View Full Version : Evo Engine / Turbo / Drivetrain
  1. Odd Idle issue
  2. clutch problem...
  3. Car wont start due to blown fuse
  4. question on where to find a specific exhaust...
  5. Tranny Vibration...I think
  6. Idle issue
  7. clutch adjustment
  8. anyone have nlmotorsports install stuff?
  9. ATP turbo "stealth" turbo kits
  10. blitz exhaust bottle necks
  11. Br8eix Plugs Gap
  12. 2 Boost Gauges?
  13. tapping sound
  14. What else do i need for my cam install?
  15. Aftermarket DP/LICP with AM turbo
  16. Over boooooosting...
  17. Walbro 255lph Questions
  18. Anyone use this clutch?
  19. greddy evo2 catback ......
  20. Horse Power Freaks?
  21. name that sound-
  22. 208 whp on a mustang dyno
  23. Why wont IT START?!!?
  24. I need exhaust gasket part numbers!
  25. Removed my thread??
  26. HKS RS Intake
  27. took 15hrs but Buschurs 37r is amazing
  28. short power loss. any ideas???
  29. im used to hondas, just trying to get some more info on evos..
  30. mobile 1 extended life .....
  31. Fujitsubo RM-01A Exhaust Box Dimensions?
  32. Post clutch install problems
  33. Evolution Mass Air Pipe Upgrade...
  34. New Turbonetics GT-K lineup
  35. Shifting still notchy
  36. Does this sound like a good 1st stage?
  37. oil light
  38. Quality LICP?
  39. Is BR3065 same size as a 50trim?
  40. Apexi intake
  41. need some help with my trany
  42. megan manifold owners
  43. Wideband sensor placement for IX
  44. which one would you guys use .....
  45. LM-1 Wideband issue???
  46. Starting Over - 2.0L/PT67dbb build, pics inside
  47. Feels like I've lost power??!
  48. Question about a part...
  49. Boost hesitation when running high boost
  50. 02 censor
  51. Rear diff problems in an EVO8
  52. Speedo not working :(
  53. 2005 MR 6spd
  54. 1 liter enough for full brake flush?
  55. Difficult boost leak
  56. BR 3065 & Clutch
  57. Tuned for test pipe, back to HFC now?
  58. High Pitched Buzzing Sound
  59. Help! What turbo do i get?
  60. Helix Hollow 272 Cams Installed - No Problems At All
  61. GSC EVO 9 CAM RESULTS DYNO'S Inside!
  62. IX shift linkage
  63. My old EVO IX dyno chart (+69ft/lbs with just exhaust)
  64. engine problem- warr, anybody?
  65. Fuel/Boost Cut question
  66. Engine Problem... please help
  67. ATP 30R vs BUSCHUR FP3065
  68. atp 35 kit
  69. ALKY Injection Gone Wrong........ WAY wrong.....
  70. clutch discs universal?
  71. 6 Speed Tranny a weak link?
  72. Lifter?
  73. Turbo prop play...options?
  74. Problem: BOOST Spike + Fuel Cut.
  75. bov leak
  76. Full Stock Turbo back exhaust with race pipe!!!
  77. Would this of put my oil pump timing off?
  78. Lots of vibrations thru clutch pedal...uh oh?
  79. turbo prices?
  80. 16G same as 20g?!?!?!
  81. My clutch made a huge adjustment!
  82. gasket?
  83. engine oil
  84. clutch slipping???
  85. forge rs problem?
  86. how much power you get on stock turbo?
  87. Transmission Question
  88. HKS intake is bad?
  89. Revolver Question
  90. Trouble engaging reverse
  91. Full-Race ProStock Turbo Manifold
  92. Your thoughts on Nitrous & Meth
  93. Least restrictive and most durable high flow cat????
  94. Fuel cut when I mounted Mongoose exhaust on my EVO 6 TME
  95. BUILT motor question
  96. What flange for a 50 trim?
  97. Tranny question
  98. billet coil cover
  99. Hello again - HKS 2604-RM002-applicaiton?
  100. Those with Invidia O2 housing...questions
  101. Hello again - HKS 2604-Rm002-applicaiton?
  102. Exedy mm022sbl - what the application?
  103. ams o2 housing???
  104. list of stock turbo replacements
  105. Cold Air Box for Injen Air intake
  106. anyone run 1000cc inj w/out ems?
  107. Question about AEM EMS + Tial BOV
  108. Fast Oil Filter
  109. Anyone with buschur stage 3 shortblock and head
  110. Clutch Installed, Is my car having problems?
  111. what to watch out for when removing 10.5 hotside??
  112. what exhaust system gets the most WHP gains?
  113. Duty Cycle of stock fuel injectors?
  114. Helppppp
  115. Any one using Ganador Titanium exhaust??
  116. 16g flange, where to buy???
  117. Alternate Comp options on GT3582R ?
  118. use stock gaskets????
  119. EVO IX Cosworth Cams - The 1st Round of Results are Here!!!
  120. car wont start, HELPPPPPPP
  121. big cam vids
  122. Average costs of machine work to build a 4g64
  123. full buschur parts ........
  124. Check Engine Fix
  125. Anyone running a cosworth crate motor
  126. Evo IX MR / RS OEM Blow Off Valve: is it ok?
  127. Where to buy an Idle Speed Control Sensor?
  128. Clutch Suggestion for Buschur Stage 5
  129. Could have this been affecting power?
  130. reliability of WB sensors
  131. Gear whine question...search is too broad (i tried though!)
  132. Guys with 2.3's Chime in please.
  133. Clutch expert, please help!!!
  134. Cams and tune VS bolt-ons and tune
  135. Old vs. New?
  136. Any benifit to a 3.5" exhaust over a 3" ?
  137. Aftermarket clutch and 2-step
  138. IX Turbo, VIII Evo, 2 Dynos, Big Post
  139. does BG Synchro Shift II bottles come with a seal
  140. Evo IX performance upgrades?
  141. 3" dp with stock exhaust question
  142. RRE's - Type-RS BOV Kit – or - WORKS - Diverter Valve
  143. headstud question
  144. How much boost on a GT35R (GT3567R)?
  145. Napa part # for accessory belt with no A.C
  146. BOV issues
  147. MBC installed. Having trouble now. Help please.
  148. Some help please from the ex DSM peeps
  149. Is Revolver out of business?
  150. do you need an upgraded ECM to run cams
  151. Evo IX compression check #'s
  152. Evo Problems. Attempting To Self Fix.!!!
  153. Clutch pedal adjustment
  154. Installed K&N drop in w/o drying it.
  155. VIII cam gears fit IX?
  156. A/Fs before and after a fuel pump...questions
  157. zeitronix meter.............
  158. Need advice Please help!
  159. Boost Guage
  160. 02 housing on EVO IX??
  161. Little Help
  162. Downpipe Difference? HKS 2.65" VS. 3"???
  163. Average life of Braile/Odessy Batter
  164. Cosworth Cams Myth
  165. Loud exhaust pops in between shifts?
  166. Exedy Twin Disc Question
  167. Threw a couple of codes...
  168. Ignition amplifiers
  169. Boost problem!!
  170. Anyone bleed lifters w/cams still in?
  171. clutch hits floor
  172. knock count
  173. Is there any intake does not require a tune?
  174. Low Trap Speed
  175. boost problem
  176. Head gasket install?
  177. confused about tranny leak from driver's side axle
  178. Extension Rod with Exedy Twin Plate
  179. 03 to 05 transfer case
  180. ping noise after oil change
  181. rebuilding motor, need parts list
  182. Pictures of my fixed head (ported) huge pictures. 56k nono
  183. Banjo Bolt
  184. Uicp
  185. Cam Question
  186. VCU vs. ACD - need input
  187. RMR Clutch Disc Question
  188. egt tapping into manifold????????
  189. hey when swaping o2 housing's??
  190. tial bov spring
  191. will it fit?
  192. tranny rebuild part prices.
  193. 3567r???? 37r ect...
  194. What Grease to Use For Clutch Install
  195. Tial leaded or unleaded fuel WG?
  196. Has anybody seen these new evo coils???
  197. Evo boost levels?
  198. What clutch to buy???
  199. Reducing Wheelhop
  200. Would like some help with re-occuring p0300 code
  201. Just installed my motor mount...
  202. what if i put stock intake back on
  203. Question about 03 and 05 T CASE
  204. leakage!
  205. stiffer rear end mounts
  206. ACT clutch = ruined tranny
  207. evo IX clutch chatter at idle
  208. Problem with car starting
  209. ebay 02 housing best for the money???
  210. Dyno'ed my stock turbo :)
  211. Things to check on if you made low hp numbers?
  212. great location for MBC
  213. clutch questions: carbonetics/ATS????
  214. OIL PRESSURE where should it be??
  215. clutch install???
  216. After licp install boost drop?
  217. alternator going out
  218. HELP!!...why does my evo keep spiking?
  219. just dynoed ATP 3071 443 whp/393wtq
  220. RNR GT3076R kit issue help please.
  221. Dumb(?) oil catch question
  222. Problems P0170 fuel trim in Evo7
  223. Spun rod bearing??
  224. another problem.. please help!!
  225. BOV flutter with a BIG turbo
  226. Hallman MBC questions
  227. Walbro GSS317 questions
  228. Coil on plug questions
  229. Evo 9 TME Turbo 6 Blade Dyno #'s
  230. Help with o2 sensor on cat delete!!
  231. Nelp Help!!! Lines On Intake Manifold!!!
  232. alky boost taper
  233. duralast clutches lol.....
  234. RNR 30r kit dyno #'s
  235. Intake Question
  236. how to clock 35r?
  237. what are the differences in a mivec vs. non-mivec cam install???
  238. Smoke at WOT?
  239. Stroker cam gear setting suggestions?
  240. Forge MBC tapering...
  241. ams 3076 question
  242. OEM tranny t-case and rear diff
  243. sporadic engine vibration/start-up
  244. hks cams and cam gear questions
  245. alky vs. cams
  246. T-case Whine
  247. what is the best bolt on turbo for the evo 8
  248. carrier bearing.
  249. post pics of your licp installed, please.
  250. boost hitting 23-24 psi?
