- 10.5 pound fly wheel
- Afr Question
- Boost drop...
- what kind of oil and oil filter do you guys use?
- Exedy Stage 2 four puck clutch - opinions
- Is This a Record?
- Cosworth Cams + 2.3 Stroker Dyno Graph
- Opinions on mods for $1100
- Anyone running a Garrett GT3071R
- TT cams on IX?
- Helix 3" Turboback Exhaust Review w/ pics
- Brian Crower Cams
- Case Study # 382 - AVCR EBC on a IX - rpm dependant boost adjustment pays off
- Mitsubishi PN# for a timing belt change
- P0171 Code
- Some spark plug questions
- Heat wrapping the cross beam by downpipe
- Would this turbo fit on my car? Any input on it? Thanks.
- what you guys think !! Evo VII
- HKS carbon/ti res delete.... Worth while?
- Alky Nozzle Size?
- Power steering fluid in differntial
- 15.5 from Mitsu Japan!!
- SLS Turbo Manifold/Turbo Kits
- cat converter for mitsu?
- Whats the oil consumption like on your stroker????
- Standalone or Ecu flash?????
- !!!why is my greddy rs bov keeps fluttering
- Redline shockproof Heavy in Tranny
- Snow Alchy Kit is decent on Evo IX Stage I - dyno sheet inside
- Any stock clutches over 80K miles?
- APEXi PS Revolution Exhaust--Anybody have it?
- Which MBC install method did you use?
- rear motor mount
- what size silicone coupler do i need for the stock throttle body
- Drop the subframe for clutch install?
- ACT carbon multi disc clutch.....
- How to fill a transfer case v2.1
- Meth injection a band-aid?
- XS power lower ic pipe fitment?
- Redline MT90 and MTL blend
- Would you take a free XS Power intercooler?
- Ahh!!! I cannot decide whether to go with GSC S1 or Cosworth Cams for my IX!
- What pistons and Rods?
- Evo 5 with 20g?
- 3076 On a IX ??
- no oil
- Rattling, Chattering, drivetrain noise w/ organic clutch. Why?
- 02 cel fix rubbing
- Help, A/C problem.
- Help!! Boost cut?, High limit?, or Spark gap?
- Monster Sport intercooler Piping kit
- Tranny, T-case, or What???!!
- Which intake???
- Limited Slip Differential
- Why Don't People Use The Hks Ssqv???
- Stock turbo 10.5 hotside
- RNR turbo kits?
- Stock rubber intake hose Vs. Hard pipe?
- maybe boost leak
- clutch ?
- RnR Racing o2 Housing vs. eBay o2 Housing
- HR:evo 8 cam install 7 jan 07SUFFOLK,va experience needed
- What should I do?
- Injen Intake=What filter?
- greddy egt guage install
- FQ-400 1/4 mile question
- Help ! with rear axle removal
- PCV Rotation ??
- Suggestion on installing Wideband!
- Who is running the Greddy or Jic Ti exhaust?
- !!The Best BOV For evo 9 Recommend!!
- How much boost on stock block evo..with stock turbo..??
- VIII & IX turbo mani the same??
- CC EVO 9 Carbon Fiber Cam Gear Cover
- Buschur Air intake Vs. Intake Kit, which one?
- problem with RSR Ex-mag
- Best Turbo for AutoCross?
- problem help please!!!
- Gearbox removal.
- Shifter Bushings...metal or poly?
- Aftermarket Oil Pan
- Not good. Ticking on start up.
- P0300
- Clutch and Restrictor Removal?
- Mr trans mission hard to get in gear in winter
- Stuck at 12 psi...
- How about a 25G (Greddy T67) and a 2.3L/280's combo?
- up the boost on my tune?
- 02 sensor help
- o2 sensor question
- Ultimate Racing FP Adaptor Threading
- Just Installed New Manifold...
- Evo 8mr
- Breaking in an ACT clutch
- ATS Clutch
- N/A 4G63 head info.
- Lightened Crank Pulley Perrin
- 4G63 forged motor?
- Weirdest Problem Ever Eoncountered...
- transfer case leaking oil
- royal purple trans fluid?
- which lower intercoller pipes....
- evo 3 4G93T drivetrain viabration
- P0011 code on evo 9?
- Evo abbreviation help
- upgraded cam gains????
- The Tuning Technologies Dynojet Database Project is ready for viewing - see link
- Aftermarket Intake Manifold Gasket
- boost leak?
- B&M Adjustable SS doesnt fit IX
- 350+whp on stock turbo? CA 91 octane
- revolver springs and retainers from buschur racing
- installed new plugs and it got worse
- Anyone re-torqued stock head bolts.
- cams
- Megan Header Cracked!!!
- 780cc on gt35r?
- How much power do I have ??????
- Is my clutch going?
- A'pexi Isamu dyno graphs?
- Converting 9.8T to Evo IX 10.5T the Mitsubishi way?
- obx cams?
- WHAT??!! Stock turbo/inj/Ecu 374 AWHP on Dynodynamics?
- Turbo Smart BOV...hopefully a good buy
- Found leak between turbo & hotside but...
- evo 9 mr part out sale !!!!!!!
- evo 9mr part out
- Clutch upgrade needed?!
- blown head gasket
- Lots of vibrations thru clutch pedal...just had exedy twin installed
- Cheapest place to buy a front LSD?
- got my head back from being ported
- Does fujitsubo legalis fit ix mr?
- Engine ticking
- TurbTrix Cams on IX?
- wierd noise?
- "cosworth Cams On Ix" By The Shop And Dynoflash!!!
- Synchronic Blow Off Valve
- Case Study - Evo IX Stage II with Alky - stock vs Cosworth Cams
- stock Turbo Q
- What kind of weld wire on exhaust?
- What do I need to put stock exhaust back on?
- upgrading to revolver cams???
- Help! Wedge collar will not click onto TOB
- APR 3.5" DR Exhaust....anyone try one yet?
- stock valve question?????
- Stock IX with compressor surge???
- 2 step?
- Rattle coming from the eng. bay
- Comparison GT3037S 52T and GT3071R (-23 CHRA) ?
- 24 psi on stock 8 MR turbo
- what can i expect with 35R and meth?
- Size and pitch of downpipe bolts
- MR Downpipe clearance?
- M-85
- HKS 272 cam kit on HRA9.8T?
- Just dropping in pistons and rods
- Snaped manifold bolts...
- Hmm...Interesting observations after electronical boost gauge install
- Looking for some help!
- cranks, LONG rods, and stroker pistons
- i need suggestions....my car's NOT boosting....
- popped out of 5th gear while driving
- Question on GT35R
- misfireing after spark plug change
- Any Truth to this? "Two Step on Stock ECU is BAD."
- Help Required
- Attention all Cosworth or GSC EVO IX cam owners
- response time of a wideband sensor
- Nisei intercooler + piping?
- Need new clutch
- Loosening/Tightning of timing belt
- hks rs intake causeing car to stall?
- map or maf? dby or cable?Mc Pherson or double wishbone?
- 650 to spend
- Tial BOV w/ stock turbo/maf but at @28psi. Who has it? Problems?
- * best cams to put on EVO IX?*
- alternator / battery question....
- mitsu gear oil ?????
- cosworth 8 cams
- 2.4 Stroker with 35r dyno graph
- Will Evo 8 Manifold covers fit Evo 9's?
- engine oil question?
- problem installing greddy bov
- Cosworth or GSC
- O2 Housing Gaskets
- Drivetrain noise, need help diagnosing
- Engine Removal: Plz Help!!!!
- Comments Required!
- Zeitronix ZT2
- CD5W Liberoz 93t Wagon
- Trouble Going into reverse
- Stock Evo 8 injector hold current spec?
- Where can I get custom IC pipe hoses?
- What DP would fit well with the Invidia o2 housing?
- Anyone using the Saiken Michi co. DC3 Catch Can?
- Engine not idling properly........EVO 7
- HKS cams for evo 9
- boost leak results..vid
- quick help tap!?
- 50 shot on evo 9?
- Who makes a good Alky Kit?
- odd boosting problems
- Having Problems with my 4th gear
- Manual Boost Controller vs. Electronic Boost Controller
- spark plugs?
- Did I Screw Up On My Boost Controller Install??
- K&N oil filters
- When to change coolant and brake fluid?
- Cosworth IX Cams RULE ! My test
- Help needed on reinstall of Tranny
- Where Can I buy a throwout Bearing?
- Scary Noise Coming From????
- more torque???
- What Gear lube do I buy?
- Understanding ACD influence on real world daily driving
- Engine Bulit help
- My new Injen Intercooler
- SCAT or Eagle ESP rods?
- Need a good mechanic for clutch install in So Cal!
- question about tranny's
- 2006 Mr Tranny Installed In 2006 Evo 9 With Ssl... Pics Inside...
- Forge MBC Part #FMCB051
- Help needed Tranny Removal
- Downpipes with flex sections. A question.
- Custom turbo kit idea cheap....does it look like a nice setup?
- Help!
- BAD lag after parts install
- hi flow kizzzat
- BPR7 OR 8 ES'S For my setup
- Stuck Clutch in 3rd Gear
- carbon tripple question
- Zeitronics Users!
- dc3 catch can or rre catch can???
- 4G64 crank or aftermarket
- My 2.0 Build Up 56k come back in a Week!
- Add on resonators
- Mine and a buds FP20gLT dyno results.
- EVO IX boost issues?
- All the small things
- Loud popping noise and smoke out the hood vent
- ACD equiped Clutch install
- HKS Filter Question
- catch can importance?
- Great deal on HKS Pistons
- EVO 9 Specific test pipe
- Santa Came 5 Days Early!
- Greddy upper ic piping question??
- HKS 280 Cams and WR-8 turbo
