- Weird Voltage Fluctuation Under Boost?
- EVO won't start, wiring harness issues...
- Question about boost comtroller
- HKS cams changing shape?
- JDM Evo 8 vs JDM evo8 MR Turbo??
- installed a 10.5 hotside from gruppe-s today and had a strange problem
- What's wrong with my car??
- boost on stock turbo
- INjen LICP?? about the coupler
- GSC Cams: How many IX owners plan to purchase?
- Dual fuel rail and 8 injectors ?
- Shifter/Slave cylinder mod **WOW**
- Tranni internals???
- Tranny noise or am I just paranoid?
- T3/T4 turbo setups
- NEED HELP (cam question)
- Help Figuring Out a Possible Problem
- Tons of oil smoke after boost! Blown Turbo??
- Help: Engine Light on because of BOV
- HKS 272 cam timing
- my DIY Ebay O2 housing bracket
- coated turbine housing
- Boost shuts down on highway
- boost question?
- cat back: Magnaflow vs. Apexi NOIR
- The "Clunk" in the "tunnel", my observations/troubles.
- Stainless steel clutchline- any reason to buy an expensive one?
- What direction should I take now??
- will mitsu void this...
- 35r boost tester?
- cold air intake question
- NEED HELP (msd)
- Overheating / AC issues
- 04 Evo rs 10.5 hotside yes or no
- What is this part called?
- Whistling Sound?
- revolvers on just a flash?
- So Pretty! + A question...
- Evo 9 clutch question
- Some help please
- P0335 and not cranking.
- valve question
- JUN Cams and the stock valvetrain
- !!!Slipping clutch!!!!!
- con shape air filter without changing stock inlet hose
- Tuneing The Exhuast Cut Out!
- Could use some help, sudden sputtering
- Max Boost w/ stock fuel system
- Make Your Own Race Gas!!!
- GT35R, stock fuel system, walbro, confused, help?
- undivided t4 ex. manifolds???
- is my clutch broken in yet?
- Completely lost in the problem....need input
- Is Revolver ever going to release more cams?
- 50 trim owners, any surging issue at high boost ?
- The reason you MUST do a "boost leak test"!! Don't pass go. Read this.
- Acd
- Rear mount removal?
- Oil Temp Gauge On The Evo9 Mr?
- How much power till tranny upgrade?
- Flame off backfire question
- Quiet free flowing exhaust
- AEM TRU Boost
- Vta Bov's
- Smoke at WOT
- Power Steering Pump Whine?
- Odd rattle/noise when accelerating
- Clutch or transmision issue?
- My 2.3L build, lots o pics
- Details of Garretts GT37R - pics please .
- Invidia G200 Catback Exhaust? Anyone?
- boost control??
- Ported Turbine Housing
- Do i need a softer spring in the TIAL bov turbo is surging..
- ACD Wiring Diagram
- Motec differential controller. RWD Evos?
- Plug Life on Leaded Gas?
- Factory boost control questions
- Could someone please answer me the following question regarding AFR's?
- looks like I'll be giving shepracing a call tomorrow morning :(
- Massachusetts Exhaust Noise Laws - Legislation Update
- Backfiring when shifting and getting into boost, help?
- ISO good quality and accurate sensors ...
- coolant temp sensor broke help:(
- 10.5 HotSide Single vs. Dual
- Who powershifts exedy twin plates...
- weird grinding noise. please help!
- Misfire Shudder Problem
- throttle stuck open
- MR Transmission Cooler
- Rough idle - need some help
- Springs and retainers
- Evo 8 turbo on Evo 1
- tilton twin cerametallic owners
- My po300 problems
- Piston Bore Spacing
- Tilton Pedal Stop
- Evo problems
- ACD - Thoughts on using the E-brake
- How do these seals go in to the TB ??
- Aftermarket turbo boost leak test problem..........
- EVO VII - Overheating
- I need more than 255 lph.... SARD 280 lph ?
- Devo Tunings Quartermaster Twin Disk
- Warming up Tilton clutches?
- This is why YOU need an oil catch can*Pics
- CEL Fix / O2 Simulator on IX
- surging 3076r, anyone else w/ this problem ?
- HKS DLI 2 Harness
- Dynoflash Vs Bigvalley @ Atco
- Gauging interest on an aluminum drag spoiler
- SBR kit installed
- engine / turbo, something is wrong
- Front Bumper Plates and pics
- BG syncroshift II,big difference
- Evo IX Turbo Kits?
- helix
- will hks rs intake for 8 fit 9 turbo?
- New mods, what do you all think?
- 10lbs of boost
- bearings
- YES or NO to new head studs?
- Where is the road speed sensor located?
- balance shaft bearing help
- Lost hp / tq with 3" TBE ?????
- Act Clutch On Stock Flywheel...
- Are head studs the same for the VIII and IX?
- Unorthodox racing pulley & stock belt
- valve noise?
- Just installed HKS 280/280
- Help: parts yield bad smell and early rev bouncing
- Boosts in gear~
- lack of power...
- Heat coating for exhaust...
- spark plug gap for 20psi and for 24psi of boost
- Will this work? Or am I crazy?
- Launch Control and NLS from a Gizzmo
- identify this part please, transmission?
- Shifter parts ? swapping shifters
- Does this affect performance?
- What would net me more performance gains?
- New 20g From Buschur???
- I noticed tonite that something was broke...
- Head gasket Help.
- boost test goes straight out exhaust
- Is this manifold crap? - The cheap Ebay stuff
- boost flutter??? help please
- Coolant lines
- BG Synchroshift or Factory Fluid
- Another MBC problem thread
- Hotside temps?
- New Turbo on EVO 9? Check it out.
- which stroker kit would you guys go with??
- Few questions
- No boost leak = car is still slow ?
- Tial BOV issues , please help
- Does the boost solenoid have to be grounded ?
- 3 bolt flange and 2 bolt problem
- "LOUD" rubbing vibration noise after new clutch.
- Will I need a new bov for alky?
- How big a deal is a small boost leak?
- Why is my torque low
- Having a boost issue..need help
- IX Front Bumper Removal
- anyone heard of compition clutches?
- SMC alky problem
- Need help with AMS UICP and TIAL bov Install!
- XSPower (eBay) Exhaust Question...
- evo9 vs evo8 aircondition compresor
- FRom 264i to 272i...
- Just changed clutch about to fill the fluids...
- Do i have an Upgraded Fuel pump?
- Hard to shift from 3rd to 4th
- Cant get greddy profec type s to hit my initial boost right
- For those running 30psi+...
- DC Downpipe on a IX...
- Maximum boost for street/ ¼ mile
- Who's running higher than 28psi on meth and stock turbo?
- For those with an AMS base tune...
- Who is squirting meth WITHOUT using a catch can?
- 20 over bore
- High rpm's
- advice pls..do i need to adjust clutch?
- Help: Sticking clutch (twin disk) at low rpms
- What keeps the voltage charged in evo...
- Some issues after clutch install..
- Why are ported or Large Throttle bodies shunned upon or deemed useless?
- Greddy Oil Filter Block
- supertech valve spring specs
- any BBT04R turbo users?
- Spark Plug Diagnosis
- 6 puck or street disk?
- No more power after many new mods...wth?
- Did i totally screw my new ACT HD clutch?
- Car bucks when I punch it......
- Stroker kit purchasing question...
- stock whp?
- Weakest link..TC or Tranny??
- $900 to spend what to buy
- exedy twin disk?
- something happended today!!
- SMC Trunk mount braided line question.
- Check out my Fugley 4"intake and mini battery tray lol
- turbo failure?
- Question to those with EBC
- evo clutch/tranny
- Advice Wanted - EBC & TBE
- Whp Expectations ?????
- Does a GT3076R Exist? - And is it better than a 3071
- running higher boost on 100+ octane
- Lost my 6th gear at the track
- Greddy R-spec HG intercooler
- Front rattle drivers side Not TOB
- Evo 9 MR ECU Exhaust compatibility & Strut tower bolt
- need a gasket
- Car nudges when putting into 1st from stop???
- Crank Vents
- Fuel Trouble: Guru's / Experts Please Help
- Need new plugs...how much to gap
- Boost Creep &/or Spike Please Help
- need advice on clutch adjustment....
- RPM specific rattle
- 400hp help
- Where can I get a tranny mount for my evo 8?
- Warning!! Alternator and potential blow-up your ride!
- Greddy Ti soundclips.....
- Anyone put kn filter on hks racing suction pipe
- Installing Exedy soon.. Quick Question for the DIY guys..
- Overfilling the transmission
- 10.88 at 130 mph, pump gas+alky.
- Felt pieces on clutch slave cylinder.
- Have to get yet another clutch
- Installed clutch and now i cant boost.
- Part numbers to the 5th gear grind TSB-04-22-003REV
- Clutch is going but still works perfectly...should my gears lock out?
- What other options for getting cold air into our intakes? One of my ideas:
- Megan Catback Fitment Issues
- i need parts asap!! HELP!!
- another TC Whine noise question
- XS-POwer UICP fitment
- New Mitsubishi books are in and ready to ship.
- Who has the strongest stock turbo IX???
- Buschur pure power?
- Need some advice
- Injen FMIC VS Buschur FMIC
- Propeller Shaft boot broken :(
- Converting back to Pull style clutch(what parts!! HELP)
- Stock IX intercooler core size please
- axial supercharger amazing!
- 3" exhaust, open air filter, MBC, walbro, which are best and where to buy?
