View Full Version : Evo Engine / Turbo / Drivetrain
  1. The cause of my TC's whine.
  2. Tial on 50Trim Install..
  3. Is this BAD???
  4. Vendors: Rebuild Kit/Package?
  5. has anyone try using Amsoil Synthetic Motor Oil ?
  6. What are the differences between good Evo's and bad Evo's??
  7. Stock maf + cold air?
  8. any tips on installing tranny and t-case
  9. Srs Light??
  10. What are the 3 most important gauges?
  11. started tearing her apart for the full race kit...
  12. clutch pedal mybe???
  13. safe psi without tune?HELP!
  14. Please Help me....
  15. easiest way to run 2 maps
  16. Looking for parts
  17. will a evo 8 turbo manifold fit a 98 eclipse gst??????
  18. AMS Ultimate Fuel Pump Test
  19. Weird 2nd gear problems
  20. Fuel Setup Needed for 2.3/35R
  21. 8 and 9 turbo
  22. Need 20G-LT hotside help ASAP :(
  23. boost controller help
  24. Exedy HD tiwn plate clutch problem with reverse gear (help please)
  25. Big turbo guys, lets reunite and show off
  26. new GT35R setup for my 2.3...
  27. t-case fluid
  28. Turn around time for a Green?
  29. drive with 280/272 w/no tune unsafe?
  30. 2.5l - 10.25:1 compression - EVO IX motor pictures!
  31. Need some informed opinions on Clutch replacement
  32. spark plugs on the 9.
  33. Black Smoke
  34. Tomei exhaust/turbo parts
  35. Ppi Ftw !!!!
  36. AMS vs HPF
  37. anything else before cams?
  38. Possible boost leak - anyone have a picture of which hose(s) I should check?
  39. Cleaned my MAF Sensor - Great Results!
  40. Cat Back With Stock Cat
  41. How to get 450hp
  42. Rear diff drain and fill
  43. fuel pump noise
  44. When is a new clutch needed?
  45. Buschur Cams BF272's here I come!!
  46. David Buschur's RS, just finished up with new pics...
  47. Suggestion Fp3065 Or Aem Ems On Ix!!!
  48. Pistons
  49. Transmission Blow-Off plate..?
  50. What plugs?
  51. Pics of 50 trim install
  52. Install another fuel pump on passanger side
  53. HKS Carbon Ti owners-Please Read
  54. HOW MANY PEOPle OWN A EVO GREEN TURBO
  55. What do i need to take off at 7k rpm ?
  56. timing and belt question
  57. On my way to fuel independence..........
  58. Whining. Possible rear diff, maybe?
  59. Check valves, Catch cans, and Vacuum for the PCV (discussion)
  60. Buschwacker is getting done
  61. DC Sports CBE.. Anyone have it?
  62. Question regarding my GT35R kit
  63. Another Clutch Question!!!!!! which one for 600 Please Help
  64. Getting ready to load a Jestr tune!! (and a couple questions)
  65. GT3076R so laggy ??
  66. turbine housing flange? help.
  67. Quick question about hotside
  68. broken axel?help?
  69. Cant find the EBay FMIC anymore?
  70. A question on injector size!!!
  71. Works exhaust?
  72. Can a o3 Evo transfercase be rebuilt?
  73. HKS EVC V problems?
  74. can anyone explain to me about the clip on the other side of the pp for tob?
  75. Which(size & brand) cams are you running with your ported head?
  76. Transfer Case Weight ?
  77. HKS DLI-II ignition on a fairly stock car?
  78. How to install different spring in Forge MBC?
  79. Thinking of 2.3L stroker
  80. Interesting testing - cosworth cams - 100 octane fuel and test pipe tested Evo IX
  81. Compression Test @ altitude question
  82. Charging issues!! Any suggestons
  83. yes another wierd noise thread...
  84. Power Loss???
  85. Swaping 9.8 to 10.5 hot side, help/sugestions needed
  86. ARC Intake Box filter help
  87. Bost Creep, o2 or 18psi Wastegate?
  88. boost levels on stock internals
  89. Is Buschur Racing's Modified Walbro a good way to go???
  90. Would a broke rear axle with a busted abs ring stop the ACD from working???
  91. i neecd help BIG TIME
  92. Possible drive-train damage???
  93. Can I install a Walbro 255lph fuel pump without a tune?
  94. 06 evo9 Transmission Drain Bolt Size? bigger than 21mm
  95. Timing Belt Noise
  96. Quick question about ultimate racing test pipe
  97. ~~~~~~Race Gas~~~~~~~?~~?~?~
  98. 2 quick cam gear questions
  99. Has anybody put a mivec motor in a 8?
  100. Shep Tre or Bushwacker????
  101. Stock evo IX turbo
  102. exhaust questions?
  103. Buying My AMS GT35R Kit tomorrow and have a question
  104. Install time question
  105. ANNOYING!!! How many people have experienced this?
  106. Transfer Case Removal Help
  107. hi flo cat
  108. Checking for removed Clutch Restrictor
  109. Boost leak test:Cap I.M. or not
  110. EGT differences - at the runner / collector / O2
  111. Grinding In 4th gear... 2005 evo 8 mr
  112. upgraded turbos? 500 whp?
  113. Invidia header?
  114. Front driver's side wheel NOT SPINNING
  115. How much abuse can stock rear axles take?
  116. 10.5 Hot side
  117. Bushur or turbo xs
  118. Cam install and knocking like a SOB?
  119. Exhaust mani bolt sizes for heatshield
  120. The path to BR BB 50Trim
  121. Anyone ran a Green on an IX?
  122. aftermarket rod bolts
  123. 119mph VIII E85
  124. HKS Twin Power DLI II???
  125. next set of mods.
  126. Clutch for Evo 2005 VIII
  127. valve springs and retainers? Do u need em
  128. Daily Driven without many mods
  129. What is the proper way to solder in a new O2 sensor???
  130. Forge Rev. How much boost?
  131. AMS 50-trim vs 20Glt whats better for daily driving?
  132. AEM owners: what do you do come inspection time?
  133. evo IX not boosting?
  134. Need Help With New Car
  135. cone intake vs stock airbox
  136. Mobil 1 15-50
  137. Boost leak at throttle body (throttle linkage)..How to fix?
  138. Evo 7 rear diff gear ratio?
  139. Silicon hose any good ?
  140. Want to know what a tcase whine sounds like? Video Inside.
  141. Which would help more? Intake Manifold or ported head???
  142. High or low boost.
  143. 548whp / 440tq, Evo IX, stock ECU!
  144. HELP!! I think something bad happen to my engine
  145. Revolver sound clips
  146. My New Rps Max Clutch!!
  147. Nisie intercooler test question
  148. Tilton clutch wierd noise. HELP PLEASE!
  149. Mobil 1 Fully Synthetic or not?
  150. Break in period for cams ?
  151. when do i need to start tuning
  152. Car's acting crazy. Need advice!
  153. Some pics of Forge MBC mounting locations?
  154. AFR'S are way off. HELP PLEASE
  155. Wire Mesh over Turbo Inlet
  156. My 280 cam / tme dyno numbers
  157. Installed IC Piping Car Will not go into boost.
  158. 03 Evo into 1st gen Talon TSI???
  159. 50 trim times slips
  160. Greddy Type S BOV. help!
  161. P0420 doesn't effect performance my a$$
  162. questions for 2.3l guys
  163. Motor Problems car wont start
  164. Tomei Cams
  165. EVO IX full bolt-ons dyno #s
  166. BPR7ES copper vs BPR7ES non copper
  167. Power Enterprise Install Pictures
  168. anyone know the bolt size for a 4 bolt gt turbo downpipe?
  169. Question about TurboSmart BOV
  170. Question about Tilton Clutch.
  171. Where to get HKS Spec-R?
  172. Pulled my CEL code, but do I need a new o2 sensor???
  173. HKS 280's...
  174. Ambient -> Post-Intercooler Temps
  175. Evo IX idle sound
  176. EvoGreen and Meth
  177. What DP the mates w/stock cat?
  178. Stock Cat Back Exhaust More Torque?
  179. IX Tranny help!!!
  180. Please help me choose a turbo
  181. anyone make a maf adaptor to fit a 4 inch cone?
  182. forge wastegate (uncontrollable boost)
  183. fuel pump electrical harness
  184. any one have dyno gains of 264/272 cams untuned?
  185. Exhaust silencer test...
  186. BOV/MBC Help!
  187. why does my car do this....
  188. supporting mod ??'s
  189. New version of Ebay IC with welded on brackets, 4" width and licp....Hmmm
  190. Is there really a difference w/ all these MBC
  191. Will raising the boost cause
  192. Important Question about cams
  193. im bout to buy cams 2nite, help me decide
  194. HKS Exhaust Brackets
  195. Gear ratios for evo8 usdm 5speed box?
  196. Which Clutch is better?
  197. Ebay intercooler testing from the Pros at Buschur Racing....the facts, the truth
  198. New HTA 35R testing finally done and in....
  199. Intercooler Piping Question
  200. EVO 8 Cam Gear Fittment Applications
  201. Please Help - Radiator Fan Question
  202. Newbi question here about Evo PSI..
  203. turbo hx40 q's
  204. HKS 272 out, GSC S1 in? on viii
  205. evo probs of course
  206. Tapping IC pipe for smc or snow
  207. should i get a green turbo
  208. NEED HELP WITH Exhaust.
  209. 5zigen Pro Racer X-Tube S-Spec Exhaust.
  210. Hks Ssqv Bov
  211. VIII E85 401whp 362WTQ
  212. 02 housing 5 bolt flange, where to buy?
  213. Tans Help in the 6sp?
  214. turbo upgrade ?'s
  215. Stock Ignition & HIGH BOOST (28psi+)
  216. Tested... FP Green IX turbo...
  217. Weird noise after using no2
  218. Stock BOV question
  219. HKS DLI 2 install question
  220. Loud whining noise
  221. Does anybody get turbo surge from their atp gt35r?
  222. 6spd short shifter.
  223. Autometer Oil Press Gauge....dead?
  224. Buddy Club Pro Spec Exhaust. anyone?
  225. UK FP Evogreen dynoed
  226. Tranny Wont Come Off!!
  227. 330 whp, 320 ft lbs
  228. Which spark plug to replace with??
  229. Cam poll
  230. Guys a little help...
  231. Just picked up an IX need some advice
  232. New Greddy ss,ti carback w/ bushur dp and what HFC?
  233. evo Suspension ????
  234. downforce games
  235. Forge UNOS springs?
  236. What BOV is this??
  237. Oil Drain Tube GASKET - HELP!
  238. Machine work for AMS 2.3L stroker
  239. Oil Squirters???!!!!
  240. EGT placement, temps, and alky use ?'s.
  241. Fuel pump ??'s
  242. Exedy Twin Noise with Cluch Engaged
  243. ebay exhaust pics and results...
  244. What manifold can i use with a atp gt35r kit, does the flange matter are their side?
  245. Spal slim fan part number#.....
  246. opinions on the perrin foam filter?
  247. 2.4 in a evo
  248. Turbo Xs Down Pipe
  249. Who's running a Maxford header?
  250. oil cooler setups
