- anyone with forge dv please help.
- Problem with Boost Creep...??
- Agency power ti exhaust?
- Who's 50 Trim Should I go with?
- Turbo Spool Tables
- Mass Air conversion, to VTA 100% and no problems
- tial bov w/o ams ems?
- could the "Death Whine" NOT bet the transfer case?
- jun cams,valve springs and retainers
- What does it take to put a EVO IX turbo on my 03 EVO
- 12 flat
- IC sprayer pump
- Main Bearings & Rod Bearings
- What is the thread size/pitch of our knock sensor?
- Carbonetics Triple Plate any good ?
- BOV ??'s
- Precision 6152E (630hp rated) ????
- Pwr Intercooler Question????
- different ebay 02 housings / turbo outlet pipes
- Anyone tried: Forge WGA &20G-LT?
- Stock turbo and meth.
- Switching Exedy Twin Plate discs???
- where to find Jun cams
- cutout question
- Will the ebay o2 fit an 06
- new exhaust for new evo ix mr
- Ordering parts
- evo engine troubles!! please help!
- Anyone Confirm 8 and 9 FP the Same???
- Megan Racing Manifold back tbe??
- cosworth stroker motor ?
- can someone explain this to me..
- ATP Kit
- Fuel Pump
- Dynoflash@Chicago 2/10 Tune results
- walbro 255
- Cat heat shield exhaust install
- soo Green on the way....now what?
- Vacuum readings after move to Denver
- Exhaust cam timing on EVO IX with aftermarket cams
- 329whp/318tq - STOCK BOOST!!!
- Blew a plug out of my head.
- how much boost
- Fuel cut with stock boost lines?
- BOV to the atmosphere Solution
- Clutch Question (Tilton and Quartermaster)
- T51R/GT42R Turbine Differences ?
- Valve Cover Oil Leak
- fuel pump question
- Technical Head Question...
- NOS injection thru UICP??
- Blowin Smoke
- Exhaust manifold bolts
- 2.3l stroker kit
- Oil leak...
- Well Dave maxed out my turbo...
- rough idle?
- Fastest EVO IX turbo cars??
- collection of intercooler fin pictures (ic insides and outs)
- What turbo is used on this vehicle to get 600hp/710ft
- The thoughts of having a 150 mph trap speed "green" EVO.
- gt37r on the street?!?
- Thanks IveyTune
- LaG LOL
- o2 sensor 2 black wires???
- Valve blow by?
- while racing i get fuel cuts? how to solve that?
- Hks Mivec Cams....
- Evo 9 power w/o tune
- What are you afr's on pumpgas?
- Idle Video of GSC S2 Cams / Vavle Springs Installed!
- injectors OR cams???
- FPR hose
- Crank sprocket bolt won't come loose
- what all is needed to install an evo-9 turbo on an evo-8???
- 06 GSR drivetrain noise & shuttering
- Dyno'd- video- evo ix mr
- evo 9 clutch job issue,
- flashed fp green.
- Would adding a larger Perrin IC and hardpipe kit change
- Water Incetion vs Race Fuel
- Chirping Spool from exhaust leak...
- How much knock if any with stock ecu
- Boost gauge tap in point
- Turbo Install Completed
- Fuel Pump...
- ticking after clutch install!!! help
- Center Diff Wet!
- 605 bhp on Pump (99 RON)
- Ralliart Ring and Pinion
- Please Help Car Running Rich At Idle
- Blue By U Motor Build (Pics 56k Beware)
- Buschur coated turbine housing or 20g
- how do i get a higher sample rate with evoscan
- Injen intake and uicp or HKS RS or Just Apex'i?
- 23psi stock EVo...
- New Rear?
- Test pipe
- JDM engine
- Cam Gears....any real differences?
- I dont want to buy full race headers!...
- Need help... unknown error
- Intercooler piping....and Q's?. Vendors ps feel free.
- Fuel Line Locations?
- Velocity stacks in air filters
- HKS vs Comp Cams?
- Pic request of ring and pinion
- Exedy Clutch Stage 1
- Why do I have a boost leak?
- Exedy Twin Plate Clutch Knocking Noise
- Rough idle
- is rear motor mount worth the trouble?
- Ebay wastegate with inter cooler kit.
- Next Step??
- Umm....Something happen, engine died
- New headgasket need for cam install?
- HorsepowerFreaks Evo8 Complete Fuel System is Released!
- Immobilization code????????
- ams intercooler feedback
- ever have this happen?
- big problem with boost! plz help!
- Broken balance shaft belt=OUCH!
- Weird RPM spike.
- 2.4 block where to get it ?
- Is it possible to kill a clutch in 4 days
- Transfer Case carrier removal ?
- Anyone have a link for the Evo IX USDM & JDM Service Manual
- why do honda engines make so much more power with less boost
- Weekend Fun
- Buschur HFC?
- Quaife?
- stock clutch
- To coat or Not ??
- Centerforce vs. ACT which do you choose?
- 05 LSD in a 03 t-case?
- Boost problem after a couple of runs at the track
- Compressor Surge???
- Just recieved my ss o2 housing/dumppipe.
- Ams Gt37r Kit Or Buschur Gt37r Kit?
- Exedy Twin Disk Clutch Problems
- Fair rebate for transmission, transfer case cores
- Whats next?
- driveshaft play
- Injen SES exhaust
- Evo Block Donor Cars
- individual cylinder knock retard
- Tanabe Ultra Medallion
- 100oct in tank and afr's are LEAN
- Simple question... why aren't any 3" O2 housings available for the stock turbo?
- Finally, wicked affordable camshafts....
- PO 304 code?
- What intake manifold, exhaust manifold, and sgould i use a igniton amplifer with meth
- what whp with stock turbo.
- ebay manifolds what is the difference in size.
- Please Post 280 cam, 16g, Gas dyno chart
- Buschur parts ftw
- Three holes in the firewall
- 16g with headers?
- Which cables do you use when hooking up aftermarket rad fans?
- Jerky with BOV
- What is your favorite Diff. fluid for your Evo?
- Possibly Clutch/Syncro Problem
- hks cams
- Evo IX spark plug cover
- Random Misfires 030X SES: Need updated information
- Clutch advise needed please
- Going with a hard pipe kit, got one question about the install
- Just got a Carbonetics twin carbon installed and it sounds bad
- Evo IX Cams
- For those who run staight race gas
- Running the car without o2 simulator
- ebay o2 housing on which downpipe...
- 20g or evo 9 turbo???
- gutted cat or test pipe
- BOV issue...causing car to die..
- Boost creep problem
- Cams, Meth or Evo 9 turbo?
- spring setting
- What meth kit ?
- mobil 1 oil for evo?
- Injector Options
- gt35r owners?
- My BR GT35R
- Boost problem
- engine upgrade
- Those of you with Helix 02 housings???
- Water and oil pump flow, l/min?
- Need upgraded Intercooler with uncut undertray?
- What is the highest PSI you can run on a stock evo9 motor?
- Forge UNOS + Cold Weather = Boost Creep?
- anyone run a gt3082r? (gt3040r)
- What is the exact purpose for a fuel rail
- Need Help with Trany/ACD Fluids, MR
- gt35r vs. 50trim (debate!)
- Forge Unos stiff spring min. boost?
- The best LICP for stock turbo?
- Drivetrain problem...I think.
- changed spark plugs, made puttering sound
- Precision PT67R, where please?
- ARP head stud install. 1by1 the right way
- Rear Diff???
- Exhaust Install Questions
- help walbro whine
- APEXi GT Hybrid intercooler
- MAF connection
- Boost Characteristics of A Large Turbo
- Bad Fuel Pump?!?!?
- Help - Need New Clutch
- WR Intake Manifold
- clutchmaster fx700 opinions
- Big Problem
- Ghost exhaust.
- help me pick a turbo kit
- APS BOV Question
- Any risks if boosting up to 25 psi
- Synchronic BOV eliminates turbo restriction
- no oil cooler
- tranny problem
- act hdss or xtss for 500whp
- No acceleration (sometimes)...
- The Perfect Exhaust?
- Back to the drawing board.
- Where Do You Get Service
- Buschur's 3065 tuned by Al
- Can I run the MBC from the driver seat.
- Installed Boost Control, now problems ??
- ACD failsafe mode??
- Tranny issue
- just picked upngk ilfr7h, gapped at .024
- ECUtek. HP gains???
- Evo 8 20g
- misfire under heavy load
- popping out of 1st
- GSC S1 cams
- Will a 2.3 Stroker outflow the stock turbo and any other uprade be4 TUNE!!!!!
- Go Fast Bits Bov ????
- Exedy HD
- Evo 9 w/ 20G-LT, S1 GSC cam + bolt on round 2
- Whats better 1g DSM BOV or Evo 9 BOV?
- some questions
- apex'i vs arc or others intake comparison
- help me pls.
- Help!
- IX o2 wire colors?
- General IX questions
- Well my clutch is going out...
- Help Evo 9 Plug Gap ILFR7H Urgent
- Is it bad if my downpipe hits my ACD?
- Why my water temp gauge wend dead ??
- Looking for bolt-on selection advice.
