View Full Version : Evo Engine / Turbo / Drivetrain
  1. I just got a "complete" turbo kit, or did?
  2. Jun Evo 8 Cam Specs???
  3. Does BR still sell ported 10.5 housings?
  4. Buddy Club Racing Spec Condenser???
  5. smoking on idle....
  6. Bigger Turbo
  7. What boost are you running on IX's with pump?
  8. Which vendors use the Garrett Core for their Intercoolers?
  9. Question
  10. Engine Compression Thread, what are your numbers?
  11. Greddy Ti-C exhaust fitting issue???
  12. Tial bov spring alternative
  13. Limp Mode
  14. clutch replacement (to use stock flywheel???)
  15. boost pressure problem
  16. S-Max intercoolers ? CO2 internally chilled
  17. Having problems after ATS Twin CF Cutch install
  18. Full Built Motors Buschur?
  19. Help! Gearbox problem!
  20. Put on catback and MBC!
  21. Not your typical TT harness question
  22. a/c compressor connector
  23. Snow Performance Meth Install Help
  24. smell something burnt everytime i hit boost
  25. wtf!! evo stuck in gear??
  26. So lets see some DIY-ers UICP
  27. crushing the stock diverter valve
  28. Can Exedy twin SD be rebuilt?
  29. whats wrong with a 35r on pump
  30. Clutch Pedal Stuck
  31. Cams in, engine bad, please help
  32. Another turbo and injector question...and yes, I did a search
  33. EVC problem
  34. Finally got back on the dyno
  35. COMPLETED!: TWIN FUEL CELL SYSTEM! (pics + vids)
  36. BIG HP EVO'S-Wheels & Tire Choices
  37. Has anyone?
  38. Perrin test pipe (cat delete) with stock down pipe and exhaust
  39. Some problems with the Zeitronix ZAVT
  40. 11 sec with stock internals Evo 3.
  41. help help help!!! - hose keeps popping off
  42. Which turos fit my car?
  43. FPRed turbo for Evo???
  44. LSD, evo 1, 2 or 3 not sure
  45. Quaife Front LSD Installed
  46. Tomei pro 270's vs Revolvers built 2.0 35r
  47. BC 280 Cams...No lopey idle?
  48. transmission power flow diagram?
  49. Clutch Pedal Adjustment Problem
  50. Is the EVO throwout bearing the same one used on STI's?
  51. how much psi
  52. How tune for better idle with more aggressive cams?
  53. Silencer
  54. HELP! Turbosmart EBoost 2
  55. Can I achieve 400 whp on pump with an evo green?
  56. Help, just had a brain fart
  57. Upgrading to Evo 9 turbo...worth it?
  58. NB plug question
  59. Problems With New Motor/turbo/dual In Tank Pump Setup???
  60. Low boosting problem..
  61. Anyone consider (or using) a vaccum disribution block?
  62. What engine for a 37R
  63. Evo Green
  64. Any one with the Tanabe Concept G Blue TBE???
  65. Stroker kit 2.3 or 2.4?
  66. Alternative to Garrett turbo maybe????
  67. Head Gasket??
  68. Samco IC inlet/outlet (PN#?)
  69. Any word on Tial DV?
  70. Look what I got at my door today
  71. P0442 help??
  72. evo 8 with AEM EMS running 24psi boost question
  73. Timing Belt Question
  74. CAS sensor questions....
  75. When installing an EBC
  76. Speedometer not working
  77. My EVO is sick
  78. Need HELP with boosting problem
  79. Any one have a Greddy Ti-C Exhaust? Need to know Ti Vs Ti-C
  80. E85 and emmisions?
  81. Stock EVO Fuel pump inside 1G Eclipse?
  82. So who does BUILD the top cars..??
  83. RnR GT40R turbo kit
  84. Buschur Racing GT45 turbo kit.
  85. Dyno numbers... 35R fell short?
  86. Can i transfer Evo6.5 gears into my 6 speeder Evo8?
  87. HKS SSQV Adjustment
  88. Ideal place to shift based on this graph?
  89. just in.....GT4094R
  90. sean ivey=savage
  91. looking to make 400whp
  92. 35r or 60-1 for pump gas?
  93. High rpm sputter
  94. Buschur Racing 3" DP Review
  95. Weird whining noise at 3500 rpm :(
  96. buschur fmic failure
  97. How mans trans/x-fer/diff changes can I get out of the oem fluid jugs?
  98. Boost Leak????
  99. 2006 EVO IX.....still having boost issues!!!
  100. Problem with idling
  101. modified bumper needed for nisei intercooler?
  102. head gasket size
  103. fp evo green turbo serial number
  104. Need my IX turbo repaired
  105. Apr Head Studs
  106. Fynetune completes 500+ AWHP on Pump Gas (93)
  107. 450whp intercooler??
  108. Car sputter!
  109. New Evolution 9 Cam Released by Buddy Club
  110. How much stability does a roll cag offer???
  111. V2 272 Helix cams
  112. Evo I-iii Bov
  113. APS coold air intake
  114. Sequential turboing an Evo?????
  115. evo 9 lsd fit into 2003 evo 8?
  116. searcing TRE upgrades?
  117. ACD transfer: noob question
  118. Shep Trans "Ultimate Ratio" Gear box Review
  119. Greddy trust front mount on ebay?
  120. e-85 and meth?
  121. Can AnyBody Tell Me the Problem??!!
  122. bov question
  123. Exedy Twin HD Cerametallic is this one? Owners READ!!!
  124. Nitrous!!
  125. Evo Flywheel
  126. whats the ideal afr ?
  127. Boost trouble!!!
  128. loud exhaust
  129. nisei ic pipe help need quick response
  130. Extreme Turbo Systems – Behind the Scenes- Turbo Kit Mock Up
  131. Exedy Twin HD question
  132. fp green turbo arriving this week!
  133. which mod between these two - Evo IX
  134. Installed an Exedy Twin and now RPM hang issue
  135. Well..... she finally went 10's!
  136. Dyno in NC?
  137. could a bov recirculation bung too close to the compressor side cause a problem?
  138. Bov setting
  139. Buschur Music
  140. scraping sound...
  141. Weird engine noise
  142. Mounting sensors for oil temp and oil pressure - remotely?
  143. Powerband of Strokers
  144. question about replacing 02 housing and downpipe
  145. VOTE please - e-mail/mail in flash POLL
  146. spark plug problem
  147. Any vendors sell these?
  148. Extended clutch rod: Whats the REAL truth behind it?
  149. next mod? Anything left thats cost efficient/ bang for buck?
  150. Street Disc vs. Puck Disc
  151. Naive about your cam gear cover? READ THIS
  152. BLown Turbo?
  153. lost boost / Greddy Profec B-Spec II
  154. Greddy TI-C Catback rear bumper shields ?
  155. Forge MBC vs. remove stock pill and ecu controlled boost
  156. BOV Mount location
  157. Forge MBC with TIAL EWG help
  158. Safe Boost
  159. Advise needed - tubo back exhaust purchasing
  160. Fuel pressure line for nitrous
  161. mitsubishi drivetrain warranty question(back axle)
  162. AEM Tru Boost
  163. 156.92 (mph) reasons why Buschur Racing is the best !
  164. Highest Hp Stock Ecu Is Here
  165. Head Studs The Right Way
  166. Front Motor Mount vs. All Motor Mounts
  167. missing At 6000 rpm
  168. mods for low 12's or high 11's
  169. Modification advise needed
  170. what w/g actuator = fp-grn/20g-lt?
  171. is my mbc bad??
  172. jdm bov
  173. Lifters
  174. pulled the head, got a question bout the cyl. walls
  175. Is this BOV a P.O.S.???
  176. Fuel cut at 4.5k with engine light
  177. Brian Crower 280's Dyno #'s!
  178. evo tranny
  179. fpevo green ordering
  180. 06 MR tranny fill/drain hole?????
  181. BOV Flutter
  182. So was i due for a drivetrain flush and fill?
  183. Please Help
  184. fuel pump needed?
  185. what does everyone tune with?
  186. Dyno #'s SAE vs. STD what's the difference?
  187. Miss shift/Grind
  188. Interesting oil performance article:
  189. piston upgrade?or not?
  190. Help!!!!!!!
  191. GREEN 20G-LT Maxed out Record HP #'S
  192. gains from a test pipe? any issues with CELs?
  193. 2.5in IC piping
  194. Engine Torque Damper Brand ?
  195. Spark Plug Installation
  196. Whats the deal with Sequential Shifters?
  197. How to tell if...
  198. will the old hks bov recirc flange work on the new hks sqv bov?
  199. Which turbo kit to get...??
  200. 35r open downpipe?
  201. Turbo kit setup questions?
  202. Clutch Master Cylinder question
  203. dp number for the Concept-G Blue TBE (Tanabe)
  204. Just got done with my turbo swap
  205. Rsr Gtii
  206. HKS RS vs. HKS super mega flow reloaded
  207. cosworth cam settings need help !!
  208. my next mod ?
  209. is flywheel decrease torque ?
  210. Concerns after install of Dual Port BOV??
  211. precision 780s
  212. maximum stock turbo boost?
  213. Transfer case?
  214. Which intake??
  215. catback and testpipe delete??
  216. How much did you pay?
  217. price for installing connecting rods?
  218. 429whp 410wtq stock turbo E85
  219. br 50 trim vs. ams 50 trim
  220. How long will a gt35r last on a 60K evo?
  221. Best Cam match for a Evo Green?
  222. weird boost leak
  223. 3rd gear not engaging under boost
  224. Help with Tranny Decision
  225. Max HP through the MAF what have people made?
  226. gt35r oil feed line volume
  227. Injectors??? Denso=HKS/Greddy/Helix?
  228. anyone using the titek o2 housing
  229. best shifter bushings for the 6sp
  230. 500hp and Single Clutch Kits
  231. How To: Make a High Priced Poorly Designed IC
  232. Here it comes Texas.... a 37R Buschur built Evo!
  233. What would you choose? 20G-5 or IX turbo W/ ebay intercooler?
  234. opinions on my plugs?
  235. evo 8 odd hp #?
  236. Head Gasket Install after ARP install..
  237. need a Transfer case NOW!!!!
  238. JDM IX Exhaust choice
  239. is it ok to put an intake on w/o a reflash?
  240. Maximum boost
  241. Flutter/Surging out of nowhere
  242. anyone with m1 cosworth cams on evo 8
  243. Should I coat my 02 housing?
  244. Transmission noise, or ?
  245. F$@# high prices build your own Intercooler:)
  246. HELP me really quick
  247. FPEvogreen Or FP3065
  248. Which more hp mods would be the next in a evo ix?
  249. terribly newb question.
  250. Can you guess what's wrong?
