View Full Version : Evo Engine / Turbo / Drivetrain
  1. Best source pressure source for MAP sensor?
  2. dip stick blew off need help
  3. Noise from the front "transaxle"???
  4. boost trouble
  5. stock piston??
  6. hks cams
  7. CEL with Catback?
  8. Megan Racing TBE
  9. Need some quick help
  10. For those wanting to upgrade fmic with stock turbo
  11. Clutch choice Exedy or Tilton?
  12. Replaced Plugs now a stutter
  13. HELP please! A few questions on a clutch.
  14. Losing Boost on Evo 6 - Help!
  15. Caped off nipple? why?
  16. 16G IX turbo on '05 VIII?
  17. Camshaft Weights!
  18. No Front O2 sensor?
  19. Very intresting read
  20. Car wont start after O2 sensor installed
  21. Stalling at Idle and Wierd Noise
  22. B.O.V. Question
  23. boost spiking problem
  24. Anyone have the Defi Blue Racer Boost Gauge?
  25. missing boost
  26. problem inside, be nancy drew for me
  27. Normal Compression Per Cylinder???
  28. Brain Crower Cams?
  29. Too much boost? ***VIDEO***
  30. Calling everyone with a SBR turbo kit!
  31. XS Power TBE --> Pics, Video, Review
  32. Best FMIC?
  33. upper intercooler pipe that will work with stock airbox and diverter valve
  34. upper intercooler pipping?
  35. Meth questions
  36. newb getting dynotuned mon, wat numbers should i expect?
  37. Which Ignition??
  38. Please help me identify this turbine housing
  39. Trying to get backhousing out... please help
  40. Little Help With AMS VSR?
  41. Br20g?
  42. 35R or T0Z??
  43. So I sold the DSM...
  44. At what point is a HKS DLI 2 needed?
  45. Failed knock sensor?
  46. Pressure @ Fuel Rail
  47. TBE; with or without resonator?
  48. cross threaded O2 sensor???
  49. Offtopic..Chris's EVO is for sale!
  50. looking for evo9 turbo upgrade....Grrr search suck...fatal errors...
  51. Awww man, my transfercase hates me...
  52. EVO_IX Clutch at 5000 miles!!
  53. Evo Ix Intercooler Piping!
  54. Need MAP sensor logs of a MBC
  55. 2.4 Brian Crower stroker with horsepower freaks 35rkit and 67mm wheel
  56. Gt32?
  57. Got fuel??
  58. Does Your Turbo Surge??
  59. Upgrade Front mount
  60. David Buschur's switch to the "big" turbo....
  61. Guess my AWHP (answer posted mid OCT)
  62. Do i torque down the spring bolts all the way on the DP ?
  63. Ceramic coat my header/exhaust manifold?
  64. Clutches for the $...
  65. evo8 5 speed gearbox - noises - what commonly fails ?
  66. cutout problem when boost builds????
  67. Blow-off Valve suggestions
  68. Cooler days and nights= more boost
  69. help!! I think i'm boosting too mucy.
  70. pssh sound when depressing clutch?
  71. How does our turbo vac system work?
  72. BMC Air Filter?
  73. 2.3 Evo IX mr
  74. HELP - Intake hose keeps popping off
  75. Exedy Twin cerametallic weight
  76. Methanol's affect on AFR readings
  77. IC pipes or sewer pipes? You decide!
  78. Accessory belt jumping a groove
  79. Inj. ID. Are these 560cc's?
  80. Spark plug question.
  81. Boost limits and failure rates
  82. Anyone has feedback on EVO IX WR turbo?
  83. BOV or what?
  84. Is a reflash needed for a bigger...
  85. quick ? need a reply asap!!! please.
  86. The notchy tranny feel
  87. Stripped Exhaust Manifold Studs...
  88. Thermal coated exhaust parts (pics)
  89. best evo IX MR exhaust
  90. left front tire coated with black substance
  91. What did you run your oil catch can lines too?
  92. Need some 101 class on 20gTME9
  93. Anyone have the exhaust port exit dimensions on their Evo VIII head?
  94. A little too much oil.
  95. Variable Clutch Engagement
  96. Lack of 6 speed short shifter in the market?
  97. Wiring Harness
  98. ACT Clutch and what happened..... :-/
  99. Had a spec stage 3 (6 puck disk) installed, will it get easier to drive?
  100. My new IX MPFab Front Mount - PICS
  101. 6 Exhaust Systems compared
  102. UR Testpipe problem.
  103. Cam install please help.....
  104. Cannot tell if I have cams.....Help
  105. I did a boost leak test...
  106. engine troubleshoot help
  107. EVO MR 6spd - 4th gear size
  108. GSC 272s best price?
  109. average clutch times?
  110. tial wastegate on stock turbo
  111. the evolution torque specs thread
  112. cam install q!!!
  113. Anyone use hks rs intake with bigger turbo
  114. IX Intake Cam more aggressive than VIII!
  115. ATP GT3076R - Impressions
  116. HKS Carbon-Ti T.B.E. Idle (video/sound)
  117. Had compression test done - numbers...
  118. SS Clutch Line Help.
  119. AMS 2.3 & 35R multi-gear spool-up data with Zeitronix
  120. buschur 35r with meth results
  121. Possible boost control solenoid problem?
  122. Numbers Too Low?
  123. Turbo Timer Help
  124. Anyone done headwork on the IX head Porting ect?
  125. New FMIC, boost spike is higher, redline boost is lower
  126. Valve cover torque specs??????
  127. Do I need to replace my exhaust manifold gasket????
  128. torque spec question
  129. Mbc Vs Elec Boost Control
  130. Noob Question, sorry but searching is getting me no where
  131. Since Revolver is taking FOREVER...what are the next best cams?
  132. T case fill and flush holes.
  133. help me out here!
  134. Check out my new cupholder
  135. Valvetrain to use with Tomei 280 procams?
  136. guru's i need help rebuilding
  137. junkyards for evo motors and trannys
  138. has anyone used apexi ps cat back exhaust???
  139. Please Diagnos - Power loss at WOT in high RPM's
  140. which hiflow cat?
  141. Who sells Evo IX TME turbo ?
  142. clutch problem
  143. Evo will not boost, and wants to cut out. Any ideas?
  144. Just installed the Green filters cone....
  145. Need CEL fix ASAP!
  146. Best Exedy Price
  147. HKS SSQV bov coming off intercooler pipe
  148. 2 weeks to make a decision/bolt on turbo/subject covered to death/help
  149. building a 2.3 or 2.4 stroker
  150. Oil Pressure Sensor Location?
  151. Evo 6.5 Air Flow Meter on Evo 1
  152. Which turbo????????????
  153. Magnus Vs Carillo
  154. Greddy RS BOV
  155. what clutch do you recommend
  156. prosport vs. autometer boost gauge!
  157. HKS RS intake tight fit?
  158. when should i get a tune??
  159. HKS RS Reloaded, Not holdin 1.5 bar, also mountin issues
  160. broken stud on fuel pump retaining black ring how to fix?
  161. EVO 9 Boost taper after MBC install
  162. Manifold / 02 Housing
  163. I need some stock pistons (evo 8-9)
  164. Going crazy!!!!!!
  165. Driveshaft hitting exhaust resonator
  166. My Evo Ix And Meth.
  167. Timing belt options
  168. My 42r kit being built by Peakboost
  169. Clutch feels different after brake bedding
  170. camshaft crower 280/280
  171. Max boost on IX without tuning
  172. Custom Turbo kit plans. Opinions?
  173. boost getting stuck from 1.5 to 0.5, help!
  174. 3.5" Exhaust/Mufflers, choices?
  175. alchy max boost
  176. Hooked up Hallman Pro RX and Boost gauge, then EVO Scaned!
  177. Need to bleed clutch again!???
  178. Coolent boiling????
  179. Cam install issue
  180. evo 9 trans in a evo 8???
  181. stock evo 8 turbo
  182. Cost of shortblock
  183. bov
  184. Doing your own Tranny rebuild...
  185. Where to flow test an intercooler?
  186. UICP Hitting Fan
  187. Tracking down a noise
  188. electronic cutout?
  189. Koyo racing radiator: where did you mount fan controller?
  190. Serious Problem,,,please help
  191. Question about stock IX turbo?
  192. Redline lightweight shockproof ok for tranny ?
  193. T04 3" Discharge Gasket
  194. URGENT HELP NEEDED: Transmission Compatibility question...
  195. Weird sound coming from pulley and belts
  196. Benchmark This Settup Vs. The 1/4 Mile Time So Far Achieved
  197. Question About ( Boost Levels )
  198. Down pipe install?
  199. Have you replaced your coil on plug boots?
  200. Funny Rattling Noise
  201. intake without tune safe?
  202. Evo9 hard pipe kits
  203. Buschur Injector reliability
  204. HELP!!..Forge Unos MBC
  205. aem uego in test pipe bung?
  206. High idle
  207. Need Help before install
  208. tore an o-ring! (what size to replace)
  209. Shearer Turbo kit??
  210. 60k Mile Service, some questions
  211. Pause in 3rd gear. Clutch?
  212. ATP 3071R and supporting mods for 400whp
  213. how many using the ATI Super Damper??
  214. clunck noise when down shifting
  215. Fluidampr balancer
  216. 3076R turbo 780cc injectors
  217. Hallman Pro RX install & test VS Forge
  218. adjusting tilton clutch
  219. Help Needed Strange Sound.
  220. Does the gt35r or the 37 kit fit the evo 9?
  221. I searched, UICP make BOV loud?
  222. where can i find a 9 WGA?
  223. put stock airbox back in now car wont boost past 12 psi
  224. Motor mount vs. torque damper review
  225. Full Race gt37 turbo kit... Our install
  226. 720cc injectors, how much whp?
  227. Cam comparison, highest hp yeilding/ better spool?!
  228. Act Clutch Problem
  229. 5 speed vs. 6 speed
  230. Whats wrong with my car?
  231. Revolver cam gear settings???
  232. Question About This Turbo Pic...
  233. Can Boost Change on its own
  234. car runs with no keys???
  235. GM blow-through & UICP - where can I get one?!?!?!?
  236. bb oil feed vs standard bearing oil feed???
  237. exedy twin users...
  238. High frequency vibration post timing belt/ balancer belt/ cam gear install
  239. Clicking noise from driveline at very light throttle.
  240. Which turbo kit will you buy??
  241. map sensor w/bov to atmosphere
  242. Drive Belt Tensioner Movemnt?
  243. 2nd gear trouble
  244. Question about ( Hp&Tq ) On Stock Motor
  245. tranny leaking at driver side axle after clutch install....
  246. Most WHP out of a 3076R?
  247. exedy twin issues ??
  248. Installing O2 housing
  249. Problems, needs answers please
  250. Installed a catback...
