- Stock IX intercooler core size please
- axial supercharger amazing!
- 3" exhaust, open air filter, MBC, walbro, which are best and where to buy?
- Is my clutch shot?
- COP ignition
- Exedy Twin disc Vs. Single disc Question...
- injen intercooler
- 5 year smog.........LOL
- Do 03-04 axles fit 05's?
- I need pics of the Buschur intake installed - Please
- Cleaning up Titanium?
- whats better... 5 speed or 6 speed?
- Is SMC Good
- tme boost log in 3rd gear needed
- ACT clutch & gear lock in
- need help...
- Exhaust bolts???
- Mr Freeze injection kit
- Stainless steel cluchline
- Anyone have a Vibrant Cat-back?
- Stock clutch & Gear Lockout?
- ix turbo installed=>03 evo/comparsion(pic)
- Greddy V-spec Intercooler
- How much WHP with my mods ???
- RMR Turboback quesions
- Looking for a utec map!
- What are the steps?
- TC howling????
- o2 housing and port exhaust manifold
- People running 91 & Alky, come on in
- ARP head studs, is this the correct part?!?!?
- Anyone does OIL Change in MR by yourself? Q inside!
- Tranni removal tricks OMG????
- porting exhaust manifold and gasket matching
- 20g records, Stock Appearing Class etc.....
- 35R dyno results??
- c16 on 104 tune
- CEL Codes p0441 & p0452
- Need to adjust the clutch?
- new intercooler installed now a noise pleas help
- Quaife owners speak up
- transfer case
- pluging hole in intake for vta?
- push and pull clutch systems?
- TINY TINY CHIP on hks272 lobe.?
- Office Evo QTP Down pipe
- Hallman boost controler evolution and evolution rx
- evo8 tranny + t-case dimension?
- Stock turbo + Cosworth Head
- In the quest for a Road Race Turbo Kit
- apex cone filter
- Please Help
- My RnR gt37r project
- SBR gt-35r kit (why i dont need a gf)
- Oil Return Line leak
- EVO VIII boosting problem....
- Need a replacement diaphram for the Greddy Type-S
- stock injector leaking boost??
- cooked head repair
- Falling Out of 3rd Gear on Track
- Tanabe Concept Blue and cell fix?
- Octaine booster?
- What you think of the AMS UICP w/ tial bov
- ARC FMIC for IX?
- 110 to 93 on tune
- What should a properly tuned BOV sound like??
- stock ecu with 35r
- Any LICP Dyno gains?
- Any aftermarket turbos bolt on to stock hotside?
- FS: USED K&N DROP IN FILTER W/ LESS THAN 4500 MILES ON IT.
- Crank Pulley Issue
- question about evo 9 cams
- Is it Blown?
- hks RS or stock w/K&N drop in?
- Best clutch for daily driver EVO
- Buschur running 8.95 @ 163?
- Flash psi vs MBC psi
- super scared possible clutch problem!! help!
- Questions on upgrades...
- Changed transfer case oil yesterday - low initially? (little long)
- gearbox oil gl-4 75w-90 75w-85 or straight 90!
- car running very badly
- prolbem with AEM wideband air/fuel
- Samco hoses
- best bang for the buck mod
- Whistle while under boost?
- launch rev limiter
- Adjusting clutch. It adjusts PEDAL height ONLY?
- Need help, can't boost to 28
- plug gap quesiton
- just installed HKS 264/272...
- Stock Injector Fuel Pressure
- Clutch update.....I think I'm done with the Evo
- Tuning and break-in period.. what to do?
- I Need Help - Oil Light Flicking - Yes I Searched
- Purpose of Replacement?
- misfire and sputtering(i did search, just read)
- how much is too much on the stock turbo?
- ebay 02 and manifold!?
- Oil filter housing plug sizes
- EXO IX CAMS, Comparison questions
- intake part question
- Gas pedal adjustment
- Greddy Type-S lower vaccume port question
- Boost problem !!!
- Help on boost loss issue
- problem at WOT....?
- Best downpipe on a IX??? Fitment/quality/craftsmanship/performance
- Opinions on Spec clutches
- greddy intercooler
- Hole in transfer case from exhaust...Help
- When should one upgrade the intercooler and radiator on a IX??
- Rs*R ExMag Downpipe
- valve clearance question (mivec)
- Pinks Evo!!!!!
- 20G Turbo
- Do revolvers only work on the east coast??
- Full Race Manifold stock manifold
- wierd gear grinding pattern
- overheating issue
- Am I getting screwed over?
- forge mbc with heavy spring?
- Tansfer Case Noise
- evo 9 cam??
- Stroker/35R cam choice?
- Clutch install ?
- Buschur Racing Raises the Bar.... A New Record has been set!
- Intakes on the IX
- has anyone ever use this clutch
- my 35r dynograph
- Which mod next?
- Prediction?
- bar and plate intercooler question
- sticky clutch pedal
- Air Research compressor maps
- evo ix intake cam
- Shimming JDM MR DV?
- Exhaust Question
- stock boost evo8
- Need Tune after raising the Boost?
- just installed tial race bov....
- fuel starvation prevention
- Rod bearings
- real boost pressure?
- Evo Cam Options?
- Thoughts on the tanabe medallion touring exhaust
- High octane leaded race gas?!?
- Best Way to make 30 whp
- Has anybody used the Gruppe-s Flywheel yet?
- Tomei Ehx. Mani - pictures
- New Clutch Questions
- Does B&B use Magnaflow mufflers?
- Is this normal after TBE install ?????
- hks ssqv problem
- Warrtalon Package
- My Evo Hiccuped today
- Blown turbo on a STOCK evo 9! Please Help! *pics inside*
- Sorry another engine noise question
- What threads are on Hallman MBC, 1/8 NPT?
- anyone w/AMS 3076R Turbo kit on thier IX
- evo 8 - no power
- 30r .63 and .82 actual comparison
- Help with flywheel autopsy
- No "balance-shafts" - Engineered 4G63 crankshaft.........??
- Can someone answer a rear diff question for me??
- 670 WHP/545ft/ib update 10.72@135mph
- A-Spec Titanium TP Review
- just installed 20g 9 5 overboosting?
- Not bad for ATP 3037s
- Whining issue
- MoTec - Mitsubishi Centre Diff Controller
- Eboost-2 ?
- Which part would you get?
- boost going up,down and up again
- Boost spazzing out
- Which clutch should I buy
- Oil question
- Is this Super AYC or a mechanical rear diff?
- Tough time shifting..... help
- Hi-Flow Cats causing CEL; solution?
- When spool-up matters
- exedy twin problem!!
- How Long Has Your Exedy Twin Plate Lasted?
- Stock Evo 8 16g or Evo 3 GT RRE B16g?
- Need Help: Installing Boost Lines To Tial Wastegate?????
- Clank when shifting from 2nd-3rd at low speed?
- questions about injectors/turbo/ic
- Boost spiking ?
- boost problem *need help*
- Did I MUFF up my car?
- Where do you get your tranny/diff fluids?
- Buschur bullet muffler and JDM rear ?
- Electronic Stethoscope For Knock Monitoring
- o2 housing now or wait for a hotside?
- Can AEM Serial gauge show EGT in over 1000c ?
- ISP turbo kit 537whp at 30 psi
- Is my car running lean?
- Is this correct for stock boost? (short vid link)
- TRE probably the most inconsiderate shop ever
- Invidia downpipe evo ix
- 2.4 block and Evo head?
- Vishnu or Buschur.... Decisions, decisions
- Cam Angle Sensor Gasket
- Who Sells a good head gasket for the IX
- Do EVO IX's regulate/stabilise oil pressure in head?
- Help on my JDM EVO7 Steptronic (pictures)
- Buschur GT3065 Review
- Throw out bearing stuff?
- A/F ratio under boost
- Anyone know this Cosworth Camshaft for EVO 9 ! *pic
- boost problme 05evo8
- Increasing down force?
- just got off the phone w/ mitsu
- Anyone have this "catch can" yet?
- found a walbro fuel pump in my spare parts box
- car not boosting
- Cosworth Head vs. Stock(EVO VIII)
- evo ix or tme turbo please help
- Strange stalling when raining
- How many miles has your stock clutch lasted?
- biggest turbo on stock flange?
- Check my setup..what else do I need?
- Ok, Had Enough, What Is This!
- Finally installed my Exedy Twin, w/ a couple of pics
- Problems with my intercooler piping!!!!
- Axle and Driveline Strength?
- just installed cams , gears and fuel pump
- Low Gas=Check Engine Light
- Intercooler piping question
- Where can i buy the....????
- 6 speed + non oem fluid = bye bye tranny
- Help! My RPMs are dropping at wot
- Does the Greddy Ti come with mounting hardware?
- Requesting a good engine pull writeup.
- Update..515 whp/362 ft bls, 93 octane alone........
- VIII exhaust bolt to IX?
- clutch issues
- Sleeper test pipe..
- 2nd gear grind
- 631 WHP/ 554 ft/ib WTQ, GT35R stroker!
- About to install exhaust....
- Dyno Database: Please Contribute
- IX runs slower until I re-set the ECU........ why?
- catback & dp, what next?
- rear 02 cross reference
- 475 whp, 341 ft lbs, 93 octane and still going.....
- heater core
- Need Help With Egt Gauge
- HKS/EIDS/ECU Help
- Need some quick help ASAP
