View Full Version : Evo Engine / Turbo / Drivetrain
  1. Gear Box F*** Up.
  2. Shimming supertech dual valve springs???
  3. will 3.5" TBE be too much? planning for about 400 AWHP ish
  4. ACT or Exedy clutch?
  5. Pick out a FMIC for the Evo 8 HELP PLEASE
  6. What to do before Tune?
  7. Is there a torque limit 4 our driveline?
  8. Tial surge even with EMS?
  9. Muffler silencer question
  10. What intake pipe brand will fit the evo 9?
  11. Question on my PT67 Dyno Graph
  12. turbo question
  13. HKS Version 2 BOV Question
  14. Tomei 270 Procams and Supertech valve springs
  15. Stock EVO 9 dynoed. Then reflash and intake.
  16. GOOD evo shop in los angeles / west los angeles area
  17. High Oil Temp Causes Questions
  18. Agency Titanium Catback
  19. Ams Catback.
  20. radiator need !
  21. what 02 housing tbe exhaust are you running?
  22. Greddy evo 9 cams?
  23. DC Sports Tubular Manifold Dyno on IX?
  24. Cams
  25. [Test] Why Revolvers are hit or Miss....
  26. Custom Turbo by FAT
  27. Review: ACT HDSS + ACT Xact Streelite flywheel
  28. temp gauge question,
  29. Head studs - why or why not?
  30. ACT street disk clutch kit.
  31. 02 sensor size?
  32. Please help. What could it be???
  33. Swapping out final gear...
  34. Exedy triple carbon vs. tilton twin carbon
  35. 2.4 vs 2.3 vs what to do?
  36. Got dynoed this weekend!
  37. 5th gear "grinds"
  38. Anyone know where to get syncros????
  39. 2000 miles on 06 IX and noisey engine
  40. Stock clutch question...
  41. ATP turbos mate up to the stock mani?
  42. Need help!!
  43. Does anyone know where to get...
  44. What power would you expect from standard'ish car with AMS GT35R?
  45. Re-use stock spring bolt setup on aftermarket downpipes?
  46. Paid for Premium fuel and got Reg
  47. Greddy TI-C Exhaust
  48. 20g9-lt mods + tune
  49. short video of idle
  50. newb question, wow.... i feel dumb
  51. Can anyone post some links?
  52. highest Whp/Wtq on exedy HD twin disc clutch???
  53. 22.8 Mpg E85
  54. New Turbo
  55. Are the Evo 9s head studs are they stronger then the Evo 8s?
  56. compresor map
  57. Worn stock clutch @ Willow Springs. Replacement....
  58. Need Help With DB Levels & Exhaust
  59. New pictures of full race kit....
  60. do i need injectors
  61. intercooler question
  62. Engine Running Hot?!
  63. trany, tranfer and diff oils...
  64. 2.0L Motor Build Need Help!
  65. HKS Kansai Sevice Intake Manifold
  66. OVer Boost Brand New Evo IX (30+ Psi)
  67. 3" exhaust flange adapter
  68. What coils for coil on plug ?
  69. noise: howling just need feedback possible bad turbo
  70. No start after some minor installs
  71. 272s finished - minor problems.
  72. what injectors for buschur 35r
  73. Urgent - Cam Installation Question
  74. Q's on a used turbo I bought...
  75. boost question
  76. stupid question
  77. mini battery problems?
  78. Which is worse in an exhaust? (types of restrictions)
  79. 4g64.....help
  80. Bushur Rocks
  81. AEM Electronic Boost Controller
  82. Buschur 20g-9LT
  83. Things that just SHOULDN'T Happen
  84. Tial V-Band Housing Pics. (LARGE PICS)
  85. Mild Tune and Head Bolts ? ? ?
  86. My Mods
  87. Clutch slipping with 20g-9-5.
  88. Getting ACT clutch, need advices
  89. benefits of proper internal wastegate setup on EvoGreen?
  90. car sputter/hiccup..Any ideas?
  91. Intake install question
  92. Tuning Question!
  93. bearings for a 2.3?
  94. Picking car up....
  95. Is this a sign of piston ring?
  96. Help with clutch replacement please!
  97. Where to get intake pressure for Forge MBC - pros and cons?
  98. Best cams for mostly street?
  99. CBRD dyno'd works P2 flash..
  100. help!! cant find torque specs any where for clutch
  101. Evo 8 vs FP Evo Green comparison *pics*
  102. What type of HFC?
  103. Cel Code P0102
  104. PLX wideband ????
  105. tranny noise yay
  106. fp green vs meth?
  107. Strange clutch issue
  108. Drive train question
  109. stroker motor cost?
  110. Need some help.
  111. 520whp for a street car isnt too bad right?
  112. Won't start HELP!
  113. greddy evo 9 cams
  114. Heellpp!! Blew My Motor Today!
  115. cutting VIII flywheel
  116. Tanabe Exhaust System
  117. Ultimate turbo
  118. GT3076 to Green install kit question
  119. Low Vacuum Issue
  120. ??? where is the evo ix suppose to hit the rev limitter???
  121. oil pressure ?
  122. Exedy twin disc rebuilds
  123. What should I expect at the dyno?
  124. obx front mount intercooler?
  125. Road Race Engineering GT3076R turbo Kit??
  126. Borg Warner S256 Turbo Kit
  127. EBC help Greddy type S
  128. putting on a turbo timer and tbe? any advice
  129. 518whp@93oct & 625whp C16 EVO 9
  130. Best prices on CUSCO twin plate clutch??
  131. Discussion: What Air/Fuel Ratios are safe and why?
  132. Installing Turbo tips!
  133. hks springs need help!!!! please evo gurus
  134. cosworth dyno on ix sean ivey
  135. 560whp Evo 9 @ Buschur Racing (yes.... another one)
  136. Review of Redline LightWeight ShockProof for Tranny
  137. Cat removal question
  138. Resurface Flywheel or dont?
  139. 4g63 to rear wheel drive trans?
  140. E85/Methanol Vs Race Gas Results!
  141. Question to Owners Past 60K Timing Belt Change
  142. My sweet new intercooler, big pictures
  143. boost controllers......
  144. Black smoke after installing TBE + flash
  145. fp green dyno today.
  146. ikeya formula shifter
  147. Exedy single plate organic clutch
  148. GT30R dyno..etc
  149. Boost dropping on high rpm, how to solve it?
  150. looking for a 4" intake pipe with a recic bung for bov...
  151. Some FPgreen spool data.
  152. The Proof is in the meter, BR intercooler testing continued.....
  153. EGR Removal
  154. RUSTY Plugs !
  155. Fuel Pump Install
  156. Heat???
  157. Stewart Warner boost gauge?
  158. solid lifters
  159. Installed Forge MBC, and WOW!!!
  160. Hey ALL...Going to the SHOP Tommrow
  161. oil light problem
  162. New Tranny, New PowerFlex Mount..LOCKOUT IN 2nd NOW!!!
  163. Exhuast Anaylisis and Discussion - and o2 housings revisited - Video
  164. What is the history of the T3, T4 nomenclature?
  165. Shep built 4.11 tranny
  166. Anyone using the new Blitz cone filter?? Impressions??
  167. just wondering if this is normal after DP install
  168. Stainless Steel Exhaust Studs?
  169. e85 users
  170. Greddy Cams
  171. Tranny Fluid Cocktail-Any issues with this?
  172. how easy to convert ayc non usdm evo to acd usdm?
  173. Anyone Have Green PumpGas Numbers?
  174. Fpgreen vs bigger turbo's for street use?
  175. Will I benefit from a Quaife front lsd?
  176. GT (GT35R) Coolant Inlet and Outlet Fittings?
  177. Installing TBE today a quick question
  178. 20g upgrade for evo ix 899$
  179. TTP 02 housing and buschur downpipe?
  180. ANOTHER fully built Buschur Racing Evo being finished up. Watch out Cali!
  181. eXHAUST
  182. oil leak. need help!
  183. Mahle piston pin offset amount?
  184. 476 Dyno Dynamics whp on stock block EVO9
  185. greddy cams??
  186. evo 9 owners
  187. Am I going to need injectors?
  188. Open element recommendations
  189. Just Dyno'd The Evo Thursday
  190. boost problem after tubo install
  191. Stock IX BOV
  192. intake question
  193. Greddy Ti & Fujitsubo RM01A dyno # plz help
  194. Megan manifold!
  195. BOV swap has me confused.
  196. Larger turbo flows more at same boost pressure?
  197. Evo VIII to VR-4 Galant
  198. Boost cut or something else?HELP
  199. ACT Flywheel, who's running it?
  200. Oil filter option
  201. Car will not start after cam install, need help.
  202. whats ur spool up like on a gt3065
  203. Loudest Exhaust???
  204. Question about a BOV configuration, for someone that REALLY knows
  205. Turbo Whine...Normal
  206. Is this normal?
  207. Greddy Cams, who running them? Jun? Toda? any word one when they are coming out?
  208. Exedy or ACT
  209. Driveshaft Issue - WTF
  210. cheapest replacement clutch disc source
  211. Injector know it alls
  212. Where to get plugs.
  213. BR tuned new best times!
  214. Car is boosting 5psi!!! HELP
  215. ACD lights..
  216. Those that have a HKS intercooler Kit!
  217. Defi BF Gauge Ranges?
  218. Invidia 02 housing hardware
  219. Whats the New Transfer case break in procedure?
  220. What size injectors would be appropriate?
  221. Help!!! i can't boost past 18lbs of boost.
  222. 06 evo 9, custom block mods!!! pics inside!!!
  223. Little dilema... car wont idle :\
  224. Anyone running Buschurs BF272's
  225. Why does wastegate spring matter?
  226. Does who have HKS intercooler Kit!
  227. 19lbs boost... no pulling like it should?
  228. topmount 35r turbo?
  229. Short shifter
  230. My ebay o2 housing
  231. evo green turbo.
  232. 35r on a IX ?
  233. knocking??
  234. 'White Rabbit" turbo
  235. what dp and test pipe should i get?
  236. any idea on hp estimate?
  237. fly wheel ?
  238. Can you hear your AVC-R click?
  239. Manifold
  240. meagan 02 and stock ported mani.
  241. Not holding boost?
  242. Dumb question on UICP
  243. Quick question about the catalytic converter. .
  244. any vendors that have Brian Crower Stage 2 cams in stock??
  245. Which is better? 2020cc or 2100cc?
  246. Is my tcase dying?
  247. Is my tcase dying
  248. Built 2.0 Motors! Need Help
  249. weird flutter in fifth???
  250. Exhaust
