- Santa Came 5 Days Early!
- Greddy upper ic piping question??
- HKS 280 Cams and WR-8 turbo
- evo 8 20g???
- AEM ECU installed on evo 9...
- Hallman PRO or Forge?
- Buschur's Turbo Choices
- Exedy TD HD engagement dead spot?
- whats required to get into the 350-380awhp league?
- Cusco Oil Catch Can Installation
- !!! Intercooler Piping Pictures!!!
- What is the correct oil for transfer case ? I got two part codes
- Should I get ARP rod bolts and main studs 4 Stock 2.0L block???
- wastespark system
- LICP: Buschur or Nisei?
- How many different model HKS downpipes are there?
- Anyone with JIC Exhaust..
- Can acceleration with low fuel cause engine skip?
- air flow meter probs
- fuel pump question
- ACT Extreme duty 6 puck sprung
- Just Installed Clutch and Flywheel:
- I hit 24 psi On Stock Setup
- Proper break-in for EXEDY HD TWIN clutch? Need input on procedures/methods
- Evo Ix Bov
- 418awhp on pump gas
- Boost goes to 29psi in the 2-step!!
- Buschur's FP3065
- Quick question...
- PeakBoost Topmount GT35R pumpgas #'s
- UIP Question
- Code 0420
- Car RPMS weres still at 6K at the light
- kakimoto regu r 06 exhaust
- AFI Turbo Kit Installed
- !!! star a second after i turn the switch !!!
- Boosting problem
- Crank/Cam timing marks
- Is it o-k to overfill the Transfer case fluid?
- evo 9 CLUTCH problems!!!
- Which clutch
- idle problem when car is cold
- buschur ic's
- Question about HFC
- Injen SES cat-back exhaust installed (pics)
- New Cosworth 2.0L and 2.2L Block 4/S at Lancershop
- Rebuilding the 2.3L more then a 2.0L? Bearings?
- Looking for information on "missing fire system" !
- noob Jack point question
- N2O Question. Please help!
- TURBOS GT42R Vs T51R KAI PLUS FUEL
- Exhaust Manifold worth it?
- boost and going to the track
- EVO Green/20gLT information and new dyno charts.
- Finally going to mod
- 1mm oversized valves: Whats the effect on power and torque?
- Tranny Problems
- bad vibration with ac on
- Help anti freeze everywhere!
- Really starting to piss me off
- Anyone Have This Tranny Problem?
- greddy headder
- ignitions for the IX
- Pics of total destruction...(no 56k)
- ***Upper intercooler Pipe...
- Any 280e cams on IX's
- Need help quick!
- What should i do for engine management???
- Modifacations to the block to fit 2.3 crank
- Warped Clutch?!?!
- is it the throw-out bearing?
- Hey Guys, I finally registered under the name for work. Im Here to help
- oil leaks
- Is this a good pump gas combination?
- jackson?
- 50 trim?
- Installed Greddy IC...
- Normal Tranny Build Up? Pic Included
- Why you should not buy a Megan DP.
- Evo IX stroker kit?
- Cosworth M2 CAM VID
- Perrin/Espelier 3" DP fitment on a IX?
- just got an 03 evo , want like 350 hp?
- cams worth it??
- Downpipe bolt spec?
- Ball Bearing Turbos Hks-sos!!!!
- New Fluid Crank Pulley Released ?
- Injen intercooler piping fit Nisei intercooler?
- Which valve springs and retainers???
- Full-Race Turbo Kits Are They The Best?
- help my exhaust is so loud !!!
- spec clutch???????
- Is my Clutch Messed up? Or Tranny problems? HELP!
- should i get this lsd
- AMS 2.3 & GT35r on my IX, I need some advice
- New Evo MR need 400+whp??
- can new exhaust effect my boost?
- TO all Fidanza Flywheel owners
- HKS TT Type-0 ?
- GReddy EVO Upper Intercooler Pipe Install
- Problem with car...
- So why not E50, E75 or ethanol BUT E85?
- The E85 thread, talk amongst yourselves
- stage 3 turbo
- Quick Question...
- Twin Pump Install Pics!!
- Borla Cat-back rattle
- boost surging HELP plz !!!
- quick question about authority short shifter
- Bush surging help plz
- best fmic?
- Cheapest Place for Trans Fluids?
- evo8 block in evo9 ? who has done this?
- So manifold cracked again!
- Turbo To4z Trade To Hks Kai
- oil leak...please help
- arp head studs install
- can't get transfer case back on
- O2 housing question...
- stock dv change?
- Clutch Problem
- How can you tell your oil pump is bad?
- Help with IX MR TBE
- Problem with car running please read and let me know what you thinks it could be...
- HELP no power to Fuel Pump car wont start
- EVO9 JDM rear bumper, the exhaust solution.
- Tuned My IX...Finally
- Air "sucking" noise...
- Starter not spining
- ???????'s for folks with RS's???
- HKS clutch durability
- To the people with 35r and alky
- newb driveline issue 3rd to 4th grind,+ rpm issue
- throttle body MOD?
- E85 Ready!! with style :)
- Boost Profile Question...
- lookin to buy turbo
- DYNO EVO9 USDM Mivec map VS JDM Mivec map
- Hallman Evolution MBC help.
- Some teaser pics of my RNR Turbo Manifold (Stock Turbo)
- **attention All Vendors**
- PP0113, P0335, P0456 codes???
- Need your advise please... (spark plugs)
- exedy rebuild q's
- David Buschur should build a turbo like this
- Spark Plug question
- Braided clutch line
- Is this possible???
- NRR EVO covered under warrenty (POWER-TRAIN WARRENTY)
- whos running a megan dp?
- boost gauge may have crapped out
- hot better than cold?
- high pitched sound
- Anybody want to trade 880cc for 1000 cc injectors?
- HKS Type R intercooler
- what is wrong with my turbo?!
- New Option to Significantly Reduce Turbo Lag
- 2.3 Stroker/GT35 vs Evo IX 20G
- clutch install!! HELP
- Did I piss off the knock sensor?
- gutting stock cat
- Ti - Ti exhaust tone comparison
- help cat back install
- Best clutch for 500+ AWHP and high rpm shifting?
- Heavy pressure plate
- RMR Inter pipes/Agency BOV
- Is there a difference in brand of injectors?
- Greddy exhaust SP2 or EVO2 which one?
- Please give me your opinions on this pictures of my transfercase!
- Has anyone built a intercooler like the Runduce Evo?
- Fuel Pump Ring Studs
- HELP!! Oil Leak from valve cover!
- Hks Oil Cooler Kit On Evo Vi
- 2.3L w/ GT35R on brand new evo9....how much am i looking at? i want reliable set up~
- Install gone wrong?
- Phenolic Intake Manifold Gasket...anyone use this?
- O2 housing
- IX boost tapering w/ hiflo cat
- Turbonetics 62-1
- Upgrading EVO Rods & Pistons w/o removing motor from car????????
- Exhaust comparison test
- What would you get first
- Evo 9 Turbo Flow n Actuator
- 5 speed clutch'flywheel fit 6 speed?
- torque!?
- alky and explosion in sheet metal intake manifold
- who sells the new RSR dp that fits IX
- Evo IX IS there any point for the 20G-LT
- Clunky noisy... lol
- cluth restrictor
- over boosting with ported manifold
- Surging on the standard VIII turbo
- early rev limit/fuel cut off at 5600rpms?!
- cosworth cams
- bc springs and retainers
- Rear Diff. Fluid change
- Weird noise after cams installed
- Blitz Dual SBC Spec R??????
- vacuum at idle.
- water pump leaking again
- Agency Power Gt35r and 30r turbo kit for evo???
- It happened:(
- TTP: dyno plot for your latest setup
- 500whp Evo VIII on pump gas (93 octane)
- Knowledge=Power : Brand new car, fresh motor, how do u like to break in?
- CEL with MBC install?
- DBB 50 trim Full boost
- 4G64 Destroker?
- stock valve spring and retainer?????
- BR 3065 kit...complete?
- Collapsing lifter?
- looking to switch from 6 speed to 5 speed. should i go through Shep for this?
- Most boost on stock fuel pump?
- EVO Green/20g-LT airflow numbers
- BR FMIC or Turbo XS
- Great Shop W/ Good Prices
- GSC 280/280 too much???
- LICP - Incomplete Bead - Would you install it?
- Save yourself a fire or atleast a big mess.......
- GSC 280/ 272 cams with Dyno chart
- GSC Releases our New S1 Cams for the Evo 9 Dyno inside!
- ARC manifold heat shield?
- Are Cams wroth it?
- help! boost trouble leaking?
- Best alky kit for road race application?
- BR's Pure Power Package
- squeaky pedal
- Performance Gains?
- ? about ebay o2 housing
- IX Studders ...
- Greddy Turbo Timer harness?
- COOLINGMIST METH KIT evo people who have it and i need a experianced installer
- ingalls stiffy?
- AVO D-Series TURBO on a 2.3 Stroker!!!! Who Knows something about this KIT!!!!!
- 11.2 @ 120 on the stock turbo, but I want more. What next?
- HorsepowerFreaks 35R makes 568whp 442wtq on stock internals, intake manifold and TB!
- need help on next mod upgrade!!!!
- 20,5CC EVO VI Vs 2.2 EVO VI WINNER IS?
- Possible TC failure?
- act clutch and prolight flywheel installed
- EVO Staged Upgrades???
- Spool of 67mm+ T4 turbos?
- A Whining noise from Trasmissin
- TBE+02 housing=boost cut?
- Rev Hard Cast Exhaust Manifold
- 90k Maintenance
- Best diff fluid/TC fill method?
- Wont start.
- more HP?
- O5 transfercase in an 03?
