- Oil Drain Tube GASKET - HELP!
- Machine work for AMS 2.3L stroker
- Oil Squirters???!!!!
- EGT placement, temps, and alky use ?'s.
- Fuel pump ??'s
- Exedy Twin Noise with Cluch Engaged
- ebay exhaust pics and results...
- What manifold can i use with a atp gt35r kit, does the flange matter are their side?
- Spal slim fan part number#.....
- opinions on the perrin foam filter?
- 2.4 in a evo
- Turbo Xs Down Pipe
- Who's running a Maxford header?
- oil cooler setups
- turbo glowing
- Am I cammed?
- Open air filter in engine bay?
- 50 trim on stock manifold ?
- Turbo spools, ready 2 go, car aint..
- AVC-R actuator valve gone bad?
- what does you boost taper to?
- smoke while on 2step?
- a few ?? on cosworth cams for evo 9
- Where can I get my turbo, manifold, and 02 housing, ported and polished?
- Idle issues after Walbro install / airbox mod
- anyone running stock clutch on evogreen?
- Transfer Case ring and pinion questions
- Stock Transmission/Transfer Case power Limits???
- turbo smart bov any good!!!
- Tuning Technologies IX 361whp 355lbft 91oct. Cossie cams
- evo and turbonetics?
- build me a built 2.0 monster
- anyone running 2.1L destroked?
- if money wasn't an issue
- F-CON VPro from Buschur
- Something is wrong with my car
- Forge UNOS MBC SPRING INFO Re: EVO IX & Tapering
- Spool up difference between br 3065r and 37r?
- Whitish smoke from manifold area
- Buschur DP and O2 Housing issues
- Tranny/ Diff/ transfer case fluid?
- Tranny fluid alternative
- clutch makes weird noise... normal???
- cams and valvetrain install time.
- engine whine after damper install....
- help! lower ic pipe off turbo outlet
- Installed Nisei Intercooler Pipe kit + Mini Battery Kit. EVO 9
- HKS Maf pipe or Buschur/
- stock to t3 adapter
- Turbo Timer Harness - MT-1 vs MT-6 - Am I screwed?
- ams lower ic pipe
- Need options?
- log of 28 pounds of boost.....93 oct
- Leaking IM spacer?
- intercooler fin engineering and design (ins and outs pics)
- HKS cam gears
- Wastegate Question
- CBRD ebay exhaust testing...
- 1st and 2nd gear noise in 05 RS.
- Curious about this setup w, Catback, DP and what HFC?
- evo 9 turbo custom manifold
- Engine building pressure
- Funny Noise
- is my stock wastegate actuator bad?
- EVO GSC S1 Cams For a Evo IX
- A couple of turbo swap questions (intall related)
- 35r turbine leak?
- What clutch to get?
- Downstream o2 sensor!!!
- car wouldnt start??
- Boost Problem...??
- Tial external wastegate problem
- which tubular header?
- discussion about how intercoolers work
- reading used plugs
- tech discussion: what keeps torque from dropping off?
- Oil cooler sending line leak
- technical resource - how mafs work
- choking car
- Low boost issue
- ebay 02 housing
- TECH ARTICLE: 16g turbos and all its variants (20g)
- Okada Projects
- Boost spikes like crazy all of a sudden
- EVO Exhaust variety *video*
- want your opinion on clutch
- Cosworth M1 cams: results on Evo8?
- WORKS 76mm Downpipe w/ eBay o2 Housing?
- 381WHP on PUMP! (EVO 9 turbo)
- Authority exhaust!!!!
- Dyno'd Evo VIII 371 whp on stock turbo
- clutch bleed question
- Helix 272 V2 cam?? Opinions
- clean engine bays post!!
- Clutch dead?
- Differance between GSC S1 cams aand gsc 272s
- Twin scroll/divided housing manifold.
- Torque-split clarification...
- Which one of the Ebay O2 housing is correct?
- S1 Cams:
- AMS db's ?
- Help with Manifold Studs
- boosting problem
- How to convert atp gt35r .63 ar to twin scroll?
- Braided Clutch Line.
- can i run the stock ecu with a walbro fuel pump??
- Balance shaft elimination kit install?
- Evolink computer
- what motor to go with?
- I can only boost to 15 psi
- Ebay FMIC testing (data log lab dyno) vs Stock FMIC
- weird noise from clutch
- missfire question and cylinder
- I went back to stock cams didnt resist the ticking noise during warmup.
- hallman mbc problem
- Can't build more that 11 psi.
- Intercooler Upgrade BIG question
- What to do next???? please help
- Po300 (isolated problem)
- Transmission mount stud inquiry
- Cossie Cams & FP GREEN Evo IX dyno numbers!!
- Dynoed - RnR BB 50 trim & Machines Gone Wild Tuning
- Do Not Buy From this Ebay company
- wondering what is that smell...need help
- transmission issues
- swapping clutch
- odd trouble codes need help
- question on stock clutch
- To much for Tranny fluid?
- Hunting the knock gremlin tomorrow!
- Intake/tune... confusion/concern
- t-stat housing gasket?
- Full Blown's Evo 8 Shop Car
- Long con-rods for evo engine?
- Drivetrain Fluids for IX?
- Got my IX tuned with graphs inside (stock + exhaust)
- Cams yes or no
- Agency Power?
- HELP!!! Low Boost at Full Throttle...
- Injector Upgrade Question
- engine flush
- Wastegate
- what turbo for my setup...GT35R or GT3076
- evo heads fit on 2003 lancer oz?
- PT67 and gt37r ??
- Evo 9 GSC S2 Cams 35R dyno Sheet and Vid
- Found two exhaust cams in the car.
- Which makes more power?
- Coolant Overflow tank.
- Boost problem please help.
- Got dyno tuned
- MAP conversion question
- Cant decide on Trans
- help !!!! pleas !!!!
- Which Injectors?
- WRC 4G63 Crank, My 4G64 Crank, and an... idiot's verison of 4G63 WRC Crank
- forge wga, Leaks like crazy??
- need help finding black manifold!
- Blouch Dominator 3.5 30psi vs 21psi DLL dyno plot
- cams, gsc 272 or 280s w/ BR3065
- Balance Shaft Elimination???
- where can i tap to get ported vacuum?
- Exhaust question
- 272 exhaust cam only, on a ix?
- Stock o2 housing port job?
- How my proyect is developing...
- anybody "crush their MR BOV like the 1g's?
- Getting ready to install cams.
- HELP....6th Gear not engaging
- FYI ... AMS Engine Break In Procedure
- Evo9 fuel pump vs Walboro 255 data inside!
- I'm a compulsive ebay purchaser
- Forge WGA torn apart... suprise inside
- alky or n20??
- Helix 3" downpipe - false knock / pulling timing?
- boost problem
- Need your thoughts on somthing
- Center Diff is out??? Front wheels spin like crazy in launch! HELP!
- Lower IC pipe Problem HELP!
- HKS DLI Twin Power - fried both Coil Packs?!
- afr's
- VIII Turbo vs IX Turbo (data)
- ok heres my setup what should my whp be?
- Guess My Hp!!!
- How much boost you running stock.? or close to stock
- Q's for anyone running 280's
- Boost Pressure??
- Buschur 3065 turbo makes 473whp
- Debate: Cams or Turbo upgrade first? (evo IX)
- Maxing out the stock turbo on pump - need your input on UICP & Stock Intake Box
- Injectors for 37r
- is this the right o2 housing from ebay
- Check It Out !!! Some Last Minute Advice Please !!! :)
- MBC Hose Size
- Nisei Licp Diameter?
- Skunk 2 CB exhaust
- Will the Forge bov hold boost on a GT35R?
- Whistling Throttle body
- Do I need a Walbro pump with just a TBE?
- Best valve springs-retainers for IX ?
- basic question, turbo upgrade on stock ecu flash....
- Dyno Numbers
- What injectors for 500 awhp Street car?
- o2 Housing/Downpipe install
- TIAL Vband turbo housings....
- what do you think of royal purple gear oil. its hard to get it in to gear!!
- do i need to tune by doing the following mods ??
- Can this piece be replaced? [PIC]
- clutch questions PLEASE HELP
- possible boost leak...
- Camshaft profiling..
- Want to get better dyno numbers without spending money?
- Max boost for a Evo IX with stock ecu???
- Silkolene?
- IX owners: Who's toasted clutch already?
- Syncro shot??? help please
- Need help car died, won't start
- how well respected is the WORKS brand??
- Help Before buying a 20 g Turbo.
- Mail In Flash
- Trans trouble already?????
- ECU Code Storage?
- Best cams for the money for Road Racing
- Intake Question
- turbo custom flange
- Need Wastegate Decision
- Why you MUST get a tune when you add a air intake to your Evo
- Buschur Exhuast testing - + 23 WHP (dyno sheet and Video!)
- HKS Downpipe on a IX
- Custom oilcooler setup and trans cooler..
- Rod Bolts-Upgrade or not to Upgrage?
- Tomei il thermostat eliminator or twin oil cooler setup?
- best clutch for the money?
- Exedy Cerametallic
- High EGT
- EVO IX Engine Gaskets.
- Clutch Position Interlock-ECU Pin / Wire
- Shearer 35R dyno results
- e10 (aka "gasohol") v/s Super Unleaded
- Fuel pump whine?
- Your thoughts on the Perrin Hoses
- just got my evo ix saturday,, 2nd gear grinds
- Diesel fuel inside the OEM lifters???
- Blouch Dominator 3.5 Data log lab dyno
- Anyone using JAMM lifters??
- Inertia of Exedy Twin Clutch Disks vs. Stock?
- I think I hear the death whine??? Not sure?
- revolver cams+stock ecu who has it i need help
- revolver cams=stock ecu who has it i need help
