys- What BOV are you running?
  114. Straight Line Specialties Top Mount T4 Manifold
  115. Modded Ebay 02 w/ Open Atmosphere Dump!
  116. Slgiht grind question..
  117. SpeedElement/Full-Race GT30R DYNO 91 OCTANE
  118. 2.4L w/ 50 Trim owners, Chime in!!
  119. Spacers for tie bar to allow downpipe to fit?
  120. My Budget oil catch can, two cans for < $33.00
  121. br 20-g-9 labor?
  122. Revolver or Jun
  123. white smoke
  124. busted diff/TC?
  125. Switching from Stock IX turbo to a 20g with Ti/AL
  126. how does this happen to a turbo, and whats involved in fixing it?
  127. What To Choose?
  128. Thank you TRE
  129. Stock Evo 9 boosting only 1 bar?
  130. walbro fuel pump failure???
  131. Halfway through o2 housing install, help?
  132. o2 censer on the o2 housing on the IX??
  133. For those of you with tubular manifolds, look here(pics)!
  134. evo runs very rich when step on gas
  135. Boost leak test problem, 0 psi, doesn't hold
  136. Nifty vid of GT35r
  137. GT35R option??
  138. A little trick that could get you 5mph higher trap
  139. 10.5 single flapper,SS o2 installed
  140. Miami Machine Shop
  141. AMS 50 trim dyno chart
  142. GT turbo Install Kits
  143. Looking for insight: XS Power Exhaust on Ebay
  144. Head Work Advice
  145. Can the ATP 3071R kit reach 500+whp on stock bottom end?
  146. Please HELP diagnose my problem! Shutter/heavy vibration when turning at low speeds
  147. Home Depot/Walmart oil catch can
  148. Clutch decision...
  149. Check out my budget oil catchcan... part II
  150. Vendors!!!!
  151. Heat and Boost
  152. Headers
  153. Question?
  154. Water Pressure Gauge
  155. Which 7 bolt 2.4 cranks are suitable for 2.3 builds?
  156. blow off valve
  157. Whats the weight oil on the BGII syncroshift??
  158. Whining Noise - Drivetrain/Clutch Related?
  159. will buschur racing 8 LIC pipe fit a 9 ?
  160. b4 i install my DNP manifold question....
  161. Buschurs modified walboro pump?
  162. Building my engine...
  163. boost problems??
  164. Input needed from those with broken drivetrain parts
  165. went through big puddle now wierd sound.
  166. GL 4 and GL 5 (for transmission) Same thing now???
  167. Need Help - AEM Ignition box bad?
  168. Can I eliminate rear o2 with the LM-1 WB Kit?
  169. Damned Clutches!!
  170. RnR Exhaust
  171. Downpipe Bolt concerns....
  172. 2.3 stroker
  173. Help with my drivetrain
  174. Tranny Oil Change!!
  175. Check out my budget oil catchcan!!
  176. replacement filter for hks rs
  177. MAF Deletion Kit
  178. Just read something interesting in the manual!!
  179. Controlling Boost Manually
  180. Exhaust
  181. Heavy oil buildup inside my MAF
  182. Random/Multiple misfire
  183. Tanabe Dp
  184. I need a quieter exhaust but same gains?
  185. Exhaust Solution?
  186. Valve diameters ?
  187. Untuned.....
  188. Problem - getting BOV sound when I dont have an aftermarket BOV
  189. 2.4L 4g64 Stock Turbo - Dyno
  190. HELP with Radiator, any evo owner can help
  191. Buschur Evo 9 LICP review and install pics
  192. My Poor Sick Evo
  193. clutch restrictor
  194. Built motor or Turbo kit first
  195. How many miles on your BUILT MOTOR!!!!
  196. Exedy Twin Plate HD after install questions
  197. who got the Buschur standard FMIC upgrade, how come mine don't fit ??
  198. BOV, What do I have
  199. Radiator Upper Hose Placement/ 97-02 Mirage/Evo5-6? Radiator the same?
  200. Spun bearing
  201. Ses P0401 Egr Flow Malfunction?
  202. max horsepower engine can take
  203. oops, i think its broke.
  204. Turbine Housing
  205. Anyone have external pictures of the fuel tank?
  206. Need Help With Blow Off Valve Placement ???
  207. switching ECUs Help
  208. Need URGENT help please
  209. 500whp stock block club
  210. Megan Racing Exhaust Manifold
  211. CLutch Install In Socal?
  212. going to the track tomoro
  213. No boost increase with TBE
  214. Best bang for the buck intercooler piping?
  215. Where is the Nitrous?? Choosing a turbo
  216. Best Clutch/Flywheel Combo
  217. MACHV goodness. Can u guess what it is? (pics)
  218. blown head gasket!!!!!!!!
  219. BB 50 trim and Fueling??
  220. 558hp Stock block on 93oct and meth
  221. Initial Mod Review
  222. CEL And Screw Size Help
  223. Stroker guys . . . lend me your ears!
  224. Brian Crower Valve Spring and Titanium Retainer Kit
  225. 03 evo 8 wont boost past 20psi ????
  226. Tilton Twin Disc, Who Has One, Who Installed it, How long, Who Who who...
  227. review of perrin catback.
  228. Evo 8 350hp+
  229. Apex-i, Garret, or HKS? to replace stock JDM Mg Turbo
  230. Question to Bushur Racing about the Bushur Ported & Jet Coated Exhaust Manifold
  231. Got my Evo 9 LICP from Buschur. WOW!!
  232. Adapters for custom oil lines?
  233. So....hot afternoon, cool evening
  234. Which Exhaust is louder?
  235. boost leak is killing me !!!
  236. SES on, now off?
  237. exedy stage 2 just installed
  238. Timing Belt at 60k...HAHA
  239. Temp sensor in DP useful?
  240. how to achieve 425WHP evo IX??
  241. Silicon IC connectors for the Evo IX
  242. Just got the 272/272 gsc cams tuned!!
  243. Idle Misfire
  244. HorsepowerFreaks GT35R (535whp, 421wtq on stock 2.0L) w/videos and dyno
  245. Evo 8 Final Drive Gear known issue/TSB?
  246. p300 code = failed inspection
  247. Does your motor make a ticking noise?
  248. Cams between tunes?
  249. Ti-Al Turbo for the EVO final version
  250. jackson auto machine?
