- apex'i vs arc or others intake comparison
- help me pls.
- Help!
- IX o2 wire colors?
- General IX questions
- Well my clutch is going out...
- Help Evo 9 Plug Gap ILFR7H Urgent
- Is it bad if my downpipe hits my ACD?
- Why my water temp gauge wend dead ??
- Looking for bolt-on selection advice.
- Anyone running the PeakBoost GT30R w/ .63 AR
- Is this my transfer case or what
- Radiator which one ?
- finally got on the dyno
- 922whp for the Danimal!
- who's running "precision" injectors?
- Buschur Custom Flash vs. full custom tune?
- 20g turbo
- The competitions coming..so AMS and Buschur Racing teamed up....
- Best Clutch for street and 400 HP?
- What do you think.
- Stroker Build: Eagle Crank or 4G64 crank
- can evo 8 head be converted to mivec to work with an evo 9?
- Wont go into gears :(
- 375whp attainable?
- problem with acd
- 20g ?
- bad BOV cause a SES light?
- Is this a complete set of IC pipes?
- Bov
- Buschur 20G-9LT Results
- oxygen sensor plug answer
- what BOV is AMS using?? *vid inside*
- Is this a good boost leak tester for evo9?
- Installed exhaust...should I reset ECU?
- is peak boost suppose to announce their group buy today?
- 5th gear vibration
- Evo 5 Tranny + transfer Case Same as Evo 8?
- Clutch install
- Triple Intank Walbro??
- another 500whp evo
- intercooler delete pipe
- Go for HKS 2.3 stroker or stick with my JUN 2.2?
- 02 sensor plug size???
- Ebay exhaust..My dealings with the vendor
- hks 264/272 to hks 280s?
- EVO 9 J Pipe?
- Exedy Stage 1
- Fuel Filter
- Need Help
- Suggestions on a good resonator?
- Would this be a boost leak?
- Megan testpipe to stock dp
- Rod Bearings
- Ideal AFR Map for 93
- service manual
- FP Green water/coolant line
- air temperature - right before IC and right after IC, on a stockish turbo
- Clutch install time ? which paint?
- IC pipe rattling sound?
- Need Help!!! Emergency!!
- Factory Cam Specs.
- Intercooler Hose Diameter
- switch transmissions??
- t/c question. does the whine get louder?
- unburnt fuel on floor at start up?
- Megan catback fitment on 05 EVO VIII MR
- Boost problems?!!!
- Which exhaust is the quietest
- Bosch LSU4.2 Wideband Sensor?
- throtle body
- Warning for anyone who cares about their transmission...
- P011? Anyone else having this problem?
- What Coolant?????
- EVO 8 MR 5 or 6 speed tranny
- Which turbo kit to get?
- HKS Evo IX cams and MIVEC controller
- Looking for Rod Bearings
- lets talk 2.2 liters
- stock IC - bottleneck for a green turbo?
- thinking about changing my goals...
- Larger Oil Cooler: Pros and Cons!
- Evo Turbo for 400 AWHP club Buschur vs. Turbochargers.com
- Pruven Evolution 9 480awhp / Street Video
- Turbo Timers - Needed ?
- The Buschur 20GLT/AMS 2.3/280's/Meth. My writeup.
- 16G boost puke-n-die help for high rpm
- t-bolt clamps
- titanium gear replacement for MR 4th gear problem?
- Not another BOV thread - stock IX BOV part throttle bucking
- Shepherd Racing options???
- Will the Invidia O2 Housing fit with the Ultimate-Racing 3inch TBE
- Bad ASS EVO on E85..........
- Injector or valve ticking?
- Tilton or Quarter Master
- dv clicking??
- New Clutch
- Lets's narrow down to IX MR w/ Jdm bumper and Ti or blue exhaust/muffler
- Intercooler pipes and prices
- evo owners be aware...
- I Just Blew My Motor!
- oem intake tube/Airbox/MAF is $HIT
- New sound from the engine....
- Buschur Racing 20G-LT DYNO results review
- Turbo housing ?
- Need help w/HKS EVC
- Idle troubles w/ my IX (video)
- Best way to set boost spike? roll-on gas from low rpm or stomp @ 4k?
- sudden OCCATIONAL rough idle
- oil was overfilled
- Spark plug cover cracks
- Ball joint pop/knock already?
- Walbro pump?
- Blown Motor
- Backfire problem at peak boost
- Best injectors?
- Exhaust data
- Dejon EBC?
- 2.3L stroker, Good Deal or not?
- Transmission
- Swap whole t-case or just LSD?
- Cam Question
- Turbo XS TBE?
- Post Turbo EGT Numbers?
- Anyone have pics of ported hotside??
- The "magnet" test for your "stainess steel" exhuast
- HELP!!! Wastegate question
- Titanium Pistons,Rods, Cranks, Camshafts,etc....
- built motor and 35r ? on oil pressure
- Whinning Sound???
- Piping blowing off
- replacement front o2 or Wideband
- st0ck clutch
- My 2.0L Motor :)
- burning oil
- Twin intake/double pumper...more Buschur results..
- '04 RS t-case into '03?
- Video of 644 whp EVO9 on Buschur Racing's dyno
- TTP-Engineering High-Flow O2 housing Bolts?
- ingalls torque dampener leaking
- boost level questions need help...
- How many 6 speed owners would put this in their tranny?
- Non ACD T/case on ACD + AYC EVO??
- MEGAS dp and ULTIMATE RACING test pipe bolt up ??'s
- Quiet exhaust with no loss in Performance
- Tuning Guides or Books...
- boost gague busted or need to turn the boost down?
- To much boost?
- Evo 9 Cosworth Cams dyno
- Timing belt change
- IK24 or IW24
- which head gasket? head gasket sizing issue..
- WAT NEXT upgraded???
- s-afc bad???
- alky injection kit???
- i need opinions
- The tip of the spark plug broked,need opinions?
- IX w/GSC S1 cams & meh - Need Injectors?
- Questions on oil lines RNR guys look!
- ATTENTION ATP turbo kit owners and others.
- Deceleration Noise?
- Strange boost problem
- Thinking of buying an Evo, but worried about tranny problems. TSB's?
- PEAK BOOST vs Shearer vs AMS <--(50trim)
- safe to turn up boost?
- Clutch pedal vibration????
- aem short ram
- greddy type s bov
- AUTOmeter z series gauges
- 20G-LT Camshaft options....
- Idle Problems Hunting
- Evo 8 front o2 sensor question
- Help please with intercooler piping !!!
- Pruven Evolution 9 39psi/687AWHP dyno video
- wat next for evo??
- Buschur Racing just finished a SICK Evo 9
- 400whp IX possible with ONLY cams or ONLY Methanol (Plus supporting mods for both)?
- ss clutch line install.. Do i need more brake fluid?
- Reseting Ecu
- 9k miles & clutch slipping???
- got a IX 23k ,,,hearing a little whinng u think its my transfer case ..
- Instron tensile test: stock headstuds Vs. ARP headstuds
- Official Dual Walbro Flow Test...
- What kind of oil is best at Evo engines? Valve ticking..
- Difference in Nisei FMIC Street & Competition?
- upgrading manifold..
- IX upgrades - sanity check
- Mail in flashes
- heat wrap downpipe.
- Intercooler upgrade question
- BR Mail-in Flash......PERFECT!
- different dyno tunes
- Has anyone used the gruppe-s flywheel on their evo?
- ECUTEK vs reg custom flash?
- Quick exhaust question
- Another turbo thread with poll
- supertech dual valve springs?
- Throw-Out Bearing or Burrs on Clutch Plate
- AEM Tru-Boost question
- noise coming from back
- Coolant leak smell
- Megan DP and test pipe. Same for both Evo VIII and IX?
- Is this a stupid idea?
- Update on second build
- zeitronix / knocking
- Best Quality High Flow Cat, And JDM Rear Bumper
- Benefits of LICP
- Changed oil now clicking sound.. help
- Ti Upper IC Piping
- Boost Cut W/Minimal mods
- 20g or 50 trim
- Question about MBC
- Which 680cc injectors to buy?
- Need Help on this subject!
- PeakBoost 35r top mount kit
- Can i run Nos on my built 2.0L engine
- Dual Denso Pumps !
- fpevo green dyno numbers
- Most WHP on Pump Gas 93/94 Octane Straight up Daily Driver
- Can someone help me identify a noise from my car?
- agency power lower motor mount
- 280 cam install
- How Important is this piece??
- About LSD
- PLEASE READ GT35 impressive setup
- Short Shifters
- AMS Ti TBE
- Wierd coolant temp gauge readings.
- BC 272s, BC Springs and Retainers and more
- all about CAM GEARS
- overboosting after 6k rpm?
- HKS carbon TI with dc sport dp NO CAT
- FP3065 on 91pump/alky - Who does it? (Compared to 50trim)
- How do i remove a pin on the ECU harnes??!!! AARRGGHH!!!
- EVO IX GSC cams
- **GSC S1 CAMS TUNED** Numbers inside!!!!
- what plugs shoud i use?
- 3" cutout or TBE
- link to TRE?
- Evo problem... Boost
- plz help hks evc is blinking
- Gearing change
- WR application question or larger turbo
- Pruven Evo IX Updated Pics/480AWHP Pump!
- Turbo XS Dtec BCFC
- AMS 50 Trim or Buschur 20G LT? I'm torn!!
- turbo xs d/s mbc
- weird situation...need exhaust advice/help
- Are all EVO IX's diffrent do to the MIVEC?
- Flywheel Question
