View Full Version : Evo Engine / Turbo / Drivetrain
  1. Which LICP is recommended?
  2. swapping 05 diff into a 03??
  3. question for peopel running larger throttle bodies
  4. Boost controller suggestions welcome!
  5. New SPEC twin disc
  6. !!!AEM Gauges Installed By Machine Gone Wild!!!
  7. 5 speed vs 6 speed centre diff
  8. What aftermarket parts are you running with your IX's and are you happy or not?
  9. buschur race ic
  10. MAJOR help needed
  11. Clarification for P0138 EGO Sensor Circuit High Voltage (Bank 1 Sensor 2) needed
  12. **GSC S1 CAMS installed**(Pix Inside)
  13. tuning for 110 oct?? lean it, more timing?
  14. Consumers be weary of misleading information.
  15. Whining Noise
  16. resurfaced flywheel
  17. Lean A/F and Idle stumbling
  18. ATS Triple Disk cltuch
  19. Question after FMIC,LICP,UICP and Forge bypass install...
  20. anyone w/an hks hi-power catback plz stand up
  21. question about dumping the clutch.....
  22. New HKS BOV ????
  23. Garrett Turbo sizing????
  24. dumping the clutch....
  25. 3.5" Over 3.0" Exhaust Debate
  26. Galant inline fuel pump...
  27. Tanabe Medallion Touring
  28. Who has the BR Stage I for the VIII?
  29. Does you exhaust hang low??
  30. Turbo Kit VS Stroker Kit???
  31. Monster Sport Intercooler Piping
  32. Got a baseline dyno today...
  33. help!!! NEED TO KNOW WHAT CLUTCH TO GO WITH!!
  34. Blitz Nur Spec Bl MM3030 ??
  35. Need ACT clutch
  36. Why most popular Evo exhuasts suck - a tube is not a tube - read - case study
  37. Help Water level low / cuts / Temp crazy / Noise at start up
  38. Dual Grey A-Pillar 60mm Gauge Pod
  39. Who's using Ultimate Racings CAI?
  40. Tilton clutch ?
  41. JUN cams in stock? Who has them?
  42. Megan Manifold vs Buschur Manifold
  43. Can a HFC be flipped and still fit?
  44. Input on an 02 housing on a IX
  45. Anyone make a Air filter w/ air funnel built in it?
  46. Exhaust troubles
  47. Full Powerflex Bushings Diagram/Part #s
  48. Truboost gAE question / Evo IX int wg spring?
  49. need a belt for NO a/c
  50. The EBAY Intercooler
  51. Weak Evo IX Turbo?
  52. Perrin exhaust clip
  53. Hks Ebc
  54. Greddy Mivec cams.
  55. max boost on stock head gasket?
  56. tranny fluid
  57. size of turbo inlet
  58. Forge wastegate actuator or Buschur's high boost wastegate actuator
  59. how to install meth kit?
  60. GSC S1 Exhaust Cam only results inside.
  61. Stock turbo removal question?
  62. Biggest Cam on Stock Valvetrain?
  63. zeitronix zt-2 and vacuum @ idle on stock IX
  64. Trouble Code PO401?????
  65. Any one jealous of my stock turbo outlet
  66. Perrin PW1 Water Injection??/
  67. Bad cam gears?
  68. Before/after dynos of BB 50 trim on a IX?
  69. clutch and turbo manifold questions
  70. 6 speed (MR) transmission fluid fill and drain bolts?
  71. Any Evo IX's with the ATP kit?
  72. The "Evo Thump" on the Shift
  73. How much HP?
  74. What do you guys think?
  75. which Kevlar clutch should i go with?
  76. Turbonetics GT-K Series
  77. going in to get tranny checked
  78. 272's vs. 280's
  79. what it takes to get 400-450 whp?
  80. what should I make?
  81. BOV connection on Garett turbo
  82. question for tranny experts
  83. Latest Tune by MZM International
  84. questions on mbc and dv!
  85. Some goodies thanks to Greg@GSC
  86. 2 small problems
  87. who sells 8 ga. SS bends?
  88. cosworth isp head flow numbers
  89. Jun 264s
  90. Looking for a BOV Flange....
  91. Motor/Tranny Mounts....Revisited
  92. Cam Install tips
  93. help my hks evo 5 just broke
  94. Aps
  95. ss 02 housing
  96. buschur modified fuel pump walbro
  97. XS Engineering Intercooler pipe kit questions
  98. ix turbo on VIII
  99. 10.5 hotside
  100. difference between 3037r and 3076
  101. Lean A/F ratio.
  102. Dual Walbro Flow Tested
  103. Clutch problem or tuning problem?
  104. Is it time to upgrade my stock IX injectors and spark plugs?
  105. Is it time to upgrade my stock IX injectors and spark plugs?
  106. magnacor wires question?
  107. Loosing boost through DV(stocker and Forge)...
  108. Profec B Noise????
  109. bov ???'s
  110. Spark Plugs For IX
  111. FMIC Thread request
  112. Walbro Importance?!!
  113. HKS Super Hybrid reviews??
  114. Help! Hiccupping problems :(
  115. CEL Light : EGR Insufficent air
  116. anyone know what about a GT61HP turbo?
  117. A chunk of my oil bracket fell off while driving. WTF?
  118. EVO 9 20G-LT + GSC S1 cams dyno!
  119. RRE GT3076R Turbo Kit Review
  120. Clutch and flywheel???
  121. EVO IX Cosworth Cam Dyno Results
  122. JUN-Revolver-Cosworth Cams?
  123. what do you think of the Turbo XS Short Ram Intake?
  124. GT37 76MM 52 TRIM 750HP. Is it direct bolt on?????
  125. Finally!! Full Blown Dual Pump with stock lines..
  126. 20G-9-5 to 20G-LT
  127. Forge FMDVEVO15 Diverter Valve on Evo 8????
  128. Dynoed 100 octane!!! ### inside...
  129. test pipe question(helix)
  130. i broke my evo!!
  131. Wow Look what i found. HKS LA CLUTCH (single plate)
  132. trouble with mbc
  133. bad idea to mix tranny fluid?
  134. Help Me Decide....on Exhaust setup!
  135. carbonetics carbon twin plate failure + pics
  136. Check out my Dyno results
  137. Gear grind only in 3rd
  138. Crushed MR BOV
  139. gsc280 cams or cossworth 272 cams
  140. vendors??? oil feed line from filter housing??
  141. Any Penzoil synch 2 BG 1 synch or BG 1 sync 2 Penzoil sync users?
  142. My EVO IX dyno #
  143. What your EVO needs for a fuel system, facts.
  144. ATP/Aftermarket Turbo Kit Boost Line Hook-up w/ Stock Boost Solenoid + MBC
  145. clutch probs, install new
  146. Anyone running SS oil cooler lines?
  147. for those running 35R with stock block and ecu
  148. RS Diff?
  149. evo 5 cam angle sensor orentation
  150. Buschur 20G-LT/FP Evo Green Arrived Today!
  151. drivetrain damage..
  152. Stock oil pressure?
  153. help with misfire~~~!!!
  154. Finally got to dyno my IX !
  155. Fixed Profec B Spec Ii...
  156. tranny, grinding a lil.
  157. Any Evo's running Zoom clutch?
  158. HKS sequential Tranny
  159. Upgraded Ignition Coils
  160. different turbos?
  161. Ceramic turbines?
  162. OBDII pin description
  163. How To Tell???
  164. Came to the conclusion tonight....
  165. what all do i need for built motor?
  166. evo 8 tsb's
  167. Where can i find a dealer that sells GSC S1 cams for my IX?
  168. Big Boost
  169. Service engine soon..HELP
  170. Which intake manifold for road racing
  171. you think i can get around 300 whp with these mods?
  172. Quick time performance Evo downpipe
  173. Greddy TI - Decibel ratings?
  174. New Clutch
  175. Stock Fuel Pump Specs?!?!
  176. 20gLT/50 trims/gt35/??
  177. Which Fluid is better??? *PICs*
  178. Fuel Lines?
  179. Evo Tire / Gear / RPM / Speed Calculator
  180. Evo Ix Ecu Pins!!
  181. 2.4 Evo?
  182. 20G LT, 1st. day review.
  183. o2 Housing causing fuel cut off?
  184. What oil do you run??
  185. High Idle
  186. Fuel Pressure at Idle W/ Walbro
  187. turbo install advice
  188. Tune and Boost
  189. p0300 code on 03 evo
  190. treperformance 255 fuel pump
  191. GSC S1's soon to be installed
  192. Clutch options
  193. evo 9 stock ecu can handle up to 500whp?
  194. stock headstuds - high boost
  195. dyno graph with STOCK downpipe
  196. New Skunk2 Composite Intake Manifold
  197. results from tuning my IX!
  198. Hard to go into gear?
  199. the drivability sucks with ac on
  200. Psi/kg
  201. Advice welders
  202. Proper use of EGT meter data
  203. Broken boost sensor: MBC = Quick fix?
  204. TREperformance fuel pump
  205. Cusco Hyper-Sinlge Clutch: Where to get rebuilt?
  206. 6Speed Stock rev limit question?
  207. Nitrous, Boost Leak?
  208. 2.5inch decat?
  209. Something New
  210. Stock vs TBE + MBC + EcuFlash
  211. Need Help On Bov!!!! Please
  212. Solid Lifters Or Shiems?
  213. Gears problem
  214. clutch questions
  215. open dumptube or recirculate into down pipe?
  216. large turbos louder
  217. Tilton Full Cerametallic Question
  218. Anyone using an eagle 94mm crank in a 2.2L stroker
  219. ATP Turbo Kit Intake Solutions
  220. What do you guys think??
  221. oil catch can?
  222. Code P0420
  223. Fynetune Gt37r Kit 695 Awhp
  224. Intercooler:
  225. Stock airbox cover removal on a IX
  226. Exhaust
  227. CEL came on tonite...
  228. Evolution IX Turbo VS. Evolution VIII 10.5 Turbo
  229. How much - Redline Water Wetter
  230. Stock BOV outside the intake?
  231. South Bend Clutches??
  232. 05 EVO 8 Turbo Kits
  233. To MuCh BoOsT!!
  234. Boost leak/Boost Controller issue?
  235. Exhaust clamps, Buschur(?) TBE
  236. Let Mitsu Replace Synchros OR ask for new Tranny?
  237. Various Intercooler Weights
  238. Buschur Evol 9 LICP installed
  239. misfire code need help
  240. New type K&N airfilter placed
  241. Oil leak at 300 miles...
  242. Hydraulic humming from rear of Evo
  243. SRT 4 Guys are Chasing us....
  244. danger to overfilled transmission and t-case?
  245. Exhaust again
  246. questions about the stock rs/mr gauge set
  247. 10.5 pound fly wheel
  248. Afr Question
  249. Boost drop...
  250. what kind of oil and oil filter do you guys use?
