View Full Version : Evo Engine / Turbo / Drivetrain
  1. us 5 or 6 speed
  2. potential blown engine. seeking Evo Mechanic
  3. jdm ix gt turbo
  4. help please!
  5. Swapping injectors...Question
  6. Low rpm acceleration not smooth
  7. How do I make the Greddy EVO2 10136630 exhaust fit on my 2006 MR?
  8. Length of T Belt Tensioner
  9. Need help on wastegate
  10. fumoto oil drain valve trouble
  11. grind going into 2nd gear
  12. engine blew!
  13. 20G9 or Meth
  14. Horrible Valve-train noise!
  15. Ebay O2 turbo outlet
  16. is this a good order?
  17. Bypass Valve Touble.
  18. Another 2.3 stroker but by RRE!!!
  19. My Buschur 2.3l is alive!!!
  20. small radiator
  21. Are IX sparks plugs longer than VIII?
  22. civic radiators
  23. what cams are these
  24. Clutch install question.
  25. Tranny help
  26. Is this a good deal on exhaust?
  27. Need help with ignition/security!
  28. Question: Under WOT Engine pauses at 5.5k and Makes a thud noise
  29. Sun auto Hyperforce Ignition
  30. stock biss screw setting.....
  31. 50Trim vs Garret30
  32. aem wide band
  33. 2-STep
  34. Quick- PWR/Koyo Radiator with AMS 3076 kit?!
  35. Comp Cams warning
  36. Please help me out blowoff problem
  37. PEAKBOOST turbo kit users!!!!!
  38. whoops
  39. Pulled the tranny today
  40. CEL Codes P69 and P113
  41. Trying to decide which ebc
  42. BPR7ES plug condition
  43. Knock sensor hook up
  44. Double clutching and clutch spring
  45. Evo 8 to Evoi IX motor swap completed today at Pruven
  46. Magnus Special Race Intake Manifold???
  47. Need Help Flooded Engine!!! Engine seized??
  48. Anyone making pistons for the 94mm?
  49. exedy stage one
  50. New Clutch Time..??
  51. does this sound like a bad fuel pump
  52. gt3567??? please
  53. Used turbo concerns?
  54. ACT Clutch burnt smell at 1000miles?!?!
  55. Timing belt at 60k okay?
  56. O2 Simulator / Mech Fix?
  57. Pt6776r
  58. Stock IX with boost controller??
  59. Stalling issue
  60. Quick ? about BG Synchroshift
  61. stock BOV fluttering/ motor stuttering?
  62. Does adding a fuel pump after dynaflash??
  63. Buschur Magnaflow Exhaust Clips!!!!!!
  64. Apex WS or Greddy SP catback??
  65. HKS DLI 2 vs Sun Hyperforce Ignition
  66. Help deciding on Turbo XS Exhaust
  67. best cam combo
  68. Big Review : JunBL, Ultimate Racing, HPF
  69. Aquamist Install question
  70. Quickest/Cheapest way to get an Evo 8 to 300-350hp?
  71. Signs of a failing stock clutch?
  72. help boost controler
  73. Ams
  74. drop in filter intake
  75. IX Transmission Into 03 VIII?
  76. ATP 3071R Installed, All smiles one question
  77. Bruce Crower or Brian Crower Stroker
  78. Good Place to buy engine parts
  79. mr tranny drain plug
  80. shed some light on....
  81. exedy clutch problem...i think?
  82. I don't think this is supposed to happen...
  83. Cheapest turbo upgrade?
  84. eagle rods
  85. aem boost solenoid
  86. Help car won't start ??
  87. Clutch Pedal low engagement?
  88. EGT Probe Installed - Boost Down
  89. Walbro Fuel pump
  90. Cosworth camshafts
  91. leak down test just tested?
  92. Somethings wrong with my Evos turbo.
  93. GT35R + stock block *help*
  94. Brian Crower Evo VIII Cams Specs and Results...
  95. Stock IX Boost Question
  96. Need help!! uncontrollable boost
  97. WOW!!! What a difference!
  98. Anyone else noticed this with 5 speed?
  99. What cams to use on a 50 trim with UTEC?
  100. need some help, 3rd and 4th messed up
  101. boost leak test black box?
  102. boost leak test: bad throttle body?
  103. Possible to transfer 5spd into 6spd MR?
  104. Strange boost leak problem? Help...
  105. Evo IX Clutches???
  106. Should I use fuel injection cleaner even tho I use Chevron Supreme?
  107. Transfer Case Problems.
  108. Help With 500
  109. Bov
  110. Stock Turbo
  111. Exhaust
  112. 9 second engine bay picture...so simple.
  113. CV joint question??
  114. Nur Spec R - Pipe Lengths
  115. what you guys did with your wideband o2
  116. How do I fix a leaking valve cover.......
  117. AMS 2.3L + RnR GT30R results
  118. Problems To Start Evo 9 New Engine
  119. Need some input on Exedy 4 puck clutch
  120. 50trim vs. GT30r vs. atp-gt3071r
  121. Quick 02 housing question.
  122. TOB help!
  123. Has anyone ever melted all 4 spark plugs?
  124. Eagle rods, what bearings ?
  125. fuel system
  126. Solid Valve Train
  127. Fuel cut
  128. GSC 280 VS HKS 280 dyno sheet inside!
  129. What is wrong with Mitsu techs!!
  130. 9.97 at 142.32 mph !!!!!!!!!!
  131. 2.3, gt35r, 720cc?
  132. Hks EVC help plz
  133. o2 sensor cap
  134. Possible tranny issue?
  135. Evo Clutch install questions...
  136. This may seem like a stupid question
  137. meth air/fuel
  138. ~~exhaust questions~~
  139. RNR/HKS Carbon Ti TBE
  140. UTEC with 1000cc injectors on a 50 trim BB
  141. Loud Thump
  142. oil sensor
  143. new pistons
  144. anybody here with the blitz turbo timer can help me?
  145. LOUD noise / echo when in boost
  146. Help-cant fit spark plug antifouler on Buschur exhaust
  147. Long Rod 2.0
  148. Hallman ES MBC?
  149. Weird vibration/humm/buzz rpm specific
  150. Is Exedy the OEM clutch?
  151. need help/ input on problem
  152. Different hotside for ATP3071R?
  153. how much can the stock head studs handle?
  154. Rods & Power Level
  155. searched and everything still nothing.......
  156. Bypass hose
  157. 1st MOST POWERFUL 9???
  158. 10.5 hotside porting?
  159. For those that have installed headtuds..
  160. HKS Cams without tuning ?
  161. Shep T/C only?
  162. Evo 7 Cluncking rear diff when shifting
  163. Who sells Fluidamper?
  164. Help Fuel Pump?
  165. 2.3 strocker kit POLL
  166. Frustrated With Meth!!
  167. Questions about tuning options.
  168. Homemade intake
  169. Info on Gear Oil for EVO IX
  170. 2.3 Strokers
  171. Does Changing your crank pulley cause knock?
  172. Anyone having drivetrain issues when running big power?
  173. Arc 079
  174. Has anyone switched from HKS cams to JUN or Tomei with stock type turbo?
  175. best turbo out?
  176. car got jacked!!!
  177. Turbotrix 50trim Kit @ the Dyno
  178. crankshaft sensor
  179. Getting some Ratterling from HEAD!!!!
  180. Headgasket how to & torque specs? where can I find this
  181. 3" exhaust ID ?
  182. 3 inch downpipe problem
  183. Can BG Syncroshift
  184. 4 month backorder on OEM 16G IX!!!
  185. clutch question
  186. Front Crank Seal
  187. Removing transmission
  188. what bov for stock ecu 35R IX?
  189. helix cams?
  190. Dyno chart/datalogs of T-67R P-trim turbo on a 2.0L?
  191. Need help
  192. How to wire 2x SPAL rad fans to AEM and controll it?
  193. So I either fixed my boost leak, or broke something **PICS**
  194. DNP manifold
  195. Motor?
  196. 110 leaded
  197. Wait..what's this? Another true daily driver running 10.17???!!!!
  198. 35r equipped evo IXs jump on in!
  199. clutches.
  200. ATP 3076R Dyno Results = 485whp, 411wtq
  201. Issue with Turbonetics Evolution wastegate (dissassembly)
  202. HKS DLI2:how does it work?
  203. Stock OEM Replacement Parts
  204. Recommended drivetrain fluids...
  205. Well i back in the EVO game this time with a IX!Couple questions on mod's take a look
  206. GSC 264 cams questions...
  207. For MR owners
  208. 400whp+ evo
  209. 04, 05, 06 Evos
  210. different boost at different gear?!
  211. True daily driver.....10.19 at 143.70 mph
  212. selling stock exhaust and flywheel
  213. Supertech dual valve springs.
  214. Weapon R intercooler piping is garbage...
  215. Ti JIC MAGIC CATBACK INSTALL QUESTION?
  216. a few questions for 10 seg
  217. 2nd oil cooler
  218. The perfect daily driver cam
  219. will evo 8 O2 housing fit evo 9?
  220. have tbe/intake about to get tuned ?'s MBC or EBC
  221. Dynoed Evo IX with just Flash!
  222. just changed spark plugs, is this normal?
  223. need help on what to do next
  224. Time for a new clutch
  225. Update on TurboTrix HP61 turbo...
  226. Manley I beam rods
  227. Help with clutch install
  228. Help! Defi Controller Wiring w/ Oil Pressure Gauge
  229. Balance shaft alignment DSM GODS PLEASE HELP!!!!
  230. AMS GT35 or Buschur GT35 kit? A question for you guys from accross the pond:)
  231. about to install clutch need advice
  232. Need help. Possible Clutch Slippage
  233. Strange boost leak
  234. transfer case oil
  235. anyone need flywheel?
  236. Stock MAP sensor?
  237. Horsepower Question
  238. Is there a Boost Gauge with built-in Map Sensor?
  239. 6 spd MR tranny weaker than 5 spd?
  240. Am I gonna blow my Driveshaft? Shaking BAD!! Intermittently
  241. Busted Crankshaft [Long w/ cliffnotes]
  242. thicker headgasket?
  243. My first dyno and tune
  244. BOV adapter, blanking plug?
  245. Buschur Racing 20G
  246. Drivetrain fluid drip on driveshaft
  247. I need help with an injector
  248. New water pump?
  249. ebay o2 housing
  250. Ported / Coated Manifold / Turbo???
