View Full Version : Evo Engine / Turbo / Drivetrain
  1. not oem fluids in mexico
  2. Hotside Studs ?
  3. Tightening the pulley on the A/C condensor?
  4. what are stock 9 plugs
  5. Okada plasma coils VS HKS twin power??
  6. new setup, will these internals work together?
  7. will this downpipe fit my ix?
  8. Strange Walbro Whine after Track Day
  9. samco intake
  10. Flywheel Clatter?
  11. Diagnostic tool to hook up to car for engine/car trouble shoot? Please help me guys!!
  12. Evo IX Vac question
  13. O2 Dump Questions
  14. Not getting full boost
  15. Straight pipe exhaust all the way
  16. Front o2 question!
  17. t bolt clamps - sizes - ams ic
  18. Evo locked up this weekend!
  19. What broke in my Tranny???
  20. Injectors...
  21. KU Engineering 70 mm Throttle body question
  22. Gummy shifter feel
  23. Weird 3rd gear shifting problem
  24. evo's not running
  25. Which turbo is most comparable to the hta3582??
  26. throw out bearing clutch help
  27. Any before and after pics of porting 02 housing?
  28. Heat Barrier Intake Manifold Gasket
  29. My Build idea...
  30. dejon mbc broken?
  31. Perrin 4.5" Filter w/Vibrant MAF Adapter Help Please!
  32. Clutch Problem
  33. What is this noise i am hearing!?
  34. Kelford 272's or GSC S2's:Do I need springs if the block can't handle ovr 8000rpms
  35. Back pressure to Boost ratio???
  36. difference between 3/4 gear in evo 8 and 9
  37. HELP: Tranny Problems
  38. Head cleaning
  39. FP Red Road Course Evo's
  40. Twin Scroll ? T3
  41. Should i port my fp red 80mm turbo
  42. Valve Train Question?
  43. Full Exhaust
  44. Vacuum line off boost solenoid
  45. Larger diameter intake systems?
  46. cause for misfire after motor mount instal
  47. 100% Injector Duty!Rewire Walbro?
  48. Heat Wave Out of Hood Vent
  49. Emissions Question
  50. My sweet custom home made aluminum fan bracket for my turbo upgrade!
  51. Help- Underhood Shifter Bushings and 6pd Reverse
  52. Ppi exhaust manifold vs bushur
  53. What #s should i be expecting?
  54. 2.3l + t67
  55. clutch problem please help
  56. Magnus V5 Cast Intake manifold installed and tested by TTP! 600whp stock motor!
  57. need help on picking a new clutch
  58. car has no power and sounds horrible... misifre cylinder 3?
  59. acd lights came on..questions??
  60. FP wastegate actuator questions
  61. Defective Piston Evo9?
  62. Shifting to Reverse is like moving through tar
  63. Act hdss
  64. had exhaust leak. took exhaust mani. off and found this ::*pics*
  65. FP Red HTA?
  66. intake vs. wideband
  67. What can I use to remove the stock lifters from the evo head?
  68. quick ? about aem and no lift shift
  69. Not sure whats wrong...
  70. 5th gear grind... 1200miles shep trans
  71. FP 80mm Compressor Cover
  72. 4g64 help
  73. Trust/Greddy T67 10cm Turbo
  74. What is going on with my oil return line
  75. Mitsubishi tools
  76. installed ex mani, now won't start
  77. S1 guys your input please.
  78. ATF SPIII fluid
  79. what clutch with mods
  80. Piston Coatings
  81. So where can I find a Mishimoto Radiator?
  82. Help me find a thread about Intecoolers comparsion
  83. (Im going to rebuild it)Anybody has a pic of bad Ring and Pinion off Evo 8 T-case?
  84. 95-97 Galant 4G64 Block Usable For Stroker?
  85. Post your setrab/mocal oil cooler pics with setup
  86. stock camshaft lift?
  87. should i do e85 or not !
  88. Dogbox
  89. need to mod oil pump with ams balancer shaft removal ????
  90. BMC drop in air filter
  91. need advice on my jdm IX MR.
  92. GT35 or 6265 turbo?
  93. Kelford 272's Timing Q's for EVO 8
  94. idle issue..
  95. how do you pull a front axle on a evo 8
  96. Phantom knock
  97. Thinking of going Catless
  98. CAT sensor
  99. Misfiring and Backfiring after Timing Belt and fluids were changed??
  100. Logical thing to do next
  101. greddy type s help
  102. Stock 9 Cam Centerlines at 0 deg adv?
  103. Bov
  104. Head Gasket reccomendation?
  105. Need help!!!! Fried ecu????
  106. Boost problem...
  107. Streetable clutch/flywheel upgrade?
  108. Streetable clutch/flywheel upgrede?
  109. Attention Quartermaster and Spec clutch users
  110. Exhaust mani options
  111. started installing my fp red today...
  112. Clutch issues 1,000 miles from home!
  113. Trans Issue ?
  114. FP3065, Boost leak Issues.....
  115. Should i do gsc s1 cams not sure !
  116. MR 6 speed made stronger?
  117. help
  118. help please
  119. Engine = boom. Questions
  120. Transfer case pressure?
  121. Weird sound, low boost NEED HELP!!
  122. installed pwr radiator and still reading hot!!!
  123. what is the flow rate for an evo 8 turbo @8 psi
  124. Magnus 75mm T/B on Stock Manifold
  125. Plz help indentifying this intake
  126. Boost control troubles after upgrades
  127. Best or really good street clutch kit, in your opinion/experience...
  128. Oklahoma/Arkansas COBB Accessport?
  129. I spun a rod bearing !! :(
  130. JMS Bumblebeast Make-Over
  131. Cam gear install and tensioner pulley problems....
  132. My car shut off will not start
  133. Odd problem.
  134. Evo IX Idling Problem
  135. check this video out
  136. Removing the balance shaft,without removing the block
  137. Spec super twin disc install
  138. Dealership mess up my clutch? Twin disk problem?
  139. Misfiring or Clutch Problem?
  140. ACD removal
  141. hmm so dc sports downpipe rubbing?wtf
  142. Throttle lagg issue HELP
  143. Lesson learned on tuning for boost upgrades.
  144. Tomei BOV?
  145. Couple questions..
  146. AC Compressor Question
  147. Need Help, Were do i start????
  148. Whining noise after belts/cam install
  149. What intake mainifold is best?
  150. how to tq crank pulley?
  151. Car wont start please help
  152. 75 mm Boomba Throttle Body VS stock dyno results
  153. ALL IX owners: What SS Braided Clutch line do you use?
  154. Noob question about Super HKS blow off valve
  155. Evo 8 Camshaft Seal Part Number
  156. Rod Knock... Now what?
  157. Opinions/Feedback on O2 Eliminator Downpipes
  158. Cars Still Smoking
  159. guys...HTA GT3582 or HTA GT3586
  160. vacuum lines
  161. EVO IX MR not boosting properly...help
  162. Eagle rods and stock e9 pistons?
  163. Broke bolt in turbo, what should I do?
  164. 2.2L or 2.3L or 2.4L?
  165. Carrillo Rods + CP Pistons in a stroker
  166. Compression Test
  167. Broken Plug wire?? What should I do?
  168. Locking out between gears..
  169. throwout bearing
  170. STMs Front Facing Turbo kit with Dyno sheets and videos!
  171. wastegate actuator problem
  172. GM 3port vs. MBC
  173. Needs Help.
  174. Size of long bolts to connect to engine stand?
  175. Cel p0401 egr...
  176. 2.3l, gt35r build
  177. Manley Pistons?
  178. MY build. Please critique
  179. Lower Injector Seals - Boost Leak
  180. Buschur C.O.P issue
  181. Is evo 9 gsr stock clutch 'pull' or push type?
  182. Car Died. Sputter Hard. Any help appreciated.
  183. Car Sputtering, not driveable Looking for help!
  184. ETS 4" Intercooler install help
  185. WOT shifting, what does it take?
  186. Is this a real fpred
  187. Hks evc-s
  188. Buschur filter replacement?
  189. TB Leak??
  190. Roaring sound coming from passenger side wheel, gets louder the faster/longer i drive
  191. Need Help Removing Water Pump Pulley
  192. ACD/Drivetrain warranty
  193. Missing bolt in Megan O2 housing?
  194. Wiseco and what compression is this..
  195. Better Fuel pump with no whine?
  196. Need clutch inputs
  197. new clutch = new flywheel?
  198. Likley hood of boost creep O2 housing
  199. TTP's FullBlown E85 upgrade and dynotesting on the stock block 571whp/481wtq!
  200. when i grind into 5th, what exactly am i grinding?
  201. 6 speed conversion to 5 speed
  202. Help needed
  203. Use Blue Locktight when doing Timing Belt?
  204. ATP EVO GOLD Turbo- Aussie Made
  205. need some advice on my set up (fpgreen)
  206. Fully Machined Compressor wheel
  207. Aftermarket Exhausts
  208. acd/Ayc Bleeding Advice needed!!
  209. Shifter sticks to the left?!
  210. Some info on a few things:)
  211. Camtech 272s or Kelford 272s
  212. What part exactly in T-case makes it whine? Mines whines 50-75mph.I want to fix it
  213. Hiccup after 5.3k with AEM EMS
  214. After trip to chicago the clutch fails and wont start?
  215. Perrin downpipe question
  216. Intercooler Piping...
  217. KELFORD 272's
  218. map 02 external wastegate setup
  219. Newest Addition to AWD Motorsports " MostH8d " GSR!!!
  220. 2005 Evo 8 stock boost confusion
  221. V A / V F rods
  222. Does the JM Fab intake pipe work with ETS UICP?
  223. New Inline Boost Controller from Boomba
  224. running hot
  225. Stainless or ARP bolts and studs????
  226. Most 'Civilized' Performance Exhaust?
  227. Exhaust Porting Questions
  228. Head issues
  229. 2.2L 4G63 Kits
  230. What is the highest psi you are running on pump gas with fp red on stock motor?
  231. bad luck
  232. Plx dm-200 obdii
  233. How to port a 9 turbo help!
  234. oil all over the Cat.
  235. Exedy Twin HD Slippage
  236. engine noise help!!
  237. Who here is running Ikeya Sequential Shifter on syncro gearbox?
  238. Comp 280's idling at 17 in-hg?
  239. question about my cams
  240. Another ACT problem?
  241. boost controller
  242. Weird "Bucking" problem?
  243. Looking for just one rod...
  244. NeW FP Red(80mm) vs FP Green(80mm)
  245. Clutch slipping??
  246. need some help from a pro. broke tensioner bolt!
  247. anyone still using syncromesh fluid or ?
  248. Look at what I found in my UICP......
  249. Boost leak test help
  250. CEL problems
