- Questions concerning new o2 housing with downpipe/cat delete installed?
- Turbo is maxed out, why?
- Anyone running a Buschur Racing 20G-9LT Turbo on a 2.3
- Boost and Wastegate Issue's.
- HKS cam question
- gear ratio 5 speed
- F/S GSC 272 cams, int-exh, cheap, pics
- Titanium exhaust manifold......
- Snap rings
- 02 housing
- Help Needed! Please Help Meeee!
- Ported Stock Turbo Manifold Question
- What's the best air filter?
- Tranny? Clutch? Synchros? How to tell...
- 2.3 stroker (prolong life or shorten)
- Vibration on Acceleration
- Installing the MR Turbo
- 6th gear problem
- Exedy Twin Plate Clutch
- 2.3L GT40R Which Clutch/Parts to go with?
- Added a couple parts and a tune
- Broken Thermostat. frozen on C
- comp cams 280
- Forge MBC Users -how much psi increase per click?
- Anyone have a APS 3.5 TBE
- Transfer Case Blown :(
- Safe mods for Stage 1 tune?
- ACD Revisited
- valve spring compressure tool NEED ASAP NJ
- DIY catch can for stock engine bay
- Is it normal to smell the clutch on Breakin?
- is this an evo 8 lsd?? with pics
- ARC Intake - gains & sound
- Detailed write-up of walboro vs stock pump
- what whp will i make? EVO IX
- injen intake on ix
- need advice!!!
- MZ313376 from MitsubishiParts.net missing part number
- Who makes the best intercooler piping kits?
- lookin for AMS GT30R kit
- Help me find a 4.11 gear, please!
- Stk ECU, Power FC some moonshine and some power...
- shortblock question
- 6 spd upgrade
- Need Help!What are the safe temperatures for Water and Oil???
- Race Gas
- weird boost problem.
- Odd Smell/Gurgle, input needed
- My little project
- Doing Pistons and Rods in the car?
- Induction Pipe
- throttle body leaking bad. HELP ASAP
- 6 Puck vs Twin disk Carbon. Lockout
- how hard is it to change syncros
- stock gauge with aftermarket
- What's a good shifter?
- See if you can figure this one out, crazy boost problem. Help!
- radiator hose burning
- Safe boost
- Anyone had success with an aftermarket head gasket?
- This look legit???
- Battery Relocation Fuse Protection
- Forge BOV Backwards Install??
- How many miles on ur exedy twin?
- Spark Plugs
- GT 55 - pissing race
- Anybody know how to get ahold of TRE?
- Just received my Carrillo Rods and Ross Pistons
- Who has/knows/can locate the TIAL Cast SS Housings
- I blew up my td06h-20g turbo =( (pics)
- full bolton--ic helping any?
- Ams 23rr & E85
- Clutch install complete w/ reviews
- removing radiator hose
- Clutches
- greddy intercooler kit evo 9?
- ported head ???
- Where can I get stiff spring for Forge UNOS???
- Turbo noisier after LICP swap?
- Stalling problems...
- help with a cat back install
- Is a tune vital if I add a FMIC and LICP?
- How bad did I mess up my head?
- Advice on 02 housing...
- Evo Cranck
- Basic Bolt on help
- Just got my JunB.L exhaust system!!! 56k beware
- Evo Cranck
- LICP popped off, after i put it back on engine wont start
- After all the BS, finally I got some dyno #'s
- BOV UICP question?
- Which intake?
- just picked up a br500bb turbo kit on ebay with pics
- Evo losing juice
- developed a 5th gear grind today!!! help
- 50 trim turbo specs?
- Mobil tranny fluid?
- what settings?
- Wheres all these Cosi Cammed 9's @??
- Buschur Racing TBE
- new intercooler or just new upper and lower tubing.
- engine issues?
- Cam install: Assembly lube needed?
- how to tell what size turbo u have? help please
- a/c line hose
- Help! HKS EVC on external wastegate setup!?!
- Is my Clutch going?
- Mods Safe to run Stock ECU
- buschur race ic install (pic)
- How to adjust boost according to weather?
- apexi s-afc II problem
- Brand New Hks Turbo Timer 110 Sipped
- Question about purchasing the green
- Shifting problems - Transmissions?
- best clutch....
- Injen intake and Uicp.
- Anyone has this coolant leak before?(pics)
- Time to replace the OEM knock sensor?
- Help with bad cylinder!!
- Does this look like a good deal? (eBay Clutch Cable)
- BR turbo outlet pipe & Forge WG, will it work?
- motor oil recommandation
- Head specification
- Best clutch for bolt ons?
- Cam Combinations "PRO’s and CON’s "
- G-Reddy EBC + Dyno Flash vs Works Flash
- SlowBoy racing Turbo Kit 35r Who is runnig it?
- 24psi with TBE/filter and stock boost control
- Safe Charge Temp for 85F Ambient/Inlet
- gt35r/stock motor
- Evo 9 Tme 20g 10.5th
- I Have a Failsafe for My Meth Kit. What Else Can I Get to Monitor Everything?
- Ultimate Racing or Buschur TBE?
- How is the 20GLT at high altitude?
- Car binding on turns. Front diff???
- projected dyno numbers???
- RMR hood scoop
- Look inside
- Any1 know any vendors selling just gsc exhaust cam?
- out with the old, in with the new
- Intake help??
- Need help asap.. Oil in IC piping
- dp and rs-r ex-mag
- Gates Racing Timing Belt
- Louder exhaust... louder BOV.
- real intercooler test on the way
- Injector Opinion
- Running lower rev limits reliably
- where to get intermidate pipe ?
- Lazy / Oen WGA???
- Valve/retainers and bov q's
- Help hooking up wideband
- Finally test data for ebay intercooler vs stock
- Opinions on the new Buschur cone filter from people that run it??
- Buschur turbo flange
- help me reach 400+hp or more
- Turbo Upgrade
- KAAZ and other REAR Diffs
- Question for those running E85 and big injectors.
- turbo flow numbers
- Serious help needed w/ fuel cut
- Rear differential noise/pulsations when turning
- BR UICP issue??
- Quick DP fitment question
- Greddy Type-S related
- About the DC Sports 3" DP on an Evo IX...
- Uprgaded turbo kit w/ pump and no meth. Do I need a wideband?
- 50 trim on my Evo V, will be out on wednesday!
- power issues
- Recommended Max RPM for BR Springs
- Engine stumble after closing hood?
- Front motor mount + side motor mounts = less vibration?
- Ebay Oil Filter Sandwich
- Radiator working properly? Simple question, help?
- evo 8 and evo 9 intercooler 100% the same??
- Wastegate
- Is this a 10.5 hot side?
- Running higher rev limits reliably
- anyone have dyno #'s for a 20g 9 5?
- next mod???
- 50 trim dyno #'s are in................
- best twin-plate??
- I need a transfer case for my evo IV
- shep racing tranny
- Megan Racing Manifold
- clutch smell
- Which turbo for my IX
- xs power/ebay parts
- ATP Tests Garrett's GT series Turbos, Very Interesting...
- Tial bolt sizes...
- PeakBoost Kits..Worth The Money???
- Boost Tap in Experiment Results
- Cam Combinations Need a little help
- EVO IX Spark plugs
- Tranny Problems?
- Rear Diff Specs (Poss. Sticky)
- *Two Manual Boost Controller Install Questions*
- EVO Motor Mounts
- help with adding powa
- Paradigm Performance Innovation (PPi) parts installed on my EVO!
- So just got my heart broken on dyno
- Am I missing anything before the reflash?
- WARNING- Ebay O2 housing from ssautochrome
- Transfer case???
- Instant help needed
- Loud Whinning Noice - Transmission?!?!?!
- Installed TBE, Lost power...
- MBC or EBC???
- Anyone running Brian Crower Cams?
- Guage ??
- exedy sport review
- Walbro 255lph?
- What next????
- Check this crap out
- boost leak test?
- will standard 03 (non MR) cams prevent my evogreen'd evo 8 breaking 315whp?
- who has pro street cam gears??
- cat + slow = very
- Does the Hi Power need relocation brackets?
- Looking to buy a greddy intercooler kit but have ????
- Stock clutch chatter?
- EBC whe?re to hook up BOV?
- IX Turbo on VIII, How do you like it?
- assembling project car 2.3 liter, finally
- MBC installation
- valves
- transmission fluid leak
- transmission problem
- Weird clutch noise
- EVO IX Cosworth Cam install info / FYI
- Which Spark Plugs should i use?
- Crank walk or bad balance shafts?
- E-85 electrical conductivity question
- FP3052...anyone use this turbo?
- How does the MIVEC actually work?
- Help: lowering boost on stock turbo
- Gear oil help please
- Lean or Not ?
- Compression on 2.3L Stroker Engine
- High knocks, Low Power
- stupid question
- Any one runing sls turbo kit or manifold
- E85 and Exhaust Temps
- Intercooler Question
- care to diagnose?
- 4th and 5th gear.
- tial 38 bolts
- Building evo 9 2.3 strocker gcs280 or cosworth272 ????
- i think i put stock dv wrong way
- mivec assembly pics?
