View Full Version : Evo Engine / Turbo / Drivetrain
  1. A Whining noise from Trasmissin
  2. TBE+02 housing=boost cut?
  3. Rev Hard Cast Exhaust Manifold
  4. 90k Maintenance
  5. Best diff fluid/TC fill method?
  6. Wont start.
  7. more HP?
  8. O5 transfercase in an 03?
  9. Jun Lash Killers
  10. replace clutch
  11. Lets get this strait 37R Q&A
  12. Bad Experience with MBC????
  13. High flow cat Q
  14. stock injectors with 20G-9-5@28 psi?
  15. Intercooler piping and BOV
  16. Jet-Hot - Not Recommended
  17. Jun 272 Vs Tomei 280 Camshafts
  18. stock heat range plugs + alky on IX
  19. High Idle?
  20. MIVEC IX into an VIII
  21. Help with SES light
  22. Part #
  23. cams before meth on ix?
  24. EVO IX w/ GT35R
  25. Safe w/ no flash until spring check...
  26. Got bored... made me a COLD AIR intake
  27. Oil Feed/Return Kits-Help!!!
  28. T3/T4 60-1 on pump?
  29. Necessary to upgrade OEM IX Spark Plugs with Alky Injection and higher boost?
  30. Is the Blitz drop in filter good?
  31. What's the best turbo kit for the street & road racing?
  32. installed testpipe..
  33. Dead After 3rd Gear...????..
  34. Turboxs DP owners with wideband please look
  35. wrapping your 02 or DP
  36. injen same as invidia exhaust
  37. E7 Rod Size / Piston fitment
  38. cat delete=failed inspection
  39. Bov help and ?
  40. IX, amazing - why?
  41. Toda 2350 kit or other stroker
  42. 0,5mm VALVES TO RUN UP TO 10.000RPM
  43. transmisson noise is this normal?
  44. Case Study # 151 - IX Evo with Intake and MBC makes great power
  45. Will a DSM manifold fit my evo?
  46. Buschur Delux FMIC & ams GT3076R?????
  47. 2.75" vs. 3" downpipe
  48. TurboXS DP
  49. Oil Light flashing WTF??!!!
  50. What Is The Higher Rpm That Evos Can Run Up To??
  51. BG Syncro Shift I vs II?
  52. Best way to make 600hp
  53. Aftermarket Throwout Bearing?
  54. Shearer 50Trim vs. HKS GT3037s
  55. OBX or Samco silicon intake hose?
  56. Stupid question...How hard is it to install a turbo kit?
  57. BOV or no BOV?
  58. Evo Ix Cams...
  59. Stock Dyno and a urgent question
  60. what flange do i need for a greedy bov
  61. HKS SSQV blow-off valve
  62. Question Regarding the IX O2 sensor.
  63. Big thanks to...
  64. New Tubo..how long before I need to tune?
  65. catback vs. tbe
  66. Tranny and tranfer case rumor
  67. JUN B.L. Exhaust Review
  68. Question about my new muffler
  69. Pure Tuning Evo IX Parts Dyno Testing
  70. Anyone Use Sard Or Magnaflow Catalytic Converters???
  71. AntiLock Light after install
  72. Oil Leak issue, Ruff idle
  73. !!!!! 5th to 2nd by accident what can happend !!!!
  74. Clutch Tranny Motor Mount or what
  75. Where to get- that gold foil heat wrap
  76. forge MBC and walbro fuel pump
  77. WARNING!! please read regarding transfercase oil!
  78. Turbo compressor housing question
  79. MAF removal? is there power to be had?
  80. Fuel Pressure Gauge Questions
  81. Looking for Options: 5k rpm pull drops off (06 IX)
  82. turbo issue or boost leakin
  83. For Street/race Use Best Clutch Are??
  84. Turbo Help-Please
  85. Best street clutch for around $500
  86. Large Thump?
  87. Blowthrough w/GM MAF installed....finally
  88. Twin scroll or not to twin scroll
  89. problems with leaky downpipe/o2 housing
  90. hard shifting at high rpm
  91. Need some help
  92. Engine shaking badly at stop!!
  93. Stock "2 step"?
  94. How do you know if the BOV is bad?
  95. Where to buy a new O2 sensor?
  96. Looking for AFR data for an VIII
  97. Determining Correct Injector Size
  98. big FMIC conseqneces.
  99. 4G63 question
  100. pinging and bucking - no codes!
  101. Case Study # 350 - Comparison - IX20G turbo vs GT35R
  102. Case Study #349 - Why I love stock injectors & what happens when you buy a bad one!
  103. Clutch questions
  104. Rattling after turbo install
  105. compare the gsc cams and cosworth cams
  106. Where can I find polished upper raiator hose
  107. Evo 9 axels
  108. Mangus Intake Manifold, Good or Not??
  109. Apexi AVCR Vs HKS EVC V
  110. evo 8 turbo vs evo 9 turbo
  111. Anyone with a NON-Ball bearing Turbo Updrade PLS READ
  112. Uprated cams
  113. Code PO230 Engine Overboost problem
  114. Blitz Car Induction Kit
  115. Camshafts Solid Or Hydraulic??
  116. CEL not coming on for disconnected catback o2 sensor
  117. Forge BOV
  118. anyone have the perrin TBE ?
  119. 50 trim or gt35r
  120. ACT HDG6 - Best clutch for the money?
  121. 50 trim or 20glt
  122. Changing Shift Knob and Boots
  123. stroker vs turbo
  124. oil questions
  125. Anyone running a NON ball bearing 50 trim?
  126. Oil Galley? Stock Turbo Bracket?
  127. Do you buy cheap japanese car and parts?
  128. Help with test pipe
  129. 50 Trim Turbo Kit
  130. Fuel Pressure Regulator MOD
  131. Help!! -AN fitting frenzy!
  132. Main bearings and rod bearing gone... :(
  133. p0335 problems
  134. Is getting my head ported worth it?
  135. are these good prices?
  136. Code P0234??
  137. Does This Sound Like a Fair Price?
  138. Turbo xs BOV adapter plate
  139. exedy twin clutch wtf need some help
  140. act clutch
  141. I ran out of gas today =(
  142. oil temp reading on triple mitsu gauge
  143. Awd to Rwd
  144. 2nd gear throw
  145. For those that have installed a transmission cooler
  146. Testpipe Vs Resonated Testpipe
  147. EGT wire colours on replacement probe for Apexi gauge
  148. Clutch help!!!
  149. Is this a boost leak??
  150. electric/manuel cutout
  151. Springs and Retainers on IX's w/mivec
  152. EVO turbo upgrade
  153. shep trans, tilton twin
  154. exhaust manifold??? need aftermarket or keep stock??
  155. has anyone tried a centerforce DF clutch for an evo?
  156. 30r vs 35r??
  157. IX Turbo Elbow & Downpipe
  158. Buschur MBC install
  159. British 8.5 MR & FQ-400 cams
  160. carbonetics clutch
  161. Any factory Port Shrouded TO4S Comp Housings ?
  162. Garrett GT3576 Turbo Details please .
  163. Has anyone ever used ebay IC piping???
  164. 10 Psi Shudder
  165. TurboXS MBC questions
  166. pause at hi rpm 3rd gear
  167. carbonetics twin clutch
  168. resonator: bigger = lower exhaust noise?
  169. Centerforce DF clutch
  170. is clutch on its way out?
  171. Which Turbo
  172. clutch
  173. Case Study # 340 - Yes I tune AEM EMS - BR Stage IV with GT35R
  174. fusitsubo cat back and down pipe
  175. Need Help
  176. Vendors, honestly? GReddy Ti for less than $1000?
  177. hks rs intake or ARC
  178. fwd tranny for evo 6 engine
  179. Couple of questions on products...
  180. Oil.Coolant Lines-Plz Help
  181. Tranny Fluid GL-4 Part Number?
  182. P0335 & P0340 Codes at the same time
  183. Hose clamp blow-off problem bit me today, sheesh!
  184. Oil In My Intake and Filter
  185. Blit'z DSBC settings?
  186. requirements to run 50trims/gt30/gt35r
  187. GSC 280 results?
  188. How to ELIMINATE the 35R Fart Can
  189. walbro with install kit needed?
  190. EGR Code!!! Is It common and how to fix!!!!!!
  191. eclipsed evolution
  192. DownPipes?
  193. cutting out
  194. Sputtering problem around 80mph!!!!!!
  195. Slowboy question?
  196. how does the exedy street twin compare to the stock clutch
  197. Drivetrain Kit
  198. BOV of stock intercooler piping??
  199. i need TPS resistance value???
  200. Buschur UICP work with Greddy IC ???
  201. EVO IX - Buschur stage 1
  202. Anyone here running...
  203. the best catch can?
  204. Is it broke??? Help?
  205. Boost restrictor pill REMOVAL
  206. Oil filter relocation
  207. best clutch
  208. Head noise need help
  209. Bung placement on HFC for IX
  210. boost problem
  211. normal to hear turbo spin down when turning car off?
  212. How get more HP?
  213. Turbo inlet ID and OD?
  214. RNR manifold and Koyo?
  215. 358 miles on engine and it's running rough..
  216. Are clutches interchangeable between 8 and 9 EVOs?
  217. Buschur Racing 50 trim turbo kit......
  218. TME, IX, or JDM IX RS Turbo
  219. What Is The Best Setup To Reach 400hp+
  220. SBr Clutch
  221. Differential fluid
  222. Bottom End Built
  223. evo 6 tme transfer oil?
  224. HKS Type S intercooler
  225. Intake Decision
  226. Do you really need a lightend flywheel?
  227. Temp rising- Help
  228. Notchy feel on release of clutch...
  229. Cosworth IX cams in
  230. Boost problem :(
  231. Boost problem
  232. BOV Flange Question ...
  233. Black box
  234. K&N Typhoon Intake Short Ram
  235. Stock Cam gears
  236. Monster Sport Evo VII Air Duct Fitted to USDM Evo IX
  237. 06 MR dyno numbers?
  238. Greddy Profec B users chime in
  239. Turbo for BC 2.4
  240. best cam settings for my 2.0 with GT37R
  241. Weird noise
  242. Boost problem with GT3071R
  243. Valves clicking after oil change?
  244. Very weird problem Please help
  245. Drivetrain fluid?s
  246. JUN cams
  247. RMR hard pipe kit owners.......
  248. Ported exhaust mani+O2 Housing=Awesome!
  249. All MIVEC upgraded CAM owners...
  250. Upgrade suggestions.
