- compression test
- FP EvoGreen + AMS VSR?
- can anyone give me some info on stock 05 turbo.
- VTA BOV mount location?
- Fixed my codes
- Quick Question
- pressure drop in turbo xs intercooler
- Bigger Injectors?
- Bigger Injectors?
- Roll cage ??
- JDM anti lag runs off DV output?????
- Next mods for bolt-on Evo IX? cams, meth, or evogreen?
- AMS TBE IX MR rubbing
- gauge help
- Where is the best place to get a Short block!?
- Car boosting slow, loss of power
- Dp
- Low budget T3/T4 maifold combo!
- Home made oil catch can thread - post your pics
- mbc location
- Cam Install the car is slower and falls on its face.....??
- AWD problem.
- Stripped screw on intake manifold suggestions?
- Fuel Cell Installation
- oil pump cover removal???
- Clutch pedal force ???
- Dumb question about 20G LT vs. 20G-9-5
- Boost creep... how bad is it?
- advice needed on awd....
- MBC boost problem
- turbo exhaust housing
- evo 9 fmic
- You wont believe what Just Fin Happend, what a Crappy Day :(
- Greddy profec b 2
- new exhaust and downpipe installed...problems.
- My winter project. Not that i want to but have to.
- Turbosmart E-Boost Problem
- Invidia downpipe installation issue. Help, please
- 712whp on E85 and Meth, 560whp on straight E85
- tranny and t-case removal?
- New Fuel Injectors and sparkplugs?
- Engine ticking during warm up after cam install??
- Anyone Thought about making their exhaust
- another stock turbo evo ix tune..
- Intercooler information..........
- comparison of flow rate of turbos, VIII, IX, EVO Green
- REplacing Clutch with OEM clutch parts...
- how accurate is the stock boost gauge?
- 272 idle..
- VIII and IX mufflers the same?
- Building a 2.3 stroker balance shaft or no balance shaft ?????
- Plug life?
- Final Twin-Disc Clutch Thread
- how to get 320-350 reliable awhp
- Question about o2 housing...
- ATP port polish question
- Just installed my BRGT35R
- Just walked over to Turbokits.com.....
- 50 Trim guys with ALKY PLEASE LOOK!!!
- Cryo treating?
- 20G-LT and E85
- Rev limiter in ECUflash, stock internalled engine
- bigger injectors?
- Any one using DNP headers / manifold
- Comp 272's question
- stock turbo outlet size??
- Anyone recognize this header?
- Please Post your EVO GREEN FP 20gLT dyno numbers and graphs
- Any info on Crower IX cams? ? ?
- 6sp transmission case question
- afi gt 35r?????
- Help!!!Spike and Creep problems!!!
- p507 code
- just saw this this second ... anyone heard anything about it?
- need help on somthing
- AMS TBE clips
- exhaust
- exhaust
- GT4094R, nobody has tried it on a evo yet?
- Best header for stock turbo???
- cams and gears ?
- TTP or Helix D/P+T/P Combo?
- Throttle body service!
- question on gt30r series turbo.
- Works ABM and IP sound
- A Public Apology To Shepard Racing.
- Valati controller......
- Please post Evo IX upgrade turbos and opinions
- PWR IC fitment and/or pics
- Best clutch for under 800$. .
- Crank pulley
- Question abot HKS Carbon TI Exhaust
- exhaust manifolds??
- Calling everybody with the HPF 3.5in turboback exhaust.
- broken evo!!!!
- Will an HKS Hi Power from 03 fit an 06?
- where can i get transfer case rebuilt?
- Tanabe or Espelir Downpipe
- spark plugs
- My alternative to can style mufflers
- Fuel Pump for 21psi?
- How much preload on Forge WG Actuator?
- The Official MBC Install Picture Thread
- Oil Pressure Question
- Bad oil leak problem. I need some ideas.
- Differences in VIII and IX intermediate pipe (exhaust)
- rear o2 sensor for evo 9
- HELP previous owner re-installed bov backwards, i think
- Anyone using an AEM tru boost?
- Installed Apex'i power intake!
- help!!! greedy type s causing surging idle
- cant remember name of part.. makes it so u dont lose boost during shifts
- Please help! T case oils
- Custom Intercooler End Tank's
- Please analize my spark plug(pic inside)
- gt30
- gt35 r
- 20g9-5 VS. 20glt..
- forged divter valve fix a lot of problems
- drivebelt noise
- Apexi N1 Titanium
- o2 simulator
- Exedy Help
- Bestest Question Ever
- Alki Injection... If you were to ....
- Divided exhaust manifold and WG... please help...
- Does anyone have the Monster Sport Power Filter?
- Customized Bolt-On GT35R Turbo
- Performance advantages to thermal coating?
- Hotside numbers?
- pulled valve cover off cam mystery numbers EP4604
- n00b
- TD06-20G vs. 50 trim
- injectors or valve ticking? vid inside.
- cammed evo, slow?
- Mobile 1 to Royal purple
- They make a 2.4 stroker?
- 16g question
- Garrett vs. HKS Turbos
- plx m-300 narrow band usage=p0031 cel
- Exhuast testing Round 2 - HKS vs Buschur
- ARC Induction Box Pre/Post dyno...
- main studes
- Invidia Manifold Released
- O2 housing ???'s
- anyone got picture of knock link sensor installed?
- clutch for my IX 6 speed
- New Owner, Modded EVO
- Weird boost problem....Help
- Does anybody make a direct bolt-on DBB 50 Trim for the Evo?
- Intake blew off ..... Need Help Plz
- Paculiar noise at decel??
- do i need this for oil pressure guage installation?
- stock 16g flow lb/min.?
- tricking the o2 sensor with catless exhaust??
- gt3040r???????
- vishnu set up
- EVO VIII pain to get in reverse...
- Hks Clutch Gd Max Twin Plate
- Authority Cat Back quick help
- how long should it take to install these????
- Nitrous?????
- Is this realistic...
- Is this my transfer case? Decel noise
- Top transmission bolt problems
- not boosting right...
- cammed evos...
- who has revolver cams, meth, 20g9-5
- 20G injectors
- Gsc 272/264
- evo8 with evo9 turbo
- Turbo Spool Fluttering
- How to tell if a turbo is bad?
- Car runs rough...
- Injectors
- White Rabbit - Evo Green
- gotta love 5th
- Perrin 3" hfc v/s Helix 3" hfc
- Atp Kit/pruven Dyno Results!!!!
- bov flutter
- HKS SSQV Recirc kit
- Weird Observation with a not so boost leak.
- What about these exhaust parts?
- OverBoosting
- compression tester tool
- custom exhaust idea
- Can you Warp the flywheel beond repair?
- Tranny Fluid mixture
- ix mr short throw shifter
- Pros/Cons of 100%meth or 50/50 mix
- Are Ferrea Dual Valve Springs, Seats and Ti Retainers a drop in affair?
- donut gasket
- Evo 9 20g Upgrade to Buschur
- Buschur DP & UR Testpipe ?
- 2003 Evo Syncro Grinding?
- boost leak.. need opinions...
- ARC intercooler.... bumper bar?
- Power Enterprise RX6R Turbo kit
- weird clutch noise
- Cheapest OE Timing Belt Kit?????
- Tial 38mm Wastegate spring?
- turboxs tbe install questions
- Very bad boost creep and boost wont go down.
- Supporting Mods For 50trim?
- EVC, Tial external wastegate hook up
- Evo VIII vs Evo IX gearing
- Help, RPM DIPPING.
- 2.3l build questions
- E85, EVO Green.................
- Titanium TBE
- Mahle pistons, who's using them in their evo engine?
- Water pump
- porting exhaust manifold
- Exhaust problem
- Spooly Jobby
- Do you have dyno graph for stock air filter vs KN vs Works?
- Power and MPG DOWN. Help Greatly Appreciated!
- Car lost power in 5th under boost for a second?
- Rpm Boost On Gt30, 35, And 37?
- Whats the Max boost level on 98 Octane
- Best location 4 >> Oil Temperature Sensor ??
- serach search search!!!
- 05 MR Drive fluids confirmation
- Anyone make 340TQ or more at 3000 RPMs?
- E85 and 20g9
- 650WHP on E85 and Meth!!! at 36lbs of Boost
- Unhooked MBC still hitting 25psi???
- IX engine technical specs
- Buddy Club Cams for IX
- intake noise.
- Stock Boost PSI for an IX
- My Winter Project... 25.1E RWD Evo 8
- Buschur Racing Dp and HFC question
- No boost Leak, but still low boost?
- Bleeding the ACD
- Does a IX Transfer case fit on the VIII
- Gear Speed sensor?
- 20/fpgreen
- need as many pics of wr9 20g-9-5 as possible
- GSC S2 cams for IX
- General question about boost
- High EGT's
- anyone with forge dv please help.
- Problem with Boost Creep...??
- Agency power ti exhaust?
- Who's 50 Trim Should I go with?
- Turbo Spool Tables
- Mass Air conversion, to VTA 100% and no problems
