- Is my tcase dying?
- Is my tcase dying
- Built 2.0 Motors! Need Help
- weird flutter in fifth???
- Exhaust
- Cams and Turbo lag
- want your input on cosi cams ix cams
- Bring Back the GReddy Evo2 exhaust thread
- Power gains from Buschur Ported Exhuast Manifold
- Any body purchase a gt30r or gt3082r from ATP recently?
- any vendors have gsc s2 280/280 cams for the ix in stock?
- SMC Control Box ??????
- CANT GET MY STOCK TURBO TO GO PAST 12.1 in 1/4 mile
- Fuel Pressure Regulator Install?
- need some help on turbo selection
- Shifter bushings?
- Turbo upgarde
- Fan in front of a/c condenser
- Anyone play w/ Piper 290's or 300 cams yet???
- Amsoil
- boost and 1/4 mile times
- ATP kit question
- P0172 Code Causes
- Turbo Mods??
- Quick question...
- Info About Titek
- ticking sound near the belt?
- Downpipe.
- 10.5 hotside
- Sputter after changing spark plug wires?
- motor toast, help please
- Starter gone? Battery? You guys can figure this out.
- Exedy Stage 1?
- ACT HSD001 240mm clutch disc
- WHO is on the Waiting list for FP EVO GREEN? Who has received theres recently?
- clutch went out today
- Injector Input
- Preferences for a MBC fitting a IX?
- Help with PO139 Code
- EVO 3 gearbox and transmission case
- Cams
- Meth Injection
- Trent's car on pump gas, low boost...not 600..yet;)
- Sorry, another 600 whp thread.........
- GT35R Numbers that should be expected (HP)
- 295 hp, 272 tq, 1 bolt on, Mase tuned.
- Who Sells Turbo Replacement Gasket Kits??
- shaft play
- highest psi on stock fmic
- Lightweight pulleys for 4g63... any updates?
- Poll: Which Motor Oil do you use or recommend?
- Greddy Performance Camshaft Easy 4g63(evo9)
- Mobil 1 15W-50
- whining noise coming when boosting
- need some help about clutch
- Buschur Stage 2 Questions
- injectors for Evo Green
- Intake Not Clearing IC Pipe
- Ecu Immobilization code at Mitsubishi dealership(am I getting screwed)
- Most PSI on Boost Juice
- Clutch Installation at Home Questions
- ? about Buschur Air Filter Kit
- meth kits...buschur??
- Shearer Evo Street Brawler Turbo Kit?
- Doughnut Gasket Replacement
- Shifting Question
- IS anyone running a SLS turbo kit?
- Stroker
- Got tuned at GST Motorsports yesterday. +42whp +53wtq (Filter & catback only)
- Which vendors sell JAM lifters?
- The Evolution of a Street Machine
- 20gLT vs 3076
- how do i reset my dash light?
- lots of boost and race gas ?
- Buschur Race vs. Buschur Deluxe FMIC
- Which meth kit for my build?
- A few shots of the turbo install
- Help
- Any 2.3/2.4's 20g-LT on pump dyno charts?
- Need advice about driveshaft vibration
- Octane VS. Boost
- Help!! I stripped my axles!!
- Anyone running a revhard manifold?
- Buschur Racing.........
- whats wrong with my car??
- GSC S1 -GSC280(older model)
- Buschur racing build
- big power 37r guys...
- installed dejon boost controller and...
- knob on the top of a TiAL bov??
- Wiseco Pistons
- Cusco differential noise?
- Fluid capacity difference between 6MT and 5MT?
- Hydaulic Release bearing Help!!
- 11.5lb Mini Battery for $60
- 582 WHP with Pump + Alky on Flash!
- hey guys newbie here need some advice
- 600+ whp again, this is getting boring....
- Machine Work Vs. No Machine Work On 9k Evo 9 Motor...
- Aluminized heat barrier wrap
- giving up on boost spike.. about to burn evo to ground
- How easy or difficult is it?
- intercooler questions
- Where can I get these??
- is there any way to improve power at low RPM? (1-2.5k)
- evo8 cams 272or280
- Exhaust Cutout?
- Excedy or Carbonetics??
- Max'd Out Stock vs. Non-BB 50 Trim
- Paging EVO Green with 9.8 HS
- built 2.0 or 2.3
- Help me understand why my MBC does not function properly
- thoughts on slowboy racing?
- Clutch problems on new Evo IX SE
- upper and lower ic pipes- who has the best for the buck???
- How A Twin Disc Clutch Works???
- so is any company ever going to make a 280 intake cam for the ix?
- GT30R #'s on 91 and race gas
- Will the real Ebay 02 housing please Stand Up? (video)
- who offeres the best deal on 880cc injectors and aeromotive fuel pumps?
- GSS342 for Subaru fitment
- cat replaced check engine light on
- Tanabe Concept Blue & Emissions!!!!!
- Look what UPS dropped off
- TTP engineering flash
- Vendors: Need Info on Greddy TI Catback
- OEM Fuel Tank+ Fuel Cell hook up
- 320 to install o2 housing?
- tranny HELP
- ARC intercooler fitment information
- Clutch Travel Question
- HELP me put my shifter back together
- Please post 50 trim pump gas dyno charts & mods
- Gear oil dripping
- dip stick...low oil(HELP)
- mr turbo
- rear diff out - large crack on the top
- Help with clutch
- Aeromotive A1000 pump+stock intake=over kill?
- motor mount recommendations good bad ugly
- waste gate spring???
- Different kind of boost problem... (i think)
- how much would it cost to rebuild evo9 motor9
- GT35R and N20, anyone run this setup?
- Boost drop/leak
- HELP!! new plugs arn't iridium!!
- factory boost solenoid
- evo8 20g/evo9 20g difference
- Stock Exhaust Manifold and coating Q's
- So...who's mixing in a couple gallons of E85 with their premium?
- Stock shortblock, stock head, new record numbers for the EVO Green turbo
- BOV Question
- Boost controller help with pics
- E9 Tune with Cosworth Cams- Dent Sport Garage tune
- Exedy Stage 1 Clutch Reviews?
- help
- another tcase ?
- AEM ugeo questions
- Redline Fluids???
- TD05 20G for evo IX...
- 5th Gear part numbers for Evo IX
- Evo 9 (or FPGreen) turbo in an Evo 8 w/o the install kit..YOU MUST READ THIS FIRST!!!
- Intake temp data [request of speed density users]
- Water temp adapter piece
- compression numbers
- Ebay o2 question
- XSPOWER(ebay) intercooler, I bought it...
- superchargerr sound?
- Buschur Power FTW! (Video Inside)
- Injectors for a GT3076R???
- FUEL line thread from firewall?
- Does Old Muffler = Less Power??
- mivec solenoid control?
- Help with 280 idle
- who has a 60 TRIM??? INFO NEEDED
- transmission noise
- i need a transfer case
- just changed o2housing..hotside..now hear new noise
- Exhaust Centering Q? Tips? (Megan Racing)
- Trouble with A/F ratio
- 03 Evo dropping a sylinder at idle
- Turbo gone bad? Diagnosis question. Pics!
- wastegatge question
- short shifter for the MR 6sp
- weird problem
- My 50trim numbers
- Need Help Again Boost
- Cutting the Cat O2...
- Boost and Tempatures
- Evo a/f ratio question
- Running rich after tbe install!!!!
- Drivetrain noise?
- At what power level does a 3" intake become restrictive?
- Shaft play
- what clutch do i need?
- Acetone as Fuel Additive
- will the pull fan thats inside the engine bay come on with the car idle?
- Engine blown?? tranny is gone ??
- GT Series turbo, which is the water feed and return line...
- Stock Evo8 and Evo9 o2 housing?
- Transfer case problem
- Redline MT-90, where to use?
- boost problem
- really worried need help ASAP
- Almost done with the full-race turbo kit install...
- transfer case
- Help!! Problems With Hallman MBC
- Meth Question
- o2 problem
- Know of any mechanics to install new clutch? NJ
- MBC install with a few problems!
- easiest way to access wastegate?
- FP HD WGA on 20G
- Car Trouble: Slipping Clutch??? Not Sure Help!
- XTD clutch and flywheel? anyone use it yet?
- Full Race Gt37 Turbo & Manifold - Dyno Sheet
- Transmission ?s
- Which Exhaust???
- Custom Intake Manifold
- Partial throttle boost.. ruins engine?
- turbo xs blow 50/50 hybrid blow off valve
- In Car - Valve Spring Install Alternate Methoc
- difficult to shift
- Best Tuned MPG?
- Transfer Case issue
- IX Engine idle noise (belt?) (video)
- Got a busted Cam position sensor--ok to drive?
- How is this tuning method accurate?
- For those of you that think twin turbo is better
- HOW can i hold more boost????
- Head unit install = CEL?
- DNP divided t4 manifold
- IX Cam Gears?
- oil leak after cam install
- After removing the clutch restrictor
- Anybody using the Blitz LM intercooler?
- royal purple in my 6sp now i need a rebuild
- Please Help!!!
- What do you guys think about all poly mounts
- TRE or Shep trans??
- HKS 280/camgear impressions
- full race GT kit running 14 psi.....
- my cam installation - halfway done!
- intake????
- APS FMIC Help please
- How much HP/Torque will a reg Exedy twin disc hold?
- Hesitation/Slight Bogging with Throttle
- Will headers make you run rich???
- prime new turbo?
