View Full Version : Evo Engine / Turbo / Drivetrain
  1. 4" intake ok?
  2. Perrin Fuel Rail - Review and Install Notes
  3. did i mess my clutch up?
  4. turbo whistling and whining!!
  5. Oil drain plug crush washer.
  6. oil catch can
  7. few q's on the 20g lt
  8. leak test help
  9. Did a boost leak test and my Hallman Pro is the leak
  10. Misfire at 3500 to 4000 rpm
  11. max boost stock turbo
  12. How to crush JDM MR DV?
  13. FPEvoGreen First Impressions
  14. Tranny screwed
  15. fouling out one plug..
  16. Transfer Case problem pics inside...
  17. Update on build (pics)
  18. What else with my BR 35r kit?
  19. bov prob. i don't know
  20. Boost controller problems...HELP...
  21. 3500 RPM Engine vibration
  22. ACT HD with Gruppe-S Fly
  23. Found boost leak problem....please help.
  24. Trouble with methanol injection
  25. yes ANOTHER 2.3 35r build...
  26. IX dyno numbers
  27. Trouble shifting gears
  28. Boost problems
  29. electric cut out
  30. Transfer case what actually fails ?
  31. fuel pump stock or not?
  32. boost problem
  33. cams
  34. Part number and name request
  35. Heater Problem ...
  36. my boost leak w/APS bov: video
  37. boost??
  38. Shifter Bushings :: Underhood or Base?
  39. Noise coming from rear end?
  40. EVO IX...ARP Head Studs Question
  41. tune with o2 housing
  42. Took my car to mitsu to fix my grind...
  43. Built 2.4L Block with GT37R???
  44. how many people running 50 trim here
  45. HFC takes a poop.
  46. Idler
  47. Car hops in 1st gear
  48. need help..have question ?
  49. What clutch do i have?
  50. Reflash and Boost controller add 60whp??
  51. Vac line Routing question on sheet metal intake with aem ems
  52. OK GT35R Setup AMS
  53. Pics Request
  54. Case Study # 335 - Stage I Evo IX - good tuning picks up great power
  55. Stock airbox restrictive?
  56. Anyone with Magnaflow Sport exhaust?
  57. Best HFC for a IX with 02 bung in stock location???
  58. greddy sp2 cat back
  59. Sectioned Exhaust Tip
  60. ignition upgrade???
  61. CAMS on EVO IX????
  62. Got tuned with turboback Now im back to stock is this gunna mess anything up?
  63. HKS 280 Cams and stock valvetrain and more questions
  64. Kelford cams 280's
  65. stock intercooler sufficient for 50 trim kit
  66. Greddy full auto timer - questions
  67. Boost Controllers
  68. Turbo problem :(
  69. Exhaust Manifolds for IX
  70. Evo Spark Plug Wires - MSD Super Conductor
  71. ACT HDSS vs XTSS
  72. Squeaking sound from engine bay. timing belt/water pump?!?
  73. Need Advice Tonight! Maf Sensor Issue
  74. Help!!! Car bucks forward only loud popping noise when rolling forward!!!
  75. Head Cam Caps swap
  76. Evo8 on a Two wheel drive dyno????
  77. MAF Translator Blow Through....
  78. EVO 8 With out ACD ?????
  79. ARP head studs retorque??
  80. best cam gears for tuning?
  81. tune with licp
  82. HKS rs replacement filter? where to buy?
  83. Fueling a NX wet Kit
  84. Evo IX, MBC Settings
  85. JUN cams...who has them?
  86. I burned my clutch today...
  87. What Hot-Side 'A/R' is everyone running on the - GT4202R ??
  88. Please critique WHP numbers/MODS.
  89. From ATP GT3071R to ATP GT35R Disappointed
  90. Case Study # 323 - Cam Gear Settings on BR Stage 3
  91. alcohol injection tank upgrade? What do u have?
  92. Case Study #331 - Stock Ecu Controlled boost on a IX with Stage I - killer combo !
  93. Case Study # 330 - Perfection in a Tune
  94. Case Study #329 - IX with BR Stage II, Pump and Alchy - Street Dominator!
  95. Looking for FP or David Buschur to answer ?
  96. modified the stock airbox
  97. how long till CEL?
  98. tubular exhaust manifold and o2 housing
  99. Got my new Buschur COP setup!
  100. Please help us Tib owners.
  101. turbo
  102. BR SS O2 Housing-- stock turbo + pump gas
  103. Took my car to the dyno today.
  104. need help..have question ?
  105. TPR Magazine - EVO8 Exhaust testing
  106. Forge Wastegate Actuator...
  107. How many people are running alky without head studs?
  108. Best injectors??
  109. Megan header+02 housing gasket question.
  110. should I get valve springs and retainers
  111. IX WOT issue
  112. Disabling MIVEC ... good idea?
  113. Oil pressure gauge reading innacurate?
  114. anybody seen 400 awhp on stock ecu, stock turbo, no nitrous no meth
  115. Stock Head VS PORTED AND POLISHED HEAD
  116. MBC help
  117. Quaife LSD
  118. new IX, gas drain plug leak?
  119. Evo8 vs Evo9 valvetrains
  120. when to upgrade fuel system?
  121. Oil pan leak?
  122. 4" Exhaust
  123. air to fuel ratio
  124. gruppe- s flywheel bolts??
  125. What Do You Think About This Radiator???
  126. Cam gears for the IX?
  127. I need a clutch that can slip
  128. Best Clutch for 400 awtq
  129. running IX stock cat
  130. knock sensor
  131. removing ac
  132. to improve stock 9 intercooler?
  133. Help me figure this out...
  134. aem cid
  135. What clutch for the 6speed?
  136. What is the best scanning software you can buy?
  137. oem clutch disc and pressure plate width?
  138. AEm twin fire ignition coils?
  139. ACT vs F1
  140. HKS 280 & 272 exact Timing ?
  141. +Video+ Help with weird sound from tranny.
  142. clutch install
  143. Spark Plug Issues
  144. anti lag in japan
  145. Cosworth Mivec Cams and fresh remap
  146. Best way to check knock
  147. Which should I buy Cams or Meth injection????
  148. Greddy Turbo kit on an Evo9...anyone try it yet
  149. waste gate spring
  150. which alky systems ..
  151. transmission oil
  152. short shifters on evos
  153. Why meth/water inj and not more fuel?
  154. odd sound diagnosis .....
  155. Maxford exhaust mani help
  156. Anyone running Forge lower front motor mount ONLY??
  157. Stock IX Dumpvalve sound
  158. Curved/Sectioned exhaust tip?
  159. ARe all driveshafts the same?
  160. p/s braket??
  161. Forge Products
  162. ACT HDSS/Gruppe-S Flywheel Review
  163. Oppinion and advise on getting a new turbo
  164. Ignition Amps - Timing Retard Necessary?
  165. Kind of a stupid question
  166. Fully Built 2.0 or 2.3
  167. Gasket Issues
  168. 5th and 6th Gear Sticking
  169. confusion on the 35r
  170. EVO IX owners... Spark plug gap ?
  171. Hallman Pro vs Pro RX
  172. Got torque? 345ft/lbs - NO LOSS IN SPOOL :D
  173. Is the Borla Equal length manifold worth it?
  174. Which turbo for my IX
  175. What numbers should I expect on 2.3L Stock turbo
  176. exedy hyper single clutch rebuild kit?
  177. Removing air filter for 1 track run?
  178. Dyno #s on HPF PT67 turbo and BC 2.4 stroker ...stock fuel and lines and maxed walbro
  179. TBE ok without tune?
  180. DIY dual catch cans
  181. 373 whp and 313 trq.....UNHAPPY
  182. Fuel consumption ?
  183. 80mm??? help me out .....
  184. AFR 21 at Idle.....
  185. New Stage1 clutch smokes out of garage
  186. BP7ES Spark Plugs ???
  187. another evo 9 dyno result
  188. Installing Perrin Boost Solenoid!!! Is this correct
  189. custom IC pipes
  190. Interesting info on Works tuned Evo...maybe the truth?
  191. Cosworth IX Camshaft Test Results
  192. Possible Scam
  193. mbc install help
  194. Another over revv
  195. i need some Help, $$$
  196. help me choose my next mod
  197. What is this tranny part for???
  198. Boost Problems with XEDE/Flash/SMART on Evo IX
  199. EVO 8 VS Dearler part2
  200. building buttom end
  201. spark plugs
  202. Anyone try Buschur's new White Cone filter???
  203. Buschur Racing's new 20gLT, EVO Green turbos ready to be ordered.....
  204. RS R 3"DP ..............
  205. Walboro 255 normal Pressure output?
  206. Black or Lower Discharge Pipe
  207. GP Sports Exhaust?
  208. 2006 Evo IX MR GG question
  209. Methanol Injection VS Race Gas...or BOTH!
  210. 2006 Mitsubishi Lancer Evolution IX MR GG
  211. Sweet new 50trim kit!
  212. Boost Leak.
  213. Car wont start for nothing! Can anyone help?
  214. Blitz Nür race spec exahust USERS
  215. SMC Alky problem ....
  216. my first stage of mods being done this week at rre... thoughts & opinions?
  217. what are ppl out there using for aftermarket tachs
  218. Attention all Buschur racing GT35R kit owners: Please give me ur input on this kit!!!
  219. Aem Tru-boost
  220. Stock Turbo Outlet?
  221. engine swap?
  222. IX EBC boost problems!
  223. Monster-Sport exhausts
  224. Exedy Twin Plate???
  225. Is my MBC broke???
  226. boost question
  227. Bolt on 35R
  228. Engine Oil Insight....
  229. Turbo XS Exhaust
  230. 03 EVO vs Dealership Powertrain Warrenty
  231. Bulgarian Evo 7
  232. Anyone have issues with KOYO Radiator (drain plug leaking!)
  233. Serious Over Boosting Problem
  234. HELP!!! very loud whinding noise evo ix!!!
  235. Powertrain loss?
  236. JUN 264s VS HKS 280s
  237. eBay O2 housing = brings the torque
  238. first time on dyno!
  239. Dual disk clutch
  240. Forge MBC question.
  241. Odd Idle issue
  242. clutch problem...
  243. Car wont start due to blown fuse
  244. question on where to find a specific exhaust...
  245. Tranny Vibration...I think
  246. Idle issue
  247. clutch adjustment
  248. anyone have nlmotorsports install stuff?
  249. ATP turbo "stealth" turbo kits
  250. blitz exhaust bottle necks
