View Full Version : Evo Engine / Turbo / Drivetrain
  1. Blew 4th gear again Evo 2... Cryo?
  2. Looking for 170 degree thermostat
  3. Magnus help!
  4. I think I need a new sump/oil pan - help
  5. Stock boost gauge
  6. FP RED 80 or regular ???
  7. Injectors leaking boost
  8. Stock motor w/ HTA 35R?
  9. Buschur is what is needed for a reliable 9sec DD!
  10. Fp red not sure how to tell a 80mm!
  11. Bought a used turbo and found this...
  12. Amsoil Manual Tranny MTG vs Amsoil Severe Gear SVG
  13. Evo ix, fail safe? (limp mode?)
  14. Engine management needed?
  15. How much whp will i make? do reply
  16. HKS Cams or Cosworth Cams
  17. Nisei FMIC
  18. 5757?
  19. Fp red budget build what is needed???
  20. Just put engine back together... STUMPED
  21. ac not working
  22. Backup Switch
  23. Anyone make an air filter heat shield?
  24. quick question about walbro 255lph pump
  25. Weird sound when at higher RPM.
  26. Feedback on the Buscher 35R cast manifold kit
  27. 2.3 stroker Rev
  28. Stripped Oil Pump Screw, help please
  29. boost leak symptoms?
  30. AGP vs Agency power lower solid front engine mount question
  31. Twin disk help!!
  32. Donut Gasket, where to buy???
  33. Advice on setup
  34. Mitsubishi Lancer Evolution Garrett Turbocharger Products article
  35. Pushing coolant?
  36. Priming the Engine?
  37. AMS manual bc issues?
  38. boost cutting
  39. broken IX transfer case
  40. Exhaust manifold help
  41. oem exhaust
  42. ECU part
  43. 2003 EVO Idle Stall/Dies
  44. GSC S2 + Stock Evo IX Turbo
  45. Were to buy replacement rear o2?
  46. Motec M800 Universal vs M800 OEM PnP - Customize
  47. Undoing Blitz "4mm hose join" ??
  48. Another ACT lock up..!
  49. ACD Lights Turn On During Long Drives
  50. Rebuilding an EVO; ACD Unknowns
  51. Found this in my combustion chamber...help
  52. build 2.0L & E-85 take a look!!!
  53. Anybody getting boost creep issues with maperformance o2 dump pipe?
  54. Replacing Stock Vacuum Lines
  55. Imaginary build questions
  56. Question on my car
  57. Price for rebuilding synchros
  58. Help..Having Boost Issues
  59. Difference between Exedy SD vs HD...
  60. wierd WOT issue...Help
  61. Timing mark question
  62. Evo 8 3-bar MAP Question
  63. clutch makes a sqeaky sound when down shifting.
  64. 2.75" downpipe to 3" test pipe - which gasket to use?
  65. Help please - clutch line bleeding
  66. Advice please!
  67. Just got my ETS Intercooler!!
  68. Twin HD max power?
  69. Where to place resonator?
  70. Anybody running close to 700 whp with drop in pistons and rods?
  71. Built head on stock block?
  72. Modified Balance Shaft
  73. Help - driveline noise
  74. a couple of clutch questions
  75. thread pattern for autometer egt gauge
  76. Boost levels for a fp red ?
  77. Clutch Not Disengaging?? Help please! Brand New AMS Exedy Twin Push Clutch!!
  78. Kelford IX Cams,Good or Not
  79. Muffler delete?
  80. Center dif just shat on me....
  81. Easier/ Cost effective??
  82. Greddy type rz
  83. Thinking of upping my boost on stock turbo.
  84. help me decide! FP RED or Twin-scroll hta
  85. Somethings really messed up about my car i dont know what...
  86. need to know evo 9 turbo coolant line part number
  87. BBK and FP Green HTA.....
  88. Thoughts on busted 2nd gear?
  89. Using rev-limiter instead of 2-step bad?
  90. LOUD ticking noise from front left wheel
  91. help
  92. Boost controller installation
  93. Buschur MBC Install
  94. Question about TTP Engineering ACT Clutch
  95. why 2.5" o2?
  96. Mod list. helppp!!!
  97. Tial BOV Springs, which one are you using in your 50mm or new "Q" Version??
  98. Fp red headstuds, and abuse or no headstuds !
  99. Stock Motor,what turbo?
  100. difference between mivec cams and non-mivec cams?
  101. need help please
  102. More issues....any input appreciated
  103. 2.3 stroker twinscroll turbo choices
  104. FP red what supporting mods ?
  105. quick injector install question
  106. New EVO 8 and 9 CNC Cylinder Heads APM Racing
  107. Size of BOV Recirc hose?
  108. The project..mild motor build pics
  109. 2nd gear pop out?
  110. Rebuilding Tcase?
  111. Greddy T67 25G Full turbo kit
  112. boost question....newb here
  113. How Long did your stock clutch last
  114. Tuning Help Needed to make smooth Idle with Cosw M2 Mivec
  115. Seriously? Another Cam gear sensor goes bad?
  116. Need Help!!! BOV question.
  117. Got a 3 hour drive to go to..safe?
  118. motor blew up!
  119. Crushing IX BOV
  120. Car turns off inbetween shifts
  121. need help with cel 172 and possible BBK hotside leak
  122. Help needed on BR turbo kit!!!!! (pics) inside, please help!
  123. Should i do a clutch upgrade advise please
  124. bbk or fp red?
  125. Jdm 6-speed mr..must come with diff in front?
  126. Problems with the walbro 255
  127. BBK full what do you guys think !
  128. Need Cometic head gasket pictures!
  129. Overboosting
  130. timing belt: to change or not to change... that is the question
  131. will a mishimoto intercooler add HP
  132. Possible Rod Knock
  133. Tanable dp and MAPerformace o2 housing questions...
  134. I searched (I DID, I DID!!)
  135. Best pump gas turbo kit
  136. lots of mods, now what next
  137. o2 housings?
  138. this is a weird one need help please..
  139. I screwed up my FP HTA3582R compressor wheel...
  140. Swapping out Clutch , question w/ after TOB removal
  141. Clutch Problem
  142. Coolant Leak around Water Pump and Head.
  143. Safe max rev limit on stock bottom end
  144. Thinking about upgrading turbo help !
  145. 35r oil feed line ?
  146. internal engine rattle?
  147. What to do next on the mod list ?
  148. Need help with COILS
  149. Exhaust Mani/O2 housing Q
  150. GT35R rebuild ?
  151. stupid question - will this work for capping off factory boost controller?
  152. Mitsu newb swapping IX engine. Quick question. Please help.
  153. Greddy Ti-C cat back come with a o2 plug?
  154. Clutch blew up at 8k RPM PICS INSIDE
  155. AMS Oil relocation line
  156. 2005 EVO 8 problems
  157. Stock MAP sensor wiring?
  158. What is the Max Boost for my mods on my IX MR?
  159. high vacume on boost gauge! 60, also no fuel pressure silanoid
  160. Clutch recommendations
  161. any info on maf box
  162. Flywheel weight??
  163. stock pistons on aftermarket rods
  164. Engine Internals, Setup.
  165. Annoying Issue with Car Pulling Timing.
  166. Clutch issues
  167. help with bc springs!!!
  168. Help!!! Drove w/out oil cap on!
  169. Stock IX plugs Lifetime on 30 PSI & race gas?
  170. Fidanza aluminum flywheel; resurface or replace friction plate?
  171. Fidanza aluminum flywheel; resurface or replace friction plate?
  172. Help! Built 2.0l has no electrical power
  173. agency power 35r turbo kit owners!!
  174. Anyone try an AMK turbo manifold?
  175. HELP about springs an retainers!!
  176. URGENT: New Motor with all supporting mods will start up, but will NOT hold an idle!!
  177. Safety of the stock motor vs power.
  178. Oil Pressure 100+ PSI???
  179. Hard To Downshift. Please help.
  180. What is the best single disk clutch?
  181. Bad thermostat? Coolant Issue inside..
  182. Grinding in 3rd, 4th and 5th
  183. More Power with Bigger Injectors???
  184. Odd Clunking Noise
  185. Exedy Twin dragging?
  186. mishimoto vs. ebay
  187. Timing=blown bottom end??
  188. All IX owners w/Cosworth M2's
  189. Whistle noise when I am in boost
  190. TB Help!!!!! What did I do wrong?
  191. When Decelerating in 5th Gear
  192. Evo 9 cam questions, help!
  193. ams race balance shaft
  194. hard shifting?
  195. Blown Motor!!! Getting swapped!!!
  196. help, light thumping sound
  197. Worried about bent valve
  198. assembly lube question ... whats better ?
  199. about cams HELP!!
  200. To port. Or not to port exhaust manifold, and turbine housing
  201. 2.2L Stroker Owner's, Let Discuss Your Set-Ups
  202. Need some help with pistons
  203. samco coolant hoses quiestion evo 8 or 9
  204. Clutch dragging?? What is the cause?
  205. enging specs, ring gap and placement ...please help
  206. oil cooler....
  207. Slim Fan Zip Ties?
  208. Camshaft sensor query?
  209. exhaust sagging and sitting way too low...
  210. MAPerformance Ultimate Duty Rods
  211. Redline 75W90ns
  212. Execy twin Hd ?'s
  213. Vacumn Hoses
  214. help with clutch diagnosis
  215. Ported throttle body plate sealant
  216. Apexi N1 EXTI CBE
  217. greddy rs bov owners please help
  218. snapped stud in head
  219. egr block off purchase recommendations
  220. Blown freeze plug without blown head gasket?
  221. AFR Question :D
  222. Motor help!!!
  223. Rattling excedy twin plate
  224. Help, engine and rpm stuck
  225. need intercooler pipe solution!
  226. I know this has been beat into the ground but...
  227. Are there any good aftermarket exhausts that don't have an angled exit?
  228. Nisei LICP VS ETS LICP
  229. Help Boost leak
  230. 05 evo noise in 1st
  231. blitz intake induction cover? wat u think?
  232. ac problem
  233. stock balance shaft
  234. Drivetrain Question...
  235. Who sells FUEL RAIL that has the LARGEST inside diameter/fuel capacity???
  236. How Choose correct main / rod bearing size?
  237. Oil in charge pipes
  238. Best Rod Bearings ?
  239. spec/quartermaster TOB
  240. Forge DV or stock ?
  241. need advice on buying clutch
  242. new clutch/flywheel!! so many!! need help!
  243. meagan header
  244. Rolling resistance
  245. Engine Commpresion Test
  246. Cam Position Tool
  247. Help - Removal of rear O2 sensor and routing of WB wiring
  248. MAP Sensor Adapter?
  249. Can some one PLEASE look at the Injector Wires for me??
  250. Evo viii vs. Evo ix
