View Full Version : Evo Engine / Turbo / Drivetrain
  1. Off throttle flutter/rattle
  2. List of Parts Needed for Timing Belt Change ?
  3. 5 bolt turbine housings
  4. A little help if you please...
  5. Deleting AC
  6. Need help with a 75mm throttle body and linkage
  7. Bad Decel Noise - have questions
  8. Need help quick.....cant get o2 sensor out
  9. Front end problem
  10. Fs Ix Turbo
  11. Air intake....
  12. Boost Level
  13. Greddy Informeter??
  14. Diverter Valve Recirculation Hose - Size/Dimmensions Anyone?!?
  15. Strange Issues with my EVO 8 MR
  16. What exhausts are louder than the Greddy Ti?
  17. 20g-9-5
  18. Oil where it shouldn't be (PICS)
  19. evo newbie needing some advice
  20. battery check lite lit up on cluster
  21. engine oil/oil filter?
  22. Clutch question
  23. upgrade my daily driver
  24. EVO IX: MIVEC and adjustable cam gears
  25. Time for a new clutch
  26. Is a T3/T4 the limit on hybrid?
  27. poppin noise
  28. Engine Decel Whine, Not Tranny or TC
  29. RMR Catback
  30. LSD Oil Help
  31. Need Advice on Ignition (Bad Misfire)
  32. Exhaust cam on IX, anybody with good results??
  33. 4 EVO IX's + Tune from Alfred @ Tuning Technologies = Simply Amazing Results
  34. Exhaust leaks HELP!!!!
  35. slickmotorsports 2.3 gt40 build "sneak peak"
  36. Ses P0507
  37. Confusion with race gas ....
  38. launching.
  39. noise when shifting faster in rear diff.
  40. Broke something....What is it?
  41. forge wga....
  42. stage vi head. (56k no way)
  43. Clips of JDM evos launching
  44. does the APS fmic come with ic piping or just by itself?
  45. ATS vs HKS twin carbon clutch
  46. What to do?
  47. Which Exhaust Manifold???
  48. valve springs
  49. Has anybody in this forum broked there transfer case with the stock clutch?
  50. Has anyone used this boost controller?
  51. ams vs buschur
  52. Good Exhaust Manifod for evo 9 mr
  53. 2003 no lsd issue?
  54. custom turbo possibility for evo9s
  55. stock oil pump efficiencies
  56. tranny and tc removal
  57. non-invasive resistor pack bypass.
  58. adjust shifter cable?
  59. Which exhaust out of these 3!?!?!
  60. Stock PSI on a 2006 IX ?
  61. installing my turbokit, help w/ vac lines please
  62. Forge Type RS never Fluttered
  63. maybe fuel cut off?
  64. Getting compressor surge & part throttle bucking in high gear
  65. loss of boost on 9 mr
  66. Problem....
  67. Service Enginge Soon Light On?
  68. Help Quick, GREY OIL! Blown head gasket???
  69. SlowBoy Racing GT35r Any good????
  70. Dirty air filter = 70 whp!
  71. Head Gasket Work
  72. Metal scraping noise?
  73. HKS BOV Question ... yes another one
  74. Flutter at WOT
  75. Buschur Racing fuel system solutions....
  76. Do I have the least powerful IX w/ mods and tune???
  77. can i use this ignition setup on the stock ecu
  78. First time at the track: Race gas & broken clutch
  79. new tilton (rebuild) AMAZING
  80. just installed a new turboback and have trouble with it
  81. Greddy E-manage + 50Trim....??
  82. just got my BR37r, need coolant lines
  83. Snow Performance Meth kit. Questions and help
  84. best/most accurate gauges ?????
  85. Fluids and dealer stuff
  86. ? for Nisei FMIC owners
  87. normal driving ?
  88. Cams and the effects on boost taper
  89. TME 6.5 turbo vs IX stock turbo.
  90. clicking sound stock?
  91. Car slower after clutch install???
  92. Anyone ever change a knock sensor?
  93. How accurate is Blitz I-colors dyno
  94. trans chatter noise
  95. ultimate racing downpipe
  96. Clanking vibration from tran?
  97. Update on 2.3 build with pt67 turbo (PICS)
  98. Is it tuned rigorously & conservative ?
  99. just out of curiousity. let me know please :)
  100. Clutch bearing noise ACT??
  101. Just had my SES codes checked, got 5 of them.
  102. Forge UNOS MBC HELP!
  103. Dc sports turboback??
  104. intercoolers
  105. clutch install question
  106. Where to buy just a TME compressor wheel?
  107. Need a new clutch, any info on what not to get and what to get?
  108. Crank Question
  109. GSC 280's installed with dynosheets
  110. cams
  111. short shift kit????
  112. Wastegate Question
  113. HKS Carbon-Titanium exhaust worth it??????
  114. Fluid spitting out of my exhaust with a little rougher idle.
  115. 20g TME turbo?
  116. Is this the "50 trim" that everyone's talking about?
  117. Evo Xi
  118. poped out of gear
  119. Shift Alignment?
  120. Aftermarket parts for sale new and used
  121. Lightened flywheel or not?
  122. A1000 in the trunk... good ?
  123. buschur intake require tune?
  124. Power potential for IX
  125. 4g63 supercharger?
  126. evo 4g63 viscous crank damper
  127. need help oil inside the maf sensor and pipe
  128. bushur racing tbe problems
  129. For those using synchromesh.
  130. WHAT WHP will stock clutch hold
  131. V Band O2
  132. HKS DL2 Dyno Gains?
  133. Engine Oil Temps
  134. TME Turbo with 9.8 Housing on 2.3 Stroker
  135. fluids please !
  136. evo ix benefits?
  137. Head Flow Testing
  138. Boost Leak test with upgraded Wastegate question
  139. EVO8 Bolt-on GT Turbo with Housing
  140. Built 2.0 or stroker? Opinions/facts wanted
  141. Quick ACT question.
  142. Invidia Manifold
  143. Manual boost controller on stock engine?
  144. Hey 05 Evo Viii Owners!!!!
  145. Brutal oil leak...bad
  146. tilton problem!!!!!
  147. buschur tbe question
  148. Only 12 PSI! What is wrong?
  149. Blox Cams
  150. evo 8 clutch
  151. Less vacuum line = Less boost?
  152. hks bov
  153. Cannot decide on universal muffler...
  154. which bearing?
  155. idle/boost prob?
  156. shoot flames
  157. Twin scroll GT3076 Vs. GT35. 93octane
  158. Question about wastegate spring strength and drivability
  159. turbo upgrade for the IX. a few ??
  160. BR stage one?
  161. TBE Question.
  162. compression numbers...
  163. Tranny flush after 2k, and look what I found...
  164. New twin scroll dynos with Comp280+
  165. want to install Ti T.M.E. Turbocharger
  166. Overvolting the fuel pump
  167. Buscher intake?
  168. Cosworth EVO IX Cams - who sells them?
  169. tbe
  170. My clutch is finally ****ed!!
  171. Smooth shifter?
  172. Short Throw Shifter For Evo MR's??
  173. Super Fast clutch Install w/pics!
  174. Whats new with the new 20g
  175. CLutch pedal....high engagement
  176. wastegate problem.Need help
  177. HKS has new stuff for 4G63
  178. valve cover gasket
  179. 2 very wierd probelms
  180. ? for stock ecu
  181. Perrin catback...What does it sound like?
  182. What is Wrong with my EVO 8?
  183. Expected bhp of a gt37, on a 2.3ltr
  184. biggest baddest turbo for 03 stock internals
  185. BR cast manifold
  186. couple problems after the track
  187. pics of forge mbc installed
  188. Forge WGA Maybe? - Boost issue.
  189. Denso Fuel pump part # ?? 255lph?
  190. compression test on evo 9
  191. Should i Heat Wrap my...
  192. a need 4 forge dv?
  193. clutch help!
  194. Red Line need help
  195. Turbo upgrade questions...
  196. Speed Source lower intercooler pipe for IX?
  197. Buschur Racing Or HPF GT35R Kit? HELP!!!
  198. just installed DC sport dp..
  199. Need heat shielding for the under side of the hood...
  200. help!? what gaskets are needed when putting in a new engine?
  201. Draining coolant?
  202. Syncromesh in Transfer Case
  203. How to get more appreciable gains from stock turbo?
  204. Stalling After 3" Intake - Resolved???
  205. Driveline Fluids??
  206. POLL: Transmission Rebuilt yet?
  207. A1000 positioning
  208. Ordering my GT35R Kit tomorrow.
  209. 3" exhaust resonator?
  210. Anyone test the limits of stock exhaust?
  211. IC piping hoses for just the connection to the IC?
  212. Megan Racing Intercooler
  213. Purchasing SBR 30r kit tomorrow!!
  214. 06 MR overboosting....
  215. 5th gear scratch
  216. Newb Question Please Help :)
  217. any pics of br-fp3065
  218. clutch opinions
  219. Hesitation at 6k?
  220. cryo2 worth it or not
  221. HELP!!! Boosting insanely
  222. My Turbo XS FMIC Review & Data
  223. just changed diff fluid.
  224. Stroker Kit Vs Rebuilt 2.0
  225. The click click from hell
  226. Blow off valve location?
  227. ALS Plugs???
  228. drivetrain shock
  229. F&F Exhaust
  230. noob DV/Boost Leak Test Question
  231. Oversize bearings? machined crank
  232. Crower 272 Cams Help
  233. greddy profecb spec 2 (EVo8)
  234. wht is a good evo 8 turbo header ??
  235. surge problem
  236. Ebay FMIC's actually perform well?!
  237. mbc problem
  238. just installed evo 9 turbo...
  239. Can't decide which cams to get. HELP
  240. EVOM Cam Guru's! Enter here
  241. TurboTrix HP61 picutres and time...
  242. Anyone have pics of an EVO starter?
  243. clutch clunk noise, HELP!
  244. For those of you that think you dont need a retune after a fp install!
  245. us 5 or 6 speed
  246. potential blown engine. seeking Evo Mechanic
  247. jdm ix gt turbo
  248. help please!
  249. Swapping injectors...Question
  250. Low rpm acceleration not smooth
